Backport usage of a new KSZ9XX1 PHY by Apalis iMX6, the old driver
located in micrel.c still used by other boards. If a board
wants to use a new PHY the old one must be disabled.
Backported from:
commit f72e48ba4d98 ("board: apalis_imx6: Add KSZ9131 phy skew settings")
Related-to: ELB-4181
Signed-off-by: Oleksii Bidnichenko <oleksii.bidnichenko@toradex.com>
This commit fixes several issues:
- Use ${OBJCOPY} if available, fallback to system default's objcopy if not
present.
- Extend the script to accept different build directory than current one.
It is extremely handy with OE usage, where source code is separated from
build.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
[Backported to 2016.11]
(cherry picked from commit 0778e7c50ba1904943a1d6b5194c29d1fee33334)
CONFIG_SYS_NAND_MX7_GPMI_62_ECC_BYTES is no longer used in code.
Remove it.
The old geometry used to round down the ECC strength. This allows to
compile a U-Boot which has the same ECC format used in current Linux
kernels by adding this line to the board configuration header file:
#define CONFIG_NAND_MXS_BCH_LEGACY_GEO
Note that this leads to 14 bit ECC per 512 byte block, which requires
2149 bytes overall. The SoC's boot ROM is only able to handle pages
up to 2112 bytes, hence this format cannot be used for the boot/flash
configuration block (BCB/FCB).
Note that upstream Linux can also calculate ECC using JEDEC/ONFI
NAND chip parameters by using the fsl,use-minimum-ecc device tree
property.
Acked-by: Brandon Shibley <brandon.shibley@toradex.com>
Make sure TPS62362 set 0 defaults to 1.200V as the Linux kernel may
switch to set 0 using TPS65911 GPIO1 (EN_CORE_DVFS_N) connected to
TPS62362 VSEL1 prior to actually setting it to a sane value dependent on
the current CPU frequency.
Just release TPS65911 GPIO1 (EN_CORE_DVFS_N) connected to TPS62362
VSEL1 to switch VDD_CORE back to boot set 1 defaulting to 1.200V.
(cherry picked from commit 622d408fea7af6d2ed778b546de346e90ea1a21f)
Implement early TPS6586X PMIC rail configuration setting SM0 being
VDD_CORE_1.2V to 1.2 volts and SM1 being VDD_CPU_1.0V to 1.0 volts.
While those are PMIC power-up defaults the SoC might have been reset
separately with certain rails being left at lower DVFS states which
is e.g. the case upon watchdog reset while otherwise nearly idling.
(cherry picked from commit f7c3186985ebb244d075b04ed7c055f39f485670)
Fix the framebuffer location to the very end of the available memory.
This allows to remove the area from available memory for the kernel,
which in turn allows to display the splash screen through the while
Linux kernel boot process.
Ideas has been taken from the sunxi display driver, e.g.
20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory")
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Code mostly ported from imx-kobs-5.3.
MTD partitioning is set accordingly.
writebcb: Write Boot Control Block (FCB and DBBT)
[ported to U-Boot 2016.11]
Add writebcb command which creates a NAND Boot Configuration Block
(BCB) at the beginning of the active flash device. The BCB stores
the information for the SoC internal boot ROM where the application
with a valid IVT header can be found on the NAND device. The first
two argument of the command need an offset of the NAND device where
the primary and secondary application can be found.
Typically, U-Boot is the application which gets loaded by the boot
ROM. Hence, the offset address need to be the address where U-Boot
(u-boot.imx along with a 0x400 long prefix) is stored on the device.
At least one location is mandatory.
Currently only the FCB (Firmware Configuration Block) is written to
the device. The DBBT (Discovered Bad Block Table) is optional and
not created by writebcb currently.
Introduce USB Gadget config option. This allows to combine Makefile
entries for SPL_USBETH_SUPPORT and SPL_DFU_SUPPORT.
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Ravi Babu <ravibabu@ti.com>
(cherry picked from commit e94793c844a40606252f2e3f6428063e057b3fd2)
The DFU Kconfig menu entries should be part of the SPL
Kconfig file. Also avoid using the top level Makefile by
moving the config dependent build artifacts to the driver/
and driver/usb/gadget/ Makfiles.
With that, DFU can be built again in SPL if
CONFIG_SPL_DFU_SUPPORT is enabled.
Fixes: 6ad6102246d8 ("usb:gadget: Disallow DFU in SPL for now")
(cherry picked from commit 5991703e88f320767d9390d64a6a9bd62560696b)
Basically running the following script:
tools/moveconfig.py CONFIG_TEGRA_MMC
Note that I left the SPL specific handling in
include/configs/tegra-common-post.h unchanged.
Migrate the PXA serial driver to be configured via Kconfig.
