2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-04-30Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge third batch of fixes from Andrew Morton: "Most of the rest. I still have two large patchsets against AIO and IPC, but they're a bit stuck behind other trees and I'm about to vanish for six days. - random fixlets - inotify - more of the MM queue - show_stack() cleanups - DMI update - kthread/workqueue things - compat cleanups - epoll udpates - binfmt updates - nilfs2 - hfs - hfsplus - ptrace - kmod - coredump - kexec - rbtree - pids - pidns - pps - semaphore tweaks - some w1 patches - relay updates - core Kconfig changes - sysrq tweaks" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (109 commits) Documentation/sysrq: fix inconstistent help message of sysrq key ethernet/emac/sysrq: fix inconstistent help message of sysrq key sparc/sysrq: fix inconstistent help message of sysrq key powerpc/xmon/sysrq: fix inconstistent help message of sysrq key ARM/etm/sysrq: fix inconstistent help message of sysrq key power/sysrq: fix inconstistent help message of sysrq key kgdb/sysrq: fix inconstistent help message of sysrq key lib/decompress.c: fix initconst notifier-error-inject: fix module names in Kconfig kernel/sys.c: make prctl(PR_SET_MM) generally available UAPI: remove empty Kbuild files menuconfig: print more info for symbol without prompts init/Kconfig: re-order CONFIG_EXPERT options to fix menuconfig display kconfig menu: move Virtualization drivers near other virtualization options Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKS relay: use macro PAGE_ALIGN instead of FIX_SIZE kernel/relay.c: move FIX_SIZE macro into relay.c kernel/relay.c: remove unused function argument actor drivers/w1/slaves/w1_ds2760.c: fix the error handling in w1_ds2760_add_slave() drivers/w1/slaves/w1_ds2781.c: fix the error handling in w1_ds2781_add_slave() ...
2013-04-30Merge tag 'md-3.10' of git://neil.brown.name/mdLinus Torvalds
Pull md fixes from NeilBrown: "A mixed bag of little fixes. No real new functionality here. Several patches are tagged for -stable." * tag 'md-3.10' of git://neil.brown.name/md: MD: ignore discard request for hard disks of hybid raid1/raid10 array md: bad block list should default to disabled. md: raid1/raid10 md devices leak memory when stopping DM RAID: Add message/status support for changing sync action MD: Export 'md_reap_sync_thread' function md: don't update metadata when stopping a read-only array. md: Allow devices to be re-added to a read-only array. md/raid10: Allow skipping recovery when clean arrays are assembled MD: Fix typos in MD documentation md/raid5: avoid an extra write when writing to a known-bad-block. md/raid5: Change or of some order to improve efficiency. md: use set_bit_le and clear_bit_le md: HOT_DISK_REMOVE shouldn't make a read-auto device active. md: use common code for all calls to ->hot_remove_disk() md: never update metadata when array is read-only.
2013-04-30Documentation/sysrq: fix inconstistent help message of sysrq keyzhangwei(Jovi)
Currently help message of /proc/sysrq-trigger highlight its upper-case characters, like below: SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) kill-all-tasks(I) ... this would confuse user trigger sysrq by upper-case character, which is inconsistent with the real lower-case character registed key. This inconsistent help message will also lead more confused when 26 upper-case letters put into use in future. This patch fix sysrq documentation. Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30ethernet/emac/sysrq: fix inconstistent help message of sysrq keyzhangwei(Jovi)
Currently help message of /proc/sysrq-trigger highlight its upper-case characters, like below: SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) kill-all-tasks(I) ... this would confuse user trigger sysrq by upper-case character, which is inconsistent with the real lower-case character registed key. This inconsistent help message will also lead more confused when 26 upper-case letters put into use in future. This patch ethernet emac sysrq key: "emac(c)" Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30sparc/sysrq: fix inconstistent help message of sysrq keyzhangwei(Jovi)
Currently help message of /proc/sysrq-trigger highlight its upper-case characters, like below: SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) kill-all-tasks(I) ... this would confuse user trigger sysrq by upper-case character, which is inconsistent with the real lower-case character registed key. This inconsistent help message will also lead more confused when 26 upper-case letters put into use in future. This patch fix spare sysrq key: "global-regs(y)" Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30powerpc/xmon/sysrq: fix inconstistent help message of sysrq keyzhangwei(Jovi)
