2015-06-25rtc: at32ap700x: update author emailHans-Christian Egtvedt
This patch updates the email address of the rtc-at32ap700x driver supported by me to an email account I will use on a more regular basis in the future. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-19rtc: imxdi: when locked, do not fail silentlyJuergen Borleis
If the DryICE unit is locked it is impossible to set the time. Provide an error message for this case. Signed-off-by: Juergen Borleis <jbe@pengutronix.de> Signed-off-by: Robert Schwebel <rsc@pengutronix.de> [rsc: got NDA clearance from Freescale] Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-19rtc: imxdi: monitor a security violation at runtimeJuergen Borleis
Maybe the unit enters the hardware related state at runtime and not at system boot time (after a power cycle). Signed-off-by: Juergen Borleis <jbe@pengutronix.de> Signed-off-by: Robert Schwebel <rsc@pengutronix.de> [rsc: got NDA clearance from Freescale] Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-19rtc: imxdi: add the unit recovery codeJuergen Borleis
This code is required to recover the unit from a security violation. Hopefully this code can recover the unit from a hardware related invalid state as well. Signed-off-by: Juergen Borleis <jbe@pengutronix.de> Signed-off-by: Robert Schwebel <rsc@pengutronix.de> [rsc: got NDA clearance from Freescale] Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-19rtc: imxdi: add some background info about the states the machine can be inJuergen Borleis
Document the i.MX DryIce machine states. Signed-off-by: Juergen Borleis <jbe@pengutronix.de> Signed-off-by: Robert Schwebel <rsc@pengutronix.de> [rsc: got NDA clearance from Freescale] Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-19rtc: imxdi: avoid the __raw* register access functionsJuergen Borleis
Be independent of the endianness of the kernel. Signed-off-by: Juergen Borleis <jbe@pengutronix.de> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-19rtc: s3c: Integrate Exynos3250 into S3C6410Krzysztof Kozlowski
There are now no differences between RTC on Exynos3250 and S3C6410. Merge everything into one so duplicated code could be removed. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-19rtc: interface: Remove unused return value from rtc_timer_cancel()Krzysztof Kozlowski
The rtc_timer_cancel() always returns 0 and cannot fail (calls only other void-returning functions). Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-19rtc: interface: Fix coding style violationsKrzysztof Kozlowski
Fix issues reported by checkpatch: ERROR: open brace '{' following struct go on the same line ERROR: "foo* bar" should be "foo *bar" Additionally adjust alignment of wrapped function arguments. Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-19rtc: mxc: Constify platform_device_idKrzysztof Kozlowski
The platform_device_id is not modified by the driver and core uses it as const. Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-19rtc: hid-sensor-time: Constify platform_device_idKrzysztof Kozlowski
2015-06-19rtc: ab8500: Constify platform_device_idKrzysztof Kozlowski
2015-06-19rtc: efi: Update author email addressdann frazier
I'm no longer employed by HP. Signed-off-by: dann frazier <dannf@dannf.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-06-14Linux 4.1-rc8v4.1-rc8Linus Torvalds
2015-06-14Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine fixes from Vinod Koul: "Here are hopefully last set of fixes for 4.1. This time we have: - fixing pause capability reporting on both dmaengine pause & resume support by Krzysztof - locking fix fir at_xdmac by Ludovic - slave configuration fix for at_xdmac by Ludovic" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: dmaengine: Fix choppy sound because of unimplemented resume dmaengine: at_xdmac: rework slave configuration part dmaengine: at_xdmac: lock fixes
2015-06-14Merge tag 'ntb-4.1' of git://github.com/jonmason/ntbLinus Torvalds
Pull NTB fixes from Jon Mason: "I apologize for the tardiness of this request. Here are a couple of last minute NTB bug fixes for v4.1: NTB bug fixes to address issues in unmapping the MW reg base and vbase, and an uninitialized variable on Atom platforms" * tag 'ntb-4.1' of git://github.com/jonmason/ntb: ntb: initialize max_mw for Atom before using it ntb: iounmap MW reg and vbase in error path
2015-06-14Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull more MIPS fixes from Ralf Baechle: "Another round of 4.1 MIPS fixes, one fix to a MIPS-specific #if condition in lib/mpi, one fix to the MIPS GIC irqchip driver and one SSB fix. Details: - fix handling of clock in chipco SSB driver. - fix two MIPS-specific #if conditions to correctly work for GCC 5.1. - fix damage to R6 pgtable bits done by XPA support. - fix possible crash due to unloading modules that contain statically defined platform devices. - fix disabling of the MSA ASE on context switch to also work correctly when a new thread/process has the CPU for the very first time. This is part of linux-next and has been beaten to death on Imagination's test farm. While things are not looking too grim this pull request also means the rate of fixes for 4.1 remains nearly constant so I'd not be unhappy if you'd delay the release" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MPI: MIPS: Fix compilation error with GCC 5.1 IRQCHIP: mips-gic: Don't nest calls to do_IRQ() MIPS: MSA: bugfix - disable MSA correctly for new threads/processes. MIPS: Loongson: Do not register 8250 platform device from module. MIPS: Cobalt: Do not build MTD platform device registration code as module. SSB: Fix handling of ssb_pmu_get_alp_clock() MIPS: pgtable-bits: Fix XPA damage to R6 definitions.
