2016-12-03pNFS/flexfiles: Minor refactoring before adding iostats to layoutreturnTrond Myklebust
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-03NFS: Fix up read of mirror statsTrond Myklebust
Need to lock while reading in order to ensure 64-bit reads are correct. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-03pNFS/flexfiles: Clean up layoutstatsTrond Myklebust
2016-12-03pNFS/flexfiles: Refactor encoding of the layoutreturn payloadTrond Myklebust
Add the layout error payload to the flexfiles layoutreturn private data, and set up the encoding mechanisms. This is a refactoring in preparation for adding the layout iostats payload. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-03pNFS: Add a layoutreturn callback to performa layout-private setupTrond Myklebust
Add a callback to allow the flexfiles layout driver to initialise the layout private payload. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-02pNFS: Allow layout drivers to manage private data in struct nfs4_layoutreturnTrond Myklebust
Cleanup to allow layout drivers to attach private data to layoutreturn, and manage the data. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-02NFSv4: Add a generic structure for managing layout-private informationTrond Myklebust
2016-12-02pNFS/flexfiles: Only send layoutstats updates for mirrors that were updatedTrond Myklebust
If there have been no reads or writes to a given mirror since the last layoutstats update, then don't resend the same data. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-02pNFS/flexfiles: Don't attempt to send layoutstats if there are no entriesTrond Myklebust
If the list of mirrors is empty, then don't send an RPC call. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-02NFS: Allow getattr to also report readdirplus cache hitsTrond Myklebust
If the use called stat() on an 'ls -l' workload, and the attribute cache was successfully revalidate by READDIRPLUS, then we want to report that back so that the readdir code continues to use readdirplus. Reviewed-by: Benjamin Coddington <bcodding@redhat.com> Tested-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-02NFS: Be more targeted about readdirplus use when doing lookup/revalidationTrond Myklebust
There is little point in setting NFS_INO_ADVISE_RDPLUS in nfs_lookup and nfs_lookup_revalidate() unless a process is actually doing readdir on the parent directory. Furthermore, there is little point in using readdirplus if we're trying to revalidate a negative dentry. Reviewed-by: Benjamin Coddington <bcodding@redhat.com> Tested-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-02NFS: Fix a performance regression in readdirTrond Myklebust
Ben Coddington reports that commit 311324ad1713, by adding the function nfs_dir_mapping_need_revalidate() that checks page cache validity on each call to nfs_readdir() causes a performance regression when the directory is being modified. If the directory is changing while we're iterating through the directory, POSIX does not require us to invalidate the page cache unless the user calls rewinddir(). However, we still do want to ensure that we use readdirplus in order to avoid a load of stat() calls when the user is doing an 'ls -l' workload. The fix should be to invalidate the page cache immediately when we're setting the NFS_INO_ADVISE_RDPLUS bit. Reported-by: Benjamin Coddington <bcodding@redhat.com> Fixes: 311324ad1713 ("NFS: Be more aggressive in using readdirplus...") Reviewed-by: Benjamin Coddington <bcodding@redhat.com> Tested-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFS: fix typo in parameter descriptionWei Yongjun
Fix typo in parameter description. Fixes: 5405fc44c337 ("NFSv4.x: Add kernel parameter to control the callback server") Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFS: discard nfs_lockowner structure.NeilBrown
It now has only one field and is only used in one structure. So replaced it in that structure by the field it contains. Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFSv4: enhance nfs4_copy_lock_stateid to use a flock stateid if there is oneNeilBrown
A process can have two possible lock owner for a given open file: a per-process Posix lock owner and a per-open-file flock owner Use both of these when searching for a suitable stateid to use. With this patch, READ/WRITE requests will use the correct stateid if a flock lock is active. Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFSv4: change nfs4_select_rw_stateid to take a lock_context inplace of ↵NeilBrown
lock_owner The only time that a lock_context is not immediately available is in setattr, and now that it has an open_context, it can easily find one with nfs_get_lock_context. This removes the need for the on-stack nfs_lockowner. This change is preparation for correctly support flock stateids. Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFSv4: change nfs4_do_setattr to take an open_context instead of a nfs4_state.NeilBrown
The open_context can always lead directly to the state, and is always easily available, so this is a straightforward change. Doing this makes more information available to _nfs4_do_setattr() for use in the next patch. Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFSv4: add flock_owner to open contextNeilBrown
