Initialize the grant table mapping at the address specified at index 0
in the DT under the /xen node.
After the grant table is initialized, call xenbus_probe (if not dom0).
Changes in v2:
- introduce GRANT_TABLE_PHYSADDR;
- remove unneeded initialization of boot_max_nr_grant_frames.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Use Xen features to figure out if we are privileged.
XENFEAT_dom0 was introduced by 23735 in xen-unstable.hg.
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Changes in v5:
- make XEN_DOM0 depend on XEN;
- avoid "select XEN_DOM0" in XEN.
Changes in v2:
- mark Xen guest support on ARM as EXPERIMENTAL.
CC: Sergei Shtylyov <sshtylyov@mvista.com>
Changes in v4:
- compile pcpu only on x86;
- use "+=" instead of ":=" for dom0- targets.
Changes in v2:
- make pci.o depend on CONFIG_PCI and acpi.o depend on CONFIG_ACPI.
All the original Xen headers have xen_ulong_t as unsigned long type, however
when they have been imported in Linux, xen_ulong_t has been replaced with
unsigned long. That might work for x86 and ia64 but it does not for arm.
Bring back xen_ulong_t and let each architecture define xen_ulong_t as they
see fit.
Also explicitly size pointers (__DEFINE_GUEST_HANDLE) to 64 bit.
Changes in v3:
- remove the incorrect changes to multicall_entry;
- remove the change to apic_physbase.
Check for a node in the device tree compatible with "xen,xen", if it is
present set xen_domain_type to XEN_HVM_DOMAIN and continue
initialization.
Map the real shared info page using XENMEM_add_to_physmap with
XENMAPSPACE_shared_info.
Changes in v4:
- simpler parsing of Xen version in the compatible DT node.
Changes in v3:
- use the "xen,xen" notation rather than "arm,xen";
- add an additional check on the presence of the Xen version.
Changes in v2:
- replace pr_info with pr_debug.
Add a doc to describe the Xen ARM device tree bindings
Changes in v5:
- add a comment about the size of the grant table memory region;
- add a comment about the required presence of a GIC node;
- specify that the described properties are part of a top-level
"hypervisor" node;
- specify #address-cells and #size-cells for the example.
Changes in v4:
- "xen,xen" should be last as it is less specific;
- update reg property using 2 address-cells and 2 size-cells.
Acked-by: Rob Herring <rob.herring@calxeda.com>
CC: devicetree-discuss@lists.ozlabs.org
CC: David Vrabel <david.vrabel@citrix.com>
CC: Rob Herring <robherring2@gmail.com>
CC: Dave Martin <dave.martin@linaro.org>
Changes in v2:
- return -ENOSYS rather than -1.
sync_bitops functions are equivalent to the SMP implementation of the
original functions, independently from CONFIG_SMP being defined.
We need them because _set_bit etc are not SMP safe if !CONFIG_SMP. But
under Xen you might be communicating with a completely external entity
who might be on another CPU (e.g. two uniprocessor guests communicating
via event channels and grant tables). So we need a variant of the bit
ops which are SMP safe even on a UP kernel.
ARM Xen guests always use paging in hardware, like PV on HVM guests in
the X86 world.
Changes in v3:
- improve comments.
Use r12 to pass the hypercall number to the hypervisor.
We need a register to pass the hypercall number because we might not
know it at compile time and HVC only takes an immediate argument.
Among the available registers r12 seems to be the best choice because it
is defined as "intra-procedure call scratch register".
Use the ISS to pass an hypervisor specific tag.
Changes in v2:
- define an HYPERCALL macro for 5 arguments hypercall wrappers, even if
at the moment is unused;
- use ldm instead of pop;
- fix up comments.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
- Basic hypervisor.h and interface.h definitions.
- Skeleton enlighten.c, set xen_start_info to an empty struct.
- Make xen_initial_domain dependent on the SIF_PRIVILIGED_BIT.
