According to the errata
https://www.rfc-editor.org/errata_search.php?rfc=5661&eid=2751
we should always send layout commit after a commit to DS.
Fixes: bc7d4b8fd091 ("nfs/filelayout: set layoutcommit...")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
While COMMIT has the potential to free up a lot of memory that is being
taken by unstable writes, it isn't guaranteed to free up this particular
page. Also, calling fsync() on the server is expensive and so we want to
do it in a more controlled fashion, rather than have it triggered at
random by the VM.
Commits are no longer required to be serialised.
It is almost always better to wait for more so that we can issue a
bulk commit.
filemap_datawrite() and friends already deal just fine with livelock.
Unless the user is using file locking, we must assume close-to-open
cache consistency when the file is open for writing. Adjust the
caching algorithm so that it does not clear the cache on out-of-order
writes and/or attribute revalidations.
If an attribute revalidation fails, then we already know that we'll
zap the access cache. If, OTOH, the inode isn't changing, there should
be no need to eject access calls just because they are old.
If there were outstanding writes then chalk up the unexpected change
attribute on the server to them.
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management fixes from Zhang Rui:
- fix an ordering issue in cpu cooling that cooling device is
registered before it's ready (freq_table being populated).
(Lukasz Luba)
- fix a missing comment update (Caesar Wang)
* 'for-rc' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux:
thermal: add the note for set_trip_temp
thermal: cpu_cooling: fix improper order during initialization
Pull block layer fixes from Jens Axboe:
"A small collection of fixes for the current series. This contains:
- Two fixes for xen-blkfront, from Bob Liu.
- A bug fix for NVMe, releasing only the specific resources we
requested.
- Fix for a debugfs flags entry for nbd, from Josef.
- Plug fix from Omar, fixing up a case of code being switched between
two functions.
- A missing bio_put() for the new discard callers of
submit_bio_wait(), fixing a regression causing a leak of the bio.
From Shaun.
- Improve dirty limit calculation precision in the writeback code,
fixing a case where setting a limit lower than 1% of memory would
end up being zero. From Tejun"
* 'for-linus' of git://git.kernel.dk/linux-block:
NVMe: Only release requested regions
xen-blkfront: fix resume issues after a migration
xen-blkfront: don't call talk_to_blkback when already connected to blkback
nbd: pass the nbd pointer for flags debugfs
block: missing bio_put following submit_bio_wait
blk-mq: really fix plug list flushing for nomerge queues
writeback: use higher precision calculation in domain_dirty_limits()
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
"A new bunch of GPIO fixes for v4.7.
This time I am very grateful that Ricardo Ribalda Delgado went in and
fixed my stupid refcounting mistakes in the removal path for GPIO
chips. I had a feeling something was wrong here and so it was. It
exploded on OMAP and it fixes their problem. Now it should be (more)
solid.
The rest i compilation, Kconfig and driver fixes. Some tagged for
stable.
Summary:
- Fix a NULL pointer dereference when we are searching the GPIO
device list but one of the devices have been removed (struct
gpio_chip pointer is NULL).
- Fix unaligned reference counters: we were ending on +3 after all
said and done. It should be 0. Remove an extraneous get_device(),
and call cdev_del() followed by device_del() in gpiochip_remove()
instead and the count goes to zero and calls the release() function
properly.
- Fix a compile warning due to a missing #include in the OF/device
tree portions.
- Select ANON_INODES for GPIOLIB, we're using that for our character
device. Some randconfig tests disclosed the problem.
- Make sure the Zynq driver clock runs also without CONFIG_PM enabled
- Fix an off-by-one error in the 104-DIO-48E driver
- Fix warnings in bcm_kona_gpio_reset()"
* tag 'gpio-v4.7-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio: bcm-kona: fix bcm_kona_gpio_reset() warnings
gpio: select ANON_INODES
gpio: include <linux/io-mapping.h> in gpiolib-of
gpiolib: Fix unaligned used of reference counters
gpiolib: Fix NULL pointer deference
gpio: zynq: initialize clock even without CONFIG_PM
gpio: 104-dio-48e: Fix control port offset computation off-by-one error
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"Two current fixes:
- one affects Qemu CD ROM emulation, which stopped working after the
updates in SCSI to require VPD pages from all conformant devices.
