When pstore_post_reboot test gets skipped because of unmet dependencies
and/or unsupported configuration, it returns 0 which is treated as a pass
by the Kselftest framework. This leads to false positive result even when
the test could not be run.
Change it to return kselftest skip code when a test gets skipped to clearly
report that the test could not be run.
Kselftest framework SKIP code is 4 and the framework prints appropriate
messages to indicate that the test is skipped.
Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org>
Pull block fixes from Jens Axboe:
"A collection of fixes that should go into -rc1. This contains:
- bsg_open vs bsg_unregister race fix (Anatoliy)
- NVMe pull request from Christoph, with fixes for regressions in
this window, FC connect/reconnect path code unification, and a
trace point addition.
- timeout fix (Christoph)
- remove a few unused functions (Christoph)
- blk-mq tag_set reinit fix (Roman)"
* tag 'for-linus-20180616' of git://git.kernel.dk/linux-block:
bsg: fix race of bsg_open and bsg_unregister
block: remov blk_queue_invalidate_tags
nvme-fabrics: fix and refine state checks in __nvmf_check_ready
nvme-fabrics: handle the admin-only case properly in nvmf_check_ready
nvme-fabrics: refactor queue ready check
blk-mq: remove blk_mq_tagset_iter
nvme: remove nvme_reinit_tagset
nvme-fc: fix nulling of queue data on reconnect
nvme-fc: remove reinit_request routine
blk-mq: don't time out requests again that are in the timeout handler
nvme-fc: change controllers first connect to use reconnect path
nvme: don't rely on the changed namespace list log
nvmet: free smart-log buffer after use
nvme-rdma: fix error flow during mapping request data
nvme: add bio remapping tracepoint
nvme: fix NULL pointer dereference in nvme_init_subsystem
blk-mq: reinit q->tag_set_list entry only after grace period
Pull documentation fixes from Mauro Carvalho Chehab:
"This solves a series of broken links for files under Documentation,
and improves a script meant to detect such broken links (see
scripts/documentation-file-ref-check).
The changes on this series are:
- can.rst: fix a footnote reference;
- crypto_engine.rst: Fix two parsing warnings;
- Fix a lot of broken references to Documentation/*;
- improve the scripts/documentation-file-ref-check script, in order
to help detecting/fixing broken references, preventing
false-positives.
After this patch series, only 33 broken references to doc files are
detected by scripts/documentation-file-ref-check"
* tag 'docs-broken-links' of git://linuxtv.org/mchehab/experimental: (26 commits)
fix a series of Documentation/ broken file name references
Documentation: rstFlatTable.py: fix a broken reference
ABI: sysfs-devices-system-cpu: remove a broken reference
devicetree: fix a series of wrong file references
devicetree: fix name of pinctrl-bindings.txt
devicetree: fix some bindings file names
MAINTAINERS: fix location of DT npcm files
MAINTAINERS: fix location of some display DT bindings
kernel-parameters.txt: fix pointers to sound parameters
bindings: nvmem/zii: Fix location of nvmem.txt
docs: Fix more broken references
scripts/documentation-file-ref-check: check tools/*/Documentation
scripts/documentation-file-ref-check: get rid of false-positives
scripts/documentation-file-ref-check: hint: dash or underline
scripts/documentation-file-ref-check: add a fix logic for DT
scripts/documentation-file-ref-check: accept more wildcards at filenames
scripts/documentation-file-ref-check: fix help message
media: max2175: fix location of driver's companion documentation
media: v4l: fix broken video4linux docs locations
media: dvb: point to the location of the old README.dvb-usb file
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull fsnotify updates from Jan Kara:
"fsnotify cleanups unifying handling of different watch types.
This is the shortened fsnotify series from Amir with the last five
patches pulled out. Amir has modified those patches to not change
struct inode but obviously it's too late for those to go into this
merge window"
* tag 'fsnotify_for_v4.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs:
fsnotify: add fsnotify_add_inode_mark() wrappers
fanotify: generalize fanotify_should_send_event()
fsnotify: generalize send_to_group()
fsnotify: generalize iteration of marks by object type
fsnotify: introduce marks iteration helpers
fsnotify: remove redundant arguments to handle_event()
fsnotify: use type id to identify connector object type
Pull fbdev updates from Bartlomiej Zolnierkiewicz:
"There is nothing really major here, few small fixes, some cleanups and
dead drivers removal:
- mark omapfb drivers as orphans in MAINTAINERS file (Tomi Valkeinen)
- add missing module license tags to omap/omapfb driver (Arnd
Bergmann)
- add missing GPIOLIB dependendy to omap2/omapfb driver (Arnd
Bergmann)
- convert savagefb, aty128fb & radeonfb drivers to use msleep & co.
