PAN capable microcode has a different
queue assignment (not just more queues
for PAN) due to the way multicast is
handled for AP mode.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
PAN ucode will require a different queue assignment,
in particular queue 9 instead of 4 should be used for
commands.
This is required because the ucode will stop/start
queues 4 and 8 depending on the PAN state, since
queue 8 will be used for PAN multicast (after DTIM).
In order to support multiple interfaces, we must move
a lot of data into per-context structures so we can
use the contexts the device offers. To start with,
this makes a lot of code context-aware, more changes
will move more things into the context structure.
Encounter compiler error when iwlwifi debugging support is
disabled, fix it.
This compiler error was introduced by the previous WiFi/BT coexist patchset.
When a mac80211-based driver advertises mesh mode
support, this will be advertised to userspace.
However, if mac80211 was compiled without mesh
support, then that won't actually be true. Fix
this by removing the bit for mesh if mesh isn't
compiled in.
Since this synchronizes what we advertise to
cfg80211 and actually support, it means we can
now rely on cfg80211's interface type checks
and need not check again in mac80211.
This patch should fix the dodgy signal and noise value
reports for most longbow (p54spi) users:
e.g.: (an older tcpdump extract)
> 2.0 Mb/s 2437 MHz (0x00a0) -49dB signal -41dB noise
> 1.0 Mb/s 2437 MHz (0x00a0) 4dB signal -41dB noise
The formula is taken from stlc45xx:
http://gitorious.org/stlc45xx/mainline/blobs/master/stlc45xx.c#line1199
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
This patch fixes a potential crash (null-pointer de-
reference) which was introduced in my previous patch:
"mac80211: AMPDU rx reorder timeout timer"
During a BA teardown, the pointer to the soon-to-be-gone
tid_ampdu_rx element will be nullified. Therefore the
release timer mechanism has to be careful not to
accidentally access the item without any RCU protection.
commit 95a6ccbb46c70cff376684c752831c014c87029d
Author: Johannes Berg <johannes.berg@intel.com>
Date: Thu Aug 12 15:38:38 2010 +0200
cfg80211/mac80211: extensible frame processing
introduced a netlink bug that caused parsing errors
in userspace because it forgot to close a nesting,
which would advertise a nesting length of zero to
userspace, which then completely threw off parsing
and led to
Illegal nla->nla_type == 0
being printed by libnl.
rt2x00 debugfs interface doesn't check the size of the data coming
from userspace, leading to a build warning. Fix That.
v2: return EINVAL if input is too long
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
During initialization each driver reads the default TX power
for each individual channel. However mac80211 only accepts the
maximum value (which is also handled as default value).
As a result, the TX power of the device was being limited to
the default value, which is often quite low compared to the
real maximum acceptable value.
This patch allows each driver to set the maximum value on a
per-channel basis which is forwarded to mac80211. The default
value will be preserved for now, in case we want to update
mac80211 to differentiate between the maximum and default txpower.
This fixes bug complaining about limited TX power values like:
https://bugzilla.kernel.org/show_bug.cgi?id=16358
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
Acked-by: Helmut Schaa <helmut.schaa@googlemail.com>
We missed a check for RF3052 in the config_channel
configuration function. As a result the channel is not
properly configured for RF3052 devices. This also
requires rt2800_config_channel_rf3xxx to support 5GHz
channels, so we must apply the TXPOWER_A_TO_DEV and
TXPOWER_G_TO_DEV conversions during rt2800_config_channel()
The functions rt2800pci_enable_radio and rt2800usb_disable_radio are
almost equal and can be merged into rt2800lib. This reduces the number
of functions which must be exported from rt2800lib to the drivers at
the same time.
Also rt2800pci_disable_radio and rt2800usb_disable_radio are almost
equal and can be merged into rt2800lib in a similar fashion.
The retry count for a frame is calculated by the realized MCS rate
subtracting of the requested MCS rate. However during TX done reporting
we accidently override the requested MCS rate with the realized MCS
rate. This causes the retry count to be reset to 0 always, and feeding
invalid rate information into minstrel_ht.
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Q_INDEX_CRYPTO and ENTRY_OWNER_DEVICE_CRYPTO where initially
added with the plan to implement hardware encryption for rt2500pci.
However there are no plans to do so anymore as the crypto
mechanism in rt2500pci is very different then any other Ralink
device.
So we can now safely remove the definitions, and don't think
about this feature anymore. :)
All access to queue->entries through the Q_INDEX/Q_INDEX_DONE
variables must be done using spinlock protection. It is best
to manage this completely from rt2x00queue.c.
For safely looping through all entries in the queue, the function
rt2x00queue_for_each_entry is added which will walk from from a index
range in a safe manner.
This also fixes rt2x00usb which walked the entries list from
0 to length to kill each entry (killing entries must be done
from Q_INDEX_DONE to Q_INDEX to enforce TX status reporting to
occur in the correct order.
Cosmetic change, reduce indenting.
write_tx_desc shouldn't pass a rt2x00dev and skb pointer,
instead it should use the same format as other TX frame
callback functions, which is passing the data_entry pointer
which contains all the information which is needed to work
on a TX frame.
Most callers of the kick_tx_queue and kill_tx_queue already
have the data_queue pointer, so rather then sending the QID
with the given function, when the driver requests a new
pointer to the data_queue, it is more efficient to just
send the data_queue pointer directly.
When aggregation is stopped again for some reason
before the queue we selected has drained, we will
currently leak the TX queue and keep it enabled
for aggregation. Normally this doesn't happen, so
the problem is rarely seen.
