path: root/nand_spl
2012-02-12Changes to move hawkboard to the new spl infrastructureSughosh Ganu
This patch moves hawkboard to the new spl infrastructure from the older nand_spl one. Removed the hawkboard_nand_config build option -- The spl code now gets compiled with hawkboard_config, after building the main u-boot image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard to reflect the same. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2012-01-26nand_spl: store ecc data on the stackScott Wood
Adapt the following patch from spl to nand_spl: Author: Stefano Babic <sbabic@denx.de> Date: Thu Dec 15 10:55:37 2011 +0100 nand_spl_simple: store ecc data on the stack Currently nand_spl_simple puts it's temp data at 0x10000 offset in SDRAM which is likely to contain already loaded data. The patch saves the oob data and the ecc on the stack replacing the fixed address in RAM. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Ilya Yanok <yanok@emcraft.com> CC: Scott Wood <scottwood@freescale.com> CC: Tom Rini <tom.rini@gmail.com> CC: Simon Schwarz <simonschwarzcor@googlemail.com> CC: Wolfgang Denk <wd@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com> While nand_spl is on its way out, in favor of spl, there are still many boards using it, and conversions are gradual. This allows us to get rid of CONFIG_SYS_NAND_ECCSTEPS and CONFIG_SYS_NAND_ECCTOTAL now, which would otherwise be likely to linger unreferenced after a conversion. It also eliminates a temporary error in the hawkboard_nand build, since the spl version of the patch removed ECCSTEPS/TOTAL from hawkboard.h, but the spl conversion is pending (and may be merged via a different tree). Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-07nand_spl/nand_boot.c: Fix build warningAnatolij Gustschin
Fix: nand_boot.c: In function 'nand_read_page': nand_boot.c:150:6: warning: variable 'stat' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-06davinci: Remove unwanted memsize.c from hawkboard's nand spl buildSughosh Ganu
dram_init function in board/davinci/common/misc.c does not get compiled for spl builds, thus rendering inclusion of memsize.c useless. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
2011-12-06arm, davinci: move misc function in arch treeHeiko Schocher
move the board/davinci/common/misc.c file to arch/arm/cpu/arm926ejs/davinci/misc.c, so all davinci boards can use this functions. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Christian Riesch <christian.riesch@omicron.at>
2011-12-06arm, hawkboard: Use the pinmux configurations defined in the arch treeChristian Riesch
The boards in board/davinci/da8xxevm/ define pinmux_config[] vectors that contain pinmux configurations for emac, uarts, memory controllers... In an earlier patch such pinmux configurations were added to the arch tree. This patch makes the hawkboard use these definitions instead of defining its own. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2011-12-06arm, davinci: Move pinmux functions from board to arch treeChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Nick Thompson <nick.thompson@ge.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Nick Thompson <nick.thompson@ge.com>
2011-12-06Fix regression in SMDK6400Simon Schwarz
s3c64xx.c implemented its own nand_read_byte, nand_write_buf and nand_read_buf functions. This provoked a regression when these functions were made public by patch 55f429bb39614a16b1bacc9a8bea9ac01a60bfc8. This deletes these duplicated functions from s3c64xx.c and adds the generic implementations in nand_base.c to the spl Makefile. It also adds -ffcuntion-sections and -gc-sections to the compilation flags of the SPL to avoid errors originating from unused functions in nand_base.c. Description of the regression: http://article.gmane.org/gmane.comp.boot-loaders.u-boot/108873 Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Cc: scottwood@freescale.com Cc: s-paulraj@ti.com Cc: albert.u.boot@aribaud.net
2011-11-16nand_boot.c: Fix GCC 4.6 build warningsStefan Roese
Fix: nand_boot.c: In function 'nand_read_page': nand_boot.c:190:6: warning: variable 'stat' set but not used [-Wunused-but-set-variable] nand_boot.c: In function 'nand_boot': nand_boot.c:271:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] Signed-off-by: Stefan Roese <sr@denx.de>
2011-10-04Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