(Jia-Ju Bai)
- allow COMPILE_TEST build for viafb driver (media part was reviewed
by media subsystem Maintainer)
- remove unused MERAM support from sh_mobile_lcdcfb and shmob-drm
drivers (drm parts were acked by shmob-drm driver Maintainer)
- remove unused auo_k190xfb drivers
- misc cleanups (Souptick Joarder, Wolfram Sang, Markus Elfring, Andy
Shevchenko, Colin Ian King)"
* tag 'fbdev-v4.18' of git://github.com/bzolnier/linux: (26 commits)
fb_omap2: add gpiolib dependency
video/omap: add module license tags
MAINTAINERS: make omapfb orphan
video: fbdev: pxafb: match_string() conversion fixup
video: fbdev: nvidia: fix spelling mistake: "scaleing" -> "scaling"
video: fbdev: fix spelling mistake: "frambuffer" -> "framebuffer"
video: fbdev: pxafb: Convert to use match_string() helper
video: fbdev: via: allow COMPILE_TEST build
video: fbdev: remove unused sh_mobile_meram driver
drm: shmobile: remove unused MERAM support
video: fbdev: sh_mobile_lcdcfb: remove unused MERAM support
video: fbdev: remove unused auo_k190xfb drivers
video: omap: Improve a size determination in omapfb_do_probe()
video: sm501fb: Improve a size determination in sm501fb_probe()
video: fbdev-MMP: Improve a size determination in path_init()
video: fbdev-MMP: Delete an error message for a failed memory allocation in two functions
video: auo_k190x: Delete an error message for a failed memory allocation in auok190x_common_probe()
video: sh_mobile_lcdcfb: Delete an error message for a failed memory allocation in two functions
video: sh_mobile_meram: Delete an error message for a failed memory allocation in sh_mobile_meram_probe()
video: fbdev: sh_mobile_meram: Drop SUPERH platform dependency
Pull AFS updates from Al Viro:
"Assorted AFS stuff - ended up in vfs.git since most of that consists
of David's AFS-related followups to Christoph's procfs series"
* 'afs-proc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
afs: Optimise callback breaking by not repeating volume lookup
afs: Display manually added cells in dynamic root mount
afs: Enable IPv6 DNS lookups
afs: Show all of a server's addresses in /proc/fs/afs/servers
afs: Handle CONFIG_PROC_FS=n
proc: Make inline name size calculation automatic
afs: Implement network namespacing
afs: Mark afs_net::ws_cell as __rcu and set using rcu functions
afs: Fix a Sparse warning in xdr_decode_AFSFetchStatus()
proc: Add a way to make network proc files writable
afs: Rearrange fs/afs/proc.c to remove remaining predeclarations.
afs: Rearrange fs/afs/proc.c to move the show routines up
afs: Rearrange fs/afs/proc.c by moving fops and open functions down
afs: Move /proc management functions to the end of the file
Pull compat updates from Al Viro:
"Some biarch patches - getting rid of assorted (mis)uses of
compat_alloc_user_space().
Not much in that area this cycle..."
* 'work.compat' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
orangefs: simplify compat ioctl handling
signalfd: lift sigmask copyin and size checks to callers of do_signalfd4()
vmsplice(): lift importing iovec into vmsplice(2) and compat counterpart
Pull aio fixes from Al Viro:
"Assorted AIO followups and fixes"
* 'work.aio' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
eventpoll: switch to ->poll_mask
aio: only return events requested in poll_mask() for IOCB_CMD_POLL
eventfd: only return events requested in poll_mask()
aio: mark __aio_sigset::sigmask const
Pull networking fixes from David Miller:
1) Various netfilter fixlets from Pablo and the netfilter team.
2) Fix regression in IPVS caused by lack of PMTU exceptions on local
routes in ipv6, from Julian Anastasov.
3) Check pskb_trim_rcsum for failure in DSA, from Zhouyang Jia.
