2016-10-21spi: spidev: Add device to spidev device tree compatibility listFabien Lahoudere
Entries are needed in the spidev ID list to configure configure it from a device tree. Add entry for the following device: - "ge,achc" : GE Healthcare USB Management Controller The USB Management Controller does not expose USB to the host, but acts as an offload engine, communicating with specific USB based data acquisition devices which are connected to it, extracting the required data and providing it to the host via other methods. SPI is used as an out-of-band configuration channel. Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-10-15Linux 4.9-rc1v4.9-rc1Linus Torvalds
2016-10-15Merge tag 'befs-v4.9-rc1' of git://github.com/luisbg/linux-befsLinus Torvalds
Pull befs fixes from Luis de Bethencourt: "I recently took maintainership of the befs file system [0]. This is the first time I send you a git pull request, so please let me know if all the below is OK. Salah Triki and myself have been cleaning the code and fixing a few small bugs. Sorry I couldn't send this sooner in the merge window, I was waiting to have my GPG key signed by kernel members at ELCE in Berlin a few days ago." [0] https://lkml.org/lkml/2016/7/27/502 * tag 'befs-v4.9-rc1' of git://github.com/luisbg/linux-befs: (39 commits) befs: befs: fix style issues in datastream.c befs: improve documentation in datastream.c befs: fix typos in datastream.c befs: fix typos in btree.c befs: fix style issues in super.c befs: fix comment style befs: add check for ag_shift in superblock befs: dump inode_size superblock information befs: remove unnecessary initialization befs: fix typo in befs_sb_info befs: add flags field to validate superblock state befs: fix typo in befs_find_key befs: remove unused BEFS_BT_PARMATCH fs: befs: remove ret variable fs: befs: remove in vain variable assignment fs: befs: remove unnecessary *befs_sb variable fs: befs: remove useless initialization to zero fs: befs: remove in vain variable assignment fs: befs: Insert NULL inode to dentry fs: befs: Remove useless calls to brelse in befs_find_brun_dblindirect ...
2016-10-15Merge tag 'gcc-plugins-v4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux Pull gcc plugins update from Kees Cook: "This adds a new gcc plugin named "latent_entropy". It is designed to extract as much possible uncertainty from a running system at boot time as possible, hoping to capitalize on any possible variation in CPU operation (due to runtime data differences, hardware differences, SMP ordering, thermal timing variation, cache behavior, etc). At the very least, this plugin is a much more comprehensive example for how to manipulate kernel code using the gcc plugin internals" * tag 'gcc-plugins-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux: latent_entropy: Mark functions with __latent_entropy gcc-plugins: Add latent_entropy plugin
2016-10-15Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main MIPS pull request for 4.9: MIPS core arch code: - traps: 64bit kernels should read CP0_EBase 64bit - traps: Convert ebase to KSEG0 - c-r4k: Drop bc_wback_inv() from icache flush - c-r4k: Split user/kernel flush_icache_range() - cacheflush: Use __flush_icache_user_range() - uprobes: Flush icache via kernel address - KVM: Use __local_flush_icache_user_range() - c-r4k: Fix flush_icache_range() for EVA - Fix -mabi=64 build of vdso.lds - VDSO: Drop duplicated -I*/-E* aflags - tracing: move insn_has_delay_slot to a shared header - tracing: disable uprobe/kprobe on compact branch instructions - ptrace: Fix regs_return_value for kernel context - Squash lines for simple wrapper functions - Move identification of VP(E) into proc.c from smp-mt.c - Add definitions of SYNC barrierstype values - traps: Ensure full EBase is written - tlb-r4k: If there are wired entries, don't use TLBINVF - Sanitise coherentio semantics - dma-default: Don't check hw_coherentio if device is non-coherent - Support per-device DMA coherence - Adjust MIPS64 CAC_BASE to reflect Config.K0 - Support generating Flattened Image Trees (.itb) - generic: Introduce generic DT-based board support - generic: Convert SEAD-3 to a generic board - Enable hardened usercopy - Don't specify STACKPROTECTOR in defconfigs Octeon: - Delete dead code and files across the platform. - Change to use all memory into use by default. - Rename upper case variables in setup code to lowercase. - Delete legacy hack for broken bootloaders. - Leave maintaining the link state to the actual ethernet/PHY drivers. - Add DTS for D-Link DSR-500N. - Fix PCI interrupt routing on D-Link DSR-500N. Pistachio: - Remove ANDROID_TIMED_OUTPUT from defconfig TX39xx: - Move GPIO setup from .mem_setup() to .arch_init() - Convert to Common Clock Framework TX49xx: - Move GPIO setup from .mem_setup() to .arch_init() - Convert to Common Clock Framework txx9wdt: - Add missing clock (un)prepare calls for CCF BMIPS: - Add PW, GPIO SDHCI and NAND device node names - Support APPENDED_DTB - Add missing bcm97435svmb to DT_NONE - Rename bcm96358nb4ser to bcm6358-neufbox4-sercom - Add DT examples for BCM63268, BCM3368 and BCM6362 - Add support for BCM3368 and BCM6362 PCI - Reduce stack frame usage - Use struct list_head lists - Support for CONFIG_PCI_DOMAINS_GENERIC - Make pcibios_set_cache_line_size an initcall - Inline pcibios_assign_all_busses - Split pci.c into pci.c & pci-legacy.c - Introduce CONFIG_PCI_DRIVERS_LEGACY - Support generic drivers CPC - Convert bare 'unsigned' to 'unsigned int' - Avoid lock when MIPS CM >= 3 is present GIC: - Delete unused file smp-gic.c mt7620: - Delete unnecessary assignment for the field "owner" from PCI BCM63xx: - Let clk_disable() return immediately if clk is NULL pm-cps: - Change FSB workaround to CPU blacklist - Update comments on barrier instructions - Use MIPS standard lightweight ordering