Fix temporarily by blacklisting Qemu (we can relax later when they
come into compliance).
- The other is a fix to the optimal transfer size. We set up a
minefield for ourselves by being confused about whether the limits
are in bytes or sectors (SCSI optimal is in blocks and the queue
parameter is in bytes).
This tries to fix the problem (wrong setting for queue limits
max_sectors) and make the problem more obvious by introducing a
wrapper function"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
sd: Fix rw_max for devices that report an optimal xfer size
scsi: Add QEMU CD-ROM to VPD Inquiry Blacklist
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
- a bigger fix for i801 to finally be able to be loaded on some
machines again
- smaller driver fixes
- documentation update because of a renamed file
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: mux: reg: Provide of_match_table
i2c: mux: refer to i2c-mux.txt
i2c: octeon: Avoid printk after too long SMBUS message
i2c: octeon: Missing AAK flag in case of I2C_M_RECV_LEN
i2c: i801: Allow ACPI SystemIO OpRegion to conflict with PCI BAR
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree fixes from Rob Herring:
- fix unflatten_dt_nodes when dad parameter is set.
- add vendor prefixes for TechNexion and UniWest
- documentation fix for Marvell BT
- OF IRQ kerneldoc fixes
- restrict CMA alignment adjustments to non dma-coherent
- a couple of warning fixes in reserved-memory code
- DT maintainers updates
* tag 'devicetree-fixes-for-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
drivers: of: add definition of early_init_dt_alloc_reserved_memory_arch
drivers/of: Fix depth for sub-tree blob in unflatten_dt_nodes()
drivers: of: Fix of_pci.h header guard
dt-bindings: Add vendor prefix for TechNexion
of: add vendor prefix for UniWest
dt: bindings: fix documentation for MARVELL's bt-sd8xxx wireless device
of: add missing const for of_parse_phandle_with_args() in !CONFIG_OF
of: silence warnings due to max() usage
drivers: of: of_reserved_mem: fixup the CMA alignment not to affect dma-coherent
of: irq: fix of_irq_get[_byname]() kernel-doc
MAINTAINERS: DeviceTree maintainer updates
git://git.kernel.org/pub/scm/linux/kernel/git/luto/linux
Pull uvc compat XU ioctl fixes from Andy Lutomirski:
"uvc's compat XU ioctls go through tons of potentially buggy
indirection. The first patch removes the indirection. The second one
cleans up the code.
Compile-tested only. I have the hardware, but I have absolutely no
idea what XU does, how to use it, what software to recompile as
32-bit, or what to test in that software"
* tag '20160610_uvc_compat_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/luto/linux:
uvc_v4l2: Simplify compat ioctl implementation
uvc: Forward compat ioctls to their handlers directly
The uvc compat ioctl implementation seems to have copied user data
for no good reason. Remove a bunch of copies.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
The current code goes through a lot of indirection just to call a
known handler. Simplify it: just call the handlers directly.
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"Has some fixes and some new self tests for btrfs. The self tests are
usually disabled in the .config file (unless you're doing btrfs dev
work), and this bunch is meant to find problems with the 64K page size
patches.
Jeff has a patch to help people see if they are using the hardware
assist crc32c module, which really helps us nail down problems when
people ask why crcs are using so much CPU.