4) Don't crash on poll in TLS, from Daniel Borkmann.
5) Revert SO_REUSE{ADDR,PORT} change, it regresses various things
including Avahi mDNS. From Bart Van Assche.
6) Missing of_node_put in qcom/emac driver, from Yue Haibing.
7) We lack checking of the TCP checking in one special case during SYN
receive, from Frank van der Linden.
8) Fix module init error paths of mac80211 hwsim, from Johannes Berg.
9) Handle 802.1ad properly in stmmac driver, from Elad Nachman.
10) Must grab HW caps before doing quirk checks in stmmac driver, from
Jose Abreu.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (81 commits)
net: stmmac: Run HWIF Quirks after getting HW caps
neighbour: skip NTF_EXT_LEARNED entries during forced gc
net: cxgb3: add error handling for sysfs_create_group
tls: fix waitall behavior in tls_sw_recvmsg
tls: fix use-after-free in tls_push_record
l2tp: filter out non-PPP sessions in pppol2tp_tunnel_ioctl()
l2tp: reject creation of non-PPP sessions on L2TPv2 tunnels
mlxsw: spectrum_switchdev: Fix port_vlan refcounting
mlxsw: spectrum_router: Align with new route replace logic
mlxsw: spectrum_router: Allow appending to dev-only routes
ipv6: Only emit append events for appended routes
stmmac: added support for 802.1ad vlan stripping
cfg80211: fix rcu in cfg80211_unregister_wdev
mac80211: Move up init of TXQs
mac80211_hwsim: fix module init error paths
cfg80211: initialize sinfo in cfg80211_get_station
nl80211: fix some kernel doc tag mistakes
hv_netvsc: Fix the variable sizes in ipsecv2 and rsc offload
rds: avoid unenecessary cong_update in loop transport
l2tp: clean up stale tunnel or session in pppol2tp_connect's error path
git://git.kernel.org/pub/scm/linux/kernel/git/jeyu/linux
Pull module updates from Jessica Yu:
"Minor code cleanup and also allow sig_enforce param to be shown in
sysfs with CONFIG_MODULE_SIG_FORCE"
* tag 'modules-for-v4.18' of git://git.kernel.org/pub/scm/linux/kernel/git/jeyu/linux:
module: Allow to always show the status of modsign
module: Do not access sig_enforce directly
git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml
Pull uml updates from Richard Weinberger:
"Minor updates for UML:
- fixes for our new vector network driver by Anton
- initcall cleanup by Alexander
- We have a new mailinglist, sourceforge.net sucks"
* 'for-linus-4.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml:
um: Fix raw interface options
um: Fix initialization of vector queues
um: remove uml initcalls
um: Update mailing list address
git://git.kernel.org/pub/scm/linux/kernel/git/palmer/riscv-linux
Pull RISC-V updates from Palmer Dabbelt:
"This contains some small RISC-V updates I'd like to target for 4.18.
They are all fairly small this time. Here's a short summary, there's
more info in the commits/merges:
- a fix to __clear_user to respect the passed arguments.
- enough support for the perf subsystem to work with RISC-V's ISA
defined performance counters.
- support for sparse and cleanups suggested by it.
- support for R_RISCV_32 (a relocation, not the 32-bit ISA).
- some MAINTAINERS cleanups.
- the addition of CONFIG_HVC_RISCV_SBI to our defconfig, as it's
always present.
I've given these a simple build+boot test"
* tag 'riscv-for-linus-4.18-merge_window' of git://git.kernel.org/pub/scm/linux/kernel/git/palmer/riscv-linux:
RISC-V: Add CONFIG_HVC_RISCV_SBI=y to defconfig
RISC-V: Handle R_RISCV_32 in modules
riscv/ftrace: Export _mcount when DYNAMIC_FTRACE isn't set
riscv: add riscv-specific predefines to CHECKFLAGS
riscv: split the declaration of __copy_user
riscv: no __user for probe_kernel_address()
riscv: use NULL instead of a plain 0
perf: riscv: Add Document for Future Porting Guide
perf: riscv: preliminary RISC-V support
MAINTAINERS: Update Albert's email, he's back at Berkeley
MAINTAINERS: Add myself as a maintainer for SiFive's drivers
riscv: Fix the bug in memory access fixup code
Pull more kvm updates from Paolo Bonzini:
"Mostly the PPC part of the release, but also switching to Arnd's fix
for the hyperv config issue and a typo fix.