barrier - Use MIPS standard completion barrier - Remove selection of sync types - Add MIPSr6 CPU support - Support CM3 changes to Coherence Enable Register SMP: - Wrap call to mips_cpc_lock_other in mips_cm_lock_other - Introduce mechanism for freeing and allocating IPIs cpuidle: - cpuidle-cps: Enable use with MIPSr6 CPUs. SEAD3: - Rewrite to use DT and generic kernel feature. USB: - host: ehci-sead3: Remove SEAD-3 EHCI code FBDEV: - cobalt_lcdfb: Drop SEAD3 support dt-bindings: - Document a binding for simple ASCII LCDs auxdisplay: - img-ascii-lcd: driver for simple ASCII LCD displays irqchip i8259: - i8259: Add domain before mapping parent irq - i8259: Allow platforms to override poll function - i8259: Remove unused i8259A_irq_pending Malta: - Rewrite to use DT of/platform: - Probe "isa" busses by default CM: - Print CM error reports upon bus errors Module: - Migrate exception table users off module.h and onto extable.h - Make various drivers explicitly non-modular: - Audit and remove any unnecessary uses of module.h mailmap: - Canonicalize to Qais' current email address. Documentation: - MIPS supports HAVE_REGS_AND_STACK_ACCESS_API Loongson1C: - Add CPU support for Loongson1C - Add board support - Add defconfig - Add RTC support for Loongson1C board All this except one Documentation fix has sat in linux-next and has survived Imagination's automated build test system" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (127 commits) Documentation: MIPS supports HAVE_REGS_AND_STACK_ACCESS_API MIPS: ptrace: Fix regs_return_value for kernel context MIPS: VDSO: Drop duplicated -I*/-E* aflags MIPS: Fix -mabi=64 build of vdso.lds MIPS: Enable hardened usercopy MIPS: generic: Convert SEAD-3 to a generic board MIPS: generic: Introduce generic DT-based board support MIPS: Support generating Flattened Image Trees (.itb) MIPS: Adjust MIPS64 CAC_BASE to reflect Config.K0 MIPS: Print CM error reports upon bus errors MIPS: Support per-device DMA coherence MIPS: dma-default: Don't check hw_coherentio if device is non-coherent MIPS: Sanitise coherentio semantics MIPS: PCI: Support generic drivers MIPS: PCI: Introduce CONFIG_PCI_DRIVERS_LEGACY MIPS: PCI: Split pci.c into pci.c & pci-legacy.c MIPS: PCI: Inline pcibios_assign_all_busses MIPS: PCI: Make pcibios_set_cache_line_size an initcall MIPS: PCI: Support for CONFIG_PCI_DOMAINS_GENERIC MIPS: PCI: Use struct list_head lists ...
2016-10-15Merge tag 'sound-fix-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Just a few trivial small fixes" * tag 'sound-fix-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: line6: fix a crash in line6_hwdep_write() ALSA: seq: fix passing wrong pointer in function call of compatibility layer ALSA: hda - Fix a failure of micmute led when having multi adcs ALSA: line6: Fix POD X3 Live audio input
2016-10-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more misc uaccess and vfs updates from Al Viro: "The rest of the stuff from -next (more uaccess work) + assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: score: traps: Add missing include file to fix build error fs/super.c: don't fool lockdep in freeze_super() and thaw_super() paths fs/super.c: fix race between freeze_super() and thaw_super() overlayfs: Fix setting IOP_XATTR flag iov_iter: kernel-doc import_iovec() and rw_copy_check_uvector() blackfin: no access_ok() for __copy_{to,from}_user() arm64: don't zero in __copy_from_user{,_inatomic} arm: don't zero in __copy_from_user_inatomic()/__copy_from_user() arc: don't leak bits of kernel stack into coredump alpha: get rid of tail-zeroing in __copy_user()
2016-10-14Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs fixes from Steve French: "Including: - nine bug fixes for stable. Some of these we found at the recent two weeks of SMB3 test events/plugfests. - significant improvements in reconnection (e.g. if server or network crashes) especially when mounted with "persistenthandles" or to server which advertises Continuous Availability on the share. - a new mount option "idsfromsid" which improves POSIX compatibility in some cases (when winbind not configured e.g.) by better (and faster) fetching uid/gid from acl (when "cifsacl" mount option is enabled). NB: we are almost complete work on "cifsacl" (querying mode/uid/gid from ACL) for SMB3, but SMB3 support for cifsacl is not included in this set. - improved handling for SMB3 "credits" (even if server is buggy) Still working on two sets of changes: - cifsacl enablement for SMB3 - cleanup of RFC1001 length calculation (so we can handle encryption and multichannel and RDMA) And a couple of new bugs were reported recently (unrelated to above) so will probably have another merge request next week" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: (21 commits) CIFS: Retrieve uid and gid from special sid if enabled CIFS: Add new mount option to set owner uid and gid from special sids in acl CIFS: Reset read oplock to NONE if we have mandatory locks after reopen CIFS: Fix persistent handles re-opening on reconnect SMB2: Separate RawNTLMSSP authentication from SMB2_sess_setup SMB2: Separate Kerberos authentication from SMB2_sess_setup Expose cifs module parameters in sysfs Cleanup missing frees on some ioctls Enable previous version support Do not send SMB3 SET_INFO request if nothing is changing SMB3: Add mount parameter to allow user to override max credits fs/cifs: reopen persistent handles on reconnect Clarify locking of cifs file and tcon structures and make more granular Fix regression which breaks DFS mounting fs/cifs: keep guid when assigning fid to fileinfo SMB3: GUIDs should be constructed as random but valid uuids Set previous session id correctly on SMB3 reconnect cifs: Limit the overall credit acquired Display number of credits available Add way to query creation time of file via cifs xattr ...