Currently help message of /proc/sysrq-trigger highlight its upper-case characters, like below: SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) kill-all-tasks(I) ... this would confuse user trigger sysrq by upper-case character, which is inconsistent with the real lower-case character registed key. This inconsistent help message will also lead more confused when 26 upper-case letters put into use in future. This patch fix powerpc xmon sysrq key: "xmon(x)" Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30ARM/etm/sysrq: fix inconstistent help message of sysrq keyzhangwei(Jovi)
Currently help message of /proc/sysrq-trigger highlights its upper-case characters, like below: SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) kill-all-tasks(I) ... this would confuse user trigger sysrq by upper-case character, which is inconsistent with the real lower-case character registed key. This inconsistent help message will also lead more confused when 26 upper-case letters put into use in future. This patch fix arm etm sysrq key: "etm-buffer-dump(v)" (This patch also add "-" to separate each sysrq key help word, instead of spaces) Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30power/sysrq: fix inconstistent help message of sysrq keyzhangwei(Jovi)
Currently help message of /proc/sysrq-trigger highlight its upper-case characters, like below: SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) kill-all-tasks(I) ... this would confuse user trigger sysrq by upper-case character, which is inconsistent with the real lower-case character registed key. This inconsistent help message will also lead more confused when 26 upper-case letters put into use in future. This patch fix power off sysrq key: "poweroff(o)" Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kgdb/sysrq: fix inconstistent help message of sysrq keyzhangwei(Jovi)
Currently help message of /proc/sysrq-trigger highlight its upper-case characters, like below: SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) kill-all-tasks(I) ... this would confuse user trigger sysrq by upper-case character, which is inconsistent with the real lower-case character registed key. This inconsistent help message will also lead more confused when 26 upper-case letters put into use in future. This patch fix kgdb sysrq key: "debug(g)" Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30lib/decompress.c: fix initconstAndi Kleen
Signed-off-by: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30notifier-error-inject: fix module names in KconfigAkinobu Mita
The Kconfig help text for MEMORY_NOTIFIER_ERROR_INJECT and OF_RECONFIG_NOTIFIER_ERROR_INJECT has mismatched module names. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kernel/sys.c: make prctl(PR_SET_MM) generally availableAmnon Shiloh
The purpose of this patch is to allow privileged processes to set their own per-memory memory-region fields: start_code, end_code, start_data, end_data, start_brk, brk, start_stack, arg_start, arg_end, env_start, env_end. This functionality is needed by any application or package that needs to reconstruct Linux processes, that is, to start them in any way other than by means of an "execve()" from an executable file. This includes: 1. Restoring processes from a checkpoint-file (by all potential user-level checkpointing packages, not only CRIU's). 2. Restarting processes on another node after process migration. 3. Starting duplicated copies of a running process (for reliability and high-availablity). 4. Starting a process from an executable format that is not supported by Linux, thus requiring a "manual execve" by a user-level utility. 5. Similarly, starting a process from a networked and/or crypted executable that, for confidentiality, licensing or other reasons, may not be written to the local file-systems. The code that does that was already included in the Linux kernel by the CRIU group, in the form of "prctl(PR_SET_MM)", but prior to this was enclosed within their private "#ifdef CONFIG_CHECKPOINT_RESTORE", which is normally disabled. The patch removes those ifdefs. Signed-off-by: Amnon Shiloh <u3557@miso.sublimeip.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30UAPI: remove empty Kbuild filesDavid Howells
Remove empty Kbuild files as they cause problems with the patch program which removes files that become empty. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30menuconfig: print more info for symbol without promptsWengmeiling