Main PPC changes:
- reimplement the MMIO instruction emulation
- transactional memory support for PR KVM
- improve radix page table handling"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (63 commits)
KVM: x86: VMX: redo fix for link error without CONFIG_HYPERV
KVM: x86: fix typo at kvm_arch_hardware_setup comment
KVM: PPC: Book3S PR: Fix failure status setting in tabort. emulation
KVM: PPC: Book3S PR: Enable use on POWER9 bare-metal hosts in HPT mode
KVM: PPC: Book3S PR: Don't let PAPR guest set MSR hypervisor bit
KVM: PPC: Book3S PR: Fix failure status setting in treclaim. emulation
KVM: PPC: Book3S PR: Fix MSR setting when delivering interrupts
KVM: PPC: Book3S PR: Handle additional interrupt types
KVM: PPC: Book3S PR: Enable kvmppc_get/set_one_reg_pr() for HTM registers
KVM: PPC: Book3S: Remove load/put vcpu for KVM_GET_REGS/KVM_SET_REGS
KVM: PPC: Remove load/put vcpu for KVM_GET/SET_ONE_REG ioctl
KVM: PPC: Move vcpu_load/vcpu_put down to each ioctl case in kvm_arch_vcpu_ioctl
KVM: PPC: Book3S PR: Enable HTM for PR KVM for KVM_CHECK_EXTENSION ioctl
KVM: PPC: Book3S PR: Support TAR handling for PR KVM HTM
KVM: PPC: Book3S PR: Add guard code to prevent returning to guest with PR=0 and Transactional state
KVM: PPC: Book3S PR: Add emulation for tabort. in privileged state
KVM: PPC: Book3S PR: Add emulation for trechkpt.
KVM: PPC: Book3S PR: Add emulation for treclaim.
KVM: PPC: Book3S PR: Restore NV regs after emulating mfspr from TM SPRs
KVM: PPC: Book3S PR: Always fail transactions in guest privileged state
Pull virtio updates from Michael Tsirkin:
"virtio, vhost: features, fixes
- PCI virtual function support for virtio
- DMA barriers for virtio strong barriers
- bugfixes"
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
virtio: update the comments for transport features
virtio_pci: support enabling VFs
vhost: fix info leak due to uninitialized memory
virtio_ring: switch to dma_XX barriers for rpmsg
As files move around, their previous links break. Fix the
references for them.
Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Acked-by: Jonathan Corbet <corbet@lwn.net>
The old HOWTO was removed a long time ago. The flat table
version is not metioned elsewhere, so just get rid of the
text.
This file doesn't exist anymore:
Documentation/cpu-freq/user-guide.txt
As the ABI already points to Documentation/cpu-freq, just
remove the broken link and the associated text.
As files got renamed, their references broke.
Manually fix a series of broken refs at the DT bindings.
Rename:
pinctrl-binding.txt -> pinctrl-bindings.txt
In order to match the current name of this file.
There were some file movements that changed the location for
some DT bindings. Fix them with:
scripts/documentation-file-ref-check --fix
After manually checking if the new file makes sense.
The specified locations are not right. Fix the wildcard logic
to point to the correct directories.
Without that, get-maintainer won't get things right:
$ ./scripts/get_maintainer.pl --no-git-fallback --no-r --no-n --no-l -f Documentation/devicetree/bindings/arm/cpu-enable-method/nuvoton,npcm750-smp
robh+dt@kernel.org (maintainer:OPEN FIRMWARE AND FLATTENED DEVICE TREE BINDINGS)
mark.rutland@arm.com (maintainer:OPEN FIRMWARE AND FLATTENED DEVICE TREE BINDINGS)
After the patch, it will properly point to NPCM arch maintainers:
avifishman70@gmail.com (supporter:ARM/NUVOTON NPCM ARCHITECTURE)
tmaimon77@gmail.com (supporter:ARM/NUVOTON NPCM ARCHITECTURE)
Cc: Avi Fishman <avifishman70@gmail.com>
Cc: Tomer Maimon <tmaimon77@gmail.com>
Cc: Patrick Venture <venture@google.com>
Cc: Nancy Yuen <yuenn@google.com>
Cc: Brendan Higgins <brendanhiggins@google.com>
Those files got a manufacturer's name prepended and were moved around.