The new code only compiles when CONFIG_XEN is set, that is going to be
added to arch/arm/Kconfig in patch #11 "xen/arm: introduce CONFIG_XEN on
ARM".
Changes in v3:
- improve comments.
bind_evtchn_to_irqhandler can legitimately return 0 (irq 0): it is not
an error.
If Linux is running as an HVM domain and is running as Dom0, use
xenstored_local_init to initialize the xenstore page and event channel.
Changes in v4:
- do not xs_reset_watches on dom0.
Changes in v2:
- refactor xenbus_init.
[v5: Fixed case switch indentations]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Adds GNTST_address_too_big and GNTST_eagain.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
* stable/128gb.v5.1:
xen/mmu: If the revector fails, don't attempt to revector anything else.
xen/p2m: When revectoring deal with holes in the P2M array.
xen/mmu: Release just the MFN list, not MFN list and part of pagetables.
xen/mmu: Remove from __ka space PMD entries for pagetables.
xen/mmu: Copy and revector the P2M tree.
xen/p2m: Add logic to revector a P2M tree to use __va leafs.
xen/mmu: Recycle the Xen provided L4, L3, and L2 pages
xen/mmu: For 64-bit do not call xen_map_identity_early
xen/mmu: use copy_page instead of memcpy.
xen/mmu: Provide comments describing the _ka and _va aliasing issue
xen/mmu: The xen_setup_kernel_pagetable doesn't need to return anything.
Revert "xen/x86: Workaround 64-bit hypervisor and 32-bit initial domain." and "xen/x86: Use memblock_reserve for sensitive areas."
xen/p2m: Fix the comment describing the P2M tree.
arch/x86/xen/mmu.c
The pagetable_init is the old xen_pagetable_setup_done and xen_pagetable_setup_start
rolled in one.
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into stable/for-linus-3.7
* 'x86/platform' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (9690 commits)
x86: Document x86_init.paging.pagetable_init()
x86: xen: Cleanup and remove x86_init.paging.pagetable_setup_done()
x86: Move paging_init() call to x86_init.paging.pagetable_init()
x86: Rename pagetable_setup_start() to pagetable_init()
x86: Remove base argument from x86_init.paging.pagetable_setup_start
Linux 3.6-rc5
HID: tpkbd: work even if the new Lenovo Keyboard driver is not configured
Remove user-triggerable BUG from mpol_to_str
xen/pciback: Fix proper FLR steps.
uml: fix compile error in deliver_alarm()
dj: memory scribble in logi_dj
Fix order of arguments to compat_put_time[spec|val]
xen: Use correct masking in xen_swiotlb_alloc_coherent.
xen: fix logical error in tlb flushing
xen/p2m: Fix one-off error in checking the P2M tree directory.
powerpc: Don't use __put_user() in patch_instruction
powerpc: Make sure IPI handlers see data written by IPI senders
powerpc: Restore correct DSCR in context switch
powerpc: Fix DSCR inheritance in copy_thread()
powerpc: Keep thread.dscr and thread.dscr_inherit in sync
Signed-off-by: Attilio Rao <attilio.rao@citrix.com>
Acked-by: <konrad.wilk@oracle.com>
Cc: <Ian.Campbell@citrix.com>
Cc: <Stefano.Stabellini@eu.citrix.com>
Cc: <xen-devel@lists.xensource.com>
Link: http://lkml.kernel.org/r/1345580561-8506-6-git-send-email-attilio.rao@citrix.com
At this stage x86_init.paging.pagetable_setup_done is only used in the
XEN case. Move its content in the x86_init.paging.pagetable_init setup
function and remove the now unused x86_init.paging.pagetable_setup_done
remaining infrastructure.
Link: http://lkml.kernel.org/r/1345580561-8506-5-git-send-email-attilio.rao@citrix.com
Move the paging_init() call to the platform specific pagetable_init()
function, so we can get rid of the extra pagetable_setup_done()
function pointer.