Otherwise, it's small fixes"
* 'for-linus-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: self-tests: Fix extent buffer bitmap test fail on BE system
Btrfs: self-tests: Fix test_bitmaps fail on 64k sectorsize
Btrfs: self-tests: Use macros instead of constants and add missing newline
Btrfs: self-tests: Support testing all possible sectorsizes and nodesizes
Btrfs: self-tests: Execute page straddling test only when nodesize < PAGE_SIZE
btrfs: advertise which crc32c implementation is being used at module load
Btrfs: add validadtion checks for chunk loading
Btrfs: add more validation checks for superblock
Btrfs: clear uptodate flags of pages in sys_array eb
Btrfs: self-tests: Support non-4k page size
Btrfs: Fix integer overflow when calculating bytes_per_bitmap
Btrfs: test_check_exists: Fix infinite loop when searching for free space entries
Btrfs: end transaction if we abort when creating uuid root
btrfs: Use __u64 in exported linux/btrfs.h.
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc fixes from
- ptrace: Fix out of bounds array access warning from Khem Raj
- pseries: Fix PCI config address for DDW from Gavin Shan
- pseries: Fix IBM_ARCH_VEC_NRCORES_OFFSET since POWER8NVL was added
from Michael Ellerman
- of: fix autoloading due to broken modalias with no 'compatible' from
Wolfram Sang
- radix: Fix always false comparison against MMU_NO_CONTEXT from Aneesh
Kumar K.V
- hash: Compute the segment size correctly for ISA 3.0 from Aneesh
Kumar K.V
- nohash: Fix build break with 64K pages from Michael Ellerman
* tag 'powerpc-4.7-3' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
powerpc/nohash: Fix build break with 64K pages
powerpc/mm/hash: Compute the segment size correctly for ISA 3.0
powerpc/mm/radix: Fix always false comparison against MMU_NO_CONTEXT
powerpc/pseries: Fix IBM_ARCH_VEC_NRCORES_OFFSET since POWER8NVL was added
powerpc/pseries: Fix PCI config address for DDW
powerpc/ptrace: Fix out of bounds array access warning
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fixes from Guenter Roeck:
- fix regression in fam15h_power driver
- minor variable type fix in lm90 driver
- document compatible statement for ina2xx driver
* tag 'hwmon-for-linus-v4.7-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (lm90) use proper type for update_interval
hwmon: (ina2xx) Document compatible for INA231
hwmon: (fam15h_power) Disable preemption when reading registers
Merge filesystem stacking fixes from Jann Horn.
* emailed patches from Jann Horn <jannh@google.com>:
sched: panic on corrupted stack end
ecryptfs: forbid opening files without mmap handler
proc: prevent stacking filesystems on top
Until now, hitting this BUG_ON caused a recursive oops (because oops
handling involves do_exit(), which calls into the scheduler, which in
turn raises an oops), which caused stuff below the stack to be
overwritten until a panic happened (e.g. via an oops in interrupt
context, caused by the overwritten CPU index in the thread_info).
Just panic directly.
Signed-off-by: Jann Horn <jannh@google.com>
This prevents users from triggering a stack overflow through a recursive
invocation of pagefault handling that involves mapping procfs files into
virtual memory.
Acked-by: Tyler Hicks <tyhicks@canonical.com>
This prevents stacking filesystems (ecryptfs and overlayfs) from using
procfs as lower filesystem. There is too much magic going on inside
procfs, and there is no good reason to stack stuff on top of procfs.
(For example, procfs does access checks in VFS open handlers, and
ecryptfs by design calls open handlers from a kernel thread that doesn't
drop privileges or so.)
