2013-09-07Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Nothing major for this kernel, just maintenance updates" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (21 commits) apparmor: add the ability to report a sha1 hash of loaded policy apparmor: export set of capabilities supported by the apparmor module apparmor: add the profile introspection file to interface apparmor: add an optional profile attachment string for profiles apparmor: add interface files for profiles and namespaces apparmor: allow setting any profile into the unconfined state apparmor: make free_profile available outside of policy.c apparmor: rework namespace free path apparmor: update how unconfined is handled apparmor: change how profile replacement update is done apparmor: convert profile lists to RCU based locking apparmor: provide base for multiple profiles to be replaced at once apparmor: add a features/policy dir to interface apparmor: enable users to query whether apparmor is enabled apparmor: remove minimum size check for vmalloc() Smack: parse multiple rules per write to load2, up to PAGE_SIZE-1 bytes Smack: network label match fix security: smack: add a hash table to quicken smk_find_entry() security: smack: fix memleak in smk_write_rules_list() xattr: Constify ->name member of "struct xattr". ...
2013-09-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 3.12: - Added MODULE_SOFTDEP to allow pre-loading of modules. - Reinstated crct10dif driver using the module softdep feature. - Allow via rng driver to be auto-loaded. - Split large input data when necessary in nx. - Handle zero length messages correctly for GCM/XCBC in nx. - Handle SHA-2 chunks bigger than block size properly in nx. - Handle unaligned lengths in omap-aes. - Added SHA384/SHA512 to omap-sham. - Added OMAP5/AM43XX SHAM support. - Added OMAP4 TRNG support. - Misc fixes" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (66 commits) Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework" hwrng: via - Add MODULE_DEVICE_TABLE crypto: fcrypt - Fix bitoperation for compilation with clang crypto: nx - fix SHA-2 for chunks bigger than block size crypto: nx - fix GCM for zero length messages crypto: nx - fix XCBC for zero length messages crypto: nx - fix limits to sg lists for AES-CCM crypto: nx - fix limits to sg lists for AES-XCBC crypto: nx - fix limits to sg lists for AES-GCM crypto: nx - fix limits to sg lists for AES-CTR crypto: nx - fix limits to sg lists for AES-CBC crypto: nx - fix limits to sg lists for AES-ECB crypto: nx - add offset to nx_build_sg_lists() padata - Register hotcpu notifier after initialization padata - share code between CPU_ONLINE and CPU_DOWN_FAILED, same to CPU_DOWN_PREPARE and CPU_UP_CANCELED hwrng: omap - reorder OMAP TRNG driver code crypto: omap-sham - correct dma burst size crypto: omap-sham - Enable Polling mode if DMA fails crypto: tegra-aes - bitwise vs logical and crypto: sahara - checking the wrong variable ...
2013-09-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A quick set of fixes, some to deal with fallout from yesterday's net-next merge. 1) Fix compilation of bnx2x driver with CONFIG_BNX2X_SRIOV disabled, from Dmitry Kravkov. 2) Fix a bnx2x regression caused by one of Dave Jones's mistaken braces changes, from Eilon Greenstein. 3) Add some protective filtering in the netlink tap code, from Daniel Borkmann. 4) Fix TCP congestion window growth regression after timeouts, from Yuchung Cheng. 5) Correctly adjust TCP's rcv_ssthresh for out of order packets, from Eric Dumazet" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: tcp: properly increase rcv_ssthresh for ofo packets net: add documentation for BQL helpers mlx5: remove unused MLX5_DEBUG param in Kconfig bnx2x: Restore a call to config_init bnx2x: fix broken compilation with CONFIG_BNX2X_SRIOV is not set tcp: fix no cwnd growth after timeout net: netlink: filter particular protocols from analyzers
2013-09-07Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging Pull hwmon fixes from Jean Delvare. * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (emc6w201) Do not declare enum variable hwmon: (w83792d) Update module author
2013-09-07Merge tag 'gpio-v3.12-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for the v3.12 series: - A new driver for the TZ1090 PDC which is used on the metag architecture. - A new driver for the Kontron ETX or COMexpress GPIO block. This is found on some ETX x86 devices. - A new driver for the Fintek Super-I/O chips, used on some x86 boards. - Added device tree probing on a few select GPIO blocks. - Drop the Exynos support from the Samsung GPIO driver. The Samsung maintainers have moved over to use the modernized pin control driver to provide GPIO for the modern platforms instead. - The usual bunch of non-critical fixes and cleanups" * tag 'gpio-v3.12-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (36 commits) gpio: return -ENOTSUPP if debounce cannot be set gpio: improve error path in gpiolib gpio: add GPIO support for F71882FG and F71889F of: add vendor prefix for Microchip Technology Inc gpio: mcp23s08: rename the device tree property gpio: samsung: Drop support for Exynos SoCs gpio: pcf857x: Remove pdata argument to pcf857x_irq_domain_init() gpio: pcf857x: Sort headers alphabetically gpio: max7301: Reverting "Do not force SPI speed when using OF Platform" gpio: Fix bit masking in Kontron PLD GPIO driver gpio: pca953x: fix gpio input on gpio offsets >= 8 drivers/gpio: simplify use of devm_ioremap_resource drivers/gpio/gpio-omap.c: convert comma to semicolon gpio-lynxpoint: Fix warning about unbalanced pm_runtime_enable gpio: Fix platform driver name in Kontron PLD GPIO driver gpio: adnp: Fix segfault if request_threaded_irq fails gpio: msm: Staticize local variable 'msm_gpio' gpio: gpiolib-of.c: make error message more meaningful by adding the node name and index gpio: use dev_get_platdata() gpio/mxc: add chained_irq_enter/exit() to mx2_gpio_irq_handler ...