Link: http://lkml.kernel.org/r/1345580561-8506-4-git-send-email-attilio.rao@citrix.com
In preparation for unifying the pagetable_setup_start() and
pagetable_setup_done() setup functions, rename appropriately all the
infrastructure related to pagetable_setup_start().
Ackedd-by: <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1345580561-8506-3-git-send-email-attilio.rao@citrix.com
We either use swapper_pg_dir or the argument is unused. Preparatory
patch to simplify platform pagetable setup further.
Ackedb-by: <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1345580561-8506-2-git-send-email-attilio.rao@citrix.com
__copy_to_user() returns the number of bytes remaining to be copied but
we want to return a negative error code here.
Acked-by: Andres Lagar-Cavilla <andres@lagarcavilla.org>
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull DMA-mapping fixes from Marek Szyprowski:
"Another set of fixes for ARM dma-mapping subsystem.
Commit e9da6e9905e6 replaced custom consistent buffer remapping code
with generic vmalloc areas. It however introduced some regressions
caused by limited support for allocations in atomic context. This
series contains fixes for those regressions.
For some subplatforms the default, pre-allocated pool for atomic
allocations turned out to be too small, so a function for setting its
size has been added.
Another set of patches adds support for atomic allocations to
IOMMU-aware DMA-mapping implementation.
The last part of this pull request contains two fixes for Contiguous
Memory Allocator, which relax too strict requirements."
* 'fixes-for-3.6' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
ARM: dma-mapping: IOMMU allocates pages from atomic_pool with GFP_ATOMIC
ARM: dma-mapping: Introduce __atomic_get_pages() for __iommu_get_pages()
ARM: dma-mapping: Refactor out to introduce __in_atomic_pool
ARM: dma-mapping: atomic_pool with struct page **pages
ARM: Kirkwood: increase atomic coherent pool size
ARM: DMA-Mapping: print warning when atomic coherent allocation fails
ARM: DMA-Mapping: add function for setting coherent pool size from platform code
ARM: relax conditions required for enabling Contiguous Memory Allocator
mm: cma: fix alignment requirements for contiguous regions
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: wacom - add support for EMR on Cintiq 24HD touch
Input: i8042 - add Gigabyte T1005 series netbooks to noloop table
Input: imx_keypad - reset the hardware before enabling
Input: edt-ft5x06 - fix build error when compiling wthout CONFIG_DEBUG_FS
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID updates from Jiri Kosina:
"It contains a fix for Eaton Ellipse MAX UPS from Alan Stern,
performance improvement (not processing debug data if noone is
interested), by Henrik Rydberg, and allowing tpkbd-driven devices to
work even with generic driver in a crippled mode, by Andres Freund."
* 'upstream-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: Only dump input if someone is listening
HID: add NOGET quirk for Eaton Ellipse MAX UPS
c1dcad2d32d0252e8a3023d20311b52a187ecda3 added a new driver configured by
HID_LENOVO_TPKBD but made the hid_have_special_driver entry non-optional which
lead to a recognized but non-working device if the new driver wasn't
configured (which is the correct default).
Signed-off-by: Andres Freund <andres@anarazel.de>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull Xen bug-fixes from Konrad Rzeszutek Wilk:
* Fix for TLB flushing introduced in v3.6
* Fix Xen-SWIOTLB not using proper DMA mask - device had 64bit but
in a 32-bit kernel we need to allocate for coherent pages from a
32-bit pool.
* When trying to re-use P2M nodes we had a one-off error and triggered
a BUG_ON check with specific CONFIG_ option.
* When doing FLR in Xen-PCI-backend we would first do FLR then save the
PCI configuration space. We needed to do it the other way around.
* tag 'stable/for-linus-3.6-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Power management
- PCI/PM: Enable D3/D3cold by default for most devices
- PCI/PM: Keep parent bridge active when probing device
- PCI/PM: Fix config reg access for D3cold and bridge suspending
- PCI/PM: Add ABI document for sysfs file d3cold_allowed
Core
- PCI: Don't print anything while decoding is disabled"
* tag '3.6-pci-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
Copy back of per-slot error codes is only necessary for V2. V1 does not provide
an error array, so copyback will unconditionally set the global rc to EFAULT.