2016-10-14Merge branch 'for-linus-4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "Some fixes from Omar and Dave Sterba for our new free space tree. This isn't heavily used yet, but as we move toward making it the new default we wanted to nail down an endian bug" * 'for-linus-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs: tests: uninline member definitions in free_space_extent btrfs: tests: constify free space extent specs Btrfs: expand free space tree sanity tests to catch endianness bug Btrfs: fix extent buffer bitmap tests on big-endian systems Btrfs: catch invalid free space trees Btrfs: fix mount -o clear_cache,space_cache=v2 Btrfs: fix free space tree bitmaps on big-endian systems
2016-10-14Merge branch 'work.uaccess' into for-linusAl Viro
2016-10-14score: traps: Add missing include file to fix build errorGuenter Roeck
score images fail to build as follows. arch/score/kernel/traps.c: In function 'show_stack': arch/score/kernel/traps.c:55:3: error: implicit declaration of function '__get_user' __get_user() is declared in asm/uaccess.h, which was previously included through asm/module.h. Cc: Al Viro <viro@zeniv.linux.org.uk> Fixes: 88dd4a748da7 ("score: separate extable.h, switch module.h to it") Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-14fs/super.c: don't fool lockdep in freeze_super() and thaw_super() pathsOleg Nesterov
sb_wait_write()->percpu_rwsem_release() fools lockdep to avoid the false-positives. Now that xfs was fixed by Dave's commit dbad7c993053 ("xfs: stop holding ILOCK over filldir callbacks") we can remove it and change freeze_super() and thaw_super() to run with s_writers.rw_sem locks held; we add two trivial helpers for that, lockdep_sb_freeze_release() and lockdep_sb_freeze_acquire(). xfstests-dev/check `grep -il freeze tests/*/???` does not trigger any warning from lockdep. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-14Merge branch 'overlayfs-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs Pull overlayfs updates from Miklos Szeredi: "This update contains fixes to the "use mounter's permission to access underlying layers" area, and miscellaneous other fixes and cleanups. No new features this time" * 'overlayfs-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs: ovl: use vfs_get_link() vfs: add vfs_get_link() helper ovl: use generic_readlink ovl: explain error values when removing acl from workdir ovl: Fix info leak in ovl_lookup_temp() ovl: during copy up, switch to mounter's creds early ovl: lookup: do getxattr with mounter's permission ovl: copy_up_xattr(): use strnlen
2016-10-14fs/super.c: fix race between freeze_super() and thaw_super()Oleg Nesterov
Change thaw_super() to check frozen != SB_FREEZE_COMPLETE rather than frozen == SB_UNFROZEN, otherwise it can race with freeze_super() which drops sb->s_umount after SB_FREEZE_WRITE to preserve the lock ordering. In this case thaw_super() will wrongly call s_op->unfreeze_fs() before it was actually frozen, and call sb_freeze_unlock() which leads to the unbalanced percpu_up_write(). Unfortunately lockdep can't detect this, so this triggers misc BUG_ON()'s in kernel/rcu/sync.c. Reported-and-tested-by: Nikolay Borisov <kernel@kyup.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-14overlayfs: Fix setting IOP_XATTR flagVivek Goyal
ovl_fill_super calls ovl_new_inode to create a root inode for the new superblock before initializing sb->s_xattr. This wrongly causes IOP_XATTR to be cleared in i_opflags of the new inode, causing SELinux to log the following message: SELinux: (dev overlay, type overlay) has no xattr support Fix this by initializing sb->s_xattr and similar fields before calling ovl_new_inode. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-14iov_iter: kernel-doc import_iovec() and rw_copy_check_uvector()Vegard Nossum