2015-06-14Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irqchip fix from Thomas Gleixner: "A single fix for an off by one bug in the sunxi irqchip driver" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip: sunxi-nmi: Fix off-by-one error in irq iterator
2015-06-14Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull lockdep fix from Ingo Molnar: "A lockdep/modules unload race fix that can oops" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: lockdep: Fix a race between /proc/lock_stat and module unload
2015-06-14Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "A regression fix for a crash, and a Intel HSW uncore PMU driver fix" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: Revert "perf/x86/intel/uncore: Move uncore_box_init() out of driver initialization" perf/x86/intel/uncore: Fix CBOX bit wide and UBOX reg on Haswell-EP
2015-06-14Merge tag 'sound-4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Most of commits are regression fixes for HD-audio: a few corner case fixes for regmap transition, and i915 binding issues. In addition, a quirk for another USB-audio device supporting DSD" * tag 'sound-4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Abort the probe without i915 binding for HSW/BDW ALSA: hda - Re-add the lost fake mute support ALSA: hda - Continue probing even if i915 binding fails ALSA: hda - Don't actually write registers for caps overwrites ALSA: hda - fix number of devices query on hotplug ALSA: usb-audio: add native DSD support for JLsounds I2SoverUSB
2015-06-13MPI: MIPS: Fix compilation error with GCC 5.1Jaedon Shin
This patch fixes mips compilation error: lib/mpi/generic_mpih-mul1.c: In function 'mpihelp_mul_1': lib/mpi/longlong.h:651:2: error: impossible constraint in 'asm' Signed-off-by: Jaedon Shin <jaedon.shin@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/10546/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-06-13IRQCHIP: mips-gic: Don't nest calls to do_IRQ()Rabin Vincent
The GIC chained handlers use do_IRQ() to call the subhandlers. This means that irq_enter() calls get nested, which leads to preempt count looking like we're in nested interrupts, which in turn leads to all system time being accounted as IRQ time in account_system_time(). Fix it by using generic_handle_irq(). Since these same functions are used in some systems (if cpu_has_veic) from a low-level vectored interrupt handler which does not go throught do_IRQ(), we need to do it conditionally. Signed-off-by: Rabin Vincent <rabin.vincent@axis.com> Reviewed-by: Andrew Bresticker <abrestic@chromium.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org Cc: tglx@linutronix.de Cc: jason@lakedaemon.net Patchwork: https://patchwork.linux-mips.org/patch/10545/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix uninitialized struct station_info in cfg80211_wireless_stats(), from Johannes Berg. 2) Revert commit attempt to fix ipv6 protocol resubmission, it adds regressions. 3) Endless loops can be created in bridge port lists, fix from Nikolay Aleksandrov. 4) Don't WARN_ON() if sk->sk_forward_alloc is non-zero in sk_clear_memalloc, it is a legal situation during swap deactivation. Fix from Mel Gorman. 5) Fix order of disabling interrupts and unlocking NAPI in enic driver to avoid a race. From Govindarajulu Varadarajan. 6) High and low register writes are swapped when programming the start of periodic output in igb driver. From Richard Cochran. 7) Fix device rename handling in mpls stack, from Robert Shearman. 8) Do not trigger compaction synchronously when optimistically trying to allocate an order 3 page in alloc_skb_with_frags() and skb_page_frag_refill(). From Shaohua Li. 9) Authentication with COOKIE_ECHO is not handled properly in SCTP, fix from Marcelo Ricardo Leitner. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: Doc: networking: Fix URL for wiki.wireshark.org in udplite.txt sctp: allow authenticating DATA chunks that are bundled with COOKIE_ECHO net: don't wait for order-3 page allocation mpls: handle device renames for per-device sysctls net: igb: fix the start time for periodic output signals enic: fix memory leak in rq_clean enic: check return value for stat dump enic: unlock napi busy poll before unmasking intr net, swap: Remove a warning and clarify why sk_mem_reclaim is required when deactivating swap bridge: fix multicast router rlist endless loop tipc: disconnect socket directly after probe failure Revert "ipv6: Fix protocol resubmission" cfg80211: wext: clear sinfo struct before calling driver