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fix from Will Deacon:
"A fix for an issue that Alex saw whilst swapping with hardware
access/dirty bit support enabled in the kernel: Fix a failure to fault
in old pages on a write when CONFIG_ARM64_HW_AFDBM is enabled"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: mm: always take dirty state from new pte in ptep_set_access_flags
Pull x86 fixes from Ingo Molnar:
"Misc fixes from all around the map, plus a commit that introduces a
new header of Intel model name symbols (unused) that will make the
next merge window easier"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/ioapic: Fix incorrect pointers in ioapic_setup_resources()
x86/entry/traps: Don't force in_interrupt() to return true in IST handlers
x86/cpu/AMD: Extend X86_FEATURE_TOPOEXT workaround to newer models
x86/cpu/intel: Introduce macros for Intel family numbers
x86, build: copy ldlinux.c32 to image.iso
x86/msr: Use the proper trace point conditional for writes
Pull scheduler fixes from Ingo Molnar:
"Two scheduler debugging fixes"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/debug: Fix 'schedstats=enable' cmdline option
sched/debug: Fix /proc/sched_debug regression
Pull perf fixes from Ingo Molnar:
"A handful of tooling fixes, two PMU driver fixes and a cleanup of
redundant code that addresses a security analyzer false positive"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/core: Remove a redundant check
perf/x86/intel/uncore: Remove SBOX support for Broadwell server
perf ctf: Convert invalid chars in a string before set value
perf record: Fix crash when kptr is restricted
perf symbols: Check kptr_restrict for root
perf/x86/intel/rapl: Fix pmus free during cleanup
Pull locking fixes from Ingo Molnar:
"Misc fixes:
- a file-based futex fix
- one more spin_unlock_wait() fix
- a ww-mutex deadlock detection improvement/fix
- and a raw_read_seqcount_latch() barrier fix"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
futex: Calculate the futex key based on a tail page for file-based futexes
locking/qspinlock: Fix spin_unlock_wait() some more
locking/ww_mutex: Report recursive ww_mutex locking early
locking/seqcount: Re-fix raw_read_seqcount_latch()
Pull EFI fixes from Ingo Molnar:
"Two fixes: a regression/crash fix, and a message output fix"
* 'efi-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
efi/arm: Fix the format of EFI debug messages
efi: Fix for_each_efi_memory_desc_in_map() for empty memmaps
Pull objtool fix from Ingo Molnar:
"Addresses a false positive warning in the GPU/DRM code"
[ Technically it's not a "false positive", but it's the virtual GPU
interface that needs the frame pointer for its own internal purposes ]
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
objtool, drm/vmwgfx: Fix "duplicate frame pointer save" warning
Pull networking fixes from David Miller:
1) nfnetlink timestamp taken from wrong skb, fix from Florian Westphal.
2) Revert some msleep conversions in rtlwifi as these spots are in
atomic context, from Larry Finger.
3) Validate that NFTA_SET_TABLE attribute is actually specified when we
call nf_tables_getset(). From Phil Turnbull.
4) Don't do mdio_reset in stmmac driver with spinlock held as that can
sleep, from Vincent Palatin.
5) sk_filter() does things other than run a BPF filter, so we should
not elide it's call just because sk->sk_filter is NULL. Fix from
Eric Dumazet.
6) Fix missing backlog updates in several packet schedulers, from Cong
Wang.
7) bnx2x driver should allow VLAN add/remove while the interface is
down, from Michal Schmidt.
8) Several RDS/TCP race fixes from Sowmini Varadhan.
9) fq_codel scheduler doesn't return correct queue length in dumps,
from Eric Dumazet.
10) Fix TCP stats for tail loss probe and early retransmit in ipv6, from
Yuchung Cheng.
11) Properly initialize udp_tunnel_socket_cfg in l2tp_tunnel_create(),
from Guillaume Nault.
12) qfq scheduler leaks SKBs if a kzalloc fails, fix from Florian
Westphal.