Both import_iovec() and rw_copy_check_uvector() take an array (typically small and on-stack) which is used to hold an iovec array copy from userspace. This is to avoid an expensive memory allocation in the fast path (i.e. few iovec elements). The caller may have to check whether these functions actually used the provided buffer or allocated a new one -- but this differs between the too. Let's just add a kernel doc to clarify what the semantics are for each function. Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-14Merge tag 'linux-kselftest-4.9-rc1-update' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest updates from Shuah Khan: "This update consists of: - Fixes and improvements to existing tests - Moving code from Documentation to selftests, samples, and tools: * Moves dnotify_test, prctl, ptp, vDSO, ia64, watchdog, and networking tests from Documentation to selftests. * Moves mic/mpssd, misc-devices/mei, timers, watchdog, auxdisplay, and blackfin examples from Documentation to samples. * Moves accounting, laptops/dslm, and pcmcia/crc32hash tools from Documentation to tools. * Deletes BUILD_DOCSRC and its dependencies" * tag 'linux-kselftest-4.9-rc1-update' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: (21 commits) selftests/futex: Check ANSI terminal color support Doc: update 00-INDEX files to reflect the runnable code move samples: move blackfin gptimers-example from Documentation tools: move pcmcia crc32hash tool from Documentation tools: move laptops dslm tool from Documentation tools: move accounting tool from Documentation samples: move auxdisplay example code from Documentation samples: move watchdog example code from Documentation samples: move timers example code from Documentation samples: move misc-devices/mei example code from Documentation samples: move mic/mpssd example code from Documentation selftests: Move networking/timestamping from Documentation selftests: move watchdog tests from Documentation/watchdog selftests: move ia64 tests from Documentation/ia64 selftests: move vDSO tests from Documentation/vDSO selftests: move ptp tests from Documentation/ptp selftests: move prctl tests from Documentation/prctl selftests: move dnotify_test from Documentation/filesystems selftests/timers: Add missing error code assignment before test selftests/zram: replace ZRAM_LZ4_COMPRESS ...
2016-10-14Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild changes from Michal Marek: "Just a few patches on the kbuild.git#misc branch this time: - New Coccinelle patch by Nicholas Mc Guire - Existing patch fixes by Julia Lawall - Minor comment fix by Markus Elfring" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Coccinelle: flag conditions with no effect scripts/coccicheck: Update reference for the corresponding documentation Coccinelle: pm_runtime: ensure relevance of pm_runtime reports Coccinelle: limit memdup_user transformation to GFP_KERNEL case
2016-10-14Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - EXPORT_SYMBOL for asm source by Al Viro. This does bring a regression, because genksyms no longer generates checksums for these symbols (CONFIG_MODVERSIONS). Nick Piggin is working on a patch to fix this. Plus, we are talking about functions like strcpy(), which rarely change prototypes. - Fixes for PPC fallout of the above by Stephen Rothwell and Nick Piggin - fixdep speedup by Alexey Dobriyan. - preparatory work by Nick Piggin to allow architectures to build with -ffunction-sections, -fdata-sections and --gc-sections - CONFIG_THIN_ARCHIVES support by Stephen Rothwell - fix for filenames with colons in the initramfs source by me. * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (22 commits) initramfs: Escape colons in depfile ppc: there is no clear_pages to export powerpc/64: whitelist unresolved modversions CRCs kbuild: -ffunction-sections fix for archs with conflicting sections kbuild: add arch specific post-link Makefile kbuild: allow archs to select link dead code/data elimination kbuild: allow architectures to use thin archives instead of ld -r kbuild: Regenerate genksyms lexer kbuild: genksyms fix for typeof handling fixdep: faster CONFIG_ search ia64: move exports to definitions sparc32: debride memcpy.S a bit [sparc] unify 32bit and 64bit string.h sparc: move exports to definitions ppc: move exports to definitions arm: move exports to definitions s390: move exports to definitions m68k: move exports to definitions alpha: move exports to actual definitions x86: move exports to actual definitions ...