Only copyback for V2.
Signed-off-by: Andres Lagar-Cavilla <andres@lagarcavilla.org>
Pull ARM SoC bug fixes from Olof Johansson:
"Mostly Renesas and Atmel bugfixes this time, targeting boot and build
problems. A couple of patches for gemini and kirkwood as well. On a
whole nothing very controversial."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: gemini: fix the gemini build
ARM: shmobile: armadillo800eva: enable rw rootfs mount
ARM: Kirkwood: Fix 'SZ_1M' undeclared here for db88f6281-bp-setup.c
ARM: shmobile: mackerel: fixup usb module order
ARM: shmobile: armadillo800eva: fixup: sound card detection order
ARM: shmobile: marzen: fixup smsc911x id for regulator
ARM: at91/feature-removal-schedule: delay at91_mci removal
ARM: mach-shmobile: armadillo800eva: Enable power button as wakeup source
ARM: mach-shmobile: armadillo800eva: Fix GPIO buttons descriptions
ARM: at91/dts: remove partial parameter in at91sam9g25ek.dts
ARM: at91/clock: fix PLLA overclock warning
ARM: at91: fix rtc-at91sam9 irq issue due to sparse irq support
ARM: at91: fix system timer irq issue due to sparse irq support
ARM: shmobile: sh73a0: fixup RELOC_BASE of intca_irq_pins_desc
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull a hwmon fix from Guenter Roeck:
"One patch, fixing DIV_ROUND_CLOSEST to support negative dividends.
While the changes are not in the drivers/hwmon directory, the problem
primarily affects hwmon drivers, and it makes sense to push the patch
through the hwmon tree."
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
linux/kernel.h: Fix DIV_ROUND_CLOSEST to support negative dividends
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild fixes from Michal Marek:
"These are two fixes that should go into 3.6. The link-vmlinux.sh one
is obvious.
The other one fixes make firmware_install with certain configurations,
where a file in the toplevel firmware tree gets installed first, and
$(INSTALL_FW_PATH)/$$(dir <file>) results in /lib/firmware/./, which
confuses make 3.82 for some reason."
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
firmware: fix directory creation rule matching with make 3.82
link-vmlinux.sh: Fix stray "echo" in error message
Trivially triggerable, found by trinity:
kernel BUG at mm/mempolicy.c:2546!
Process trinity-child2 (pid: 23988, threadinfo ffff88010197e000, task ffff88007821a670)
Call Trace:
show_numa_map+0xd5/0x450
show_pid_numa_map+0x13/0x20
traverse+0xf2/0x230
seq_read+0x34b/0x3e0
vfs_read+0xac/0x180
sys_pread64+0xa2/0xc0
system_call_fastpath+0x1a/0x1f
RIP: mpol_to_str+0x156/0x360
Cc: stable@vger.kernel.org
Signed-off-by: Dave Jones <davej@redhat.com>
When we do FLR and save PCI config we did it in the wrong order.
The end result was that if a PCI device was unbind from
its driver, then binded to xen-pciback, and then back to its
driver we would get:
> lspci -s 04:00.0
04:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
13:42:12 # 4 :~/
> echo "0000:04:00.0" > /sys/bus/pci/drivers/pciback/unbind
> modprobe e1000e
e1000e: Intel(R) PRO/1000 Network Driver - 2.0.0-k
e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
e1000e 0000:04:00.0: Disabling ASPM L0s L1
e1000e 0000:04:00.0: enabling device (0000 -> 0002)
xen: registering gsi 48 triggering 0 polarity 1
Already setup the GSI :48
e1000e 0000:04:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
e1000e: probe of 0000:04:00.0 failed with error -2
This fixes it by first saving the PCI configuration space, then
doing the FLR.
