2005-09-30drm: add option to force writeback off.Dave Airlie
In order to get some better debugging from people about certain hangs/crashes we need to be able to turn AGP writeback off permanently... Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25drm: fix some lindent damageDave Airlie
2005-09-25drm: cast handle to a pointer to avoid warningDave Airlie
Andrew reported a warning on this line, just case to void *. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25drm: use kernel macrosDave Airlie
Make some of the DRM_ macros use the real kernel macros. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25update from upstreamDave Airlie
2005-09-24Merge master.kernel.org:/home/rmk/linux-2.6-ucbLinus Torvalds
2005-09-24Merge master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
2005-09-24Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-09-24[PATCH] Input: check switch bitmap when matching handlersDmitry Torokhov
The wwitch bitmap was added to input_device_id structure and we should check it when matching handlers and input devices. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-24[ARM] Fix compiler warnings for memcpy_toio/memcpy_fromio/memset_ioRussell King
Add 'volatile' to the __iomem pointers for these functions as per x86. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-24[MFD] Fix "bious one-bit signed bitfield" errorsRussell King
ucb1x00-ts declared a couple of one-bit 'int' bitfields. Make them unsigned. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-24[SERIAL] Remove unused variable in clps711x.cRussell King
2005-09-23Merge branch 'upstream' from ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
2005-09-23Merge branch 'upstream-fixes' from ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-09-23[PATCH] skge: fix Yukon-Lite A0 workaroundStephen Hemminger
This is one of those workarounds sucked over from sk98lin driver. The skge driver needs to detect the Yukon-Lite A0 chip properly, and turn of Rx FIFO Flush. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-23Merge /spare/repo/linux-2.6/Jeff Garzik
2005-09-23Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-09-23[ARM] Fix context switch with ARMv6 + TLSRussell King
We accidentally corrupted the TLS value when clearing out the ARMv6 exclusive monitor. Avoid doing so. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-23[PATCH] revert oversized kmalloc checkAndrew Morton
As davem points out, this wasn't such a great idea. There may be some code which does: size = 1024*1024; while (kmalloc(size, ...) == 0) size /= 2; which will now explode. Cc: "David S. Miller" <davem@davemloft.net> Cc: Christoph Lameter <christoph@lameter.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23[PATCH] documentation: sparse no longer uses bk, but gitHarald Welte
Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23[PATCH] ipmi_msghandler: inconsistent spin_lock usageHironobu Ishii
I found an inconsistent spin_lock usage in ipmi_smi_msg_received. Signed-off-by: Hironobu Ishii <hishii@soft.fujitsu.com> Cc: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23[PATCH] ppc64: Fix huge pages MMU mapping bugBenjamin Herrenschmidt
Current kernel has a couple of sneaky bugs in the ppc64 hugetlb code that cause huge pages to be potentially left stale in the hash table and TLBs (improperly invalidated), with all the nasty consequences that can have. One is that we forgot to set the "secondary" bit in the hash PTEs when hashing a huge page in the secondary bucket (fortunately very rare). The other one is on non-LPAR machines (like Apple G5s), flush_hash_range() which is used to flush a batch of PTEs simply did not work for huge pages. Historically, our huge page code didn't batch, but this was changed without fixing this routine. This patch fixes both. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23[PATCH] atyfb c99 fixAndrew Morton
- fix this: drivers/video/aty/xlinit.c: In function `atyfb_xl_init': drivers/video/aty/xlinit.c:256: warning: ISO C90 forbids mixed declarations and code - repair some kooky coding style - Use ARRAY_SIZE() Cc: Tom 'spot' Callaway <tcallawa@redhat.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23[PATCH] hisax: remove URB_ASYNC_UNLINKKarsten Keil
usb_unlink_urb is always async now, so URB_ASYNC_UNLINK was removed from core USB and we must do as well. Signed-off-by: Karsten Keil <kkeil@suse.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23Make sure SIGKILL gets proper respectLinus Torvalds
Bhavesh P. Davda <bhavesh@avaya.com> noticed that SIGKILL wouldn't properly kill a process under just the right cicumstances: a stopped task that already had another signal queued would get the SIGKILL queued onto the shared queue, and there it would remain until SIGCONT. This simplifies the signal acceptance logic, and fixes the bug in the process. Losely based on an earlier patch by Bhavesh. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23[PATCH] cifs: Add support for suspendSteve French
cifsd had been preventing software suspend from completing. Signed-off-by: pavel@suse.de Signed-off-by: Steve French <sfrench@us.ibm.com> lightly modified Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23[PATCH] pci: fixup parent subordinate busnrIvan Kokshaysky
I believe the change that broke things is introduction of pci_fixup_parent_subordinate_busnr(). The patch here does two things: - hunk #1 should fix the problems you've seen when you boot without additional "pci" kernel options; - hunk #2 supposedly fixes boot with "pci=assign-busses" option which otherwise hangs Acer TM81xx machines as reported. Please try this with and without "pci=assign-busses". If it boots, I'd like to see 'lspci -vvx' for both cases. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-23Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/shaggy/jfs-2.6
2005-09-23[PATCH] 8390 Tx fix for non i386 machinesPaul Gortmaker
While this is true, E8390_CMD is zero on i386, and thus there should be no effect for these machines. Machines like Mac, Amiga etc. which use Alan's clever register mapping may have a non-zero E8390_CMD and result in bogus "transmitter busy" type messages from this bug. Fixes BUG# 3991.
