path: root/tools/mingw_support.h
2010-01-26getline: split out for darwin systemsMike Frysinger
At least on OS X 10.5 and older, getline does not exist. So split out the function from the mingw code so that we can pull it in for Darwin systems. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-11-23Fix mingw tools buildRemy Bohmer
mkimage does not build due to missing strtok_r() and getline() implementation Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-07-19compiler.h: unify system ifdef cruft hereMike Frysinger
Shove a lot of the HOSTCC and related #ifdef checking crap into the new compiler.h header so that we can keep all other headers nice and clean. Also introduce custom uswap functions so we don't have to rely on the non standard implementations that a host may (or may not in the case of OS X) provide. This allows mkimage to finally build cleanly on an OS X system. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-04Add support for building native win32 toolsPeter Tyser
Add support for compiling the host tools in the tools directory using the MinGW toolchain. This produces executables which can be used on standard Windows computers without requiring cygwin. One must specify the MinGW compiler and strip utilities as if they were the host toolchain in order to build win32 executables, eg: make HOSTCC=i586-mingw32msvc-gcc HOSTSTRIP=i586-mingw32msvc-strip tools Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