When we search a config symbol, if it has no prompt the position of this symbol in the Kconfig file and it's dependencies are not printed. This can be inconvenient, especially when it's set to n and we want to find out why. the following is an example: before: Symbol: GENERIC_SMP_IDLE_THREAD [=y] Type : boolean Selected by: X86 [=y] after: Symbol: GENERIC_SMP_IDLE_THREAD [=y] Type : boolean Defined at arch/Kconfig:213 Selected by: X86 [=y] Signed-off-by: Weng Meiling <wengmeiling.weng@huawei.com> Signed-off-by: Libo Chen <libo.chen@huawei.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30init/Kconfig: re-order CONFIG_EXPERT options to fix menuconfig displayMike Frysinger
The kconfig language requires that dependent options all follow the menuconfig symbol in order to be collapsed below it. Recently some hidden options were added below the EXPERT menuconfig, but did not depend on EXPERT (because hidden options can't). This broke the display. So re-order all these options, and while we're here stick the PCI quirks under the EXPERT menu (since it isn't sitting with any related options). Before this commit, we get: [*] Configure standard kernel features (expert users) ---> [ ] Sysctl syscall support [*] Load all symbols for debugging/ksymoops ... [ ] Embedded system Now we get the older (and correct) behavior: [*] Configure standard kernel features (expert users) ---> [ ] Embedded system And if you go into the expert menu you get the expert options: [ ] Sysctl syscall support [*] Load all symbols for debugging/ksymoops ... Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kconfig menu: move Virtualization drivers near other virtualization optionsRandy Dunlap
Make virtualization drivers be logically grouped together (physically near each other) in the kconfig menu by moving "Virtualization drivers" to be near "Virtio drivers", Microsort Hyper-V, and Xen driver support. This is just a user-friendly, visual search change. Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Alexander Graf <agraf@suse.de> Cc: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKSStephen Boyd
The help text for this config is duplicated across the x86, parisc, and s390 Kconfig.debug files. Arnd Bergman noted that the help text was slightly misleading and should be fixed to state that enabling this option isn't a problem when using pre 4.4 gcc. To simplify the rewording, consolidate the text into lib/Kconfig.debug and modify it there to be more explicit about when you should say N to this config. Also, make the text a bit more generic by stating that this option enables compile time checks so we can cover architectures which emit warnings vs. ones which emit errors. The details of how an architecture decided to implement the checks isn't as important as the concept of compile time checking of copy_from_user() calls. While we're doing this, remove all the copy_from_user_overflow() code that's duplicated many times and place it into lib/ so that any architecture supporting this option can get the function for free. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Helge Deller <deller@gmx.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30relay: use macro PAGE_ALIGN instead of FIX_SIZEzhangwei(Jovi)
Macro FIX_SIZE is same as PAGE_ALIGN at present, so use PAGE_ALIGN instead. Thanks Andrew found this. Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kernel/relay.c: move FIX_SIZE macro into relay.czhangwei(Jovi)
It's better to place FIX_SIZE macro in relay.c, instead of relay.h Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kernel/relay.c: remove unused function argument actorzhangwei(Jovi)
Currently argument `actor' is never used in the relay reading path, so remove it. Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30drivers/w1/slaves/w1_ds2760.c: fix the error handling in w1_ds2760_add_slave()Wei Yongjun
Use platform_device_put() instead of platform_device_unregister() if platform_device_add() fail, and platform_device_del() should be used in the error handling case after platform_device_add() success. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Evgeniy Polyakov <zbr@ioremap.net> Cc: Greg KH <greg@kroah.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30drivers/w1/slaves/w1_ds2781.c: fix the error handling in w1_ds2781_add_slave()Wei Yongjun
2013-04-30drivers/w1/slaves/w1_ds2780.c: fix the error handling in w1_ds2780_add_slave()Wei Yongjun
2013-04-30drivers/w1/slaves/w1_bq27000.c: fix the error handling in w1_bq27000_add_slave()Wei Yongjun
Use platform_device_put() instead of platform_device_unregister() if platform_device_add() fails, and also add the return value check of platform_device_add_data(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Evgeniy Polyakov <zbr@ioremap.net> Cc: Greg KH <greg@kroah.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30drivers/memstick/host/r592.c: make r592_pm_ops staticJingoo Han