Reported-by: Ren, Yongjie <yongjie.ren@intel.com>
Reported-and-Tested-by: Tobias Geiger <tobias.geiger@vido.info>
CC: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC fixes from Chris Ball:
- a firmware bug on several Samsung MoviNAND eMMC models causes
permanent corruption on the device when secure erase and secure trim
requests are made, so we disable those requests on these eMMC devices.
- atmel-mci: fix a hang with some SD cards by waiting for not-busy flag.
- dw_mmc: low-power mode breaks SDIO interrupts; fix PIO error handling;
fix handling of error interrupts.
- mxs-mmc: fix deadlocks; fix compile error due to dma.h arch change.
- omap: fix broken PIO mode causing memory corruption.
- sdhci-esdhc: fix card detection.
* tag 'mmc-fixes-for-3.6-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc:
mmc: omap: fix broken PIO mode
mmc: card: Skip secure erase on MoviNAND; causes unrecoverable corruption.
mmc: dw_mmc: Disable low power mode if SDIO interrupts are used
mmc: dw_mmc: fix error handling in PIO mode
mmc: dw_mmc: correct mishandling error interrupt
mmc: dw_mmc: amend using error interrupt status
mmc: atmel-mci: not busy flag has also to be used for read operations
mmc: sdhci-esdhc: break out early if clock is 0
mmc: mxs-mmc: fix deadlock caused by recursion loop
mmc: mxs-mmc: fix deadlock in SDIO IRQ case
mmc: bfin_sdh: fix dma_desc_array build error
Fix the following compile error on UML.
arch/um/os-Linux/time.c: In function 'deliver_alarm':
arch/um/os-Linux/time.c:117:3: error: too few arguments to function 'alarm_handler'
arch/um/os-Linux/internal.h:1:6: note: declared here
The error was introduced by commit d3c1cfcd ("um: pass siginfo to guest
process") in 3.6-rc1.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
CC: Martin Pärtel <martin.partel@gmail.com>
Allocate a structure not a pointer to it !
Signed-off-by: Alan Cox <alan@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc fixes from Benjamin Herrenschmidt:
"Here are a few fixes for 3.6 that were piling up while I was away or
busy (I was mostly MIA a week or two before San Diego).
Some fixes from Anton fixing up issues with our relatively new DSCR
control feature, and a few other fixes that are either regressions or
bugs nasty enough to warrant not waiting."
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc: Update DSCR on all CPUs when writing sysfs dscr_default
powerpc/powernv: Always go into nap mode when CPU is offline
powerpc: Give hypervisor decrementer interrupts their own handler
powerpc/vphn: Fix arch_update_cpu_topology() return value
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
"These are some GPIO regression fixes for v3.6:
- Erroneous debug message from of_get_named_gpio_flags()
- Make sure the MC9S08DZ60 GPIO driver depend on I2C being compiled
in (not module) or allmodconfig breaks.
- Check return value from irq_alloc_descs() in the Emma Mobile GPIO
driver.
- Assign the owner field for the rdc321x driver so the module won't
be removed if it has active GPIOs."