2013-09-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "A new driver for slidebar on Ideapad laptops and a bunch of assorted driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (32 commits) Input: add SYN_MAX and SYN_CNT constants Input: max11801_ts - convert to devm Input: egalax-ts - fix typo and improve text Input: MAINTAINERS - change maintainer for cyttsp driver Input: cyttsp4 - kill 'defined but not used' compiler warnings Input: add driver for slidebar on Lenovo IdeaPad laptops Input: omap-keypad - set up irq type from DT Input: omap-keypad - enable wakeup capability for keypad. Input: omap-keypad - clear interrupts on open Input: omap-keypad - convert to threaded IRQ Input: omap-keypad - use bitfiled instead of hardcoded values Input: cyttsp4 - remove useless NULL test from cyttsp4_watchdog_timer() Input: wacom - fix error return code in wacom_probe() Input: as5011 - fix error return code in as5011_probe() Input: keyboard, serio - simplify use of devm_ioremap_resource Input: tegra-kbc - simplify use of devm_ioremap_resource Input: htcpen - fix incorrect placement of __initdata Input: qt1070 - add power management ops Input: wistron_btns - add MODULE_DEVICE_TABLE Input: wistron_btns - mark the Medion MD96500 keymap as tested ...
2013-09-07Revert "Input: introduce BTN/ABS bits for drums and guitars"Linus Torvalds
This reverts commits 61e00655e9cb, 73f8645db191 and 8e22ecb603c8: "Input: introduce BTN/ABS bits for drums and guitars" "HID: wiimote: add support for Guitar-Hero drums" "HID: wiimote: add support for Guitar-Hero guitars" The extra new ABS_xx values resulted in ABS_MAX no longer being a power-of-two, which broke the comparison logic. It also caused the ioctl numbers to overflow into the next byte, causing problems for that. We'll try again for 3.13. Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-06Merge branch 'next' into for-linusDmitry Torokhov
Merge first round of changes for 3.12 merge window.
2013-09-07Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This patch reinstates commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Now that module softdeps are in the kernel we can use that to resolve the boot issue which cause the revert. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-09-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linuxHerbert Xu
Merge upstream tree in order to reinstate crct10dif.
2013-09-06Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board updates from Olof Johansson: "Board updates for 3.12. Again, a bit of domain overlap with SoC and DT branches, but most of this is around legacy code and board support. We've found that platform maintainers have a hard time separating all of these out and might move towards fewer branches for next release. - Removal of a number of Marvell Kirkwood board files, since contents is now common and mostly configured via DT. - Device-tree updates for Marvell Dove, including irqchip and clocksource setup. - Defconfig updates. Gotta go somewhere. One new one for Renesas Lager. - New backlight drivers for backlights used on Renesas shmobile platforms. - Removal of Renesas leds driver. - Shuffling of some of the new Broadcom platforms to give room for others in the same mach directory. More in 3.13" * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion ARM: bcm: Make secure API call optional ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers) ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona ARM: bcm: Rename board_bcm mmc: sdhci-bcm-kona: make linker-section warning go away ARM: tegra: defconfig updates ARM: dove: add initial DT file for Globalscale D2Plug ARM: dove: add GPIO IR receiver node to SolidRun CuBox ARM: dove: add common pinmux functions to DT ARM: dove: add cpu device tree node ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument ARM: kirkwood: fix DT building and update defconfig ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code ARM: configs: disable DEBUG_LL in bcm_defconfig ARM: bcm281xx: Board specific reboot code ARM bcm281xx: Turn on socket & network support. ARM: bcm281xx: Turn on L2 cache. ...
2013-09-06Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This branch contains mostly additions and changes to platform enablement and SoC-level drivers. Since there's sometimes a dependency on device-tree changes, there's also a fair amount of those in this branch. Pieces worth mentioning are: - Mbus driver for Marvell platforms, allowing kernel configuration and resource allocation of on-chip peripherals. - Enablement of the mbus infrastructure from Marvell PCI-e drivers. - Preparation of MSI support for Marvell platforms. - Addition of new PCI-e host controller driver for Tegra platforms - Some churn caused by sharing of macro names between i.MX 6Q and 6DL platforms in the device tree sources and header files. - Various suspend/PM updates for Tegra, including LP1 support. - Versatile Express support for MCPM, part of big little support. - Allwinner platform support for A20 and A31 SoCs (dual and quad Cortex-A7) - OMAP2+ support for DRA7, a new Cortex-A15-based SoC. The code that touches other architectures are patches moving MSI arch-specific functions over to weak symbols and removal of ARCH_SUPPORTS_MSI, acked by PCI maintainers" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (266 commits) tegra-cpuidle: provide stub when !CONFIG_CPU_IDLE PCI: tegra: replace devm_request_and_ioremap by devm_ioremap_resource ARM: tegra: Drop ARCH_SUPPORTS_MSI and sort list ARM: dts: vf610-twr: enable i2c0 device ARM: dts: i.MX51: Add one more I2C2 pinmux entry ARM: dts: i.MX51: Move pins configuration under "iomuxc" label ARM: dtsi: imx6qdl-sabresd: Add USB OTG vbus pin to pinctrl_hog ARM: dtsi: imx6qdl-sabresd: Add USB host 1 VBUS regulator ARM: dts: imx27-phytec-phycore-som: Enable AUDMUX ARM: dts: i.MX27: Disable AUDMUX in the template ARM: dts: wandboard: Add support for SDIO bcm4329 ARM: i.MX5 clocks: Remove optional clock setup (CKIH1) from i.MX51 template ARM: dts: imx53-qsb: Make USBH1 functional ARM i.MX6Q: dts: Enable I2C1 with EEPROM and PMIC on Phytec phyFLEX-i.MX6 Ouad module ARM i.MX6Q: dts: Enable SPI NOR flash on Phytec phyFLEX-i.MX6 Ouad module ARM: dts: imx6qdl-sabresd: Add touchscreen support ARM: imx: add ocram clock for imx53 ARM: dts: imx: ocram size is different between imx6q and imx6dl ARM: dts: imx27-phytec-phycore-som: Fix regulator settings ARM: dts: i.MX27: Remove clock name from CPU node ...