2015-06-12Doc: networking: Fix URL for wiki.wireshark.org in udplite.txtMasanari Iida
This patch fix URL (http to https) for wiki.wireshark.org. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-12sctp: allow authenticating DATA chunks that are bundled with COOKIE_ECHOMarcelo Ricardo Leitner
Currently, we can ask to authenticate DATA chunks and we can send DATA chunks on the same packet as COOKIE_ECHO, but if you try to combine both, the DATA chunk will be sent unauthenticated and peer won't accept it, leading to a communication failure. This happens because even though the data was queued after it was requested to authenticate DATA chunks, it was also queued before we could know that remote peer can handle authenticating, so sctp_auth_send_cid() returns false. The fix is whenever we set up an active key, re-check send queue for chunks that now should be authenticated. As a result, such packet will now contain COOKIE_ECHO + AUTH + DATA chunks, in that order. Reported-by: Liu Wei <weliu@redhat.com> Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-12Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "Remember about a week ago when I sent the last pull request for 4.1? Well, I lied. Now, I don't want to shift the blame, but Dan, Ming, and Richard made a liar out of me. Here are three small patches that should go into 4.1. More specifically, this pull request contains: - A Kconfig dependency for the pmem block driver, so it can't be selected if HAS_IOMEM isn't availble. From Richard Weinberger. - A fix for genhd, making the ext_devt_lock softirq safe. This makes lockdep happier, since we also end up grabbing this lock on release off the softirq path. From Dan Williams. - A blk-mq software queue release fix from Ming Lei. Last two are headed to stable, first fixes an issue introduced in this cycle" * 'for-linus' of git://git.kernel.dk/linux-block: block: pmem: Add dependency on HAS_IOMEM block: fix ext_dev_lock lockdep report blk-mq: free hctx->ctxs in queue's release handler
2015-06-12Merge tag 'md/4.1-rc7-fixes' of git://neil.brown.name/mdLinus Torvalds
Pull three more md fixes from Neil Brown: "Hasn't been a good cycle for md has it :-( The main issue fixed here is a rare race which can result in two reshape threads running at once, which doesn't end well. Also a minor issue with a write to a sysfs file returning the wrong value. Backports to 4.0-stable are indicated" * tag 'md/4.1-rc7-fixes' of git://neil.brown.name/md: md: make sure MD_RECOVERY_DONE is clear before starting recovery/resync md: Close race when setting 'action' to 'idle'. md: don't return 0 from array_state_store
2015-06-12Merge git://git.infradead.org/intel-iommuLinus Torvalds
Pull VT-d hardware workarounds from David Woodhouse: "This contains a workaround for hardware issues which I *thought* were never going to be seen on production hardware. I'm glad I checked that before the 4.1 release... Firstly, PASID support is so broken on existing chips that we're just going to declare the old capability bit 28 as 'reserved' and change the VT-d spec to move PASID support to another bit. So any existing hardware doesn't support SVM; it only sets that (now) meaningless bit 28. That patch *wasn't* imperative for 4.1 because we don't have PASID support yet. But *even* the extended context tables are broken — if you just enable the wider tables and use none of the new bits in them, which is precisely what 4.1 does, you find that translations don't work. It's this problem which I thought was caught in time to be fixed before production, but wasn't. To avoid triggering this issue, we now *only* enable the extended context tables on hardware which also advertises "we have PASID support and we actually tested it this time" with the new PASID feature bit. In addition, I've added an 'intel_iommu=ecs_off' command line parameter to allow us to disable it manually if we need to" * git://git.infradead.org/intel-iommu: iommu/vt-d: Only enable extended context tables if PASID is supported iommu/vt-d: Change PASID support to bit 40 of Extended Capability Register