2016-10-14Merge tag 'docs-4.9-2' of git://git.lwn.net/linuxLinus Torvalds
Pull one more documentation update from Jonathan Corbet: "A single commit converting the mac80211 DocBook template over to Sphinx. Only 32 more to go..." * tag 'docs-4.9-2' of git://git.lwn.net/linux: docs-rst: sphinxify 802.11 documentation
2016-10-14Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma qedr RoCE driver from Doug Ledford: "Early on in the merge window I mentioned I had a backlog of new drivers waiting to be reviewed and that, in addition to the hns-roce driver, I wanted to get possible a couple more reviewed. I ended up only having the time to complete one of the additional drivers. During Dave Miller's pull request this go around, there were a series of 9 patches to the QLogic qed net driver that add basic support for a paired RoCE driver. That support is currently not functional because it is missing the matching RoCE driver in the RDMA subsystem. I managed to finish that review. However, because it goes against part of Dave's net pull, and a part that was accepted a day or two after the merge window opened, to apply cleanly it has to be applied to either the tip of Dave's net branch, or as I did in this case, I just applied it to your master after you had taken Dave's pull request." * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: qedr: Add events support and register IB device qedr: Add GSI support qedr: Add LL2 RoCE interface qedr: Add support for data path qedr: Add support for memory registeration verbs qedr: Add support for QP verbs qedr: Add support for PD,PKEY and CQ verbs qedr: Add support for user context verbs qedr: Add support for RoCE HW init qedr: Add RoCE driver framework
2016-10-14Merge tag 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull more rdma updates from Doug Ledford: "This merge window was the first where Huawei had to try and coordinate their patches between their net driver and their new roce driver (similar to mlx4 and mlx5). They didn't do horribly, but there were some issues (and we knew that because they simply didn't know what to do in the beginning). As a result, I had a set of patches that depended on some patches that normally would have come to you via Dave's tree. Those patches have been on netdev@ for a while, so I got Dave to give me his approval to send them to you. As such, the other 29 patches I had behind them are also now ready to go. This catches the hns and hns-roce drivers up to current, and for future patches we are working with them to get them up to speed on how to do joint driver development so that they don't have these sorts of cross tree dependency issues again. BTW, Dave gave me permission to add his Acked-by: to the patches against the net tree, but I've had this branch through 0day (but not linux-next since it was off by itself) and I didn't want to rebase the series just to add Dave's ack for the 8 patches in the net area. Updates to the hns drivers: - Small patch set for hns net driver that the roce patches depend on - Various fixes to the hns-roce driver - Add connection manager support to the hns-roce driver" * tag 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (36 commits) IB/hns: Fix for removal of redundant code IB/hns: Delete the redundant lines in hns_roce_v1_m_qp() IB/hns: Fix the bug when platform_get_resource() exec fail IB/hns: Update the rq head when modify qp state IB/hns: Cq has not been freed IB/hns: Validate mtu when modified qp IB/hns: Some items of qpc need to take user param IB/hns: The Ack timeout need a lower limit value IB/hns: Return bad wr while post send failed IB/hns: Fix bug of memory leakage for registering user mr IB/hns: Modify the init of iboe lock IB/hns: Optimize code of aeq and ceq interrupt handle and fix the bug of qpn IB/hns: Delete the sqp_start from the structure hns_roce_caps IB/hns: Fix bug of clear hem IB/hns: Remove unused parameter named qp_type IB/hns: Simplify function of pd alloc and qp alloc IB/hns: Fix bug of using uninit refcount and free IB/hns: Remove parameters of resize cq IB/hns: Remove unused parameters in some functions IB/hns: Add node_guid definition to the bindings document ...
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull some more input subsystem updates from Dmitry Torokhov: "An update to the ALPS driver to support the V8 protocol with touchstick, a change for i8042 to skip selftest on many Asus laptops which helps to keep their touchpads working after resume, and a couple other driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: i8042 - skip selftest on ASUS laptops Input: melfas_mip4 - add ic_name sysfs attribute Input: melfas_mip4 - add maintainer information Input: melfas_mip4 - add devicetree binding documentations Input: elantech - add Fujitsu Lifebook E556 to force crc_enabled Input: synaptics-rmi4 - fix error handling in I2C transport driver Input: synaptics-rmi4 - fix error handling in SPI transport driver Input: ALPS - add V8 protocol documentation Input: ALPS - set DualPoint flag for 74 03 28 devices Input: ALPS - allow touchsticks to report pressure Input: ALPS - handle 0-pressure 1F events Input: ALPS - add touchstick support for SS5 hardware Input: elantech - force needed quirks on Fujitsu H760 Input: elantech - fix Lenovo version typo
2016-10-14Merge tag 'rtc-4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux Pull RTC updates from Alexandre Belloni: "RTC for 4.9 Subsystem: - delete owner assignment in multiple drivers - constify rtc_class_ops structures Drivers: - ac100: support clock-output-names - cmos: properly handle ACPI alarms and quirky BIOSes and other fixes - ds1307: fix century bit support while staying comaptible with previous behaviour by default - ds1347: switch to regmap - isl12057 is now handled by ds1307 - omap: support external wakeup - rv8803: allow to disable voltage drop detection" * tag 'rtc-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (25 commits) rtc: rv8803: set VDETOFF and SWOFF via device tree dt/bindings: Add bindings for Micro Crystal rv8803 devicetree: Add Micro Crystal AG vendor id rtc: cmos: avoid unused function warning rtc: ac100: Add NULL checking for devm_kzalloc call rtc: ds1347: changed raw spi calls to register map calls rtc: cmos: Restore alarm after resume rtc: cmos: Clear ACPI-driven alarms upon resume rtc: omap: Support ext_wakeup configuration rtc: cmos: Initialize hpet timer before irq is registered rtc: asm9260: rework locking rtc: asm9260: allow COMPILE_TEST rtc: constify rtc_class_ops structures rtc: ac100: support clock-output-names in device tree binding rtc: rx6110: remove owner assignment rtc: pic32: Delete owner assignment rtc: bq32k: Fix handling of oscillator failure flag rtc: bq32k: Use correct mask name for 'minutes' register. rtc: sysfs: fix a cast removing the const attribute Documentation: dt: Intersil isl12057 is not a trivial device ...