2013-09-06Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "Device tree and bindings updates for 3.12. General additions of various on-chip and on-board peripherals on various platforms as support gets added. Some of the bigger changes are: - Addition of (new) PCI-e support on Tegra. - More Tegra4 support, including PMC configuration for Dalmore. - Addition of a new board for Exynos4 (trats2) and more bindings for 4x12 IP. - Addition of Allwinner A20 and A31 SoC and board files. - Move of the ST Ericsson device tree files to now use ste-* prefix. - More move of hardware description of shmobile platforms to DT. - Two new board dts files for Freescale MXs" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (177 commits) dts: Rename DW APB timer compatible strings dts: Deprecate ALTR as a vendor prefix of: add vendor prefix for Altera Corp. ARM: at91/dt: sam9x5ek: add sound configuration ARM: at91/dt: sam9x5ek: enable SSC ARM: at91/dt: sam9x5ek: add WM8731 codec ARM: at91/dt: sam9x5: add SSC DMA parameters ARM: at91/dt: add at91rm9200 PQFP package version ARM: at91: at91rm9200: set default mmc0 pinctrl-names ARM: at91: at91sam9n12: correct pin number of gpio-key ARM: at91: at91sam9n12: add qt1070 support ARM: at91: at91sam9n12: add pinctrl of TWI ARM: at91: Add PMU support for sama5d3 ARM: at91: at91sam9260: add missing pinctrl-names on mmc ARM: tegra: configure power off for Dalmore ARM: DT: binding fixup to align with vendor-prefixes.txt (DT) ARM: dts: add sdio blocks to bcm28155-ap board ARM: dts: align sdio numbers to HW definition ARM: sun7i: Add Olimex A20-Olinuxino-Micro support ARM: sun7i: Add Allwinner A20 DTSI ...
2013-09-06Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This branch contains code cleanups, moves and removals for 3.12. There's a large number of various cleanups, and a nice net removal of 13500 lines of code. Highlights worth mentioning are: - A series of patches from Stephen Boyd removing the ARM local timer API. - Move of Qualcomm MSM IOMMU code to drivers/iommu. - Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM driver and switching over to the drivers/pwm one. - Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM). There's also a move of a header file out of include/linux/i2c/ to platform_data, where it really belongs. It touches mostly ARM platform code for include changes so we took it through our tree" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits) ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK gpio: (gpio-pca953x) move header to linux/platform_data/ arm: zynq: hotplug: Remove unreachable code ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*() tegra: simplify use of devm_ioremap_resource ARM: SAMSUNG: Remove plat/regs-timer.h header ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header ARM: SAMSUNG: Remove pwm-clock infrastructure ARM: SAMSUNG: Remove old PWM timer platform devices pwm: Remove superseded pwm-samsung-legacy driver ARM: SAMSUNG: Modify board files to use new PWM platform device ARM: SAMSUNG: Rework private data handling in dev-backlight pwm: Add new pwm-samsung driver ARM: mach-mvebu: remove redundant DT parsing and validation ARM: msm: Only compile io.c on platforms that use it iommu/msm: Move mach includes to iommu directory ARM: msm: Remove devices-iommu.c ARM: msm: Move mach/board.h contents to common.h ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE ARM: msm: Remove TMR and TMR0 static mappings ...
2013-09-06Merge tag 'fixes-nc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC low-priority fixes from Olof Johansson: "This branch contains a handful of fixes for various platforms that weren't serious enough to be included in late 3.11-rc releases. Most of them are for minor cleanups and cosmetic fixes. There's also a bit of code removal here, one board file removal for clps711x, and removal of some legacy device creation on OMAP2+" * tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (25 commits) ARM: OMAP2: use 'int' instead of 'unsigned' for variable 'gpmc_irq_start' ARM: OMAP2: remove useless variable 'ret' ARM: OMAP: dma: fix error return code in omap_system_dma_probe() ARM: OMAP2+: fix wrong address when loading PRM_FRAC_INCREMENTOR_DENUMERATOR_RELOAD ARM: OMAP2+: am33xx-restart: trigger warm reset on omap2+ boards ARM: OMAP2: Use a consistent AM33XX SoC option description ARM: OMAP2+: Remove legacy device creation for McPDM and DMIC ARM: clps711x: edb7211: Remove extra iotable_init() call ARM: clps711x: autcpu12: Remove incorrect config checking ARM: clps711x: Drop fortunet board support ARM: clps711x: Remove the special name for the syscon driver ARM: dts: Fix memory node in skeleton64.dtsi ARM: Keystone: Convert device tree file to use IRQ defines ARM: keystone: use #include to include skeleton.dtsi ARM: keystone: Drop the un-necessary dsb from keystone_cpu_smc() ARM: Keystone: No need to preserve r12 across smc call ARM: keystone: remove redundant smp_init_cpus definition ARM: keystone: drop useless HAVE_SCHED_CLOCK ARM: dove: fix missing __init section of dove_mpp_gpio_mode ARM: shmobile: armadillo800eva-reference: fix compiler warning ...