13) sock_fprog passed into PACKET_FANOUT_DATA needs compat handling,
from Willem de Bruijn.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (85 commits)
vmxnet3: segCnt can be 1 for LRO packets
packet: compat support for sock_fprog
stmmac: fix parameter to dwmac4_set_umac_addr()
net/mlx5e: Fix blue flame quota logic
net/mlx5e: Use ndo_stop explicitly at shutdown flow
net/mlx5: E-Switch, always set mc_promisc for allmulti vports
net/mlx5: E-Switch, Modify node guid on vf set MAC
net/mlx5: E-Switch, Fix vport enable flow
net/mlx5: E-Switch, Use the correct error check on returned pointers
net/mlx5: E-Switch, Use the correct free() function
net/mlx5: Fix E-Switch flow steering capabilities check
net/mlx5: Fix flow steering NIC capabilities check
net/mlx5: Fix root flow table update
net/mlx5: Fix MLX5_CMD_OP_MAX to be defined correctly
net/mlx5: Fix masking of reserved bits in XRCD number
net/mlx5: Fix the size of modify QP mailbox
mlxsw: spectrum: Don't sleep during ndo_get_phys_port_name()
mlxsw: spectrum: Make split flow match firmware requirements
wext: Fix 32 bit iwpriv compatibility issue with 64 bit Kernel
cfg80211: remove get/set antenna and tx power warnings
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"We have only few, mainly HD-audio device-specific fixes. Realtek
codec driver got a slightly more LOC, but they are all for the new
codec chip, and won't affect others at all"
* tag 'sound-4.7-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Add PCI ID for Kabylake
ALSA: hda/realtek: Add T560 docking unit fixup
ALSA: hda - Fix headset mic detection problem for Dell machine
ALSA: uapi: Add three missing header files to Kbuild file
ALSA: hda/realtek - Add support for new codecs ALC700/ALC701/ALC703
ALSA: hda/realtek - ALC256 speaker noise issue
git://people.freedesktop.org/~airlied/linux
Pull drm fixes from Dave Airlie:
"This weeks instalment of fixes:
amdgpu:
Lots of memory leak and firmware leak fixes
nouveau:
Collection of display fixes, KASAN fixes
vc4:
vblank/pageflipping fixes
fsl-dcu:
Regmap cache fix
omap:
Unused variable warning fix.
Nothing too surprising so far"
* tag 'drm-fixes-for-v4.7-rc3' of git://people.freedesktop.org/~airlied/linux: (46 commits)
drm/amdgpu: fix warning with powerplay disabled.
drm/amd/powerplay: delete useless code as pptable changed in vbios.
drm/amd/powerplay: fix bug visit array out of bounds
drm/amdgpu: fix smu ucode memleak (v2)
drm/amdgpu: add release firmware for cgs
drm/amdgpu: fix tonga smu_fini mem leak
drm/amdgpu: fix fiji smu fini mem leak
drm/amdgpu: fix cik sdma ucode memleak
drm/amdgpu: fix sdma24 ucode mem leak
drm/amdgpu: fix sdma3 ucode mem leak
drm/amdgpu: fix uvd fini mem leak
drm/amdgpu: fix gfx 7 ucode mem leak
drm/amdgpu: fix gfx8 ucode mem leak
drm/amdgpu: fix missing free wb for cond_exec
drm/amdgpu: fix memleak in pptable_init
drm/amdgpu: fix mem leak in atombios
drm/amdgpu: fix mem leak in pplib/hwmgr
drm/amdgpu: fix mem leak in smumgr
drm/amdgpu: add pipeline sync while vmid switch in same ctx
drm/amdgpu: vBIOS post only call when mem_size zero
Pull ACPI fix from Rafael Wysocki:
"A recently introduced boot regression related to the ACPI EC
initialization is addressed by restoring the previous behavior (Lv
Zheng)"
* tag 'acpi-4.7-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / EC: Fix a boot EC regresion by restoring boot EC support for the DSDT EC
Pull power management fixes from Rafael Wysocki:
"Stable-candidate fixes for the intel_pstate driver and the cpuidle
core.
