Add a test for the dm drivers command. Also fix a null pointer dereference
revealed by said test.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
We don't need 5KB to test things out. A smaller size makes it easier to
look at the FIT with fdtdump.
This code is repeated so move it into a function with a parameter.
Fix various minor things noticed by pylint.
Fix some long lines and comments. Use a distinct name for the
'required key' test.
This test is actually made up of five separate tests. Split them out so
that they appear as separate tests.
Unfortunately this restarts U-Boot multiple times which adds about a
second to the already-long vboot test, about 8 seconds total on my
machine. We could add a special 'teardown' test afterwards but if the
tests are executed out of order that would not work.
Changing test_vboot into a class causes it not to be discovered and makes
it different from all other tests.
Add a check to make sure that it is not possible to add a new
configuration and use the hashed nodes and hash of another configuration.
This tool only uses the last -k parameter provided. Drop the earlier one
since it has no effect.
With CONFIG_OF_CONTROL environment variable $fdtcontroladdr is not defined
and test_efi_grub_net() fails.
and test_efi_helloworld_net() fails.
%s/decopmression/decompression/
Commit 41e30dcf8796 ("cmd: mmc: Make Mode: printout consistent") fixed
the layout of `mmc info` output. Reflect this change in the respective
testcase.
Also fix a typo in the documentation.
Fixes: 41e30dcf8796 ("cmd: mmc: Make Mode: printout consistent")
Signed-off-by: Harald Seiler <hws@denx.de>
4dbc107f4683 ("cmd: gpio: Correct do_gpio() return value") correctly
changed the behaviour of the gpio command to return CMD_RET_SUCCESS or
CMD_RET_FAILURE, but any existing script which expects the return value
to be the pin value is broken by this change.
Reinstate the legacy behaviour for `gpio input` only.
Fixes: 4dbc107f4683 ("cmd: gpio: Correct do_gpio() return value")
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Signed-off-by: Alex Kiernan <alex.kiernan@hivehome.com>
In the first version, the result of malloc is checked
with ut_assertnonnull. But on a fail, this macro exit
the function, so previously malloc are not freed.
So to avoid a memleak, we don't use ut_assertnonnull,
but simply check the return of malloc. If one has failed,
we freed all the allocated memory and quit the function.
Reported-by: Coverity (CID: 284403)
Reported-by: Coverity (CID: 284404)
Reported-by: Coverity (CID: 284405)
Reported-by: Coverity (CID: 284406)
Reported-by: Coverity (CID: 284407)
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
sandbox conversion to SDL2
TPM TEE driver
Various minor sandbox video enhancements
New driver model core utility functions
- Move P2SB from Apollo Lake to a more generic location
- Add a function to find a device by drvdata in DM core
- Enhancement of DM IRQ uclass driver
- Add a clock driver for Intel devices
- Add support for ACPI general-purpose events
- Add a TPM driver for H1/Cr50
- Enable TPM on Google Chromebook Coral
At present driver model supports the IRQ uclass but there is no way to
request a particular interrupt for a driver.
Add a mechanism, similar to clock and reset, to read the interrupts
required by a device from the device tree and to request those interrupts.
U-Boot itself does not have interrupt-driven handlers, so just provide a
means to read and clear an interrupt. This can be useful to handle
peripherals which must use an interrupt to determine when data is
available, for example.
Bring over the basic binding file as well, from Linux v5.4. Note that the
older binding is not supported in U-Boot; the newer 'special form' must be
used.
Add a simple test of the new functionality.
There can be different types of interrupt controllers in a system and some
drivers may need to distinguish between these. In general this can be
handled using the device tree by adding the interrupt information to
device nodes.
However on x86 devices we have interrupt controllers which are not tied
to any particular device and not really used in U-Boot. These still need
to be inited, so a convenient method is to give each controller a type
and allow a particular controller type to be probed.
Add support for this in sandbox along with a test.
[bmeng: remove the new bland line at EOF of test/dm/irq.c]
It is sometimes useful to find a device in a uclass using only its driver
data. The driver data often indicates the 'subtype' of the device, e,g,
via its compatible string.
Add a function to handle this.
At present we have uclass_foreach_dev() which requires that uclass_get()
be called beforehand to find the uclass. This is good if we suspect that
that function might fail, but often we know that the uclass is available.
Add a new helper which does this uclass_get() automatically, so that only
the uclass ID is needed.
At present dm/device.h includes the linux-compatible features. This
requires including linux/compat.h which in turn includes a lot of headers.
One of these is malloc.h which we thus end up including in every file in
U-Boot. Apart from the inefficiency of this, it is problematic for sandbox
which needs to use the system malloc() in some files.
Move the compatibility features into a separate header file.
At present devres.h is included in all files that include dm.h but few
make use of it. Also this pulls in linux/compat which adds several more
headers. Drop the automatic inclusion and require files to include devres
themselves. This provides a good indication of which files use devres.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
At present there is no positive indication that U-Boot has finished
sending sound data. This means that it is not possible to power down an
audio codec, for example. Add a new method that is called once all sound
data has been sent.
Add a new method for this, called when the sound_play() call is done.
When writing tests to check the output from commands it is useful to be
able to check the output line by line using an assertion. Add helper
macros to support this and to check that there is no unexpected trailing
data.