r592_pm_ops is not exported. Also, CONFIG_PM_SLEEP is used to remove unnecessary ifdefs. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30semaphore: use `bool' type for semaphore_waiter's upliguang
Signed-off-by: liguang <lig.fnst@cn.fujitsu.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30semaphore: use unlikely() for down's timeoutliguang
2013-04-30pps: pps_kc_hardpps_lock can be staticFengguang Wu
drivers/pps/kc.c:37:1: sparse: symbol 'pps_kc_hardpps_lock' was not declared. Should it be static? drivers/pps/kc.c:39:19: sparse: symbol 'pps_kc_hardpps_dev' was not declared. Should it be static? drivers/pps/kc.c:40:5: sparse: symbol 'pps_kc_hardpps_mode' was not declared. Should it be static? Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30pps: hide more configuration symbols behind CONFIG_PPSFlorian Fainelli
Make CONFIG_PPS_DEBUG and CONFIG_NTP_PPS be hidden if CONFIG_PPS is not selected, so that we are not prompted for these configuration options if CONFIG_PPS is not set. Signed-off-by: Florian Fainelli <florian@openwrt.org> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30aoe: replace kmalloc and then memcpy with kmemdupMihnea Dobrescu-Balaur
Signed-off-by: Mihnea Dobrescu-Balaur <mihneadb@gmail.com> Cc: Ed Cashin <ecashin@coraid.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30nbd: increase default and max request sizesMichal Belczyk
Raise the default max request size for nbd to 128KB (from 127KB) to get it 4KB aligned. This patch also allows the max request size to be increased (via /sys/block/nbd<x>/queue/max_sectors_kb) to 32MB. The patch makes nbd network traffic more efficient by: - reducing request fragmentation (4KB alignment) - reducing the number of requests (fewer round trips, less network overhead) Especially in high latency networks, larger request size can make a dramatic Signed-off-by: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Michal Belczyk <belczyk@bsd.krakow.pl> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30pid_namespace.c/.h: simplify definesRaphael S.Carvalho
Move BITS_PER_PAGE from pid_namespace.c to pid_namespace.h, since we can simplify the define PID_MAP_ENTRIES by using the BITS_PER_PAGE. [akpm@linux-foundation.org: kernel/pid.c:54:1: warning: "BITS_PER_PAGE" redefined] Signed-off-by: Raphael S.Carvalho <raphael.scarv@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kernel/pid.c: improve flow of a loop inside alloc_pidmap.Raphael S. Carvalho
find_next_offset() searches for an available "cleaned bit" in the respective pid bitmap (page), so returns the offset if found, otherwise it returns a value equals to BITS_PER_PAGE. For example, suppose find_next_offset didn't find any available bit, so there's no purpose to call mk_pid (Wasteful Cpu Cycles). Therefore, I found it could be better to call mk_pid after the checking (offset < BITS_PER_PAGE) returned sucessfully! Another point: If (offset < BITS_PER_PAGE) results in a "failure", then mk_pid would be called again afterwards. [akpm@linux-foundation.org: simplify code] Signed-off-by: Raphael S. Carvalho <raphael.scarv@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30rbtree_test: add __init/__exit annotationsDavidlohr Bueso
Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Reviewed-by: Michel Lespinasse <walken@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30rbtree_test: add extra rbtree integrity checkDavidlohr Bueso
Account for the rbtree having 2**bh(v)-1 internal nodes. While this can be seen as a consequence of other checks, Michel states that it nicely sums up what the other properties are for. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Reviewed-by: Michel Lespinasse <walken@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kexec: Use min() and min_t() to simplify logicZhang Yanfei
Simplify the logic of variable assignments. [akpm@linux-foundation.org: replace min_t with min, remove unneeded casts] Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Reviewed-by: Simon Horman <horms@verge.net.au> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kexec: fix wrong types of some local variablesZhang Yanfei
The types of the following local variables: - ubytes/mbytes in kimage_load_crash_segment()/kimage_load_normal_segment() - r in vmcoreinfo_append_str() are wrong, so fix them. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Simon Horman <horms@verge.net.au> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30exec: do not abuse ->cred_guard_mutex in threadgroup_lock()Oleg Nesterov