* tag 'gpio-fixes-for-v3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio: rdc321x: Prevent removal of modules exporting active GPIOs
gpio: em: Fix checking return value of irq_alloc_descs
gpio: mc9s08dz60: Fix build error if I2C=m
gpio: Fix debug message in of_get_named_gpio_flags()
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"There are nothing scaring, contains only small fixes for HD-audio and
USB-audio:
- EPSS regression fix and GPIO fix for HD-audio IDT codecs
- A series of USB-audio regression fixes that are found since 3.5
kernel"
* tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: snd-usb: fix cross-interface streaming devices
ALSA: snd-usb: fix calls to next_packet_size
ALSA: snd-usb: restore delay information
ALSA: snd-usb: use list_for_each_safe for endpoint resources
ALSA: snd-usb: Fix URB cancellation at stream start
ALSA: hda - Don't trust codec EPSS bit for IDT 92HD83xx & co
ALSA: hda - Avoid unnecessary parameter read for EPSS
ALSA: hda - Do not set GPIOs for speakers on IDT if there are no speakers
Pull fbdev fixes from Florian Tobias Schandinat:
- a fix by Paul Cercueil to prevent a possible buffer overflow
- a fix by Bruno Prémont to prevent a rare sleep in invalid context
- a fix by Julia Lawall for a double free in auo_k190x
- a fix by Dan Carpenter to prevent a division by zero in mb862xxfb
- a regression fix by Tomi Valkeinen for the SDI output in OMAP
- a fix by Grazvydas Ignotas to fix the console colors in OMAP
* tag 'fbdev-fixes-for-3.6-1' of git://github.com/schandinat/linux-2.6:
OMAPFB: fix framebuffer console colors
OMAPDSS: Fix SDI PLL locking
video: mb862xxfb: prevent divide by zero bug
drivers/video/auo_k190x.c: drop kfree of devm_kzalloc's data
fbcon: Fix bit_putcs() call to kmalloc(s, GFP_KERNEL)
fbcon: prevent possible buffer overflow.
Pull ubi fix from Artem Bityutskiy:
"A single small fix for memory deallocation: we allocated memory using
'kmem_cache_alloc()' but were freeing it using 'kfree()' in some
cases. Now we fix this by using 'kmem_cache_free()' instead."
* tag 'upstream-3.6-rc5' of git://git.infradead.org/linux-ubi:
UBI: fix a horrible memory deallocation bug
Commit 644595f89620 ("compat: Handle COMPAT_USE_64BIT_TIME in
net/socket.c") introduced a bug where the helper functions to take
either a 64-bit or compat time[spec|val] got the arguments in the wrong
order, passing the kernel stack pointer off as a user pointer (and vice
versa).
Because of the user address range check, that in turn then causes an
EFAULT due to the user pointer range checking failing for the kernel
address. Incorrectly resuling in a failed system call for 32-bit
processes with a 64-bit kernel.
On odder architectures like HP-PA (with separate user/kernel address
spaces), it can be used read kernel memory.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
PRIVCMD_MMAPBATCH_V2 extends PRIVCMD_MMAPBATCH with an additional
field for reporting the error code for every frame that could not be
mapped. libxc prefers PRIVCMD_MMAPBATCH_V2 over PRIVCMD_MMAPBATCH.
Also expand PRIVCMD_MMAPBATCH to return appropriate error-encoding top nibble
in the mfn array.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Callers of xen_remap_domain_range() need to know if the remap failed
because frame is currently paged out. So they can retry the remap
later on. Return -ENOENT in this case.
This assumes that the error codes returned by Xen are a subset of
those used by the kernel. It is unclear if this is defined as part of
the hypercall ABI.
When running 32-bit pvops-dom0 and a driver tries to allocate a coherent
DMA-memory the xen swiotlb-implementation returned memory beyond 4GB.
The underlaying reason is that if the supplied driver passes in a
DMA_BIT_MASK(64) ( hwdev->coherent_dma_mask is set to 0xffffffffffffffff)
our dma_mask will be u64 set to 0xffffffffffffffff even if we set it to
DMA_BIT_MASK(32) previously. Meaning we do not reset the upper bits.
By using the dma_alloc_coherent_mask function - it does the proper casting
and we get 0xfffffffff.
This caused not working sound on a system with 4 GB and a 64-bit
compatible sound-card with sets the DMA-mask to 64bit.
On bare-metal and the forward-ported xen-dom0 patches from OpenSuse a coherent
DMA-memory is always allocated inside the 32-bit address-range by calling
dma_alloc_coherent_mask.
This patch adds the same functionality to xen swiotlb and is a rebase of the
original patch from Ronny Hegewald which never got upstream b/c the
underlaying reason was not understood until now.