2016-10-14Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull more i2c updates from Wolfram Sang: "A small update pull request from I2C. This adds one comment to a change we did in this merge window to handle lockdep better, and pulls in a branch which should have been in 4.8 already improving DT support for I2C" * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: gpio: pca953x: add a comment explaining the need for a lockdep subclass i2c: core: Add support for 'i2c-bus' subnode dt-bindings: i2c: Add support for 'i2c-bus' subnode
2016-10-14Merge tag 'acpi-extra-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI updates from Rafael Wysocki: "This includes a couple of fixes needed after recent changes, two ACPI driver fixes (fan and "Processor Aggregator"), an update of the ACPI device properties handling code and a new MAINTAINERS entry for ACPI on ARM64. Specifics: - Fix an unused function warning that started to appear after recent changes in the ACPI EC driver (Eric Biggers). - Fix the KERN_CONT usage in acpi_os_vprintf() that has become (particularly) annoying recently (Joe Perches). - Fix the fan status checking in the ACPI fan driver to avoid returning incorrect error codes sometimes (Srinivas Pandruvada). - Fix the ACPI Processor Aggregator driver (PAD) to always let the special processor_aggregator driver from Xen take over when running as Xen dom0 (Juergen Gross). - Update the handling of reference device properties in ACPI by allowing empty rows ("holes") to appear in reference property lists (Mika Westerberg). - Add a new MAINTAINERS entry for ACPI on ARM64 (Lorenzo Pieralisi)" * tag 'acpi-extra-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: acpi_os_vprintf: Use printk_get_level() to avoid unnecessary KERN_CONT ACPI / PAD: don't register acpi_pad driver if running as Xen dom0 ACPI / property: Allow holes in reference properties MAINTAINERS: Add ARM64-specific ACPI maintainers entry ACPI / EC: Fix unused function warning when CONFIG_PM_SLEEP=n ACPI / fan: Fix error reading cur_state
2016-10-14Merge tag 'pm-extra-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more power management updates from Rafael Wysocki: "This includes a couple of fixes for cpufreq regressions introduced in 4.8, a rework of the intel_pstate algorithm used on Atom processors (that took some time to test) plus a fix and a couple of cleanups in that driver, a CPPC cpufreq driver fix, and a some devfreq fixes and cleanups (core and exynos-nocp). Specifics: - Fix two cpufreq regressions causing undesirable changes in behavior to appear (one in the core and one in the conservative governor) introduced during the 4.8 cycle (Aaro Koskinen, Rafael Wysocki). - Fix the way the intel_pstate driver accesses MSRs related to the hardware-managed P-states (HWP) feature during the initialization which currently is unsafe and may cause the processor to generate a general protection fault (Srinivas Pandruvada). - Rework the intel_pstate's P-state selection algorithm used on Atom processors to avoid known problems with the current one and to make the computation more straightforward, which also happens to improve performance in multiple benchmarks a bit (Rafael Wysocki). - Improve two comments in the intel_pstate driver (Rafael Wysocki). - Fix the desired performance computation in the CPPC cpufreq driver (Hoan Tran). - Fix the devfreq core to avoid printing misleading error messages in some cases (Tobias Jakobi). - Fix the error code path in devfreq_add_device() to use proper locking around list modifications (Axel Lin). - Fix a build failure and remove a couple of redundant updates of variables in the exynos-nocp devfreq driver (Axel Lin)" * tag 'pm-extra-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpufreq: CPPC: Correct desired_perf calculation cpufreq: conservative: Fix next frequency selection cpufreq: skip invalid entries when searching the frequency cpufreq: intel_pstate: Fix struct pstate_adjust_policy kerneldoc cpufreq: intel_pstate: Proportional algorithm for Atom PM / devfreq: Skip status update on uninitialized previous_freq PM / devfreq: Add proper locking around list_del() PM / devfreq: exynos-nocp: Remove redundant code PM / devfreq: exynos-nocp: Select REGMAP_MMIO cpufreq: intel_pstate: Clarify comment in get_target_pstate_use_performance() cpufreq: intel_pstate: Fix unsafe HWP MSR access
2016-10-14CIFS: Retrieve uid and gid from special sid if enabledSteve French
New mount option "idsfromsid" indicates to cifs.ko that it should try to retrieve the uid and gid owner fields from special sids. This patch adds the code to parse the owner sids in the ACL to see if they match, and if so populate the uid and/or gid from them. This is faster than upcalling for them and asking winbind, and is a fairly common case, and is also helpful when cifs.upcall and idmapping is not configured. Signed-off-by: Steve French <steve.french@primarydata.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2016-10-14CIFS: Add new mount option to set owner uid and gid from special sids in aclSteve French