threadgroup_lock() takes signal->cred_guard_mutex to ensure that thread_group_leader() is stable. This doesn't look nice, the scope of this lock in do_execve() is huge. And as Dave pointed out this can lead to deadlock, we have the following dependencies: do_execve: cred_guard_mutex -> i_mutex cgroup_mount: i_mutex -> cgroup_mutex attach_task_by_pid: cgroup_mutex -> cred_guard_mutex Change de_thread() to take threadgroup_change_begin() around the switch-the-leader code and change threadgroup_lock() to avoid ->cred_guard_mutex. Note that de_thread() can't sleep with ->group_rwsem held, this can obviously deadlock with the exiting leader if the writer is active, so it does threadgroup_change_end() before schedule(). Reported-by: Dave Jones <davej@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30set_task_comm: kill the pointless memset() + wmb()Oleg Nesterov
set_task_comm() does memset() + wmb() before strlcpy(). This buys nothing and to add to the confusion, the comment is wrong. - We do not need memset() to be "safe from non-terminating string reads", the final char is always zero and we never change it. - wmb() is paired with nothing, it cannot prevent from printing the mixture of the old/new data unless the reader takes the lock. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30fs, proc: truncate /proc/pid/comm writes to first TASK_COMM_LEN bytesDavid Rientjes
Currently, a write to a procfs file will return the number of bytes successfully written. If the actual string is longer than this, the remainder of the string will not be be written and userspace will complete the operation by issuing additional write()s. Hence $ echo -n "abcdefghijklmnopqrs" > /proc/self/comm results in $ cat /proc/$$/comm pqrs since the final four bytes were written with a second write() since TASK_COMM_LEN == 16. This is obviously an undesired result and not equivalent to prctl(PR_SET_NAME). The implementation should not need to know the definition of TASK_COMM_LEN. This patch truncates the string to the first TASK_COMM_LEN bytes and returns the bytes written as the length of the string written so the second write() is suppressed. $ cat /proc/$$/comm abcdefghijklmno Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: change wait_for_dump_helpers() to use wait_event_interruptible()Oleg Nesterov
wait_for_dump_helpers() calls wake_up/kill_fasync from inside the wait_event-like loop. This is not needed and in fact this is not strictly correct, we can/should do this only once after we change pipe->writers. We could even check if it becomes zero. Change this code to use use wait_event_interruptible(), this can also help to make this wait freezable. With this patch we check pipe->readers without pipe_lock(), this is fine. Once we see pipe->readers == 1 we know that the handler decremented the counter, this is all we need. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Mandeep Singh Baines <msb@chromium.org> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: factor out the setting of PF_DUMPCOREOleg Nesterov
Cleanup. Every linux_binfmt->core_dump() sets PF_DUMPCORE, move this into zap_threads() called by do_coredump(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Mandeep Singh Baines <msb@chromium.org> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: introduce dump_interrupted()Oleg Nesterov
By discussion with Mandeep. Change dump_write(), dump_seek() and do_coredump() to check signal_pending() and abort if it is true. dump_seek() does this only before f_op->llseek(), otherwise it relies on dump_write(). We need this change to ensure that the coredump won't delay suspend, and to ensure it reacts to SIGKILL "quickly enough", a core dump can take a lot of time. In particular this can help oom-killer. We add the new trivial helper, dump_interrupted() to add the comments and to simplify the potential freezer changes. Perhaps it will have more callers. Ideally it should do try_to_freeze() but then we need the unpleasant changes in dump_write() and wait_for_dump_helpers(). It is not trivial to change dump_write() to restart if f_op->write() fails because of freezing(). We need to handle the short writes, we need to clear TIF_SIGPENDING (and we can't rely on recalc_sigpending() unless we change it to check PF_DUMPCORE). And if the buggy f_op->write() sets TIF_SIGPENDING we can not distinguish this case from the race with freeze_task() + __thaw_task(). So we simply accept the fact that the freezer can truncate a core-dump but at least you can reliably suspend. Hopefully we can tolerate this unlikely case and the necessary complications doesn't worth a trouble. But if we decide to make the coredumping freezable later we can do this on top of this change. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Mandeep Singh Baines <msb@chromium.org> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: sanitize the setting of signal->group_exit_codeOleg Nesterov