Specifics:
- Fix two intel_pstate initialization issues, one of which was
introduced during the 4.4 cycle (Srinivas Pandruvada)
- Fix kernel build with CONFIG_UBSAN set and CONFIG_CPU_IDLE unset
(Catalin Marinas)"
* tag 'pm-4.7-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpufreq: intel_pstate: Fix ->set_policy() interface for no_turbo
cpufreq: intel_pstate: Fix code ordering in intel_pstate_set_policy()
cpuidle: Do not access cpuidle_devices when !CONFIG_CPU_IDLE
Merge misc fixes from Andrew Morton:
"7 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
mm/fadvise.c: do not discard partial pages with POSIX_FADV_DONTNEED
mm: introduce dedicated WQ_MEM_RECLAIM workqueue to do lru_add_drain_all
kernel/relay.c: fix potential memory leak
mm: thp: broken page count after commit aa88b68c3b1d
revert "mm: memcontrol: fix possible css ref leak on oom"
kasan: change memory hot-add error messages to info messages
mm/hugetlb: fix huge page reserve accounting for private mappings
On a 4-socket Brickland system, hot-removing one ioapic is fine.
Hot-removing the 2nd one causes panic in mp_unregister_ioapic()
while calling release_resource().
It is because the iomem_res pointer has already been released
when removing the first ioapic.
To explain the use of &res[num] here: res is assigned to ioapic_resources,
and later in ioapic_insert_resources() we do:
struct resource *r = ioapic_resources;
for_each_ioapic(i) {
insert_resource(&iomem_resource, r);
r++;
Here 'r' is treated as an arry of 'struct resource', and the r++ ensures
that each element of the array is inserted separately. Thus we should call
release_resouce() on each element at &res[num].
Fix it by assigning the correct pointers to ioapics[i].iomem_res in
ioapic_setup_resources().
Signed-off-by: Rui Wang <rui.y.wang@intel.com>
Cc: tony.luck@intel.com
Cc: linux-pci@vger.kernel.org
Cc: rjw@rjwysocki.net
Cc: linux-acpi@vger.kernel.org
Cc: bhelgaas@google.com
Link: http://lkml.kernel.org/r/1465369193-4816-3-git-send-email-rui.y.wang@intel.com
Forcing in_interrupt() to return true if we're not in a bona fide
interrupt confuses the softirq code. This fixes warnings like:
NOHZ: local_softirq_pending 282
... which can happen when running things like selftests/x86.
This will change perf's static percpu buffer usage in IST context.
I think this is okay, and it's changing the behavior to match
historical (pre-4.0) behavior.
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Fixes: 959274753857 ("x86, traps: Track entry into and exit from IST context")
Link: http://lkml.kernel.org/r/cdc215f94d118d691d73df35275022331156fb45.1464130360.git.luto@kernel.org
The device emulation may send segCnt of 1 for LRO packets.
Signed-off-by: Shrikrishna Khare <skhare@vmware.com>
Signed-off-by: Jin Heo <heoj@vmware.com>
Socket option PACKET_FANOUT_DATA takes a struct sock_fprog as argument
if PACKET_FANOUT has mode PACKET_FANOUT_CBPF. This structure contains
a pointer into user memory. If userland is 32-bit and kernel is 64-bit
the two disagree about the layout of struct sock_fprog.
Add compat setsockopt support to convert a 32-bit compat_sock_fprog to
a 64-bit sock_fprog. This is analogous to compat_sock_fprog support for
SO_REUSEPORT added in commit 1957598840f4 ("soreuseport: add compat
case for setsockopt SO_ATTACH_REUSEPORT_CBPF").
Reported-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Willem de Bruijn <willemb@google.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
The dwmac4_set_umac_addr() takes a struct mac_device_info as
the first parameter, but is being passed a ioaddr instead from
dwmac4_set_filter(). Fix the warning/bug by changing the first
parameter.
drivers/net/ethernet/stmicro/stmmac/dwmac4_core.c:159:46: warning: incorrect type in argument 1 (different address spaces)
drivers/net/ethernet/stmicro/stmmac/dwmac4_core.c:159:46: expected struct mac_device_info *hw
drivers/net/ethernet/stmicro/stmmac/dwmac4_core.c:159:46: got void [noderef] <asn:2>*ioaddr
Note, only compile tested this as do not have any
hardware with it in.