Add "idsfromsid" mount option to indicate to cifs.ko that it should try to retrieve the uid and gid owner fields from special sids in the ACL if present. This first patch just adds the parsing for the mount option. Signed-off-by: Steve French <steve.french@primarydata.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2016-10-14Merge branch 'for-4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - tracepoints for basic cgroup management operations added - kernfs and cgroup path formatting functions updated to behave in the style of strlcpy() - non-critical bug fixes * 'for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: blkcg: Unlock blkcg_pol_mutex only once when cpd == NULL cgroup: fix error handling regressions in proc_cgroup_show() and cgroup_release_agent() cpuset: fix error handling regression in proc_cpuset_show() cgroup: add tracepoints for basic operations cgroup: make cgroup_path() and friends behave in the style of strlcpy() kernfs: remove kernfs_path_len() kernfs: make kernfs_path*() behave in the style of strlcpy() kernfs: add dummy implementation of kernfs_path_from_node()
2016-10-14qedr: Add events support and register IB deviceRam Amrani
Add error handling support. Register ib device with ib stack. Signed-off-by: Rajesh Borundia <rajesh.borundia@cavium.com> Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-10-14qedr: Add GSI supportRam Amrani
Add support for GSI over light L2. Signed-off-by: Rajesh Borundia <rajesh.borundia@cavium.com> Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-10-14qedr: Add LL2 RoCE interfaceRam Amrani
Add light L2 interface for RoCE. Signed-off-by: Rajesh Borundia <rajesh.borundia@cavium.com> Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-10-14qedr: Add support for data pathRam Amrani
Implement fastpath verbs like ib_send_post, ib_post_recv and ib_poll_cq. Signed-off-by: Rajesh Borundia <rajesh.borundia@cavium.com> Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-10-14qedr: Add support for memory registeration verbsRam Amrani
Add support for user, dma and memory regions registration. Signed-off-by: Rajesh Borundia <rajesh.borundia@cavium.com> Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-10-14qedr: Add support for QP verbsRam Amrani
Add support for Queue Pair verbs which adds, deletes, modifies and queries Queue Pairs. Signed-off-by: Rajesh Borundia <rajesh.borundia@cavium.com> Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-10-14qedr: Add support for PD,PKEY and CQ verbsRam Amrani
Add support for protection domain and completion queue verbs. Signed-off-by: Rajesh Borundia <rajesh.borundia@cavium.com> Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-10-14qedr: Add support for user context verbsRam Amrani
Add support for ucontext, query port, add and del gid verbs. Signed-off-by: Rajesh Borundia <rajesh.borundia@cavium.com> Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-10-14qedr: Add support for RoCE HW initRam Amrani
Allocate and setup RoCE resources, interrupts and completion queues. Adds device attributes. Signed-off-by: Rajesh Borundia <rajesh.borundia@cavium.com> Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-10-14qedr: Add RoCE driver frameworkRam Amrani
Adds a skeletal implementation of the qed* RoCE driver - basically the ability to communicate with the qede driver and receive notifications from it regarding various init/exit events. Signed-off-by: Rajesh Borundia <rajesh.borundia@cavium.com> Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu updates from Tejun Heo: - Nick improved generic implementations of percpu operations which modify the variable and return so that they calculate the physical address only once. - percpu_ref percpu <-> atomic mode switching improvements. The patchset was originally posted about a year ago but fell through the crack. - misc non-critical fixes. * 'for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: mm/percpu.c: fix potential memory leakage for pcpu_embed_first_chunk() mm/percpu.c: correct max_distance calculation for pcpu_embed_first_chunk() percpu: eliminate two sparse warnings percpu: improve generic percpu modify-return implementation percpu-refcount: init ->confirm_switch member properly percpu_ref: allow operation mode switching operations to be called concurrently percpu_ref: restructure operation mode switching percpu_ref: unify staggered atomic switching wait behavior percpu_ref: reorganize __percpu_ref_switch_to_atomic() and relocate percpu_ref_switch_to_atomic() percpu_ref: remove unnecessary RCU grace period for staggered atomic switching confirmation
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: - Write same support added - Minor ahci MSIX irq handling updates - Non-critical SCSI command translation fixes - Controller specific changes * 'for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ahci: qoriq: Revert "ahci: qoriq: Disable NCQ on ls2080a SoC" libata: remove <asm-generic/libata-portmap.h> libata: remove unused definitions from <asm/libata-portmap.h> pata_at91: Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR ata: Replace BUG() with BUG_ON(). ata: sata_mv: Replacing dma_pool_alloc and memset with a single call dma_pool_zalloc. libata: Some drives failing on SCT Write Same ahci: use pci_alloc_irq_vectors libata: SCT Write Same handle ATA_DFLAG_PIO libata: SCT Write Same / DSM Trim libata: Add support for SCT Write Same libata: Safely overwrite attached page in WRITE SAME xlat ahci: also use a per-port lock for the multi-MSIX case ARM: dts: STiH407-family: Add ports-implemented property in sata nodes ahci: st: Add ports-implemented property in support ahci: qoriq: enable snoopable sata read and write ahci: qoriq: adjust sata parameter libata-scsi: fix MODE SELECT translation for Control mode page libata-scsi: use u8 array to store mode page copy