Also some commands produce a dump using print_buffer(). Add a way to check
that the correct number of bytes are dumped (ignoring the actual
contents).
At present we reset the console buffer before each test but do not
actually set the recording flag. Without this, the output is not
recorded.
Update the code to set the flag before the test and clear it afterwards.
It is convenient for bloblist to zero out the contents of a records when
it is added. This saves the callers having to do it.
Update the API accordingly.
A common check is to see if a blob is present, create it if not and make
sure that the size is large enough. Add a function to handle this.
It is sometimes useful to process all children, making sure they are
probed first. Add functions to help with this and a macro to make it more
convenient.
When generating ACPI tables we need to make sure that all devices have
read their platform data, so that they can generate the tables correctly.
Rather than adding this code in ACPI, create a core function to handle it.
Add a function to read a property from the chosen node, providing access
to its length. Update ofnode_get_chosen_string() to make use of it.
Add a new function to read a property that supports reading the length as
well.
Reimplement ofnode_read_string() using it and fix its comment.
This function is actually intended to read a string rather than a
property. All of its current callers use it that way. Also there is no way
to return the length of the property from this function.
Rename it to better indicate its purpose, using ofnode_read as the prefix
since this matches most other functions.
Also add some tests which are missing for these functions.
Fix pylint warnings:
* add missing module and function documentation
* correct indentation
Fix warnings issued by pylint:
* naming of variables
* usage of commas and semicolons
* indentation
* placement of module description
Unit test for 'abootimg' command. Right now it covers dtb/dtbo
functionality in Android Boot Image v2, which was added recently.
Running test:
$ ./test/py/test.py --bd sandbox --build -k test_abootimg
shows that 1/1 tests passes successfully.
Signed-off-by: Sam Protsenko <joe.skb7@gmail.com>
Convert Android documentation from regular txt format to Sphinx (RST).
Also add Android index.rst file and reference it in root index.rst, so
that Android documentation is visible.
Test:
$ make htmldocs
$ xdg-open doc/output/index.html
Coreutils command nproc can be used on Linux and BSD to count the number of
available CPU cores. Use this instead of relying on the parsing of the
Linux specific proc file system.
Per sandbox_cs_info(), sandbox spi controller only supports chip
select 0. Current test case tries to locate devices on chip select
1, and any call to spi_get_bus_and_cs() or spi_cs_info() with cs
number 1 should not return 0.
This updates the test case to handle it correctly.
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
This commit add test unit for aes196 and aes256.
This commit add test unit for aes128.
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx/FPGA changes for v2020.04
ARM64:
- Add INIT_SPL_RELATIVE dependency
SPL:
- FIT image fix
- Enable customization of bl2_plat_get_bl31_params()
Pytest:
- Add test for octal/hex conversions
Microblaze:
- Fix manual relocation for one SPI instance
Nand:
- Convert zynq/zynqmp drivers to DM
Xilinx:
- Enable boot script location via Kconfig
- Support OF_SEPARATE in board FDT selection
- Remove low level uart setup it is done later by code
- Add support for DEVICE_TREE variable passing for SPL
Zynq:
- Enable jtag boot mode via distro boot
- Removing unused baseaddresses from hardware.h
- DT fixups
ZynqMP:
- Fix emmc boot sequence
- Simplify spl logic around bss and board_init_r()
- Support psu_post_config_data() calling
- Tune mini-nand DTS
- Fix psu wiring for a2197 boards
- Add runtime MMC device boot order filling in spl
- Clear ATF handoff handling with custom bl2_plat_get_bl31_params()
- Add support u-boot.its generation
- Use single image configuration for all platforms
- Enable PANIC_HANG via Kconfig
- DT fixups
- Firmware fixes
- Add support for zcu208 and zcu1285
Versal:
- Enable board_late_init() by default
The device tree compiler expects that a node with a unit-address has a reg
property.
Extend test suite to cover also automatic octal/hex converstions which
haven't been implemented in past.
In the function cmd_ut_category, the prefix is used with
the function strncmp to know if the prefix should be
removed from the test name, even if the prefix is NULL.
To avoid this issue, we consider that a prefix NULL
mean no prefix. So we only try to remove the prefix
from the test_name if the prefix is not NULL, then
we avoid to call the function strncmp with a NULL
prefix.
Reported-by: Coverity CID 281110
Fixes: 4ad4edfe ("cmd_ut: add a parameter prefix to the function cmd_ut_category")
dm: Increased separation of ofdata_to_platdata() and probe methods
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2020-04-rc1
This pull request provides:
* support for FIT images for UEFI binaries
* drivers for hardware random number generators
* an implementation of the EFI_RNG_PROTOCOL
* a sub-command for efidebug to display configuration tables
Since the ofdata_to_platdata() method can allocate resources, add it as a
new devres phase.
The devres functionality has very few users in U-Boot, but it still should
have tests. Add a few basic tests of the main functions.
Add a driver which does devres allocations so that we can write tests for
devres.
The malloc() implementations provides a way of finding out the approximate
amount of memory that is allocated. Add helper functions to make it easier
to access this and see changes over time. This is useful for tests that
want to check if memory has been allocated or freed.