Adjust their references accordingly.
Also, due those movements, Documentation/devicetree/bindings/video
doesn't exist anymore.
Cc: David Airlie <airlied@linux.ie>
Cc: David Lechner <david@lechnology.com>
Cc: Peter Senna Tschudin <peter.senna@collabora.com>
Cc: Martin Donnelly <martin.donnelly@ge.com>
Cc: Martyn Welch <martyn.welch@collabora.co.uk>
Cc: Stefan Agner <stefan@agner.ch>
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Eric Anholt <eric@anholt.net>
The alsa parameters file was renamed to alsa-configuration.rst.
With regards to OSS, it got retired as a hole by at changeset
727dede0ba8a ("sound: Retire OSS"). So, it doesn't make sense
to keep mentioning it at kernel-parameters.txt.
Fixes: 727dede0ba8a ("sound: Retire OSS")
The location pointed there is missing "bindings/" on its path.
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
As we move stuff around, some doc references are broken. Fix some of
them via this script:
./scripts/documentation-file-ref-check --fix
Manually checked that produced results are valid.
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Takashi Iwai <tiwai@suse.de>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
Some files, like tools/memory-model/README has references to
a Documentation file that is locale to it. Handle references
that are relative to them too.
Now that the number of broken refs are smaller, improve the logic
that gets rid of false-positives.
Sometimes, people use dash instead of underline or vice-versa.
Try to autocorrect it.
There are several links broken due to DT file movements. Add
a hint logic to seek for those changes.
at MAINTAINERS, some filename paths use '?' and things like [7,9].
So, accept more wildcards, in order to avoid false-positives.
The name of the --fix option was renamed, but it was not
changed at the quick help message.
There's a missing ".rst" at the doc's file name.
Acked-by: Ramesh Shanmugasundaram <Ramesh.shanmugasundaram@bp.renesas.com>
There are several places pointing to old documentation files:
Documentation/video4linux/API.html
Documentation/video4linux/bttv/
Documentation/video4linux/cx2341x/fw-encoder-api.txt
Documentation/video4linux/m5602.txt
Documentation/video4linux/v4l2-framework.txt
Documentation/video4linux/videobuf
Documentation/video4linux/Zoran
Make them point to the new location where available, removing
otherwise.
This file got renamed, but the references still point to the
old place.
This script was moved out of Documentation/dvb, but the
links weren't updated.
Manually checked if the produced result is valid, removing a few
false-positives.
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Stephen Boyd <sboyd@kernel.org>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Acked-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Reviewed-by: Coly Li <colyli@suse.de>
The script:
Gives multiple hints for broken references on some files.
Manually use the one that applies for some files.
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Acked-by: James Morris <james.morris@microsoft.com>
Currently we were running HWIF quirks before getting HW capabilities.
This is not right because some HWIF callbacks depend on HW caps.
Lets save the quirks callback and use it in a later stage.
This fixes Altera socfpga.
Signed-off-by: Jose Abreu <joabreu@synopsys.com>
Fixes: 5f0456b43140 ("net: stmmac: Implement logic to automatically select HW Interface")
Reported-by: Dinh Nguyen <dinh.linux@gmail.com>
Cc: Joao Pinto <jpinto@synopsys.com>
Cc: Vitor Soares <soares@synopsys.com>
Cc: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Cc: Alexandre Torgue <alexandre.torgue@st.com>
Cc: Dinh Nguyen <dinh.linux@gmail.com>
Commit 9ce33e46531d ("neighbour: support for NTF_EXT_LEARNED flag")
added support for NTF_EXT_LEARNED for neighbour entries.
NTF_EXT_LEARNED entries are neigh entries managed by control
plane (eg: Ethernet VPN implementation in FRR routing suite).
Periodic gc already excludes these entries. This patch extends
it to forced gc which the earlier patch missed.
Fixes: 9ce33e46531d ("neighbour: support for NTF_EXT_LEARNED flag")
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
When sysfs_create_group fails, the lack of error-handling code may
cause unexpected results.
This patch adds error-handling code after calling sysfs_create_group.