2016-10-14Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull more SCSI updates from James Bottomley: "This is just a set of minor updates and fixes which weren't quite ready in time for the first pull request. The only real thing of note is Mike Christie is stepping down as Maintainer of iscsi to be replaced by Lee Duncan and Chris Leech" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: scsi: ufs: Kconfig fix scsi: g_NCR5380: Stop using scsi_module.c scsi: g_NCR5380: Reduce overrides[] from array to struct scsi: g_NCR5380: Remove deprecated __setup scsi: ufs: Fix error return code in ufshcd_init() scsi: ufs: Data Segment only needed for WRITE DESCRIPTOR scsi: cxgb4i: Set completion bit in work request MAINTAINERS: Update open-iscsi maintainers scsi: ufs: Enable no vccq quirk for skhynix device scsi: be2iscsi: mark symbols static where possible
2016-10-14pkeys: Remove easily triggered WARNDave Jones
This easy-to-trigger warning shows up instantly when running Trinity on a kernel with CONFIG_X86_INTEL_MEMORY_PROTECTION_KEYS disabled. At most this should have been a printk, but the -EINVAL alone should be more than adequate indicator that something isn't available. Signed-off-by: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-14Merge tag 'metag-for-v4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull metag architecture fix from James Hogan: "A simple build fix for irqsoff atomics which has started hitting meta1_defconfig during the 4.9 merge window" * tag 'metag-for-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag: Only define atomic_dec_if_positive conditionally
2016-10-14Merge tag 'powerpc-4.9-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull more powerpc updates from Michael Ellerman: "Some more powerpc updates for 4.9: Freescale updates from Scott Wood: - qbman support (a prerequisite for datapath drivers such as ethernet) - a PCI DMA fix+improvement - reset handler changes - more 8xx optimizations - some cleanups and fixes.' Fixes: - selftests/powerpc: Add missing binaries to .gitignores (Michael Ellerman) - selftests/powerpc: Fix build break caused by EXPORT_SYMBOL changes (Michael Ellerman) - powerpc/pseries: Fix stack corruption in htpe code (Laurent Dufour) - powerpc/64s: Fix power4_fixup_nap placement (Nicholas Piggin) - powerpc/64: Fix incorrect return value from __copy_tofrom_user (Paul Mackerras) - powerpc/mm/hash64: Fix might_have_hea() check (Michael Ellerman) Other: - MAINTAINERS: Remove myself from PA Semi entries (Olof Johansson) - MAINTAINERS: Drop separate pseries entry (Michael Ellerman) - MAINTAINERS: Update powerpc website & add selftests (Michael Ellerman): * tag 'powerpc-4.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (35 commits) powerpc/mm/hash64: Fix might_have_hea() check powerpc/64: Fix incorrect return value from __copy_tofrom_user powerpc/64s: Fix power4_fixup_nap placement powerpc/pseries: Fix stack corruption in htpe code selftests/powerpc: Fix build break caused by EXPORT_SYMBOL changes MAINTAINERS: Update powerpc website & add selftests MAINTAINERS: Drop separate pseries entry MAINTAINERS: Remove myself from PA Semi entries selftests/powerpc: Add missing binaries to .gitignores arch/powerpc: Add CONFIG_FSL_DPAA to corenetXX_smp_defconfig soc/qman: Add self-test for QMan driver soc/bman: Add self-test for BMan driver soc/fsl: Introduce DPAA 1.x QMan device driver soc/fsl: Introduce DPAA 1.x BMan device driver powerpc/8xx: make user addr DTLB miss the short path powerpc/8xx: Move additional DTLBMiss handlers out of exception area powerpc/8xx: use r3 to scratch CR in ITLBmiss soc/fsl/qe: fix gpio save_regs functions powerpc/8xx: add dedicated machine check handler powerpc/8xx: add system_reset_exception ...
2016-10-14MIPS: Wire up new pkey_{mprotect,alloc,free} syscallsRalf Baechle
Signed-off-by: Marcin Nowakowski <marcin.nowakowski@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/14380/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-14Merge branches 'acpi-fan', 'acpi-ec', 'acpi-drivers' and 'acpi-osl'Rafael J. Wysocki
* acpi-fan: ACPI / fan: Fix error reading cur_state * acpi-ec: ACPI / EC: Fix unused function warning when CONFIG_PM_SLEEP=n * acpi-drivers: ACPI / PAD: don't register acpi_pad driver if running as Xen dom0 * acpi-osl: acpi_os_vprintf: Use printk_get_level() to avoid unnecessary KERN_CONT
2016-10-14Merge branches 'device-properties' and 'acpi-misc'Rafael J. Wysocki
* device-properties: ACPI / property: Allow holes in reference properties * acpi-misc: MAINTAINERS: Add ARM64-specific ACPI maintainers entry
2016-10-14Merge branches 'pm-cpufreq' and 'pm-devfreq'Rafael J. Wysocki
* pm-cpufreq: cpufreq: CPPC: Correct desired_perf calculation cpufreq: conservative: Fix next frequency selection cpufreq: skip invalid entries when searching the frequency cpufreq: intel_pstate: Fix struct pstate_adjust_policy kerneldoc cpufreq: intel_pstate: Proportional algorithm for Atom cpufreq: intel_pstate: Clarify comment in get_target_pstate_use_performance() cpufreq: intel_pstate: Fix unsafe HWP MSR access * pm-devfreq: PM / devfreq: Skip status update on uninitialized previous_freq PM / devfreq: Add proper locking around list_del() PM / devfreq: exynos-nocp: Remove redundant code PM / devfreq: exynos-nocp: Select REGMAP_MMIO
