path: root/tools/img2srec.c
2009-11-24img2srec: use standard typesMike Frysinger
The img2srec code creates a lot of typedefs with common names. These easily clash with system headers that include these typedefs (like mingw). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-19compiler.h: unify system ifdef cruft hereMike Frysinger
Shove a lot of the HOSTCC and related #ifdef checking crap into the new compiler.h header so that we can keep all other headers nice and clean. Also introduce custom uswap functions so we don't have to rely on the non standard implementations that a host may (or may not in the case of OS X) provide. This allows mkimage to finally build cleanly on an OS X system. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2001-10-23Initial revisionwdenk
