The nr_pages field in struct kcopyd_job is only used temporarily in
run_pages_job() to count the number of required pages.
We can use a local variable instead.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
The offset field in struct kcopyd_job is always zero so remove it.
Use vzalloc() instead of vmalloc()+memset().
Replace list_del() followed by list_add() with list_move().
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Using __test_and_{set,clear}_bit_le() with ignoring its return value
can be replaced with __{set,clear}_bit_le().
This also removes unnecessary casts.
Remove 'discards_supported' from the dm_table structure. The same
information can be easily discovered from the table's target(s) in
dm_table_supports_discards().
Before this fix dm_table_supports_discards() would skip checking the
individual targets' 'discards_supported' flag if any one target in the
table didn't set num_discard_requests > 0. Now the per-target
'discards_supported' flag is effective at insuring the final DM device
advertises discard support. But, to be clear, targets that don't
support discards (!num_discard_requests) will not receive discard
requests.
Also DMWARN if a target sets 'discards_supported' override but forgets
to set 'num_discard_requests'.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Suppress sparse warnings about cpu_to_le32() by using __le32 types for
on-disk data etc.
Destroy _minor_idr when unloading the core dm module. (Found by kmemleak.)
Cc: stable@kernel.org
For normal kernel pages, CPU cache is synchronized by the dma layer.
However, this is not done for pages allocated with vmalloc. If we do I/O
to/from vmallocated pages, we must synchronize CPU cache explicitly.
Prior to doing I/O on vmallocated page we must call
flush_kernel_vmap_range to flush dirty cache on the virtual address.
After finished read we must call invalidate_kernel_vmap_range to
invalidate cache on the virtual address, so that accesses to the virtual
address return newly read data and not stale data from CPU cache.
This patch fixes metadata corruption on dm-snapshots on PA-RISC and
possibly other architectures with caches indexed by virtual address.
Cc: stable <stable@kernel.org>
Avoid dereferencing a NULL pointer if the number of feature arguments
supplied is fewer than indicated.
This patch makes dm-snapshot flush disk cache when writing metadata for
merging snapshot.
Without cache flushing the disk may reorder metadata write and other
data writes and there is a possibility of data corruption in case of
power fault.
* 'for-linus' of git://neil.brown.name/md: (75 commits)
md/raid10: handle further errors during fix_read_error better.
md/raid10: Handle read errors during recovery better.
md/raid10: simplify read error handling during recovery.
md/raid10: record bad blocks due to write errors during resync/recovery.
md/raid10: attempt to fix read errors during resync/check
md/raid10: Handle write errors by updating badblock log.
md/raid10: clear bad-block record when write succeeds.
md/raid10: avoid writing to known bad blocks on known bad drives.
md/raid10 record bad blocks as needed during recovery.
md/raid10: avoid reading known bad blocks during resync/recovery.
md/raid10 - avoid reading from known bad blocks - part 3
md/raid10: avoid reading from known bad blocks - part 2
md/raid10: avoid reading from known bad blocks - part 1
md/raid10: Split handle_read_error out from raid10d.
md/raid10: simplify/reindent some loops.
md/raid5: Clear bad blocks on successful write.
md/raid5. Don't write to known bad block on doubtful devices.
md/raid5: write errors should be recorded as bad blocks if possible.
md/raid5: use bad-block log to improve handling of uncorrectable read errors.
md/raid5: avoid reading from known bad blocks.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
sound: oss: rename local change_bits to avoid powerpc bitsops.h definition
ALSA: hda - Fix duplicated DAC assignments for Realtek
ALSA: asihpi - off by one in asihpi_hpi_ioctl()
ALSA: hda - Fix Oops with Realtek quirks with NULL adc_nids
ALSA: asihpi - bug fix pa use before init.
ALSA: hda - Add support for vref-out based mute LED control on IDT codecs
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits)
tpm_nsc: Fix bug when loading multiple TPM drivers
tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block
tpm: Fix compilation warning when CONFIG_PNP is not defined
TOMOYO: Update kernel-doc.
tpm: Fix a typo
tpm_tis: Probing function for Intel iTPM bug
tpm_tis: Fix the probing for interrupts
tpm_tis: Delay ACPI S3 suspend while the TPM is busy
tpm_tis: Re-enable interrupts upon (S3) resume
tpm: Fix display of data in pubek sysfs entry
tpm_tis: Add timeouts sysfs entry
tpm: Adjust interface timeouts if they are too small
tpm: Use interface timeouts returned from the TPM
tpm_tis: Introduce durations sysfs entry
tpm: Adjust the durations if they are too small
tpm: Use durations returned from TPM
TOMOYO: Enable conditional ACL.
TOMOYO: Allow using argv[]/envp[] of execve() as conditions.
TOMOYO: Allow using executable's realpath and symlink's target as conditions.
TOMOYO: Allow using owner/group etc. of file objects as conditions.