* 'master' of git://git.denx.de/u-boot-nand-flash: PPC: Fix socrates NAND problem PPC: Fix fsl_upm.c by renaming nand handling functions NAND: Make page, erase, oob size available via cmd_nand mtd: eLBC NAND: remove elbc_fcm_ctrl->oob_poi NAND: Add -y option to nand scrub command NAND: Add nand read.raw and write.raw commands NAND: Really ignore bad blocks when scrubbing spl, nand: add 4bit HW ecc oob first nand_read_page function mxc_nand: fix a problem writing more than 32MB mxc_nand: fixed some typos (cosmetic) nand: increase chip_delay in mv kirkwood nand driver
2011-10-04Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: powerpc/p3060: Add SoC related support for P3060 platform powerpc/85xx: Add support for setting up RAID engine liodns on P5020 powerpc/85xx: Refactor some defines out of corenet_ds.h fm-eth: Add ability for board code to disable a port powerpc/mpc8548: Add workaround for erratum NMG_LBC103 powerpc/mpc8548: Add workaround for erratum NMG_DDR120 powerpc/mpc85xxcds: Fix PCI speed powerpc/mpc8548cds: Fix booting message powerpc/p4080: Add support for secure boot flow powerpc/85xx: Add Secure Boot support on P1010RDB for NOR, NAND & SPIFLASH powerpc/85xx: Add PBL & SECUREBOOT support on P3041/P5020DS boards powerpc/p2041rdb: remove watch dog related codes powerpc/p2041rdb: updated description of cpld command powerpc/p2041rdb: add more ddr frequencies support powerpc/p2041rdb: set sysclk according to status of physical switch SW1 powerpc/p2041rdb: update cpld reset command according to CPLD 2.0 powerpc/mpc8349emds: Migrate from spd_sdram to unified DDR driver powerpc/mpc83xx: Migrate from spd_sdram to unified DDR driver powerpc/mpc8xxx: Add DDR2 to unified DDR driver powerpc/mpc8xxx: Fix picos_to_mclk() and get_memory_clk_period_ps() powerpc/mpc8xxx: Add SPD EEPROM address for single controller 2 slots powerpc/mpc8xxx: Fix DDR code for empty first DIMM slot and enable DQS_en powerpc/85xx: Refactor P2041RDB to use common p_corenet files powerpc/85xx: refactor common P-Series CoreNet files for FSL boards powerpc/85xx: Enable CMD_REGINFO on corenet boards powerpc/85xx: p2041rdb - Remove unused 'execute' perm in TLB entries powerpc/85xx: Fix USB protocol definitions for P1020RDB powerpc/corenet_ds: Use separated speed tables for UDIMM and RDIMM powerpc/mpc8xxx: Move DDR RCW overriding to common code powerpc/mpc8xxx: Extend CWL table powerpc/85xx: Cleanup how SVR_MAJ() is defined on MPC8536 powerpc/85xx: Cleanup extern in corenet_ds board code powerpc/p2041rdb: Add ethernet support on P2041RDB board powerpc/85xx: Add networking support to P1023RDS powerpc/hydra: Add ethernet support on P5020/P3041 DS boards powerpc/85xx: Add FMan ethernet support to P4080DS powerpc/85xx: Add support for FMan ethernet in Independent mode powerpc/mpc8548cds: Cleanup mpc8548cds.c powerpc/mp: add support for discontiguous cores powerpc/85xx: corenet_ds - Remove unused 'execute' perm in TLB entries fdt: Add new fdt_create_phandle helper fdt: Rename fdt_create_phandle to fdt_set_phandle powerpc/85xx: Fix compile warnings/errors if CONFIG_SYS_DPAA_FMAN isn't set fsl_ifc: Add the workaround for erratum IFC A-003399(enabled on P1010) powerpc/P1010: Add workaround for erratum P1010-A003549 (related to IFC) fsl_ifc: Add the workaround for erratum IFC-A002769 (enable on P1010) powerpc/85xx: Expanding the window of CCSRBAR in AS=1 from 4k to 1M powerpc/85xx: Add NAND/NAND_SPL support to P1010RDB nand: Freescale Integrated Flash Controller NAND support powerpc/85xx: Add basic support for P1010RDB powerpc/85xx: Add support for new P102x/P2020 RDB style boards powerpc/85xx: relocate CCSR before creating the initial RAM area powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macros powerpc/85xx: Enable internal USB UTMI PHY on p204x/p3041/p50x0 powerpc/85xx: Add ULPI and UTMI USB Phy support for P1010/P1014
2011-10-03spl, nand: add 4bit HW ecc oob first nand_read_page functionHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-09-30MX31: mx31pdk: Remove nand_spl config.mk fileFabio Estevam
No need to have a config.mk to only store a single line. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-29powerpc/85xx: Add NAND/NAND_SPL support to P1010RDBDipen Dudhat