2015-06-12iommu/vt-d: Only enable extended context tables if PASID is supportedDavid Woodhouse
Although the extended tables are theoretically a completely orthogonal feature to PASID and anything else that *uses* the newly-available bits, some of the early hardware has problems even when all we do is enable them and use only the same bits that were in the old context tables. For now, there's no motivation to support extended tables unless we're going to use PASID support to do SVM. So just don't use them unless PASID support is advertised too. Also add a command-line bailout just in case later chips also have issues. The equivalent problem for PASID support has already been fixed with the upcoming VT-d spec update and commit bd00c606a ("iommu/vt-d: Change PASID support to bit 40 of Extended Capability Register"), because the problematic platforms use the old definition of the PASID-capable bit, which is now marked as reserved and meaningless. So with this change, we'll magically start using ECS again only when we see the new hardware advertising "hey, we have PASID support and we actually tested it this time" on bit 40. The VT-d hardware architect has promised that we are not going to have any reason to support ECS *without* PASID any time soon, and he'll make sure he checks with us before changing that. In the future, if hypothetical new features also use new bits in the context tables and can be seen on implementations *without* PASID support, we might need to add their feature bits to the ecs_enabled() macro. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2015-06-12md: make sure MD_RECOVERY_DONE is clear before starting recovery/resyncNeilBrown
MD_RECOVERY_DONE is normally cleared by md_check_recovery after a resync etc finished. However it is possible for raid5_start_reshape to race and start a reshape before MD_RECOVERY_DONE is cleared. This can lean to multiple reshapes running at the same time, which isn't good. To make sure it is cleared before starting a reshape, and also clear it when reaping a thread, just to be safe. Signed-off-by: NeilBrown <neilb@suse.de>
2015-06-12md: Close race when setting 'action' to 'idle'.NeilBrown
Checking ->sync_thread without holding the mddev_lock() isn't really safe, even after flushing the workqueue which ensures md_start_sync() has been run. While this code is waiting for the lock, md_check_recovery could reap the thread itself, and then start another thread (e.g. recovery might finish, then reshape starts). When this thread gets the lock md_start_sync() hasn't run so it doesn't get reaped, but MD_RECOVERY_RUNNING gets cleared. This allows two threads to start which leads to confusion. So don't both if MD_RECOVERY_RUNNING isn't set, but if it is do the flush and the test and the reap all under the mddev_lock to avoid any race with md_check_recovery. Signed-off-by: NeilBrown <neilb@suse.de> Fixes: 6791875e2e53 ("md: make reconfig_mutex optional for writes to md sysfs files.") Cc: stable@vger.kernel.org (v4.0+)
2015-06-12md: don't return 0 from array_state_storeNeilBrown
Returning zero from a 'store' function is bad. The return value should be either len length of the string or an error. So use 'len' if 'err' is zero. Fixes: 6791875e2e53 ("md: make reconfig_mutex optional for writes to md sysfs files.") Signed-off-by: NeilBrown <neilb@suse.de> Cc: stable@vger.kernel (v4.0+)
2015-06-12dmaengine: Fix choppy sound because of unimplemented resumeKrzysztof Kozlowski
Some drivers implement only pause operation (no resuming). Example is pl330 where pause is needed for getting residuum. pl330 does not support resume operation, transfer must be stopped after pause. However for slaves this is exposed always as "pause and resume" which introduces subtle errors on Odroid U3 board (Exynos4412 with pl330). After adding pause function to pl330 driver the audio playback (utilizing DMA) gets choppy after some time (approximately 24 hours). Fix this by exposing "cmd_pause" if and only if pause and resume are implemented. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reported-by: gabriel@unseen.is Reported-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: <stable@vger.kernel.org> Fixes: 88987d2c7534 ("dmaengine: pl330: add DMA_PAUSE feature") Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-06-12ALSA: hda - Abort the probe without i915 binding for HSW/BDWTakashi Iwai