An open file description (struct file) in a given process can be associated with two different lock owners. It can have a Posix lock owner which will be different in each process that has a fd on the file. It can have a Flock owner which will be the same in all processes. When searching for a lock stateid to use, we need to consider both of these owners So add a new "flock_owner" to the "nfs_open_context" (of which there is one for each open file description). This flock_owner does not need to be reference-counted as there is a 1-1 relation between 'struct file' and nfs open contexts, and it will never be part of a list of contexts. So there is no need for a 'flock_context' - just the owner is enough. The io_count included in the (Posix) lock_context provides no guarantee that all read-aheads that could use the state have completed, so not supporting it for flock locks in not a serious problem. Synchronization between flock and read-ahead can be added later if needed. When creating an open_context for a non-openning create call, we don't have a 'struct file' to pass in, so the lock context gets initialized with a NULL owner, but this will never be used. The flock_owner is not used at all in this patch, that will come later. Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFS: remove l_pid field from nfs_lockownerNeilBrown
this field is not used in any important way and probably should have been removed by Commit: 8003d3c4aaa5 ("nfs4: treat lock owners as opaque values") which removed the pid argument from nfs4_get_lock_state. Except in unusual and uninteresting cases, two threads with the same ->tgid will have the same ->files pointer, so keeping them both for comparison brings no benefit. Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFS: Remove unused argument from nfs_direct_write_complete()Anna Schumaker
This parameter hasn't been used since 2a009ec9 (Linux 3.13-rc3), so let's remove it from this function. Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFS: Remove unused authflavour parameter from nfs_get_client()Anna Schumaker
This parameter hasn't been used since f8407299 (Linux 3.11-rc2), so let's remove it from this function and callers. Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01nfs: fix false positives in nfs40_walk_client_list()J. Bruce Fields
It's possible that two different servers can return the same (clientid, verifier) pair purely by coincidence. Both are 64-bit values, but depending on the server implementation, they can be highly predictable and collisions may be quite likely, especially when there are lots of servers. So, check for this case. If the clientid and verifier both match, then we actually know they *can't* be the same server, since a new SETCLIENTID to an already-known server should have changed the verifier. This helps fix a bug that could cause the client to mount a filesystem from the wrong server. Reviewed-by: Jeff Layton <jlayton@redhat.com> Tested-by: Yongcheng Yang <yoyang@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01sunrpc: Don't engage exponential backoff when connection attempt is rejected.NeilBrown
xs_connect() contains an exponential backoff mechanism so the repeated connection attempts are delayed by longer and longer amounts. This is appropriate when the connection failed due to a timeout, but it not appropriate when a definitive "no" answer is received. In such cases, call_connect_status() imposes a minimum 3-second back-off, so not having the exponetial back-off will never result in immediate retries. The current situation is a problem when the NFS server tries to register with rpcbind but rpcbind isn't running. All connection attempts are made on the same "xprt" and as the connection is never "closed", the exponential back delays successive attempts to register, or de-register, different protocols. This results in a multi-minute delay with no benefit. So, when call_connect_status() receives a definitive "no", use xprt_conditional_disconnect() to cancel the previous connection attempt. This will set XPRT_CLOSE_WAIT so that xprt->ops->close() calls xs_close() which resets the reestablish_timeout. To ensure xprt_conditional_disconnect() does the right thing, we ensure that rq_connect_cookie is set before a connection attempt, and allow xprt_conditional_disconnect() to complete even when the transport is not fully connected. Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Skip invalid stateids when doing a bulk destroyTrond Myklebust
If the layout stateid is already invalid, we have no work to do. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Wait on outstanding layoutreturns to complete in pnfs_roc()Trond Myklebust
2016-12-01pNFS: Don't mark the layout as freed if the last lseg is marked for returnTrond Myklebust
Address another memory leak. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Sync the layout state bits in pnfs_cache_lseg_for_layoutreturnTrond Myklebust
Ensure that the layout state bits are synced when we cache a layout segment for layoutreturn using an appropriate call to pnfs_set_plh_return_info. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Fix bugs in _pnfs_return_layoutTrond Myklebust
We need to honour the NFS_LAYOUT_RETURN_REQUESTED bit regardless of whether or not there are layout segments pending. Furthermore, we should ensure that we leave the plh_return_segs list empty. This patch fixes a memory leak of the layout segments on plh_return_segs. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Clear all layout segment state in pnfs_mark_layout_stateid_invalidTrond Myklebust
When the layout state is invalidated, then so is the layout segment state, and hence we do need to clean up the state bits. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Prevent unnecessary layoutreturns after delegreturnTrond Myklebust
If we cannot grab the inode or superblock, then we cannot pin the layout header, and so we cannot send a layoutreturn as part of an async delegreturn call. In this case, we currently end up sending an extra layoutreturn after the delegreturn. Since the layout was implicitly returned by the delegreturn, that just gets a BAD_STATEID. The fix is to simply complete the return-on-close immediately. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Enable layoutreturn operation for return-on-closeTrond Myklebust