Now that the coredumping process can be SIGKILL'ed, the setting of ->group_exit_code in do_coredump() can race with complete_signal() and SIGKILL or 0x80 can be "lost", or wait(status) can report status == SIGKILL | 0x80. But the main problem is that it is not clear to me what should we do if binfmt->core_dump() succeeds but SIGKILL was sent, that is why this patch comes as a separate change. This patch adds 0x80 if ->core_dump() succeeds and the process was not killed. But perhaps we can (should?) re-set ->group_exit_code changed by SIGKILL back to "siginfo->si_signo |= 0x80" in case when core_dumped == T. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Tested-by: Mandeep Singh Baines <msb@chromium.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Roland McGrath <roland@hack.frob.com> Cc: Tejun Heo <tj@kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: ensure that SIGKILL always kills the dumping threadOleg Nesterov
prepare_signal() blesses SIGKILL sent to the dumping process but this signal can be "lost" anyway. The problems is, complete_signal() sees SIGNAL_GROUP_EXIT and skips the "kill them all" logic. And even if the dumping process is single-threaded (so the target is always "correct"), the group-wide SIGKILL is not recorded in task->pending and thus __fatal_signal_pending() won't be true. A multi-threaded case has even more problems. And even ignoring all technical details, SIGNAL_GROUP_EXIT doesn't look right to me. This coredumping process is not exiting yet, it can do a lot of work dumping the core. With this patch the dumping process doesn't have SIGNAL_GROUP_EXIT, we set signal->group_exit_task instead. This makes signal_group_exit() true and thus this should equally close the races with exit/exec/stop but allows to kill the dumping thread reliably. Notes: - It is not clear what should we do with ->group_exit_code if the dumper was killed, see the next change. - we need more (hopefully straightforward) changes to ensure that SIGKILL actually interrupts the coredump. Basically we need to check __fatal_signal_pending() in dump_write() and dump_seek(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Tested-by: Mandeep Singh Baines <msb@chromium.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Roland McGrath <roland@hack.frob.com> Cc: Tejun Heo <tj@kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: only SIGKILL should interrupt the coredumping taskOleg Nesterov
There are 2 well known and ancient problems with coredump/signals, and a lot of related bug reports: - do_coredump() clears TIF_SIGPENDING but of course this can't help if, say, SIGCHLD comes after that. In this case the coredump can fail unexpectedly. See for example wait_for_dump_helper()->signal_pending() check but there are other reasons. - At the same time, dumping a huge core on the slow media can take a lot of time/resources and there is no way to kill the coredumping task reliably. In particular this is not oom_kill-friendly. This patch tries to fix the 1st problem, and makes the preparation for the next changes. We add the new SIGNAL_GROUP_COREDUMP flag set by zap_threads() to indicate that this process dumps the core. prepare_signal() checks this flag and nacks any signal except SIGKILL. Note that this check tries to be conservative, in the long term we should probably treat the SIGNAL_GROUP_EXIT case equally but this needs more discussion. See marc.info/?l=linux-kernel&m=120508897917439 Notes: - recalc_sigpending() doesn't check SIGNAL_GROUP_COREDUMP. The patch assumes that dump_write/etc paths should never call it, but we can change it as well. - There is another source of TIF_SIGPENDING, freezer. This will be addressed separately. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Tested-by: Mandeep Singh Baines <msb@chromium.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Roland McGrath <roland@hack.frob.com> Cc: Tejun Heo <tj@kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kmod: remove call_usermodehelper_fns()Lucas De Marchi
This function suffers from not being able to determine if the cleanup is called in case it returns -ENOMEM. Nobody is using it anymore, so let's remove it. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tejun Heo <tj@kernel.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30usermodehelper: split remaining calls to call_usermodehelper_fns()Lucas De Marchi
These are the only users of call_usermodehelper_fns(). This function suffers from not being able to determine if the cleanup is called. Even if in this places the cleanup pointer is NULL, convert them to use the separate call_usermodehelper_setup() + call_usermodehelper_exec() functions so we can remove the _fns variant. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tejun Heo <tj@kernel.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: remove trailling whitespaceLucas De Marchi