The previous patch tried to continue the probe if i915 binding fails. For for simplicity reason, we haven't implemented abort even for controller chips that are dedicated for HDMI/DP on HSW and BDW. However, Mengdong suggested that this can be dangerous; BIOS may disable gfx power well although the PCI entry for HD-audio is left, and this may result in the unexpected behavior, kernel errors, etc. For avoiding this situation, abort the probe at i915 binding failure only for HSW/BDW chips selectively. For other chips, it still continues. Fixes: bf06848bdbe5 ('ALSA: hda - Continue probing even if i915 binding fails') Reported-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-06-11Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "i915 and radeon fixes: i915: fix for connector oops regression DDC probing fix radeon: two radeon reverts, along with a freeze workaround and a fix" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/radeon: Make sure radeon_vm_bo_set_addr always unreserves the BO Revert "drm/radeon: adjust pll when audio is not enabled" Revert "drm/radeon: don't share plls if monitors differ in audio support" drm/radeon: fix freeze for laptop with Turks/Thames GPU. drm/i915: Fix DDC probe for passive adapters drm/i915: Properly initialize SDVO analog connectors
2015-06-11net: don't wait for order-3 page allocationShaohua Li
We saw excessive direct memory compaction triggered by skb_page_frag_refill. This causes performance issues and add latency. Commit 5640f7685831e0 introduces the order-3 allocation. According to the changelog, the order-3 allocation isn't a must-have but to improve performance. But direct memory compaction has high overhead. The benefit of order-3 allocation can't compensate the overhead of direct memory compaction. This patch makes the order-3 page allocation atomic. If there is no memory pressure and memory isn't fragmented, the alloction will still success, so we don't sacrifice the order-3 benefit here. If the atomic allocation fails, direct memory compaction will not be triggered, skb_page_frag_refill will fallback to order-0 immediately, hence the direct memory compaction overhead is avoided. In the allocation failure case, kswapd is waken up and doing compaction, so chances are allocation could success next time. alloc_skb_with_frags is the same. The mellanox driver does similar thing, if this is accepted, we must fix the driver too. V3: fix the same issue in alloc_skb_with_frags as pointed out by Eric V2: make the changelog clearer Cc: Eric Dumazet <edumazet@google.com> Cc: Chris Mason <clm@fb.com> Cc: Debabrata Banerjee <dbavatar@gmail.com> Signed-off-by: Shaohua Li <shli@fb.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-12Merge tag 'drm-intel-fixes-2015-06-11' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-fixes Fix for the regression Linus called out, and another for probing dongles. * tag 'drm-intel-fixes-2015-06-11' of git://anongit.freedesktop.org/drm-intel: drm/i915: Fix DDC probe for passive adapters drm/i915: Properly initialize SDVO analog connectors
2015-06-12Merge branch 'drm-fixes-4.1' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-fixes Two regression reverts, and two fixes, one for a dpm boot freeze. * 'drm-fixes-4.1' of git://people.freedesktop.org/~agd5f/linux: drm/radeon: Make sure radeon_vm_bo_set_addr always unreserves the BO Revert "drm/radeon: adjust pll when audio is not enabled" Revert "drm/radeon: don't share plls if monitors differ in audio support" drm/radeon: fix freeze for laptop with Turks/Thames GPU.
2015-06-11mpls: handle device renames for per-device sysctlsRobert Shearman