2005-09-22[SCTP]: Fix SCTP_SHUTDOWN notifications.Sridhar Samudrala
Fix to allow SCTP_SHUTDOWN notifications to be received on 1-1 style SCTP SOCK_STREAM sockets. Add SCTP_SHUTDOWN notification to the receive queue before updating the state of the association. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[NETFILTER] Fix conntrack event cache deadlock/oopsHarald Welte
This patch fixes a number of bugs. It cannot be reasonably split up in multiple fixes, since all bugs interact with each other and affect the same function: Bug #1: The event cache code cannot be called while a lock is held. Therefore, the call to ip_conntrack_event_cache() within ip_ct_refresh_acct() needs to be moved outside of the locked section. This fixes a number of 2.6.14-rcX oops and deadlock reports. Bug #2: We used to call ct_add_counters() for unconfirmed connections without holding a lock. Since the add operations are not atomic, we could race with another CPU. Bug #3: ip_ct_refresh_acct() lost REFRESH events in some cases where refresh (and the corresponding event) are desired, but no accounting shall be performed. Both, evenst and accounting implicitly depended on the skb parameter bein non-null. We now re-introduce a non-accounting "ip_ct_refresh()" variant to explicitly state the desired behaviour. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[NETFILTER] remove unneeded structure definition from conntrack helperHarald Welte
2005-09-22[NETFILTER] Fix sparse endian warnings in pptp helperAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[NETFILTER] fix DEBUG statement in PPTP helperHarald Welte
As noted by Alexey Dobriyan, the DEBUGP statement prints the wrong callID. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[BRIDGE]: TSO fix in br_dev_queue_push_xmitVlad Drukker
Signed-off-by: Vlad Drukker <vlad@storewiz.com> Acked-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[TCP]: Adjust Reno SACK estimate in tcp_fragmentHerbert Xu
Since the introduction of TSO pcount a year ago, it has been possible for tcp_fragment() to cause packets_out to decrease. Prior to that, tcp_retrans_try_collapse() was the only way for that to happen on the retransmission path. When this happens with Reno, it is possible for sasked_out to become invalid because it is only an estimate and not tied to any particular packet on the retransmission queue. Therefore we need to adjust sacked_out as well as left_out in the Reno case. The following patch does exactly that. This bug is pretty difficult to trigger in practice though since you need a SACKless peer with a retransmission that occurs just as the cached MTU value expires. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[PATCH] Add dm-snapshot tutorial in DocumentationPaolo 'Blaisorblade' Giarrusso
I've recently discovered the real functionality of device-mapper snapshots, and since they are not well known, I've decided to write some docs for them. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] NFS: fix client oops when debugging is onNick Wilson
nfs_readpage_release() causes an oops while accessing a file with NFS debugging turned on (echo 32767 > /proc/sys/sunrpc/nfs_debug) and a kernel built with CONFIG_DEBUG_SLAB. This patch moves the debugging statement above nfs_release_request() to avoid accessing freed memory. Signed-off-by: Nick Wilson <njw@osdl.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] Fix bd_claim() error code.Rob Landley
Problem: In some circumstances, bd_claim() is returning the wrong error code. If we try to swapon an unused block device that isn't swap formatted, we get -EINVAL. But if that same block device is already mounted, we instead get -EBUSY, even though it still isn't a valid swap device. This issue came up on the busybox list trying to get the error message from "swapon -a" right. If a swap device is already enabled, we get -EBUSY, and we shouldn't report this as an error. But we can't distinguish the two -EBUSY conditions, which are very different errors. In the code, bd_claim() returns either 0 or -EBUSY, but in this case busy means "somebody other than sys_swapon has already claimed this", and _that_ means this block device can't be a valid swap device. So return -EINVAL there. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] ext3: EXT3_DEBUG build fixesGlauber de Oliveira Costa