Signed-off-by: Zhouyang Jia <jiazhouyang09@gmail.com>
Daniel Borkmann says:
Two tls fixes
First one is syzkaller trigered uaf and second one noticed
while writing test code with tls ulp. For details please see
individual patches.
Current behavior in tls_sw_recvmsg() is to wait for incoming tls
messages and copy up to exactly len bytes of data that the user
provided. This is problematic in the sense that i) if no packet
is currently queued in strparser we keep waiting until one has been
processed and pushed into tls receive layer for tls_wait_data() to
wake up and push the decrypted bits to user space. Given after
tls decryption, we're back at streaming data, use sock_rcvlowat()
hint from tcp socket instead. Retain current behavior with MSG_WAITALL
flag and otherwise use the hint target for breaking the loop and
returning to application. This is done if currently no ctx->recv_pkt
is ready, otherwise continue to process it from our strparser
backlog.
Fixes: c46234ebb4d1 ("tls: RX path for ktls")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Dave Watson <davejwatson@fb.com>
syzkaller managed to trigger a use-after-free in tls like the
following:
BUG: KASAN: use-after-free in tls_push_record.constprop.15+0x6a2/0x810 [tls]
Write of size 1 at addr ffff88037aa08000 by task a.out/2317
CPU: 3 PID: 2317 Comm: a.out Not tainted 4.17.0+ #144
Hardware name: LENOVO 20FBCTO1WW/20FBCTO1WW, BIOS N1FET47W (1.21 ) 11/28/2016
Call Trace:
dump_stack+0x71/0xab
print_address_description+0x6a/0x280
kasan_report+0x258/0x380
? tls_push_record.constprop.15+0x6a2/0x810 [tls]
tls_sw_push_pending_record+0x2e/0x40 [tls]
tls_sk_proto_close+0x3fe/0x710 [tls]
? tcp_check_oom+0x4c0/0x4c0
? tls_write_space+0x260/0x260 [tls]
? kmem_cache_free+0x88/0x1f0
inet_release+0xd6/0x1b0
__sock_release+0xc0/0x240
sock_close+0x11/0x20
__fput+0x22d/0x660
task_work_run+0x114/0x1a0
do_exit+0x71a/0x2780
? mm_update_next_owner+0x650/0x650
? handle_mm_fault+0x2f5/0x5f0
? __do_page_fault+0x44f/0xa50
? mm_fault_error+0x2d0/0x2d0
do_group_exit+0xde/0x300
__x64_sys_exit_group+0x3a/0x50
do_syscall_64+0x9a/0x300
? page_fault+0x8/0x30
entry_SYSCALL_64_after_hwframe+0x44/0xa9
This happened through fault injection where aead_req allocation in
tls_do_encryption() eventually failed and we returned -ENOMEM from
the function. Turns out that the use-after-free is triggered from
tls_sw_sendmsg() in the second tls_push_record(). The error then
triggers a jump to waiting for memory in sk_stream_wait_memory()
resp. returning immediately in case of MSG_DONTWAIT. What follows is
the trim_both_sgl(sk, orig_size), which drops elements from the sg
list added via tls_sw_sendmsg(). Now the use-after-free gets triggered
when the socket is being closed, where tls_sk_proto_close() callback
is invoked. The tls_complete_pending_work() will figure that there's
a pending closed tls record to be flushed and thus calls into the
tls_push_pending_closed_record() from there. ctx->push_pending_record()
is called from the latter, which is the tls_sw_push_pending_record()
from sw path. This again calls into tls_push_record(). And here the
tls_fill_prepend() will panic since the buffer address has been freed
earlier via trim_both_sgl(). One way to fix it is to move the aead
request allocation out of tls_do_encryption() early into tls_push_record().
This means we don't prep the tls header and advance state to the
TLS_PENDING_CLOSED_RECORD before allocation which could potentially
fail happened. That fixes the issue on my side.
Fixes: 3c4d7559159b ("tls: kernel TLS support")
Reported-by: syzbot+5c74af81c547738e1684@syzkaller.appspotmail.com
Reported-by: syzbot+709f2810a6a05f11d4d3@syzkaller.appspotmail.com
Guillaume Nault says:
l2tp: l2tp_ppp must ignore non-PPP sessions
The original L2TP code was written for version 2 of the protocol, which
could only carry PPP sessions. Then L2TPv3 generalised the protocol so that
it could transport different kinds of pseudo-wires. But parts of the
l2tp_ppp module still break in presence of non-PPP sessions.