If a device is renamed and the original name is subsequently reused for a new device, the following warning is generated: sysctl duplicate entry: /net/mpls/conf/veth0//input CPU: 3 PID: 1379 Comm: ip Not tainted 4.1.0-rc4+ #20 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014 0000000000000000 0000000000000000 ffffffff81566aaf 0000000000000000 ffffffff81236279 ffff88002f7d7f00 0000000000000000 ffff88000db336d8 ffff88000db33698 0000000000000005 ffff88002e046000 ffff8800168c9280 Call Trace: [<ffffffff81566aaf>] ? dump_stack+0x40/0x50 [<ffffffff81236279>] ? __register_sysctl_table+0x289/0x5a0 [<ffffffffa051a24f>] ? mpls_dev_notify+0x1ff/0x300 [mpls_router] [<ffffffff8108db7f>] ? notifier_call_chain+0x4f/0x70 [<ffffffff81470e72>] ? register_netdevice+0x2b2/0x480 [<ffffffffa0524748>] ? veth_newlink+0x178/0x2d3 [veth] [<ffffffff8147f84c>] ? rtnl_newlink+0x73c/0x8e0 [<ffffffff8147f27a>] ? rtnl_newlink+0x16a/0x8e0 [<ffffffff81459ff2>] ? __kmalloc_reserve.isra.30+0x32/0x90 [<ffffffff8147ccfd>] ? rtnetlink_rcv_msg+0x8d/0x250 [<ffffffff8145b027>] ? __alloc_skb+0x47/0x1f0 [<ffffffff8149badb>] ? __netlink_lookup+0xab/0xe0 [<ffffffff8147cc70>] ? rtnetlink_rcv+0x30/0x30 [<ffffffff8149e7a0>] ? netlink_rcv_skb+0xb0/0xd0 [<ffffffff8147cc64>] ? rtnetlink_rcv+0x24/0x30 [<ffffffff8149df17>] ? netlink_unicast+0x107/0x1a0 [<ffffffff8149e4be>] ? netlink_sendmsg+0x50e/0x630 [<ffffffff8145209c>] ? sock_sendmsg+0x3c/0x50 [<ffffffff81452beb>] ? ___sys_sendmsg+0x27b/0x290 [<ffffffff811bd258>] ? mem_cgroup_try_charge+0x88/0x110 [<ffffffff811bd5b6>] ? mem_cgroup_commit_charge+0x56/0xa0 [<ffffffff811d7700>] ? do_filp_open+0x30/0xa0 [<ffffffff8145336e>] ? __sys_sendmsg+0x3e/0x80 [<ffffffff8156c3f2>] ? system_call_fastpath+0x16/0x75 Fix this by unregistering the previous sysctl table (registered for the path containing the original device name) and re-registering the table for the path containing the new device name. Fixes: 37bde79979c3 ("mpls: Per-device enabling of packet input") Reported-by: Scott Feldman <sfeldma@gmail.com> Signed-off-by: Robert Shearman <rshearma@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-11net: igb: fix the start time for periodic output signalsRichard Cochran
When programming the start of a periodic output, the code wrongly places the seconds value into the "low" register and the nanoseconds into the "high" register. Even though this is backwards, it slipped through my testing, because the re-arming code in the interrupt service routine is correct, and the signal does appear starting with the second edge. This patch fixes the issue by programming the registers correctly. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Reviewed-by: Jacob Keller <jacob.e.keller@intel.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-11block: pmem: Add dependency on HAS_IOMEMRichard Weinberger
Not all architectures have io memory. Fixes: drivers/block/pmem.c: In function ‘pmem_alloc’: drivers/block/pmem.c:146:2: error: implicit declaration of function ‘ioremap_nocache’ [-Werror=implicit-function-declaration] pmem->virt_addr = ioremap_nocache(pmem->phys_addr, pmem->size); ^ drivers/block/pmem.c:146:18: warning: assignment makes pointer from integer without a cast [enabled by default] pmem->virt_addr = ioremap_nocache(pmem->phys_addr, pmem->size); ^ drivers/block/pmem.c:182:2: error: implicit declaration of function ‘iounmap’ [-Werror=implicit-function-declaration] iounmap(pmem->virt_addr); ^ Signed-off-by: Richard Weinberger <richard@nod.at> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-11Merge tag 'trace-rb-bm-fix-4.1-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull ring buffer benchmark buglet fix from Steven Rostedt: "Wang Long fixed a minor bug in the module parameter for the ring buffer benchmark, where the produce_fifo was being ignored and the producer thread's priority was being set with the consumer_fifo parameter" * tag 'trace-rb-bm-fix-4.1-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ring-buffer-benchmark: Fix the wrong sched_priority of producer
2015-06-11block: fix ext_dev_lock lockdep reportDan Williams
