currently all of the notification systems implemented select which inodes
they care about and receive messages only about those inodes (or the
children of those inodes.) This patch begins to flesh out fsnotify support
for the concept of listeners that want to hear notification for an inode
accessed below a given monut point. This patch implements a second list
of fsnotify groups to hold these types of groups and a second global mask
to hold the events of interest for this type of group.
The reason we want a second group list and mask is because the inode based
notification should_send_event support which makes each group look for a mark
on the given inode. With one nfsmount listener that means that every group would
have to take the inode->i_lock, look for their mark, not find one, and return
for every operation. By seperating vfsmount from inode listeners only when
there is a inode listener will the inode groups have to look for their
mark and take the inode lock. vfsmount listeners will have to grab the lock and
look for a mark but there should be fewer of them, and one vfsmount listener
won't cause the i_lock to be grabbed and released for every fsnotify group
on every io operation.
Signed-off-by: Eric Paris <eparis@redhat.com>
Currently all fsnotify groups are added immediately to the
fsnotify_inode_groups list upon creation. This means, even groups with no
watches (common for audit) will be on the global tracking list and will
get checked for every event. This patch adds groups to the global list on
when the first inode mark is added to the group.
Signed-of-by: Eric Paris <eparis@redhat.com>
Currently the comments say that group->num_marks is held because the group
is on the fsnotify_group list. This isn't strictly the case, we really
just hold the num_marks for the life of the group (any time group->refcnt
is != 0) This patch moves the initialization stuff and makes it clear when
it is really being held.
Simple renaming patch. fsnotify is about to support mount point listeners
so I am renaming fsnotify_groups and fsnotify_mask to indicate these are lists
used only for groups which have watches on inodes.
Nothing uses the mask argument to fsnotify_alloc_group. This patch drops
that argument.
Currently the audit watch group always sets a mask equal to all events it
might care about. We instead should only set the group mask if we are
actually watching inodes. This should be a perf win when audit watches are
compiled in.
fsnotify_obtain_group was intended to be able to find an already existing
group. Nothing uses that functionality. This just renames it to
fsnotify_alloc_group so it is clear what it is doing.
fsnotify_obtain_group uses kzalloc but then proceedes to set things to 0.
This patch just deletes those useless lines.
The original fsnotify interface has a group-num which was intended to be
able to find a group after it was added. I no longer think this is a
necessary thing to do and so we remove the group_num.
fsnotify_replace_event need to lock both the old and the new event. This
causes lockdep to get all pissed off since it dosn't know this is safe.
It's safe in this case since the new event is impossible to be reached from
other places in the kernel.
fanotify would like to clone events already on its notification list, make
changes to the new event, and then replace the old event on the list with
the new event. This patch implements the replace functionality of that
process.
fsnotify_clone_event will take an event, clone it, and return the cloned
event to the caller. Since events may be in use by multiple fsnotify
groups simultaneously certain event entries (such as the mask) cannot be
changed after the event was created. Since fanotify would like to merge
events happening on the same file it needs a new clean event to work with
so it can change any fields it wishes.
inotify only wishes to merge a new event with the last event on the
notification fifo. fanotify is willing to merge any events including by
means of bitwise OR masks of multiple events together. This patch moves
the inotify event merging logic out of the generic fsnotify notification.c
and into the inotify code. This allows each use of fsnotify to provide
their own merge functionality.
fanotify needs a path in order to open an fd to the object which changed.
Currently notifications to inode's parents are done using only the inode.
For some parental notification we have the entire file, send that so
fanotify can use it.
fanotify, the upcoming notification system actually needs a struct path so it can
do opens in the context of listeners, and it needs a file so it can get f_flags
from the original process. Close was the only operation that already was passing
a struct file to the notification hook. This patch passes a file for access,
modify, and open as well as they are easily available to these hooks.
fanotify is going to need to look at file->private_data to know if an event
should be sent or not. This passes the data (which might be a file,
dentry, inode, or none) to the should_send function calls so fanotify can
get that information when available
fanotify is only interested in event types which contain enough information
to open the original file in the context of the fanotify listener. Since
fanotify may not want to send events if that data isn't present we pass
the data type to the should_send_event function call so fanotify can express
its lack of interest.
inotify was supposed to have a dmesg printk ratelimitor which would cause
inotify to only emit one message per boot. The static bool was never set
so it kept firing messages. This patch correctly limits warnings in multiple
places.
nothing uses inotify in the kernel, drop it!
