path: root/net/Makefile
2010-10-11rarp: Condtionally compile rarp supportPeter Tyser
Most people don't use the 'rarpboot' command, so only enable it when CONFIG_CMD_RARP is defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13net: pull CONFIG checks out of source and into makefileMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-07minor debug cleanups in ./netRobin Getz
Minor ./net cleanups - no functional changes - change #ifdef DEBUG printf(); #endif to just debug() - changed __FUNCTION__ to __func__ - got rid of extra whitespace between function and opening brace - removed unnecessary braces on if statements gcc dead code elimination should make this functionally/size equivalent when DEBUG is not defined. (confirmed on Blackfin, with gcc 4.3.3). Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22Add DNS supportRobin Getz
On 04 Oct 2008 Pieter posted a dns implementation for U-Boot. http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg10216.html > > DNS can be enabled by setting CFG_CMD_DNS. After performing a query, > the serverip environment var is updated. > > Probably there are some cosmetic issues with the patch. Unfortunatly I > do not have the time to correct these. So if anybody else likes DNS > support in U-Boot and has the time, feel free to patch it in the main tree. Here it is again - slightly modified & smaller: - update to 2009-06 (Pieter's patch was for U-Boot 1.2.0) - README.dns is added - syntax is changed (now takes a third option, the env var to store the result in) - add a random port() function in net.c - sort Makefile in ./net/Makefile - dns just returns unless a env var is given - run through checkpatch, and clean up style issues - remove packet from stack - cleaned up some comments - failure returns much faster (if server responds, don't wait for timeout) - use built in functions (memcpy) rather than byte copy. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-09net/sntp.c: move ifdef into Makefile COBJS-$(...)Mike Frysinger
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2005-04-01* Patch by Masami Komiya, 30 Mar 2005:wdenk
add SNTP support and expand time server and time offset fields of DHCP support. See doc/README.SNTP * Patch by Steven Scholz, 13 Dec 2004: Fix bug in at91rm920 ethernet driver
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
2002-02-24Initial revisionwdenk