2013-09-06Merge tag 'please-pull-misc-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull ia64 fixes from Tony Luck: "Couple of small cleanups for ia64" * tag 'please-pull-misc-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: [IA64] Use asm-generic/bitops/builtin-ffs.h [IA64] dmi.h: Make dmi_alloc use kzalloc
2013-09-06tcp: properly increase rcv_ssthresh for ofo packetsEric Dumazet
TCP receive window handling is multi staged. A socket has a memory budget, static or dynamic, in sk_rcvbuf. Because we do not really know how this memory budget translates to a TCP window (payload), TCP announces a small initial window (about 20 MSS). When a packet is received, we increase TCP rcv_win depending on the payload/truesize ratio of this packet. Good citizen packets give a hint that it's reasonable to have rcv_win = sk_rcvbuf/2 This heuristic takes place in tcp_grow_window() Problem is : We currently call tcp_grow_window() only for in-order packets. This means that reorders or packet losses stop proper grow of rcv_win, and senders are unable to benefit from fast recovery, or proper reordering level detection. Really, a packet being stored in OFO queue is not a bad citizen. It should be part of the game as in-order packets. In our traces, we very often see sender is limited by linux small receive windows, even if linux hosts use autotuning (DRS) and should allow rcv_win to grow to ~3MB. Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-06net: add documentation for BQL helpersFlorian Fainelli
Provide a kernel-doc comment documentation for the BQL helpers: - netdev_sent_queue - netdev_completed_queue - netdev_reset_queue Similarly to how it is done for the other functions, the documentation only covers the function operating on struct net_device and not struct netdev_queue. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-06mlx5: remove unused MLX5_DEBUG param in KconfigMichael Opdenacker
This patch proposes to remove the MLX5_DEBUG kernel configuration parameter defined in drivers/net/ethernet/mellanox/mlx5/core/Kconfig, but used nowhere in the makefiles and source code. This could also be fixed by using this parameter, but this may be a leftover from driver development... Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-06bnx2x: Restore a call to config_initEilon Greenstein
Commit c0a77ec74f295013d7ba3204dd3ed25fccf83cb4 'bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize' identified indentation problem, but resolved it by adding braces instead of fixing the indentation. The braces now prevents a config_init call in some cases, though it should be called regardless of that condition. This patch removes the braces and fix the confusing indentation that caused this mess. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> CC: Dave Jones <davej@redhat.com> Tested-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-06bnx2x: fix broken compilation with CONFIG_BNX2X_SRIOV is not setDmitry Kravkov
Since commit 60cad4e67bd6ff400e7ea61fe762b3042b12ae9d "bnx2x: VF RSS support - VF side" fails to compile w/o CONFIG_BNX2X_SRIOV option. Reported-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Ariel Elior <ariele@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-06tcp: fix no cwnd growth after timeoutYuchung Cheng
In commit 0f7cc9a3 "tcp: increase throughput when reordering is high", it only allows cwnd to increase in Open state. This mistakenly disables slow start after timeout (CA_Loss). Moreover cwnd won't grow if the state moves from Disorder to Open later in tcp_fastretrans_alert(). Therefore the correct logic should be to allow cwnd to grow as long as the data is received in order in Open, Loss, or even Disorder state. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-06net: netlink: filter particular protocols from analyzersDaniel Borkmann
Fix finer-grained control and let only a whitelist of allowed netlink protocols pass, in our case related to networking. If later on, other subsystems decide they want to add their protocol as well to the list of allowed protocols they shall simply add it. While at it, we also need to tell what protocol is in use otherwise BPF_S_ANC_PROTOCOL can not pick it up (as it's not filled out). Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull Tile arch updates from Chris Metcalf: "These changes bring in a bunch of new functionality that has been maintained internally at Tilera over the last year, plus other stray bits of work that I've taken into the tile tree from other folks. The changes include some PCI root complex work, interrupt-driven console support, support for performing fast-path unaligned data fixups by kernel-based JIT code generation, CONFIG_PREEMPT support, vDSO support for gettimeofday(), a serial driver for the tilegx on-chip UART, KGDB support, more optimized string routines, support for ftrace and kprobes, improved ASLR, and many bug fixes. We also remove support for the old TILE64 chip, which is no longer buildable" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (85 commits) tile: refresh tile defconfig files tile: rework <asm/cmpxchg.h> tile PCI RC: make default consistent DMA mask 32-bit tile: add null check for kzalloc in tile/kernel/setup.c tile: make __write_once a synonym for __read_mostly tile: remove support for TILE64 tile: use asm-generic/bitops/builtin-*.h tile: eliminate no-op "noatomichash" boot argument tile: use standard tile_bundle_bits type in traps.c tile: simplify code referencing hypervisor API addresses tile: change <asm/system.h> to <asm/switch_to.h> in comments tile: mark pcibios_init() as __init tile: check for correct compiler earlier in asm-offsets.c tile: use standard 'generic-y' model for <asm/hw_irq.h> tile: use asm-generic version of <asm/local64.h> tile PCI RC: add comment about "PCI hole" problem tile: remove DEBUG_EXTRA_FLAGS kernel config option tile: add virt_to_kpte() API and clean up and document behavior tile: support FRAME_POINTER tile: support reporting Tilera hypervisor statistics ...