And various defines to enable NAND support and NAND spl code for the P1010RDB platform. Signed-off-by: Dipen Dudhat <Dipen.Dudhat@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29nand: Freescale Integrated Flash Controller NAND supportDipen Dudhat
Add NAND support (including spl) on IFC, such as is found on the p1010. Note that using hardware ECC on IFC with small-page NAND (which is what comes on the p1010rdb reference board) means there will be insufficient OOB space for JFFS2, since IFC does not support 1-bit ECC. UBI should work, as it does not use OOB for anything but ECC. When hardware ECC is not enabled in CSOR, software ECC is now used. Signed-off-by: Dipen Dudhat <Dipen.Dudhat@freescale.com> [scottwood@freescale.com: ECC rework and misc fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-09-29powerpc/85xx: Add support for new P102x/P2020 RDB style boardsLi Yang
The following boards share a common design but with minor variations between them: P1020MSBG-PC P1020RDB-PC P1020UTM-PC P1021RDB-PC P1024RDB P1025RDB P2020RDB-PC The P1020RDB-PC shares its roots in the existing P1020RDB board design, however uses DDR3 instead of DDR2. P2020RDB-PC differs from the P102x RDB-PC with 64-bit DDR and 100Mhz SYSCLK. Key features on these boards include: * DDR3 * NOR flash * NAND flash (on RDB's only) * SPI flash (on RDB's only) * SDHC/MMC card slot * VSC7385 Ethernet switch (on P1020MBG, P1020RDB, & P1021RDB) * PCIE slot and mini-PCIE slots As these boards use soldered DDR chips not regular DIMMs, an on-board EEPROM is used to store SPD data. In case of absent or corrupted SPD, falling back to timing data embedded in the source code will be used. Raw timing data is extracted from DDR chip datasheet. Different speeds of DDR are supported with this approach. ODT option is forced to fit this set of boards, again because they don't have regular DIMMs. CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS is defined as 5ms to meet specification for writing timing. VSC firmware Address is defined by default in config file for eTSEC1. SD width is based off DIP switch. DIP switch is detected on the board by reading i2c bus and setting the appropriate mux values. Some boards have QE module in the silicon (P1021 and P1025). QE and eLBC have pins multiplexing. QE function needs to be disabled to access Nor Flash and CPLD. QE-UEC and QE-UART can be enabled for linux kernel by setting "qe" in hwconfig. In addition, QE-UEC and QE-TDM also have pins multiplexing, to enable QE-TDM for linux kernel, set "qe;tdm" in hwconfig. Syntax is as below 'setenv hwconfig qe' to enable QE UEC/UART and disable Nor-Flash/CPLD. 'setenv hwconfig 'qe;tdm'' to enalbe QE TDM and disable Nor-Flash/CPLD. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Zhao Chenhui <b26998@freescale.com> Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Tang Yuantian <b29983@freescale.com> Signed-off-by: ramneek.mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Xie Xiaobo <X.Xie@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Akhil Goyal <akhil.goyal@freescale.com>
2011-09-10ARM: hawkboard_nand: fix compilation of nand_splStefano Babic
get_ram_size() is called, but memsize.c is not compiled. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-26replace CONFIG_PRELOADER with CONFIG_SPL_BUILDAneesh V
replace all occurences of CONFIG_PRELOADER with CONFIG_SPL_BUILD Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-11powerpc/85xx: Add basic support for P1023RDS boardRoy Zang
The P1023RDS board is the reference board for the P1023 SoC. Add support for booting it from NOR or NAND, with fixed 2G of DDR, PCIe, UART, I2C, etc. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Signed-off-by: Lei Xu <B33228@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-01NAND: Add 16bit NAND support for the NDFCAlex Waterman
This patch adds support for 16 bit NAND devices attached to the NDFC on ppc4xx processors. Two config entries were added: CONFIG_SYS_NDFC_16 - Setting this tells the NDFC that a 16 bit device is attached. CONFIG_SYS_NDFC_EBC0_CFG - This is for the External Bus Controller configuration register. Also, a new ndfc_read_byte() function was added which does not first convert the data to little endian. The NAND SPL was also modified to do 16bit bad block testing when a 16 bit chip is being used. Signed-off-by: Alex Waterman <awaterman@dawning.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-05-26Add _end for the end of u-boot image for SMDK6400seedshope