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Acked-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Saeed Mahameed says:
Mellanox 100G mlx5 fixes for 4.7-rc
The following series provides some small fixes for mlx5 driver.
Two small fixes for the mlx5e netdev, the 1st is for the blue flame
quota accounting and the 2nd is a small refactoring in shutdown flow.
Five trivial fixes for mlx5 E-Switch.
- Allmulti mc_promisc flag was not set in a specific flow.
- Modify VF node guid when admin mac is changed.
- Race in vport enable flow.
- Misc code fixes (kvfree when needed and error pointers checking).
Three in mlx5 steering area. Correct capabilities checking and root flow table update.
Three misc fixes in mlx5 commands enum and layouts.
Blue flame is a latency enhancement feature that allows the driver to
write the packet data directly to the NIC's registers thus making the
read of the packet data from host memory redundant.
We maintain a quota for the blue flame which is reloaded whenever we
identify that the hardware is processing send requests and processes
them fast enough so by the time we post the next send request it was
able to process all the pending ones. This indicates that the hardware
is capable of processing more blue flame requests efficiently. The blue
flame quota is decremented whenever we send using blue flame.
The current code erroneously clears the budget if we did not use blue
flame for the current post send operation and we fix it here.
Fixes: 88a85f99e51f ('net/mlx5e: TX latency optimization to save DMA reads')
Signed-off-by: Eli Cohen <eli@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
The current implementation copies the flow of ndo_stop instead of
calling it explicitly, Fixed it.
Fixes: 5fc7197d3a25 ("net/mlx5: Add pci shutdown callback")
Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com>
Set the mc_promisc flag also in the case of adding new mc address to
existing allmulti vport.
Fixes: a35f71f27a61 ('net/mlx5: E-Switch, Implement promiscuous rx modes vf request handling')
Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com>
In RoCE, the RDMA-CM needs the node guid to establish connection
between nodes.
Today, the node guid exposed to mlx5 Ethernet VFs is zero, therefore
RDMA-CM on the VF is broken.
Whenever the administrator sets a MAC for a VF, derive the node guid
from it and set it as well in the following way:
MAC: e4:1d:2d:b3:f4:01 -> node_guid: e4:1d:2d:ff:fe:b3:f4:01
Fixes: 77256579c6b43 ('net/mlx5: E-Switch, Introduce Vport...')
Signed-off-by: Noa Osherovich <noaos@mellanox.com>
Signed-off-by: Majd Dibbiny <majd@mellanox.com>
Reorder vport enable flow to mark the vport as enabled before calling
the vport change handler which was modified to handle the case for
when vport is not enabled.
This fixes the case for when the PF netdev is open before sriov is
enabled, once sriov is enabled at esw_enable_vport,
esw_vport_change_handle_locked didn't read the PF context since it
thought the PF vport was not enabled.
When we enable the vport, arming for events is not required anymore,
since it's done on the vport change handle
Fixes: 586cfa7f1d58 ('net/mlx5: E-Switch, Use vport event handler for vport cleanup')
The mlx5 flow-steering API (mlx5_create_flow_table/group/rule) never
returns null pointer on error. Even if it was doing that, checking
for IS_ERR_OR_NULL(p) and then returning PTR_ERR(p) would have cause
bugs, since PTR_ERR(NULL) --> success, crash.
To make things more robust and protect against related future bugs,
convert all IS_ERR_OR_NULL checks on returned values to IS_ERR.
Fixes: 5742df0f7dbe ('net/mlx5: E-Switch, Introduce VST vport ingress/egress ACLs')
Fixes: 86d722ad2c3b ('net/mlx5: Use flow steering infrastructure for mlx5_en')
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Reported-by: Ilya Lesokhin <ilyal@mellanox.com>
