path: root/tools/omapimage.c
2011-09-04mkimage: Fix 'Unknown OMAP image type - 5'Dirk Behme
Using mkimage with e.g. tools/mkimage -A arm -T firmware -O u-boot -d u-boot.bin foo.img gives a warning "Unknown OMAP image type - 5" while it seems that the image itself is created successfully. This does come from the patch "mkimage: Add OMAP boot image support". The method check_image_type in image_type_params is supposed to just return success or failure. However, for omap it also calls fprintf: static int omapimage_check_image_types(uint8_t type) { if (type == IH_TYPE_OMAPIMAGE) return EXIT_SUCCESS; else { fprintf(stderr, "Unknown OMAP image type - %x", type); return EXIT_FAILURE; } } All the other image checkers and no others have this, so the fix is to simply remove the fprintf. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> CC: John Rigby <john.rigby@linaro.org> CC: Aneesh V <aneesh@ti.com> CC: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-03mkimage: Add OMAP boot image supportJohn Rigby
- Add mkimage support for OMAP boot image - Add support for OMAP boot image(MLO) generation in the new SPL framework Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
