path: root/tools/ublimage.h
2011-11-03arm, davinci: add cam_enc_4xx supportHeiko Schocher
- DM368 SOC - booting with spl not with UBL from TI - before loading u-boot from NAND into RAM, test the RAM with the post memory test. If error is found, switch all LEDs on and halt system. - SPI Flash Dataflash Typ: M25PE80 - Ethernet DM9161BI - MMC - USB Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-06ublimage: NAND block size isn't set at build-timeLoïc Minier
mkimage's ublimage support can't depend of build-time board configs; instead, this should be set in ublimage.cfg. Since currently no configs in u-boot override the NAND block size, hardcode it as such in ublimage.h to fix a build failure with "make tools": gcc [...] -o ublimage.o ublimage.c -c In file included from ublimage.c:37:0: ublimage.h:31:20: fatal error: config.h: No such file or directory Cc: Heiko Schocher <hs@denx.de> Cc: patches@linaro.org Signed-off-by: Loïc Minier <loic.minier@linaro.org> Acked-by: Heiko Schocher <hs@denx.de>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