Fix some warnings and a build error when EXT3_DEBUG is enabled. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] oss: don't concatenate __FUNCTION__ with stringsClemens Buchacher
It's deprecated. Use "%s", __FUNCTION__ instead. Signed-off-by: Clemens Buchacher <drizzd@aon.at> Signed-off-by: Maximilian Attems <janitor@sternwelten.at> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] xtensa: remove io_remap_page_range and minor clean-upsChris Zankel
Remove io_remap_page_range() from all of Linux 2.6.x (as requested and suggested by Randy Dunlap) and minor clean-ups. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] uml: replace printk with "stack-friendly" printf - to report console ↵Paolo 'Blaisorblade' Giarrusso
failure User get *a lot* confused when consoles don't work but we don't report anything. And, as reported in the comment, using printk to report "your console doesn't work" isn't likely to go that far. Fix the problem on the base of this: stack consumption by host printf(). Use kernel sprintf() and os_write_file, using a wild guess that one page will be enough for the message, to preallocate the buffer with kmalloc(). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] uml: use GFP_ATOMIC for allocations under spinlocks.Paolo 'Blaisorblade' Giarrusso
setup_initial_poll is only called with sigio_lock() held, so use appropriate allocation. Also, parse_chan() can also be called when holding a spinlock (see line_open() -> parse_chan_pair()). I have sporadic problems (spinlock taken twice, with spinlock debugging on UP) which could be caused by a sequence like "take spinlock, alloc and go to sleep, take again the spinlock in the other thread". Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] uml: Fix GFP_ flags usagePaolo 'Blaisorblade' Giarrusso
GFP_ATOMIC | GFP_KERNEL is meaningless and won't work. Actually it never worked, even in 2.4. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] uml: avoid fixing faults while atomicPaolo 'Blaisorblade' Giarrusso
Following i386, we should maybe refuse trying to fault in pages when we're doing atomic operations, because to handle the fault we could need to take already taken spinlocks. Also, if we're doing an atomic operation (in the sense of in_atomic()) we're surely in kernel mode and we're surely going to handle adequately the failed fault, so it's safe to behave this way. Currently, on UML SMP is rarely used, and we don't support PREEMPT, so this is unlikely to create problems right now, but it might in the future. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] uml: run mconsole "sysrq" in process contextPaolo 'Blaisorblade' Giarrusso
Things are breaking horribly with sysrq called in interrupt context. I want to try to fix it, but probably this is simpler. To tell the truth, sysrq is normally run in interrupt context, so there shouldn't be any problem. There's also a warning from the fault handler because it's run in atomic context (I have a patch for that, only I deferred it). This is why I'm doing this. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] uml: fix condition in tlb flushPaolo 'Blaisorblade' Giarrusso
Avoid setting w = 0 twice. Spotted this (trivial) thing which is needed for another patch. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] uml: fix hang in TT mode on faultPaolo 'Blaisorblade' Giarrusso
The current code doesn't handle well general protection faults on the host - it thinks that cr2 is always the address of a page fault. While actually, on general protection faults, that address is not accessible, so we'd better assume we couldn't satisfy the fault. Currently instead we think we've fixed it, so we go back, retry the instruction and fault again endlessly. This leads to the kernel hanging when doing copy_from_user(dest, -1, ...) in TT mode, since reading *(-1) causes a GFP, and we don't support kernel preemption. Thanks to Luo Xin for testing UML with LTP and reporting the failures he got. Cc: Luo Xin <luothing@sina.com> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