2013-09-06Merge tag 'arm64-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull ARM64 update from Catalin Marinas: - User tagged pointers support (top 8-bit of user pointers automatically ignored by the CPU). - Kernel mode NEON (no users for arm64 yet but work in progress). - arm64 kernel Image header extended to accommodate future EFI stub. - Remove BogoMIPS reporting (not relevant, it's just the timer frequency). - Clean-up (EM_AARCH64/EM_ARM to elf-em.h, ELF notes in read-only segment, unused variable). - Bug-fixes (RAM boundaries not 2MB aligned, perf, includes). * tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: Documentation/arm64: clarify requirements for DTB placement arm64: mm: permit use of tagged pointers at EL0 Move the EM_ARM and EM_AARCH64 definitions to uapi/linux/elf-em.h arm64: Remove unused cpu_name ascii in arch/arm64/mm/proc.S arm64: delay: don't bother reporting bogomips in /proc/cpuinfo arm64: Fix mapping of memory banks not ending on a PMD_SIZE boundary arm64: move elf notes into readonly segment arm64: Enable interrupts in the EL0 undef handler arm64: Expand arm64 image header ARM64: include: asm: include "asm/types.h" in "pgtable-2level-types.h" and "pgtable-3level-types.h" arm64: add support for kernel mode NEON arm64: perf: fix ARMv8 EVTYPE_MASK to include NSH bit arm64: perf: fix group validation when using enable_on_exec
2013-09-06Merge tag 'microblaze-3.12-rc1' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
Pull Microblaze patches from Michal Simek: - PCI fixes - Selfmod code removing - Intc and timer fixes - Adding new MB versions - Minor fixes * tag 'microblaze-3.12-rc1' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Show message when reset gpio is not present microblaze: Add linux.bin.ub target microblaze: Add PVR version string for MB v9.0 and v9.1 microblaze: timer: Replace microblaze_ prefix by xilinx_ microblaze: timer: Update header microblaze: timer: Remove unused header microblaze: timer: Clear driver init function microblaze: timer: Use CLKSRC_OF initialization microblaze: intc: Remove unused header microblaze: intc: Clean driver init function microblaze: intc: Using irqchip microblaze: intc: Update header microblaze: intc: Remove unused headers microblaze: Remove selfmodified feature of/pci: Use of_pci_range_parser
2013-09-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "Here's the powerpc batch for this merge window. Some of the highlights are: - A bunch of endian fixes ! We don't have full LE support yet in that release but this contains a lot of fixes all over arch/powerpc to use the proper accessors, call the firmware with the right endian mode, etc... - A few updates to our "powernv" platform (non-virtualized, the one to run KVM on), among other, support for bridging the P8 LPC bus for UARTs, support and some EEH fixes. - Some mpc51xx clock API cleanups in preparation for a clock API overhaul - A pile of cleanups of our old math emulation code, including better support for using it to emulate optional FP instructions on embedded chips that otherwise have a HW FPU. - Some infrastructure in selftest, for powerpc now, but could be generalized, initially used by some tests for our perf instruction counting code. - A pile of fixes for hotplug on pseries (that was seriously bitrotting) - The usual slew of freescale embedded updates, new boards, 64-bit hiberation support, e6500 core PMU support, etc..." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (146 commits) powerpc: Correct FSCR bit definitions powerpc/xmon: Fix printing of set of CPUs in xmon powerpc/pseries: Move lparcfg.c to platforms/pseries powerpc/powernv: Return secondary CPUs to firmware on kexec powerpc/btext: Fix CONFIG_PPC_EARLY_DEBUG_BOOTX on ppc32 powerpc: Cleanup handling of the DSCR bit in the FSCR register powerpc/pseries: Child nodes are not detached by dlpar_detach_node powerpc/pseries: Add mising of_node_put in delete_dt_node powerpc/pseries: Make dlpar_configure_connector parent node aware powerpc/pseries: Do all node initialization in dlpar_parse_cc_node powerpc/pseries: Fix parsing of initial node path in update_dt_node powerpc/pseries: Pack update_props_workarea to map correctly to rtas buffer header powerpc/pseries: Fix over writing of rtas return code in update_dt_node powerpc/pseries: Fix creation of loop in device node property list powerpc: Skip emulating & leave interrupts off for kernel program checks powerpc: Add more exception trampolines for hypervisor exceptions powerpc: Fix location and rename exception trampolines powerpc: Add more trap names to xmon powerpc/pseries: Add a warning in the case of cross-cpu VPA registration powerpc: Update the 00-Index in Documentation/powerpc ...