Since we rename _end to __bss_end__, But we need add _end symbol for the end of u-boot image. Signed-off-by: Zhong Hongbo <bocui107@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-05-16nand_spl: nand_boot.c: Remove last CONFIG_SYS_NAND_READ_DELAY occuranceStefan Roese
Remove the last CONFIG_SYS_NAND_READ_DELAY occurance from nand_boot.c. I missed this one in patch a9c847cb [nand_spl: nand_boot.c: Remove CONFIG_SYS_NAND_READ_DELAY]. This fixes a compile breakage on kilauea_nand for example. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-05-13nand_spl: nand_boot.c: Remove CONFIG_SYS_NAND_READ_DELAYStefan Roese
There are multiple reasons why this define should be removed: First it saves some space and therefore fixes a problem we have on the canyonlands_nand and glacier_nand targets right now. Second, the define was hackish and would most likely not work on all board using nand_boot.c. Boards not providing a real dev_ready() function should implement a board specific function instead. I checked and it seems, that all boards using nand_boot.c right now already implement a board specific dev_ready() function. So this patch should not break any boards and will result in smaller NAND_SPL images. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Tested-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-05-13nand_spl: nand_boot.c: Init nand_chip.options to 0Stefan Roese
Patch 65a9db7b [nand_spl: Fix large page nand_command()] broke nand booting on canyonlands. "options" has to be initialized to 0. If not, boards might have the NAND_BUSWIDTH_16 bit set, resulting in wrong offset calculation. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Alex Waterman <awaterman@dawning.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-05-13Decreases code size of the nand_splAlex Waterman
The canyonland boards nand_spl size is just under the maximum 4KByte size. This patch decreases the size of the nand_spl to make a previous commit - commit 65a9db7be0868be91ba81b9b5bf821de82e6d9b0 - fit in the nand_spl. Signed-off-by: Alex Waterman <awaterman@dawning.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-04-27Fix the issue of _end symbol not being found while buildingSughosh Ganu
Fix the nand_spl build for the hawkboard Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
2011-04-27MX25: tx25: Add _end section on nand_splFabio Estevam
Commit f326cbb (arm: fix incorrect monitor protection region in FLASH) missed to update nand_spl/board/karo/tx25/u-boot.lds. Add the _end section. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-04-27MX31: mx31pdk: fix nand_splStefano Babic
Commit f326cbba98bae21d41df8daac0bd78121d557af1 breaks mx31pdk, as the _end section in u-boot.lds is missing for the nand_spl production. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-04-27IMX: MX31: Cleanup include files and drop nasty #ifdef in driversStefano Babic
As exception among the i.MX processors, the i.MX31 has headers without general names (mx31-regs.h, mx31.h instead of imx-regs.h and clock.h). This requires several nasty #ifdef in the drivers to include the correct header. The patch cleans up the driver and renames the header files as for the other i.MX processors. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-04-15powerpc/85xx: Modify NAND loader makefiles to compile NAND_SPL linker scriptDipen Dudhat
Modify eLBC based platform's NAND loader Makefile to preprocess nand loader linker script and then use it. Signed-off-by: Dipen Dudhat <Dipen.Dudhat@freescale.com> CC: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-15nand_spl: Fix large page nand_command()Alex Waterman
This patch changes the large page nand_command() routine to use a word offset instead of a byte offset. The 'offs' argument gets divided by 2 so that the offset passed to nand_command() is still by byte offset. Originally, the offset was not shifted and when too high an offset was requested the nand chip would attempt to read non-existent data. Signed-off-by: Alex Waterman <awaterman@dawning.com>
2011-04-15nand/spl: Assuming a static nand page size to reduce code sizeMatthew McClintock
Change variables to const to reduce code size, these values are hardcoded via defines anyways so we might as well assume they are constants Signed-off-by: Matthew McClintock <msm@freescale.com> cc: Scott Wood <scottwood@freescale.com>