Amend the pnfs return on close helper functions to enable sending the layoutreturn op in CLOSE/DELEGRETURN. This closes a potential race between CLOSE/DELEGRETURN and parallel OPEN calls to the same file, and allows the client and the server to agree on whether or not there is an outstanding layout. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Clean up - add a helper to initialise struct layoutreturn_argsTrond Myklebust
2016-12-01NFSv4: Add encode/decode of the layoutreturn op in DELEGRETURNTrond Myklebust
Add XDR encoding for the layoutreturn op, and storage for the layoutreturn arguments to the DELEGRETURN compound. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFSv4: Add encode/decode of the layoutreturn op in CLOSETrond Myklebust
Add XDR encoding for the layoutreturn op, and storage for the layoutreturn arguments to the CLOSE compound. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFSv4: Fix missing operation accounting in NFS4_dec_delegreturn_szTrond Myklebust
We need to account for the reply to the PUTFH operation in the DELEGRETURN compound. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Don't mark layout segments invalid on layoutreturn in pnfs_rocTrond Myklebust
The layoutreturn call will take care of invalidating the layout segments once the call is successful. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Get rid of unnecessary layout parameter in encode_layoutreturn callbackTrond Myklebust
The parameter is already present in the "args" structure. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Skip checking for return-on-close if the layout is invalidTrond Myklebust
2016-12-01pNFS: Remove spurious wake up in pnfs_layout_remove_lseg()Trond Myklebust
There is no change to the value of NFS_LAYOUT_RETURN, so we should not be waking up the RPC call. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01NFSv4: Ignore LAYOUTRETURN result if the layout doesn't match or is invalidTrond Myklebust
Fix a potential race with CB_LAYOUTRECALL in which the server recalls the remaining layout segments while our LAYOUTRETURN is still in transit. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Do not free layout segments that are marked for returnTrond Myklebust
We may want to process and transmit layout stat information for the layout segments that are being returned, so we should defer freeing them until after the layoutreturn has completed. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Delay getting the layout header in CB_LAYOUTRECALL handlersTrond Myklebust
Instead of grabbing the layout, we want to get the inode so that we can reduce races between layoutget and layoutrecall when the server does not support call referring. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: consolidate the different range intersection testsTrond Myklebust
Both pnfs.c and the flexfiles code have their own versions of the range intersection testing, and the "end_offset" helper. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Fix race in pnfs_wait_on_layoutreturnTrond Myklebust
We must put the task to sleep while holding the inode->i_lock in order to ensure atomicity with the test for NFS_LAYOUT_RETURN. Fixes: 500d701f336b ("NFS41: make close wait for layoutreturn") Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: On error, do not send LAYOUTGET until the LAYOUTRETURN has completedTrond Myklebust
If there is an I/O error, we should not call LAYOUTGET until the LAYOUTRETURN that reports the error is complete. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Cc: stable@vger.kernel.org # v4.8+
2016-12-01pNFS: Force a retry of LAYOUTGET if the stateid doesn't match our cacheTrond Myklebust
If the server sends us a completely new stateid, and the client thinks it already holds a layout, then force a retry of the LAYOUTGET after invalidating the existing layout in order to avoid corruption due to races. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2016-12-01pNFS: Clear NFS_LAYOUT_RETURN_REQUESTED when invalidating the layout stateidTrond Myklebust
We must ensure that we don't schedule a layoutreturn if the layout stateid has been marked as invalid. Fixes: 2a59a0411671e ("pNFS: Fix pnfs_set_layout_stateid() to clear...") Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Cc: stable@vger.kernel.org # v4.8+
2016-12-01pNFS: Don't clear the layout stateid if a layout return is outstandingTrond Myklebust
If we no longer hold any layout segments, we're normally expected to consider the layout stateid to be invalid. However we cannot assume this if we're about to, or in the process of sending a layoutreturn. Fixes: 334a8f37115b ("pNFS: Don't forget the layout stateid if...") Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Cc: stable@vger.kernel.org # v4.8+
2016-12-01pNFS: Fix a deadlock between read resends and layoutreturnTrond Myklebust
We must not call nfs_pageio_init_read() on a new nfs_pageio_descriptor while holding a reference to a layout segment, as that can deadlock pnfs_update_layout(). Fixes: d67ae825a59d6 ("pnfs/flexfiles: Add the FlexFile Layout Driver") Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Cc: stable@vger.kernel.org # v4.0+
2016-12-01NFSv4.1: Fix regression in callback retry handlingFred Isaman
When initializing a freshly created slot for the calllback channel, the seq_nr needs to be 0, not 1. Otherwise validate_seqid and nfs4_slot_wait_on_seqid get confused and believe that the mpty slot corresponds to a previously sent reply. Signed-off-by: Fred Isaman <fred.isaman@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