Prior to 2.6.31 inotify would not reuse watch descriptors until all of
them had been used at least once. After the rewrite inotify would reuse
watch descriptors. The selinux utility 'restorecond' was found to have
problems when watch descriptors were reused. This patch reverts to the
pre inotify rewrite behavior to not reuse watch descriptors.
fsnotify event initialization is done entry by entry with almost everything
set to either 0 or NULL. Use kmem_cache_zalloc and only initialize things
that need non-zero initialization. Also means we don't have to change
initialization entries based on the config options.
Use kzalloc for fsnotify_groups so that none of the fields can leak any
information accidentally.
inotify_free_mark casts directly from an fsnotify_mark_entry to an
inotify_inode_mark_entry. This works, but should use container_of instead
for future proofing.
Currently fsnotify defines a static fsnotify event which is sent when a
group overflows its allotted queue length. This patch just allocates that
event from the event cache rather than defining it statically. There is no
known reason that the current implementation is wrong, but this makes sure the
event is initialized and created like any other.
Audit watch init and fsnotify init both use subsys_initcall() but since the
audit watch code is linked in before the fsnotify code the audit watch code
would be using the fsnotify srcu struct before it was initialized. This
patch fixes that problem by moving audit watch init to device_initcall() so
it happens after fsnotify is ready.
Tested-by : Sachin Sant <sachinp@in.ibm.com>
Audit watch should depend on CONFIG_AUDIT_SYSCALL and should select
FSNOTIFY. This splits the spagetti like mixing of audit_watch and
audit_filter code so they can be configured seperately.
CONFIG_AUDIT builds audit_watches which depend on fsnotify. Make
CONFIG_AUDIT select fsnotify.
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
Simply switch audit_trees from using inotify to using fsnotify for it's
inode pinning and disappearing act information.
This patch allows a task to add a second fsnotify mark to an inode for the
same group. This mark will be added to the end of the inode's list and
this will never be found by the stand fsnotify_find_mark() function. This
is useful if a user wants to add a new mark before removing the old one.
Simple copy fsnotify information from one mark to another in preparation
for the second mark to replace the first.
deleting audit watch rules is not currently done under audit_filter_mutex.
It was done this way because we could not hold the mutex during inotify
manipulation. Since we are using fsnotify we don't need to do the extra
get/put pair nor do we need the private list on which to store the parents
while they are about to be freed.
fsnotify can handle mutexes to be held across all fsnotify operations since
it deals strickly in spinlocks. This can simplify and reduce some of the
audit_filter_mutex taking and dropping.
Audit currently uses inotify to pin inodes in core and to detect when
watched inodes are deleted or unmounted. This patch uses fsnotify instead
of inotify.
No real changes, just cleanup to the audit_watch split patch which we done
with minimal code changes for easy review. Now fix interfaces to make
things work better.
This patch moves all of the idr editing operations into their own idr
functions. It makes it easier to prove locking correctness and to to
understand the code flow.
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9p: Pass the correct end of buffer to p9stat_read
When freeing a gpio that has not been exported, gpio_unexport() prints a
debug message when it should just fall through silently.
Example spurious message:
gpio_unexport: gpio0 status -22
Signed-off-by: Jon Povey <jon.povey@racelogic.co.uk>
Cc: David Brownell <david-b@pacbell.net>
Acked-by: Uwe Kleine-K?nig <u.kleine-koenig@pengutronix.de>
Cc: Gregory Bean <gbean@codeaurora.org>
The MPC85xx EDAC driver is missing module device aliases, so the driver
won't load automatically on boot. This patch fixes the issue by adding
proper MODULE_DEVICE_TABLE() macros.
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
Cc: Doug Thompson <dougthompson@xmission.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Dave Jiang <djiang@mvista.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Fix the logic while writing new date/time to the chip. The driver
incorrectly wrote back register values to different registers and even
with wrong mask. The patch adds clearing of the VLF register, which
should be cleared if all date/time values are set.
Signed-off-by: Rudolf Marek <rudolf.marek@sysgo.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: Martyn Welch <martyn.welch@gefanuc.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
The command
echo "file ec.c +p" >/sys/kernel/debug/dynamic_debug/control
causes an oops.
