path: root/tools/mkenvimage.c
2012-01-05Correctly handle input files beginning with several newlinesDavid Wagner
Also, fix some comments (minor) Signed-off-by: David Wagner <david.wagner@free-electrons.com>
2012-01-05tools/mkenvimage.c: Fix a merge issueHorst Kronstorfer
With bfcc40bb09b05c90cc3b1496abb270eb8aa72134 'optopt' was reverted. Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
2011-12-23Merge branch 'next' of ../nextWolfgang Denk
* 'next' of ../next: mkenvimage: Add version info switch (-V) mkenvimage: Fix getopt() error handling mkenvimage: Fix some typos phy: add Micrel KS8721BL phy definition net: introduce per device index mvgbe: remove setting of ethaddr within the driver x86: Add support for specifying an initrd with the zboot command x86: Refactor the zboot innards so they can be reused with a vboot image x86: Add infrastructure to extract an e820 table from the coreboot tables x86: Add support for booting Linux using the 32 bit boot protocol x86: Clean up the x86 zimage code in preparation to extend it x86: Import code from coreboot's libpayload to parse the coreboot table x86: Initial commit for running as a coreboot payload CHECKPATCH: ./board/esd/hh405/logo_320_240_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/hh405/fpgadata.c CHECKPATCH: ./board/esd/pci405/fpgadata.c CHECKPATCH: ./board/esd/tasreg/fpgadata.c CHECKPATCH: ./board/esd/apc405/fpgadata.c CHECKPATCH: ./board/esd/voh405/fpgadata.c CHECKPATCH: ./board/esd/ash405/fpgadata.c CHECKPATCH: ./board/esd/dasa_sim/fpgadata.c CHECKPATCH: ./board/esd/ar405/fpgadata_xl30.c CHECKPATCH: ./board/esd/ar405/fpgadata.c CHECKPATCH: ./board/esd/plu405/fpgadata.c CHECKPATCH: ./board/esd/wuh405/fpgadata.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405ab.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci4052.c CHECKPATCH: ./board/esd/canbt/fpgadata.c CHECKPATCH: ./board/esd/du405/fpgadata.c CHECKPATCH: ./board/esd/cpciiser4/fpgadata.c CHECKPATCH: ./board/dave/PPChameleonEVB/fpgadata.c avr32:mmu.c: fix printf() length modifier fat.c: fix printf() length modifier cmd_sf.c: fix printf() length modifier Make printf and vprintf safe from buffer overruns vsprintf: Move function documentation into header file Add safe vsnprintf and snprintf library functions Move vsprintf functions into their own header Conflicts: tools/mkenvimage.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-22Print program basename instead of whole path in usage()Horst Kronstorfer
2011-12-20mkenvimage: Add version info switch (-V)Horst Kronstorfer
2011-12-20mkenvimage: Fix getopt() error handlingHorst Kronstorfer
Since the original implementation indicates explicit error handling we turn off getopt()'s internal error messaging to avoid duplicate error messages. Additionally we add ':' (missing option argument) error handling. Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
2011-12-20mkenvimage: Fix some typosHorst Kronstorfer
2011-11-22new tool mkenvimage: generates an env image from an arbitrary config fileDavid Wagner
This tool takes a key=value configuration file (same as would a `printenv' show) and generates the corresponding environment image, ready to be flashed. use case: flash the environment with an external tool Signed-off-by: David Wagner <david.wagner@free-electrons.com> Acked-by; Mike Frysinger <vapier@gentoo.org> Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