The original email with the original patch is in:
http://old-list-archives.xen.org/archives/html/xen-devel/2010-02/msg00038.html
the original thread from where the discussion started is in:
http://old-list-archives.xen.org/archives/html/xen-devel/2010-01/msg00928.html
Signed-off-by: Ronny Hegewald <ronny.hegewald@online.de>
Signed-off-by: Stefano Panella <stefano.panella@citrix.com>
Acked-By: David Vrabel <david.vrabel@citrix.com>
While TLB_FLUSH_ALL gets passed as 'end' argument to
flush_tlb_others(), the Xen code was made to check its 'start'
parameter. That may give a incorrect op.cmd to MMUEXT_INVLPG_MULTI
instead of MMUEXT_TLB_FLUSH_MULTI. Then it causes some page can not
be flushed from TLB.
This patch fixed this issue.
Reported-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Alex Shi <alex.shi@intel.com>
Acked-by: Jan Beulich <jbeulich@suse.com>
Tested-by: Yongjie Ren <yongjie.ren@intel.com>
* commit '4cb38750d49010ae72e718d46605ac9ba5a851b4': (6849 commits)
bcma: fix invalid PMU chip control masks
[libata] pata_cmd64x: whitespace cleanup
libata-acpi: fix up for acpi_pm_device_sleep_state API
sata_dwc_460ex: device tree may specify dma_channel
ahci, trivial: fixed coding style issues related to braces
ahci_platform: add hibernation callbacks
libata-eh.c: local functions should not be exposed globally
libata-transport.c: local functions should not be exposed globally
sata_dwc_460ex: support hardreset
ata: use module_pci_driver
drivers/ata/pata_pcmcia.c: adjust suspicious bit operation
pata_imx: Convert to clk_prepare_enable/clk_disable_unprepare
ahci: Enable SB600 64bit DMA on MSI K9AGM2 (MS-7327) v2
[libata] Prevent interface errors with Seagate FreeAgent GoFlex
drivers/acpi/glue: revert accidental license-related 6b66d95895c bits
libata-acpi: add missing inlines in libata.h
i2c-omap: Add support for I2C_M_STOP message flag
i2c: Fall back to emulated SMBus if the operation isn't supported natively
i2c: Add SCCB support
i2c-tiny-usb: Add support for the Robofuzz OSIF USB/I2C converter
We would traverse the full P2M top directory (from 0->MAX_DOMAIN_PAGES
inclusive) when trying to figure out whether we can re-use some of the
P2M middle leafs.
Which meant that if the kernel was compiled with MAX_DOMAIN_PAGES=512
we would try to use the 512th entry. Fortunately for us the p2m_top_index
has a check for this:
BUG_ON(pfn >= MAX_P2M_PFN);
which we hit and saw this:
(XEN) domain_crash_sync called from entry.S
(XEN) Domain 0 (vcpu#0) crashed on cpu#0:
(XEN) ----[ Xen-4.1.2-OVM x86_64 debug=n Tainted: C ]----
(XEN) CPU: 0
(XEN) RIP: e033:[<ffffffff819cadeb>]
(XEN) RFLAGS: 0000000000000212 EM: 1 CONTEXT: pv guest
(XEN) rax: ffffffff81db5000 rbx: ffffffff81db4000 rcx: 0000000000000000
(XEN) rdx: 0000000000480211 rsi: 0000000000000000 rdi: ffffffff81db4000
(XEN) rbp: ffffffff81793db8 rsp: ffffffff81793d38 r8: 0000000008000000
(XEN) r9: 4000000000000000 r10: 0000000000000000 r11: ffffffff81db7000
(XEN) r12: 0000000000000ff8 r13: ffffffff81df1ff8 r14: ffffffff81db6000
(XEN) r15: 0000000000000ff8 cr0: 000000008005003b cr4: 00000000000026f0
(XEN) cr3: 0000000661795000 cr2: 0000000000000000
Fixes-Oracle-Bug: 14570662
CC: stable@vger.kernel.org # only for v3.5