Move the call to ddebug_remove_module() down into free_module(). In this
way it should be called from all error paths. Currently, we are missing
the remove if the module init routine fails.
Signed-off-by: Jason Baron <jbaron@redhat.com>
Reported-by: Thomas Renninger <trenn@suse.de>
Tested-by: Thomas Renninger <trenn@suse.de>
Cc: <stable@kernel.org> [2.6.32+]
Pass the correct end of the buffer to p9stat_read.
Signed-off-by: Latchesar Ionkov <lucho@ionkov.net>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/perf
* 'urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/perf:
perf, powerpc: Use perf_sample_data_init() for the FSL code
* git://git.infradead.org/users/cbou/battery-2.6.35:
ds2782_battery: Rename get_current to fix build failure / name conflict
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
s2io: fixing DBG_PRINT() macro
ath9k: fix dma direction for map/unmap in ath_rx_tasklet
net: dev_forward_skb should call nf_reset
net sched: fix race in mirred device removal
tun: avoid BUG, dump packet on GSO errors
bonding: set device in RLB ARP packet handler
wimax/i2400m: Add PID & VID for Intel WiMAX 6250
ipv6: Don't add routes to ipv6 disabled interfaces.
net: Fix skb_copy_expand() handling of ->csum_start
net: Fix corruption of skb csum field in pskb_expand_head() of net/core/skbuff.c
macvtap: Limit packet queue length
ixgbe/igb: catch invalid VF settings
bnx2x: Advance a module version
bnx2x: Protect statistics ramrod and sequence number
bnx2x: Protect a SM state change
wireless: use netif_rx_ni in ieee80211_send_layer2_update
We should use perf_sample_data_init() to initialize struct
perf_sample_data. As explained in the description of commit dc1d628a
("perf: Provide generic perf_sample_data initialization"), it is
possible for userspace to get the kernel to dereference data.raw,
so if it is not initialized, that means that unprivileged userspace
can possibly oops the kernel. Using perf_sample_data_init makes sure
it gets initialized to NULL.
This conversion should have been included in commit dc1d628a, but it
got missed.
Acked-by: Kumar Gala <kumar.gala@freescale.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Do not try to disable hpet if it hasn't been initialized before
x86, i8259: Only register sysdev if we have a real 8259 PIC
Patch 9e39f7c5b311a306977c5471f9e2ce4c456aa038 changed the
DBG_PRINT() macro and the if clause was wrongly changed. It means
that currently all the DBG_PRINT are being printed, flooding the
kernel log buffer with things like:
s2io: eth6: Next block at: c0000000b9c90000
s2io: eth6: In Neterion Tx routine
Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com>
Acked-by: Sreenivasa Honnur <Sreenivasa.Honnur@neterion.com>
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] powernow-k8: Limit Pstate transition latency check
[CPUFREQ] Fix PCC driver error path
[CPUFREQ] fix double freeing in error path of pcc-cpufreq
[CPUFREQ] pcc driver should check for pcch method before calling _OSC
[CPUFREQ] fix memory leak in cpufreq_add_dev
[CPUFREQ] revert "[CPUFREQ] remove rwsem lock from CPUFREQ_GOV_STOP call (second call site)"
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus:
MIPS: Set io_map_base for several PCI bridges lacking it
MIPS: Alchemy: Define eth platform devices in the correct order
MIPS: BCM63xx: Prevent second enet registration on BCM6338
MIPS: Quit using undefined behavior of ADDU in 64-bit atomic operations.
MIPS: N32: Define getdents64.
MIPS: MTX-1: Fix PCI on the MeshCube and related boards
MIPS: Make init_vdso a subsys_initcall.
MIPS: "Fix" useless 'init_vdso successfully' message.
MIPS: PowerTV: Move register setup to before reading registers.
SOUND: Au1000: Fix section mismatch
VIDEO: Au1100fb: Fix section mismatch
VIDEO: PMAGB-B: Fix section mismatch
VIDEO: PMAG-BA: Fix section mismatch
NET: declance: Fix section mismatches
VIDEO. gbefb: Fix section mismatches.
Fix error from the last pull request. Making sure we shut the panel off
is more correct and saves power.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