Add the debugfs file to show current bluetooth traffic load
Update bt status upon receive scan complete notification
Move bt coex functions to iwl-agn-lib.c, so those functions
can be shared by multiple wifi/bt combo devices
Current BT traffic load should based on the following conditions:
1. BT On/Off status
2. Channel announcement enable/disable
3. Curren traffic load report from uCode
Need to modify rate scale to down-grade from MIMO to SISO if detected
high BT traffic load. Also need to make sure not using chain "B" with high
BT traffic or if it is in "full concurrency" mode.
Add bt_ch_announce module parameter to enable/disable BT channel
announcement mode; default is "enable"
Based on the bt channel announcement module parameter to configure the
bt_config host command.
Add additional bt coex related parameters and initialize at init
time.
Thoese parameters will be used in later implementations.
1. Based on uart message from uCode, re-configure BT kill ack mask
messages from uCode
2. send REPLY_BT_COEX_SCO command to uCode based on the uart frame
received from uCode
Use .cfg to configure the default bt priority boost value;
the default bt priority boost is 0xf0
Adding configurable parameter in .cfg for the initial Bluetooth traffic
load; set it to IWL_BT_COEX_TRAFFIC_LOAD_NONE for now, but can be change
for debugging or other reason.
In current implementation, stuck queue timer is fixed to 1 second. Add
debugfs file to modify the timer to enhance the flexibility:
Set the monitor_period as following:
0: disable stuck queue force reset function
1 - 60000: monitor period (1 - 60 second)
Generate log when receive tx reply with bt_kill count > 0 and
in advance bt coex mode
bt config command need to send before the init calibration command,
driver need to let uCode know that calibrations are being performed now
in order to assure antenna is not being taken to BT use during radio/dsp
reads/writes
Also, bt_coex_priorty_table command need to be send right after the
bt_config_command during init sequence. Followed by bt coex envelope
command to initialize and prepare uCode bt state machine
Adding the bluetooth full concurrency support for WiFi/BT combo devices.
Driver should configure uCode to operate in "full concurrency" mode (via
LUT) if both conditions are met:
- Antenna Coupling is more than 35dB
- WiFi Channel Inhibition Request is hornored by BT Core
Currently, there is no antenna coupling information provided by uCode;
use module parameter to specified the antenna coupling in dB.
When in "full concurrency" mode, driver need to download different LUT
to uCode while sending bt configuration command; also, driver need to
configure the device operate in 1x1 while in full concurrency mode.
When bluetooth indicated high load, we should use
only antenna A in 2.4 GHz for management frames.
Add this condition to iwl_toggle_tx_ant() to make
sure it'll always be met. Note that scanning has
a separate way of forcing the antenna, because we
should scan on antenna A only regardless of BT
traffic load.
Disable plcp error checking for 6000g2b devices, with wifi/bt coex;
this got trigger too often, disable for now until finding better
trigger point.
Also extend the firmware reload timer much longer for BT coex to make sure
there are will be no mistake to reload firmware too fast and too often.
The BT SCO needs to be re-applied to the device,
while the traffic load just needs to be correct
in software.
IBSS doesn't allow for coexistence, so it
should be disabled.
Additionally, disable reacting to the BT
profile notification when in IBSS mode,
it likely won't be sent by the device to
start with though.
Also, in IBSS mode, BT coexistence isn't as fully-featured
and we must use a single antenna only. So instead of
peppering the code with new checks, simply pretend
we are in high BT traffic load, which has the needed
effect of disabling antenna B use.
When we turn off the device, reset BT
data so that we don't have outdated
information when we come up again.
Depending on the amount of bluetooth traffic,
using the shared antenna (antenna B) will have
adverse impact on both bluetooth and wireless
traffic. Add controls to improve the situation
by making rate scaling depend on the BT load.
When there's high bluetooth traffic load, there's
little point in trying to aggregate as BT traffic
would disrupt the aggregated frames all the time,
so simply don't start sessions then.
When BT traffic returns to lower levels, the rate
scaling will come here again automatically when
wifi traffic is high enough, and then it will be
able to successfully enable aggregation.
When advanced bt coex enabled, uCode will send bt status
notification to driver, here add support for it.
The BT ignore bit should be set when transmitting
auth, assoc response and eap frames.
Also, scanning should set the BT ignore bit for the
probe request transmission; Note that we only use
the non-shared antenna.
6000g2b hardware implements advance bluetooth coexist command,
implement base on the new API command strucutre.
Also increment the API 5 to support the advance BT/WIfi coex.
The new 6000g2b hardware requires a different
bluetooth coexist implementation on the host,
this adds the command/notification definitions
for it.
No code or function changes, just some cleanup work for
out-of-date comments
No functional changes, update comments to match current file structure
Unlike most other workqueue-tasks, the restart_work is
not scheduled onto mac80211's private per-interface
workqueue, but onto one of the system-wide workqueues.
Therefore the mac80211-stack has to cancel any pending
restarts, before destroying the shared device context
and handing back the memory. Otherwise - under very
unlucky circumstances - there could be a stale work-
item left, because some other kernel component might
have delayed the execution of ieee80211_restart_work
for too long.
The ISL3887 chip needs a USB reset, whenever the
usb-frontend module "p54usb" is reloaded.
This patch fixes an off-by-one bug, if the user
is running a kernel without the CONFIG_PM option
set and for some reason (e.g.: compat-wireless)
wants to switch between different p54usb modules.
Cc: <stable@kernel.org>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Signed-off-by: Kalle Valo <kvalo@adurom.com>
As my nokia address doesn't work anymore, it's better just to remove the
copyright contact altogether. We have MODULE_AUTHOR() scripts for these
anyway.
Acked-by: Luciano Coelho <luciano.coelho@nokia.com>
Luciano should be the contact person for the include/linux/spi/wl12xx.h file.