Fix up trivial conflict in security/tomoyo/realpath.c
If we find more read/write errors we should record a bad block before
failing the device.
Signed-off-by: NeilBrown <neilb@suse.de>
Currently when we get a read error during recovery, we simply abort
the recovery.
Instead, repeat the read in page-sized blocks.
On successful reads, write to the target.
On read errors, record a bad block on the destination,
and only if that fails do we abort the recovery.
As we now retry reads we need to know where we read from. This was in
bi_sector but that can be changed during a read attempt.
So store the correct from_addr and to_addr in the r10_bio for later
access.
Signed-off-by: NeilBrown<neilb@suse.de>
If a read error is detected during recovery the code currently
fails the read device.
This isn't really necessary. recovery_request_write will signal
a write error to end_sync_write and it will record a write
error on the destination device which will record a bad block
there or kick it from the array.
So just remove this call to do md_error.
If we get a write error during resync/recovery don't fail the device
but instead record a bad block. If that fails we can then fail the
device.
We already attempt to fix read errors found during normal IO
and a 'repair' process.
It is best to try to repair them at any time they are found,
so move a test so that during sync and check a read error will
be corrected by over-writing with good data.
If both (all) devices have known bad blocks in the sync section we
won't try to fix even though the bad blocks might not overlap. That
should be considered later.
Also if we hit a read error during recovery we don't try to fix it.
It would only be possible to fix if there were at least three copies
of data, which is not very common with RAID10. But it should still
When we get a write error (in the data area, not in metadata),
update the badblock log rather than failing the whole device.
As the write may well be many blocks, we trying writing each
block individually and only log the ones which fail.
If we succeed in writing to a block that was recorded as
being bad, we clear the bad-block record.
This requires some delayed handling as the bad-block-list update has
to happen in process-context.
Writing to known bad blocks on drives that have seen a write error
is asking for trouble. So try to avoid these blocks.
When recovering one or more devices, if all the good devices have
bad blocks we should record a bad block on the device being rebuilt.
If this fails, we need to abort the recovery.
To ensure we don't think that we aborted later than we actually did,
we need to move the check for MD_RECOVERY_INTR earlier in md_do_sync,
in particular before mddev->curr_resync is updated.
During resync/recovery limit the size of the request to avoid
reading into a bad block that does not start at-or-before the current
read address.
Similarly if there is a bad block at this address, don't allow the
current request to extend beyond the end of that bad block.
Now that we don't ever read from known bad blocks, it is safe to allow
devices with those blocks into the array.
When attempting to repair a read error, don't read from
devices with a known bad block.
As we are only reading PAGE_SIZE blocks, we don't try to
narrow down to smaller regions in the hope that only part of this
page is bad - it isn't worth the effort.
When redirecting a read error to a different device, we must
again avoid bad blocks and possibly split the request.
Spin_lock typo fixed thanks to Dan Carpenter <error27@gmail.com>
This patch just covers the basic read path:
1/ read_balance needs to check for badblocks, and return not only
the chosen slot, but also how many good blocks are available
there.
2/ read submission must be ready to issue multiple reads to
different devices as different bad blocks on different devices
could mean that a single large read cannot be served by any one
device, but can still be served by the array.
This requires keeping count of the number of outstanding requests
per bio. This count is stored in 'bi_phys_segments'
On read error we currently just fail the request if another target
cannot handle the whole request. Next patch refines that a bit.
raid10d() is too big and is about to get bigger, so split
handle_read_error() out as a separate function.
When a loop ends with a large if, it can be neater to change the
if to invert the condition and just 'continue'.
Then the body of the if can be indented to a lower level.
On a successful write to a known bad block, flag the sh
so that raid5d can remove the known bad block from the list.
If a device has seen write errors, don't write to any known
bad blocks on that device.
When a write error is detected, don't mark the device as failed
immediately but rather record the fact for handle_stripe to deal with.
Handle_stripe then attempts to record a bad block. Only if that fails
does the device get marked as faulty.
If we get an uncorrectable read error - record a bad block rather than
failing the device.
And if these errors (which may be due to known bad blocks) cause
recovery to be impossible, record a bad block on the recovering
devices, or abort the recovery.
As we might abort a recovery without failing a device we need to teach
RAID5 about recovery_disabled handling.
There are two times that we might read in raid5:
1/ when a read request fits within a chunk on a single
working device.
In this case, if there is any bad block in the range of
the read, we simply fail the cache-bypass read and
perform the read though the stripe cache.
2/ when reading into the stripe cache. In this case we
mark as failed any device which has a bad block in that
strip (1 page wide).
Note that we will both avoid reading and avoid writing.
This is correct (as we will never read from the block, there
is no point writing), but not optimal (as writing could 'fix'
the error) - that will be addressed later.