2013-09-06tile: refresh tile defconfig filesChris Metcalf
These are based on the current shipping versions of the config files from Tilera, as synced up to the tip, so are a better starting point for folks who want a default configuration. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-09-06tile: rework <asm/cmpxchg.h>Chris Metcalf
The macrology in cmpxchg.h was designed to allow arbitrary pointer and integer values to be passed through the routines. To support cmpxchg() on 64-bit values on the 32-bit tilepro architecture, we used the idiom "(typeof(val))(typeof(val-val))". This way, in the "size 8" branch of the switch, when the underlying cmpxchg routine returns a 64-bit quantity, we cast it first to a typeof(val-val) quantity (i.e. size_t if "val" is a pointer) with no warnings about casting between pointers and integers of different sizes, then cast onwards to typeof(val), again with no warnings. If val is not a pointer type, the additional cast is a no-op. We can't replace the typeof(val-val) cast with (for example) unsigned long, since then if "val" is really a 64-bit type, we cast away the high bits. HOWEVER, this fails with current gcc (through 4.7 at least) if "val" is a pointer to an incomplete type. Unfortunately gcc isn't smart enough to realize that "val - val" will always be a size_t type even if it's an incomplete type pointer. Accordingly, I've reworked the way we handle the casting. We have given up the ability to use cmpxchg() on 64-bit values on tilepro, which is OK in the kernel since we should use cmpxchg64() explicitly on such values anyway. As a result, I can just use simple "unsigned long" casts internally. As I reworked it, I realized it would be cleaner to move the architecture-specific conditionals for cmpxchg and xchg out of the atomic.h headers and into cmpxchg, and then use the cmpxchg() and xchg() primitives directly in atomic.h and elsewhere. This allowed the cmpxchg.h header to stand on its own without relying on the implicit include of it that is performed by <asm/atomic.h>. It also allowed collapsing the atomic_xchg/atomic_cmpxchg routines from atomic_{32,64}.h into atomic.h. I improved the tests that guard the allowed size of the arguments to the routines to use a __compiletime_error() test. (By avoiding the use of BUILD_BUG, I could include cmpxchg.h into bitops.h as well and use the macros there, which is otherwise impossible due to include order dependency issues.) The tilepro _atomic_xxx internal methods were previously set up to take atomic_t and atomic64_t arguments, which isn't as convenient with the new model, so I modified them to take int or u64 arguments, which is consistent with how they used the arguments internally anyway, so provided some nice simplification there too. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "The usual trivial updates all over the tree -- mostly typo fixes and documentation updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits) doc: Documentation/cputopology.txt fix typo treewide: Convert retrun typos to return Fix comment typo for init_cma_reserved_pageblock Documentation/trace: Correcting and extending tracepoint documentation mm/hotplug: fix a typo in Documentation/memory-hotplug.txt power: Documentation: Update s2ram link doc: fix a typo in Documentation/00-INDEX Documentation/printk-formats.txt: No casts needed for u64/s64 doc: Fix typo "is is" in Documentations treewide: Fix printks with 0x%# zram: doc fixes Documentation/kmemcheck: update kmemcheck documentation doc: documentation/hwspinlock.txt fix typo PM / Hibernate: add section for resume options doc: filesystems : Fix typo in Documentations/filesystems scsi/megaraid fixed several typos in comments ppc: init_32: Fix error typo "CONFIG_START_KERNEL" treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks page_isolation: Fix a comment typo in test_pages_isolated() doc: fix a typo about irq affinity ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: "Highlights: - conversion of HID subsystem to use devm-based resource management, from Benjamin Tissoires - i2c-hid support for DT bindings, from Benjamin Tissoires - much improved support for Win8-multitouch devices, from Benjamin Tissoires - cleanup of core code using common hidinput_input_event(), from David Herrmann - fix for bug in implement() access to the bit stream (causing oops) that has been present in the code for ages, but devices that are able to trigger it have started to appear only now, from Jiri Kosina - fixes for CVE-2013-2899, CVE-2013-2898, CVE-2013-2896, CVE-2013-2892, CVE-2013-2888 (all triggerable only by specially crafted malicious HW devices plugged into the system), from Kees Cook - hidraw oops fix, from Manoj Chourasia - various smaller fixes here and there, support for a bunch of new devices by various contributors" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (53 commits) HID: MAINTAINERS: add roccat drivers HID: hid-sensor-hub: change kmalloc + memcpy by kmemdup HID: hid-sensor-hub: move to devm_kzalloc HID: hid-sensor-hub: fix indentation accross the code HID: move HID_REPORT_TYPES closer to the report-definitions HID: check for NULL field when setting values HID: picolcd_core: validate output report details HID: sensor-hub: validate feature report details HID: ntrig: validate feature report details HID: pantherlord: validate output report details HID: hid-wiimote: print small buffers via %*phC HID: uhid: improve uhid example client HID: Correct the USB IDs for the new Macbook Air 6 HID: wiimote: add support for Guitar-Hero guitars HID: wiimote: add support for Guitar-Hero drums Input: introduce BTN/ABS bits for drums and guitars HID: battery: don't do DMA from stack HID: roccat: add support for KonePureOptical v2 HID: picolcd: Prevent NULL pointer dereference on _remove() HID: usbhid: quirk for N-Trig DuoSense Touch Screen ...
