2006-01-12[XFS] Merge in trivial changes, sync up headers with userspaceNathan Scott
equivalents. SGI-PV: 907752 SGI-Modid: xfs-linux-melb:xfs-kern:24961a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fix compiler warnings from older gcc versions wrt printfalikeNathan Scott
arguments. SGI-PV: 907752 SGI-Modid: xfs-linux-melb:xfs-kern:24901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fix some build fallout from atime changes.Nathan Scott
SGI-PV: 946679 SGI-Modid: xfs-linux-melb:xfs-kern:24899a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] remove XFS_LOG_RES_DEBUG and turn on the res history all the time toTim Shimmin
get more useful error info on space for trans items SGI-PV: 947110 SGI-Modid: xfs-linux-melb:xfs-kern:24886a Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] xfssyncd is responsible for flushing inode or device's data byYingping Lu
extracting the work from its queue. In addition, this processing also decrement the inode's i_count. If there are any remaining works in queue before this process terminates, we have unbalanced increment and decrement of i_count. Thus it can cause assertion failure of vn_count. The fix allows xyssyncd to process any remaining work before it is shutdown. SGI-PV: 945935 SGI-Modid: xfs-linux-melb:xfs-kern:203970a Signed-off-by: Yingping Lu <yingping@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] add helper to get xfs_inode from vnodeChristoph Hellwig
SGI-PV: 947206 SGI-Modid: xfs-linux-melb:xfs-kern:203960a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fix up offset type inconsistencies and gcc warnings from earlierNathan Scott
changes. SGI-PV: 947038 SGI-Modid: xfs-linux-melb:xfs-kern:24875a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] fix up per-device xfsbufdChristoph Hellwig
SGI-PV: 947098 SGI-Modid: xfs-linux-melb:xfs-kern:203831a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] fix writeback control handling fix a reversed condition on where toChristoph Hellwig
trylock and deal with block layer congestion properly. Patch from David Chinner and Christoph Hellwig. SGI-PV: 947118 SGI-Modid: xfs-linux-melb:xfs-kern:203830a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] cluster rewrites We can cluster mapped pages aswell, this improvesChristoph Hellwig
performances on rewrites since we can reduce the number of allocator calls. SGI-PV: 947118 SGI-Modid: xfs-linux-melb:xfs-kern:203829a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] pass full 64bit offsets to xfs_add_to_ioendChristoph Hellwig
SGI-PV: 947118 SGI-Modid: xfs-linux-melb:xfs-kern:203828a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] consolidate some code in xfs_page_state_convert The unmapped bufferChristoph Hellwig
case is very similar to delayed and unwritten extends. Reorganize the code to share some code for these cases. SGI-PV: 947118 SGI-Modid: xfs-linux-melb:xfs-kern:203827a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] various fixes for xfs_convert_page fix various bogusities inChristoph Hellwig
handling offets From David Chinner and Christoph Hellwig SGI-PV: 947118 SGI-Modid: xfs-linux-melb:xfs-kern:203826a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] clean up the xfs_offset_to_map interface Currently we pass a structChristoph Hellwig
page and a relative offset into that page around, and returns the current xfs_iomap_t if the block at the specified offset fits into it, or a NULL pointer otherwise. This patch passed the full 64bit offset into the inode that all callers have anyway, and changes the return value to a simple boolean. Also the function gets a more descriptive name: xfs_iomap_valid. SGI-PV: 947118 SGI-Modid: xfs-linux-melb:xfs-kern:203825a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] use pagevec lookups This reduces the time spend in the radix treeChristoph Hellwig
lookups and avoids unessecary look roundtrips. SGI-PV: 947118 SGI-Modid: xfs-linux-melb:xfs-kern:203823a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Export pagevec_lookup for use on the XFS page writeout path,Christoph Hellwig
for dealing with delayed allocate and unwritten extents (as well). Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Initial pass at going directly-to-bio on the buffered IO path. ThisChristoph Hellwig
allows us to submit much larger I/Os instead of sending down lots of small buffer_heads. To do this we need to have a rather complicated I/O submission and completion tracking infrastructure. Part of the latter has been merged already a long time ago for direct I/O support. Part of the problem is that we need to track sub-pagesize regions and for that we still need buffer_heads for the time beeing. Long-term I hope we can move to better data strucutures and/or maybe move this to fs/mpage.c instead of having it in XFS. Original patch from Nathan Scott with various updates from David Chinner and Christoph Hellwig. SGI-PV: 947118 SGI-Modid: xfs-linux-melb:xfs-kern:203822a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Complete the pagebuf -> xfs_buf naming convention transition,Nathan Scott
finally. SGI-PV: 947038 SGI-Modid: xfs-linux-melb:xfs-kern:24866a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fixed delayed_blks assert failure during umount. The delayed_blksYingping Lu
was caused by ENOSPC but not Rreclaimed by xfs_release or xfs_inactive. The fix changed the condition in xfs_release and xfs_inactive to invoke xfs_inactive_free_eofblocks for this special case, changed xfs_inactive_free_eofblocks to clean the delayed blks after eof. It also changed xfs_write to set correct eof when ENOSPC occurs. SGI-PV: 946267 SGI-Modid: xfs-linux-melb:xfs-kern:203788a Signed-off-by: Yingping Lu <yingping@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Introduce per-filesystem delwri pagebuf flushing to reduceDavid Chinner
contention between filesystems and prevent deadlocks between filesystems when a flush dependency exists between them. SGI-PV: 947098 SGI-Modid: xfs-linux-melb:xfs-kern:24844a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] take out the call to vn_mark_bad() used when acl inherit fails andTim Shimmin