Assuming L2TPv2 tunnels can only transport PPP sessions is right, but
l2tp_netlink failed to ensure that (fixed in patch 1).
When retrieving a session from an arbitrary tunnel, l2tp_ppp needs to
filter out non-PPP sessions (last occurrence fixed in patch 2).
pppol2tp_tunnel_ioctl() can act on an L2TPv3 tunnel, in which case
'session' may be an Ethernet pseudo-wire.
However, pppol2tp_session_ioctl() expects a PPP pseudo-wire, as it
assumes l2tp_session_priv() points to a pppol2tp_session structure. For
an Ethernet pseudo-wire l2tp_session_priv() points to an l2tp_eth_sess
structure instead, making pppol2tp_session_ioctl() access invalid
memory.
Fixes: d9e31d17ceba ("l2tp: Add L2TP ethernet pseudowire support")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
The /proc/net/pppol2tp handlers (pppol2tp_seq_*()) iterate over all
L2TPv2 tunnels, and rightfully expect that only PPP sessions can be
found there. However, l2tp_netlink accepts creating Ethernet sessions
regardless of the underlying tunnel version.
This confuses pppol2tp_seq_session_show(), which expects that
l2tp_session_priv() returns a pppol2tp_session structure. When the
session is an Ethernet pseudo-wire, a struct l2tp_eth_sess is returned
instead. This leads to invalid memory access when
pppol2tp_session_get_sock() later tries to dereference ps->sk.
Ido Schimmel says:
mlxsw: IPv6 and reference counting fixes
The first three patches fix a mismatch between the new IPv6 behavior
introduced in commit f34436a43092 ("net/ipv6: Simplify route replace and
appending into multipath route") and mlxsw. The patches allow the driver
to support multipathing in IPv6 overlays with GRE tunnel devices. A
selftest will be submitted when net-next opens.
The last patch fixes a reference count problem of the port_vlan struct.
I plan to simplify the code in net-next, so that reference counting is
not necessary anymore.
Switchdev notifications for addition of SWITCHDEV_OBJ_ID_PORT_VLAN are
distributed not only on clean addition, but also when flags on an
existing VLAN are changed. mlxsw_sp_bridge_port_vlan_add() calls
mlxsw_sp_port_vlan_get() to get at the port_vlan in question, which
implicitly references the object. This then leads to discrepancies in
reference counting when the VLAN is removed. spectrum.c warns about the
problem when the module is removed:
[13578.493090] WARNING: CPU: 0 PID: 2454 at drivers/net/ethernet/mellanox/mlxsw/spectrum.c:2973 mlxsw_sp_port_remove+0xfd/0x110 [mlxsw_spectrum]
[13578.627106] Call Trace:
[13578.629617] mlxsw_sp_fini+0x2a/0xe0 [mlxsw_spectrum]
[13578.634748] mlxsw_core_bus_device_unregister+0x3e/0x130 [mlxsw_core]
[13578.641290] mlxsw_pci_remove+0x13/0x40 [mlxsw_pci]
[13578.646238] pci_device_remove+0x31/0xb0
[13578.650244] device_release_driver_internal+0x14f/0x220
[13578.655562] driver_detach+0x32/0x70
[13578.659183] bus_remove_driver+0x47/0xa0
[13578.663134] pci_unregister_driver+0x1e/0x80
[13578.667486] mlxsw_sp_module_exit+0xc/0x3fa [mlxsw_spectrum]
[13578.673207] __x64_sys_delete_module+0x13b/0x1e0
[13578.677888] ? exit_to_usermode_loop+0x78/0x80
[13578.682374] do_syscall_64+0x39/0xe0
[13578.685976] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fix by putting the port_vlan when mlxsw_sp_port_vlan_bridge_join()
determines it's a flag-only change.
Fixes: b3529af6bb0d ("spectrum: Reference count VLAN entries")
Signed-off-by: Petr Machata <petrm@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Commit f34436a43092 ("net/ipv6: Simplify route replace and appending
into multipath route") changed the IPv6 route replace logic so that the
first matching route (i.e., same metric) is replaced.
Have mlxsw replace the first matching route as well.
Fixes: f34436a43092 ("net/ipv6: Simplify route replace and appending into multipath route")