================================= [ INFO: inconsistent lock state ] 4.1.0-rc7+ #217 Tainted: G O --------------------------------- inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage. swapper/6/0 [HC0[0]:SC1[1]:HE1:SE0] takes: (ext_devt_lock){+.?...}, at: [<ffffffff8143a60c>] blk_free_devt+0x3c/0x70 {SOFTIRQ-ON-W} state was registered at: [<ffffffff810bf6b1>] __lock_acquire+0x461/0x1e70 [<ffffffff810c1947>] lock_acquire+0xb7/0x290 [<ffffffff818ac3a8>] _raw_spin_lock+0x38/0x50 [<ffffffff8143a07d>] blk_alloc_devt+0x6d/0xd0 <-- take the lock in process context [..] [<ffffffff810bf64e>] __lock_acquire+0x3fe/0x1e70 [<ffffffff810c00ad>] ? __lock_acquire+0xe5d/0x1e70 [<ffffffff810c1947>] lock_acquire+0xb7/0x290 [<ffffffff8143a60c>] ? blk_free_devt+0x3c/0x70 [<ffffffff818ac3a8>] _raw_spin_lock+0x38/0x50 [<ffffffff8143a60c>] ? blk_free_devt+0x3c/0x70 [<ffffffff8143a60c>] blk_free_devt+0x3c/0x70 <-- take the lock in softirq [<ffffffff8143bfec>] part_release+0x1c/0x50 [<ffffffff8158edf6>] device_release+0x36/0xb0 [<ffffffff8145ac2b>] kobject_cleanup+0x7b/0x1a0 [<ffffffff8145aad0>] kobject_put+0x30/0x70 [<ffffffff8158f147>] put_device+0x17/0x20 [<ffffffff8143c29c>] delete_partition_rcu_cb+0x16c/0x180 [<ffffffff8143c130>] ? read_dev_sector+0xa0/0xa0 [<ffffffff810e0e0f>] rcu_process_callbacks+0x2ff/0xa90 [<ffffffff810e0dcf>] ? rcu_process_callbacks+0x2bf/0xa90 [<ffffffff81067e2e>] __do_softirq+0xde/0x600 Neil sees this in his tests and it also triggers on pmem driver unbind for the libnvdimm tests. This fix is on top of an initial fix by Keith for incorrect usage of mutex_lock() in this path: 2da78092dda1 "block: Fix dev_t minor allocation lifetime". Both this and 2da78092dda1 are candidates for -stable. Fixes: 2da78092dda1 ("block: Fix dev_t minor allocation lifetime") Cc: <stable@vger.kernel.org> Cc: Keith Busch <keith.busch@intel.com> Reported-by: NeilBrown <neilb@suse.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-11drm/radeon: Make sure radeon_vm_bo_set_addr always unreserves the BOMichel Dänzer
Some error paths didn't unreserve the BO. This resulted in a deadlock down the road on the next attempt to reserve the (still reserved) BO. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=90873 Cc: stable@vger.kernel.org Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2015-06-11Revert "drm/radeon: adjust pll when audio is not enabled"Alex Deucher
This reverts commit 7fe04d6fa824ccea704535a597dc417c8687f990. Fixes some systems at the expense of others. Need to properly fix the pll divider selection. bug: https://bugzilla.kernel.org/show_bug.cgi?id=99651 Cc: stable@vger.kernel.org
2015-06-11Revert "drm/radeon: don't share plls if monitors differ in audio support"Alex Deucher
This reverts commit a10f0df0615abb194968fc08147f3cdd70fd5aa5. Fixes some systems at the expense of others. Need to properly fix the pll divider selection. bug: https://bugzilla.kernel.org/show_bug.cgi?id=99651 Cc: stable@vger.kernel.org
2015-06-11drm/radeon: fix freeze for laptop with Turks/Thames GPU.Jérôme Glisse
Laptop with Turks/Thames GPU will freeze if dpm is enabled. It seems the SMC engine is relying on some state inside the CP engine. CP needs to chew at least one packet for it to get in good state for dynamic power management. This patch simply disabled and re-enable DPM after the ring test which is enough to avoid the freeze. Signed-off-by: Jérôme Glisse <jglisse@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2015-06-11ring-buffer-benchmark: Fix the wrong sched_priority of producerWang Long
The producer should be used producer_fifo as its sched_priority, so correct it. Link: http://lkml.kernel.org/r/1433923957-67842-1-git-send-email-long.wanglong@huawei.com Cc: stable@vger.kernel.org # 2.6.33+ Signed-off-by: Wang Long <long.wanglong@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-06-11ntb: initialize max_mw for Atom before using itDaniel Verkamp
Commit ab760a0 (ntb: Adding split BAR support for Haswell platforms) changed ntb_device's mw from a fixed-size array into a pointer that is allocated based on limits.max_mw; however, on Atom platforms, max_mw is not initialized until ntb_device_setup(), which happens after the allocation. Fill out max_mw in ntb_atom_detect() to match ntb_xeon_detect(); this happens before the use of max_mw in the ndev->mw allocation. Fixes a null pointer dereference on Atom platforms with ntb hardware. v2: fix typo (mw_max should be max_mw) Signed-off-by: Daniel Verkamp <daniel.verkamp@intel.com> Acked-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