(cherry picked from commit d804a5e1c369e59f23723cd21e1e422b7702a0ac)
remove now unused CONFIG_TRDX_PID_XXX
(cherry picked from commit 877ea607a8e07a9ed308e44a58e8e2b9028f01f2)
CONFIG_SUNXI -> CONFIG_ARCH_SUNXI
and removed CONFIG_SUNIX from config_whitelist.txt
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use
CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
[trini: Re-sync]
CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_CONSOLE_ENV_OVERWRITE
CONFIG_CONSOLE_SCROLL_LINES
This is not used in U-Boot. Drop it.
CONFIG_CONSOLE_EXTRA_INFO
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this
option.
This is not used in U-Boot anymore.
CONFIG_SYS_CONSOLE_BG_COL
CONFIG_SYS_CONSOLE_FG_COL
CONFIG_VIDEO_CT69000
CONFIG_CFB_CONSOLE_ANSI
CONFIG_CFB_CONSOLE
This is not really a config. Rename it to avoid confusion.
Reviewed-by: Jagan Teki <jteki@openedev.com>
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_LCD
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
[trini: Re-migrate, update common/console.c logic]
include/configs/ls1021aqds.h
include/configs/ls1021atwr.h
Our build system still parses ad-hoc CONFIG options in header files
and generates include/autoconf.mk so that Makefiles can reference
them. This gimmick was introduced in the pre-Kconfig days and will
be kept until Kconfig migration is completed.
The include/autoconf.mk is generated like follows:
[1] Preprocess include/common.h with -DDO_DEPS_ONLY and
retrieve macros into include/autoconf.mk.tmp
[2] Reformat include/autoconf.mk.dep into include/autoconf.mk
with tools/scripts/define2mk.sed script
[3] Remove include/autoconf.mk.tmp
Here, include/autoconf.mk.tmp is similar to u-boot.cfg, which is
also generated by preprocessing include/config.h with -DDO_DEPS_ONLY.
In other words, there is much overlap among include/autoconf.mk and
u-boot.cfg build rules.
So, the idea is to split the build rule of include/autoconf.mk
into two stages. The first preprocesses headers into u-boot.cfg.
The second parses the u-boot.cfg into include/autoconf.mk. The
build rules of u-boot.cfg in Makefile and spl/Makefile will be gone.
I do not remember why I wrote the code like this, but let's make it
a bit more readable.
The command suggested in this comment block is wrong; it would not
rip off CONFIG options that had already been converted to Kconfig.
Instead, we should use the scripts/build-whitelist.sh tool.
These are not CONFIG options (detected by my eyes).
CONFIG_SPL_BUILD and CONFIG_TPL_BUILD are build options defined only
for building SPL and TPL, respectively.
The others are just mentioned in comment blocks.
Now, scripts/build-whitelist.sh never picks up new options. Once
we kill these false ones, they will never revive.
It is a good practice to drop an option from the whitelist when we
convert it to Kconfig, but we may sometimes forget to do that.
So, it might be a good idea to sync the whitelist from time to time.
This commit was generated by:
Looks like we had a bit progress...
If somebody adds references to new CONFIG options in source files,
they will be added in the whitelist when we sync it. (For example,
if we run scripts/build-whitelist.sh against commit 42f75050667b,
new options CONFIG_SPL_DFU_SUPPORT and CONFIG_USB_XHCI_UNIPHIER will
appear in the list.)
In order to make steady progress of Kconfig migration, we want to
only decrease whitelist options, but never increase.
So, when we update the whitelist, we should create a temporary list,
then take the intersection of the temporary one and the current one.
This script looks for env_common.o object file and extracts from it default
u-boot environment, which is afterwards printed on standard output.
Usage example:
get_default_envs.sh > u-boot-env-default.txt
The generated text file can be used as input for mkenvimage.
Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
Fix various misspellings of:
* deprecated
* partition
* preceding,preceded
* preparation
* its versus it's
* export
* existing
* scenario
* redundant
* remaining
* value
* architecture
Move these options to Kconfig and create a sub-menu to avoid name
conflict with other architectures.
Signed-off-by: York Sun <york.sun@nxp.com>
Traditionally the DFU support is available only
as part 2nd stage boot loader(u-boot) and DFU
is not supported in SPL.
The SPL-DFU feature is useful for boards which
does not have MMC/SD, ethernet boot mechanism
to boot the board and only has USB inteface.
This patch add DFU support in SPL with RAM
memory device support to load and execute u-boot.
And then leverage full functionality DFU in
u-boot to flash boot inital binary images to
factory or bare-metal boards to memory devices
like SPI, eMMC, MMC/SD card using USB interface.
This SPL-DFU support can be enabled through
Menuconfig->Boot Images->Enable SPL-DFU support
Signed-off-by: Ravi Babu <ravibabu@ti.com>