it needs to back out the inode creation. Tested by xfs_tests/077. SGI-PV: 930841 SGI-Modid: xfs-linux-melb:xfs-kern:24842a Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] endianess annotations and tidying for the uuid codeChristoph Hellwig
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:203709a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fix a thinko when generating a forced shutdown stack trace.Nathan Scott
SGI-PV: 929558 SGI-Modid: xfs-linux-melb:xfs-kern:203817a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Add a stack trace in the case of xfs_forced_shutdown.Ryan Hankins
SGI-PV: 929558 SGI-Modid: xfs-linux-melb:xfs-kern:203701a Signed-off-by: Ryan Hankins <hankins@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fix quotaoff logitem for project quota, affects log recovery only.Nathan Scott
SGI-PV: 946444 SGI-Modid: xfs-linux-melb:xfs-kern:24768a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Add an XFS callout to security_inode_init_security; SE Linux is notNathan Scott
functional with XFS without this change. SGI-PV: 946762 SGI-Modid: xfs-linux-melb:xfs-kern:24766a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fix v2 log bufsize reporting in /proc/mounts.Nathan Scott
SGI-PV: 946760 SGI-Modid: xfs-linux-melb:xfs-kern:24765a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] fix, speedup and simplify atime handling let the VFS handle atimeChristoph Hellwig
updates and only sync back to the xfs inode when nessecary SGI-PV: 946679 SGI-Modid: xfs-linux-melb:xfs-kern:203362a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] turn xlog helper macros into real functionsChristoph Hellwig
SGI-PV: 946205 SGI-Modid: xfs-linux-melb:xfs-kern:203360a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] remove unused vars, args, & unneeded intermediate vars from zeroingEric Sandeen
code SGI-PV: 946641 SGI-Modid: xfs-linux-melb:xfs-kern:203328a Signed-off-by: Eric Sandeen <sandeen@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] remove unused "readonly" arg from xlog_find_tail and xlog_recoverEric Sandeen
SGI-PV: 946611 SGI-Modid: xfs-linux-melb:xfs-kern:203307a Signed-off-by: Eric Sandeen <sandeen@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Ensure max diosize reported is aligned with minimum diosize.Nathan Scott
SGI-PV: 910890 SGI-Modid: xfs-linux-melb:xfs-kern:24689a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fix an intermittent pquota panic caused by dodgey quota flags to anNathan Scott
umount dquot flush call. SGI-PV: 946444 SGI-Modid: xfs-linux-melb:xfs-kern:24680a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Sort out cosmetic differences between user and kernel copies of someNathan Scott
sources. SGI-PV: 907752 SGI-Modid: xfs-linux-melb:xfs-kern:24659a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Make d_maxiosz report the real maximum (INT_MAX) so we dontNathan Scott
incorrectly limit people using this interface to size IO buffers. SGI-PV: 910890 SGI-Modid: xfs-linux-melb:xfs-kern:24657a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Disable write barriers for now till intermittent IO errors areNathan Scott
understood. SGI-PV: 912426 SGI-Modid: xfs-linux-melb:xfs-kern:202962a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Reverse the sense of COMPAT_ATTR and ATTR2, keeps it simple andNathan Scott
consistent. SGI-PV: 941645 SGI-Modid: xfs-linux-melb:xfs-kern:202961a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Write log dummy record when freezing filesystemChristoph Hellwig
SGI-PV: 945483 SGI-Modid: xfs-linux-melb:xfs-kern:202638a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Mark some lookup tables const. Thanks to Arjan van de Ven forChristoph Hellwig
spotting these. SGI-PV: 946028 SGI-Modid: xfs-linux-melb:xfs-kern:202617a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fixed an assertion failure in xfs_reclaim caused by delayed block.Yingping Lu
The assertion failure came from XFS QA41. The fix is done by enabling truncate for delayed block in xfs_inactive. SGI-PV: 945412 SGI-Modid: xfs-linux-melb:xfs-kern:202521a Signed-off-by: Yingping Lu <yingping@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] do barrier checks earlier. quota initialization may write to theChristoph Hellwig
filesystem SGI-PV: 912426 SGI-Modid: xfs-linux-melb:xfs-kern:202355a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fix typo from when enabling write barriers by default, flags botchNathan Scott
in showargs. SGI-PV: 912426 SGI-Modid: xfs-linux-melb:xfs-kern:24383a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Implement the di_extsize allocator hint for non-realtime files asNathan Scott
well. Also provides a mechanism for inheriting this property from the parent directory for new files. SGI-PV: 945264 SGI-Modid: xfs-linux-melb:xfs-kern:24367a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Do not inherit properties for the quota inodes from the root inode.Nathan Scott
SGI-PV: 945264 SGI-Modid: xfs-linux-melb:xfs-kern:24366a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] enable write barriers by defaultChristoph Hellwig
SGI-PV: 912426 SGI-Modid: xfs-linux-melb:xfs-kern:201981a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] merge xfs_arch.h userspace changes backChristoph Hellwig
SGI-PV: 907752 SGI-Modid: xfs-linux-melb:xfs-kern:201882a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] remove over-eager assertChristoph Hellwig
SGI-PV: 941804 SGI-Modid: xfs-linux-melb:xfs-kern:201702a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-10Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2006-01-10[PATCH] mark mutex_lock*() as might_sleep()Ingo Molnar
Mark mutex_lock() and mutex_lock_interruptible() as might_sleep() functions. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fix i386 mutex fastpath on FRAME_POINTER && !DEBUG_MUTEXESIngo Molnar
Call the mutex slowpath more conservatively - e.g. FRAME_POINTERS can change the calling convention, in which case a direct branch to the slowpath becomes illegal. Bug found by Hugh Dickins. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