2013-09-06Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext3, reiserfs, udf & isofs fixes from Jan Kara: "The contains a bunch of ext3 cleanups and minor improvements, major reiserfs locking changes which should hopefully fix deadlocks introduced by BKL removal, and udf/isofs changes to refuse mounting fs rw instead of mounting it ro automatically which makes eject button work as expected for all media (see the changelog for why userspace should be ok with this change)" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: jbd: use a single printk for jbd_debug() reiserfs: locking, release lock around quota operations reiserfs: locking, handle nested locks properly reiserfs: locking, push write lock out of xattr code jbd: relocate assert after state lock in journal_commit_transaction() udf: Refuse RW mount of the filesystem instead of making it RO udf: Standardize return values in mount sequence isofs: Refuse RW mount of the filesystem instead of making it RO ext3: allow specifying external journal by pathname mount option jbd: remove unneeded semicolon
2013-09-06Merge tag 'for-f2fs-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs updates from Jaegeuk Kim: "This patch-set includes the following major enhancement patches: - support inline xattrs - add sysfs support to control GCs explicitly - add proc entry to show the current segment usage information - improve the GC/SSR performance The other bug fixes are as follows: - avoid the overflow on status calculation - fix some error handling routines - fix inconsistent xattr states after power-off-recovery - fix incorrect xattr node offset definition - fix deadlock condition in fsync - fix the fdatasync routine for power-off-recovery" * tag 'for-f2fs-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (40 commits) f2fs: optimize gc for better performance f2fs: merge more bios of node block writes f2fs: avoid an overflow during utilization calculation f2fs: trigger GC when there are prefree segments f2fs: use strncasecmp() simplify the string comparison f2fs: fix omitting to update inode page f2fs: support the inline xattrs f2fs: add the truncate_xattr_node function f2fs: introduce __find_xattr for readability f2fs: reserve the xattr space dynamically f2fs: add flags for inline xattrs f2fs: fix error return code in init_f2fs_fs() f2fs: fix wrong BUG_ON condition f2fs: fix memory leak when init f2fs filesystem fail f2fs: fix a compound statement label error f2fs: avoid writing inode redundantly when creating a file f2fs: alloc_page() doesn't return an ERR_PTR f2fs: should cover i_xattr_nid with its xattr node page lock f2fs: check the free space first in new_node_page f2fs: clean up the needless end 'return' of void function ...
2013-09-06hwmon: (emc6w201) Do not declare enum variableGuenter Roeck
Fix the following smatch warning: emc6w201.c:52:26: warning: symbol 'subfeature' was not declared. Should it be static? 'enum { } subtype' declares an enum as (global) variable which we don't want. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2013-09-06hwmon: (w83792d) Update module authorShane Huang
w83792d was written by me in 2004, I'd like to update my first name into my current one to keep consistent, and delete invalid address. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2013-09-06Merge branch 'for-3.12/sensor-hub' into for-linusJiri Kosina
Conflicts: drivers/hid/hid-sensor-hub.c
2013-09-06Merge branches 'for-3.12/devm', 'for-3.12/i2c-hid', 'for-3.12/i2c-hid-dt', ↵Jiri Kosina
'for-3.12/logitech', 'for-3.12/multitouch-win8', 'for-3.12/trasnport-driver-cleanup', 'for-3.12/uhid', 'for-3.12/upstream' and 'for-3.12/wiimote' into for-linus
2013-09-05Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "This set includes adding support for Neon acceleration of RAID6 XOR code from Ard Biesheuvel, cache flushing and barrier updates from Will Deacon, and a cleanup to the ARM debug code which reduces the amount of code by about 500 lines. A few other cleanups, such as constifying the machine descriptors which already shouldn't be written to, cleaning up the printing of the L2 cache size" * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (55 commits) ARM: 7826/1: debug: support debug ll on hisilicon soc ARM: 7830/1: delay: don't bother reporting bogomips in /proc/cpuinfo ARM: 7829/1: Add ".text.unlikely" and ".text.hot" to arm unwind tables ARM: 7828/1: ARMv7-M: implement restart routine common to all v7-M machines ARM: 7827/1: highbank: fix debug uart virtual address for LPAE ARM: 7823/1: errata: workaround Cortex-A15 erratum 773022 ARM: 7806/1: allow DEBUG_UNCOMPRESS for Tegra ARM: 7793/1: debug: use generic option for ep93xx PL10x debug port ARM: debug: move SPEAr debug to generic PL01x code ARM: debug: move davinci debug to generic 8250 code ARM: debug: move keystone debug to generic 8250 code ARM: debug: remove DEBUG_ROCKCHIP_UART ARM: debug: provide generic option choices for 8250 and PL01x ports ARM: debug: move PL01X debug include into arch/arm/include/debug/ ARM: debug: provide PL01x debug uart phys/virt address configuration options ARM: debug: add support for word accesses to debug/8250.S ARM: debug: move 8250 debug include into arch/arm/include/debug/ ARM: debug: provide 8250 debug uart phys/virt address configuration options ARM: debug: provide 8250 debug uart register shift configuration option ARM: debug: provide 8250 debug uart flow control configuration option ...