If we have not seen any write errors on the device yet, we treat a bad
block like a recent read error. This will encourage an attempt to fix
the read error which will either generate a write error, or will
ensure good data is stored there. We don't yet forget the bad block
in that case. That comes later.
Now that we honour bad blocks when reading we can allow devices with
bad blocks into the array.
raid1d is too big with several deep branches.
So separate them out into their own functions.
Reviewed-by: Namhyung Kim <namhyung@gmail.com>
If we cannot read a block from anywhere during recovery, there is
now a better approach than just giving up.
We can record a bad block on each device and keep going - being
careful not to clear the bad block when a write succeeds as it might -
it will be a write of incorrect data.
We have now reached the state where - for raid1 - we only call
md_error if md_set_badblocks has failed.
If we find a bad block while writing as part of resync/recovery we
need to report that back to raid1d which must record the bad block,
or fail the device.
Similarly when fixing a read error, a further error should just
record a bad block if possible rather than failing the device.
When performing write-behind we allocate pages to store the data
during write.
Previously we just keep a list of pages. Now we keep a list of
bi_vec which includes offset and size.
This means that the r1bio has complete information to create a new
bio which will be needed for retrying after write errors.
If we have seen any write error on a drive, then don't write to
any known-bad blocks on that drive.
If necessary, we divide the write request up into pieces just
like we do for reads, so each piece is either all written or
all not written to any given drive.
Previous patches in the bad block series extended behavior of
rdev's 'state' interface but lacked documentation update.
Fix it.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
It is only safe to choose not to write to a bad block if that bad
block is safely recorded in metadata - i.e. if it has been
'acknowledged'.
If it hasn't we need to wait for the acknowledgement.
We support that using rdev->blocked wait and
md_wait_for_blocked_rdev by introducing a new device flag
'BlockedBadBlock'.
This flag is only advisory.
It is cleared whenever we acknowledge a bad block, so that a waiter
can re-check the particular bad blocks that it is interested it.
It should be set by a caller when they find they need to wait.
This (set after test) is inherently racy, but as
md_wait_for_blocked_rdev already has a timeout, losing the race will
have minimal impact.
When we clear "Blocked" was also clear "BlockedBadBlocks" incase it
was set incorrectly (see above race).
We also modify the way we manage 'Blocked' to fit better with the new
handling of 'BlockedBadBlocks' and to make it consistent between
externally managed and internally managed metadata. This requires
that each raidXd loop checks if the metadata needs to be written and
triggers a write (md_check_recovery) if needed. Otherwise a queued
write request might cause raidXd to wait for the metadata to write,
and only that thread can write it.
Before writing metadata, we set FaultRecorded for all devices that
are Faulty, then after writing the metadata we clear Blocked for any
device for which the Fault was certainly Recorded.
The 'faulty' device flag now appears in sysfs if the device is faulty
*or* it has unacknowledged bad blocks. So user-space which does not
understand bad blocks can continue to function correctly.
User space which does, should not assume a device is faulty until it
sees the 'faulty' flag, and then sees the list of unacknowledged bad
blocks is empty.
If a device has ever seen a write error, we will want to handle
known-bad-blocks differently.
So create an appropriate state flag and export it via sysfs.
When performing resync/etc, keep the size of the request
small enough that it doesn't overlap any known bad blocks.
Devices with badblocks at the start of the request are completely
excluded.
If there is nowhere to read from due to bad blocks, record
a bad block on each target device.
Now that we never read from known-bad-blocks we can allow devices with
known-bad-blocks into a RAID1.
Now that we have a bad block list, we should not read from those
blocks.
There are several main parts to this:
1/ read_balance needs to check for bad blocks, and return not only
the chosen device, but also how many good blocks are available
there.
2/ fix_read_error needs to avoid trying to read from bad blocks.
3/ read submission must be ready to issue multiple reads to
4/ retrying a read needs to also be ready to submit a smaller read
and queue another request for the rest.
This does not yet handle bad blocks when reading to perform resync,
recovery, or check.
'md_trim_bio' will also be used for RAID10, so put it in md.c and
export it.
v0.90 metadata cannot record bad blocks, so when loading metadata
for such a device, set shift to -1.
Space must have been allocated when array was created.
A feature flag is set when the badblock list is non-empty, to
ensure old kernels don't load and trust the whole device.
We only update the on-disk badblocklist when it has changed.
If the badblocklist (or other metadata) is stored on a bad block, we
don't cope very well.
If metadata has no room for bad block, flag bad-blocks as disabled,
and do the same for 0.90 metadata.
As no personality understand bad block lists yet, we must
reject any device that is known to contain bad blocks.
As the personalities get taught, these tests can be removed.
This only applies to raid1/raid5/raid10.
For linear/raid0/multipath/faulty the whole concept of bad blocks
doesn't mean anything so there is no point adding the checks.
Previous patch in the bad block series added new sysfs interfaces
([unacknowledged_]bad_blocks) for each rdev without documentation.
Add it.