2013-09-05net: stmmac: fix bad merge conflict resolutionOlof Johansson
Merge commit 06c54055bebf did a bad conflict resolution accidentally leaving out a closing brace. Add it back. This breaks a handful of defconfigs on ARM, so it'd be good to see it applied pretty quickly. Signed-off-by: Olof Johansson <olof@lixom.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/ideLinus Torvalds
Pull IDE changes from David Miller: "Mostly cleanups, and changes part of tree-wide adjustments, this code is in deep freeze so that's pretty much what we expect these days" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide: ide: sgiioc4: Staticize ioc4_ide_attach_one() ide: palm_bk3710: add missing __iomem annotation ide: use dev_get_platdata() ide-disk_proc: use macro to replace magic number ide: replace strict_strtol() with kstrtol()
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc changes from David Miller: "Several bug fixes (from Kirill Tkhai, Geery Uytterhoeven, and Alexey Dobriyan) and some support for Fujitsu sparc64x chips (from Allen Pais)" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Export flush_ptrace_access() (needed by lustre) sparc: fix PCI device proc file mmap(2) sparc64: Remove RWSEM export leftovers sparc64: Fix off by one in trampoline TLB mapping installation loop. sparc64: Fix ITLB handler of null page esp_scsi: Fix tag state corruption when autosensing. sparc64: Fix not SRA'ed %o5 in 32-bit traced syscall sparc64: cleanup: Rename ret_from_syscall to ret_from_fork sparc32: Fix exit flag passed from traced sys_sigreturn sparc64: Fix wrong syscall return value passed to trace_sys_exit() support sparc64x chip type in cpumap.c cpu hw caps support for sparc64x
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: "Noteworthy changes this time around: 1) Multicast rejoin support for team driver, from Jiri Pirko. 2) Centralize and simplify TCP RTT measurement handling in order to reduce the impact of bad RTO seeding from SYN/ACKs. Also, when both timestamps and local RTT measurements are available prefer the later because there are broken middleware devices which scramble the timestamp. From Yuchung Cheng. 3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel memory consumed to queue up unsend user data. From Eric Dumazet. 4) Add a "physical port ID" abstraction for network devices, from Jiri Pirko. 5) Add a "suppress" operation to influence fib_rules lookups, from Stefan Tomanek. 6) Add a networking development FAQ, from Paul Gortmaker. 7) Extend the information provided by tcp_probe and add ipv6 support, from Daniel Borkmann. 8) Use RCU locking more extensively in openvswitch data paths, from Pravin B Shelar. 9) Add SCTP support to openvswitch, from Joe Stringer. 10) Add EF10 chip support to SFC driver, from Ben Hutchings. 11) Add new SYNPROXY netfilter target, from Patrick McHardy. 12) Compute a rate approximation for sending in TCP sockets, and use this to more intelligently coalesce TSO frames. Furthermore, add a new packet scheduler which takes advantage of this estimate when available. From Eric Dumazet. 13) Allow AF_PACKET fanouts with random selection, from Daniel Borkmann. 14) Add ipv6 support to vxlan driver, from Cong Wang" Resolved conflicts as per discussion. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits) openvswitch: Fix alignment of struct sw_flow_key. netfilter: Fix build errors with xt_socket.c tcp: Add missing braces to do_tcp_setsockopt caif: Add missing braces to multiline if in cfctrl_linkup_request bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize vxlan: Fix kernel panic on device delete. net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls net: mvneta: properly disable HW PHY polling and ensure adjust_link() works icplus: Use netif_running to determine device state ethernet/arc/arc_emac: Fix huge delays in large file copies tuntap: orphan frags before trying to set tx timestamp tuntap: purge socket error queue on detach qlcnic: use standard NAPI weights ipv6:introduce function to find route for redirect bnx2x: VF RSS support - VF side bnx2x: VF RSS support - PF side vxlan: Notify drivers for listening UDP port changes net: usbnet: update addr_assign_type if appropriate driver/net: enic: update enic maintainers and driver driver/net: enic: Exposing symbols for Cisco's low latency driver ...
2013-09-05openvswitch: Fix alignment of struct sw_flow_key.Jesse Gross
sw_flow_key alignment was declared as " __aligned(__alignof__(long))". However, this breaks on the m68k architecture where long is 32 bit in size but 16 bit aligned by default. This aligns to the size of a long to ensure that we can always do comparsions in full long-sized chunks. It also adds an additional build check to catch any reduction in alignment. CC: Andy Zhou <azhou@nicira.com> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull cputime fix from Ingo Molnar: "This fixes a longer-standing cputime accounting bug that Stanislaw Gruszka finally managed to track down" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/cputime: Do not scale when utime == 0
2013-09-05Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Fix for the annoying paravirt.o build warning under allmodconfig, and a MAINTAINERS file update" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, doc: Add an entry in MAINTAINERS for arch/x86/kernel/cpu/vmware.c x86, paravirt: Remove duplicate definition for DEF_NATIVE
2013-09-05ide: sgiioc4: Staticize ioc4_ide_attach_one()Jingoo Han
ioc4_ide_attach_one() is used only in this file. Fix the following sparse warnings: drivers/ide/sgiioc4.c:603:5: warning: symbol 'ioc4_ide_attach_one' was not declared. Should it be static? Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05ide: palm_bk3710: add missing __iomem annotationJingoo Han
Added missing __iomem annotation in order to fix the following sparse warnings: drivers/ide/palm_bk3710.c:194:31: warning: incorrect type in initializer (different address spaces) drivers/ide/palm_bk3710.c:194:31: expected void [noderef] <asn:2>*base drivers/ide/palm_bk3710.c:194:31: got void *<noident> drivers/ide/palm_bk3710.c:212:31: warning: incorrect type in initializer (different address spaces) drivers/ide/palm_bk3710.c:212:31: expected void [noderef] <asn:2>*base drivers/ide/palm_bk3710.c:212:31: got void *<noident> Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05ide: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05ide-disk_proc: use macro to replace magic numberXinghai Yu
Signed-off-by: Xinghai Yu <yuxinghai@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05ide: replace strict_strtol() with kstrtol()Jingoo Han
The usage of strict_strtol() is not preferred, because strict_strtol() is obsolete. Thus, kstrtol() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