2011-03-31Fix build issues cause by LDFLAGS_FINAL changesWolfgang Denk
Commit 6dc1ece "Introduce a new linker flag LDFLAGS_FINAL" modified a number of Makefiles in a way that broke out-of-tree builds. The problem was that $(nandobj) was used before it got defined. Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-03-27SMDK6400: Add some labels to u-boot.lds to support nand_splseedshope
In the nand_spl feature of SMDK6400. Add some relocation symbols to nand_spl/board/samsung/smdk6400/u-boot.lds to fix the compile error. Signed-off-by: Zhong Hongbo <bocui107@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-03-22Introduce a new linker flag LDFLAGS_FINALHaiying Wang
commit 8aba9dceebb14144e07d19593111ee3a999c37fc Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGS breaks the usage of --gc-section to build nand_spl. We still need linker option --gc-section for every uboot image, not only the main one. LDFLAGS_FINAL passes the --gc-sections to each uboot image. To get the proper linker flags, we use LDFLAGS and LDFLAGS_FINAL to replace PLATFORM_LDFLAGS in the Makefile of each nand_spl board. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2011-02-21mx31pdk: Use the new relocation schemeFabio Estevam
2011-01-14powerpc/85xx: Add support for booting from NAND on MPC8572DSKumar Gala
Mimic support that exists on MPC8536DS on the MPC8572DS to allow booting from NAND. Signed-off-by: Jin Qing <b24347@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-12-17PowerPC, nand_spl: Add relocation support for -fpicJoakim Tjernlund
By rearranging the linker script we get support for relocation of -fpic for free. Move __got2_entries outside _GOT2_TABLE_ defining scope matching the rest of PowerPC Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Acked-by: Scott Wood <scottwood@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2010-12-16powerpc/nand spl: link libgccScott Wood
Recent GCC (4.4+) performs out-of-line epilogues in some cases, when optimizing for size. It causes a link error for _restgpr_30_x (and similar) if libgcc is not linked. It actually increases size with very small binaries, due to the fixed size of the out-of-line code, and not having any functions that actually need to restore more than 2 or 3 registers. But I don't see a way to turn it off, other than asking GCC to optimize for speed -- which may also increase size for some boards. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Wolfgang Denk <wd@denx.de>
2010-11-30Davinci 8xx: Move common functions to share codeStefano Babic
As more Davinci 8xx board can be added, move common code to be shared between boards. * rebased ontop of Sugosh's patches * moving the HAWKBOARD_KICK{0,1}_UNLOCK defines to arch/arm/include/asm/arch-davinci/davinci_misc.h from to arch/arm/include/asm/arch-davinci/da8xx_common.h * don't define dram functions in PRELOADER * move sync_env_enetaddr into existing EMAC ifdef * use misc.c in hawkboard nand_spl Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-30Add board support for hawkboardSughosh Ganu
The patch adds basic board support for TI's OMAP-L138 based Hawkboard. This board is pretty similar to the da850 EVM. Support for nand and network access is added in this version. The following bootup procedure is used. At reset, the Rom Boot Loader(RBL), initialises the ddr and the nand controllers and copies the second stage bootloader(nand_spl) to RAM. The secondary bootloader then copies u-boot from a predefined location in the nand flash to the RAM, and passes control to the u-boot image. Three config options are supported * hawkboard_config - Used to create the u-boot.bin. Tftp the u-boot.bin image to the RAM from u-boot, and flash to the nand flash at address 0xe0000. * hawkboard_nand_config - Used to generate the secondary bootloader(nand_spl) image. This creates an elf file u-boot-spl under nand_spl/. Create an AIS signed image using this file, and flash it to the nand flash at address 0x20000. The ais file should fit in one block. * hawkboard_uart_config - This is same as the first image, but with the TEXT_BASE as expected by the RBL(0xc1080000). Create the AIS Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-28Remove board_init_f function from nand_boot.cSughosh Ganu
Remove the board_init_f function from nand_spl/nand_boot.c. This function is to be defined by all boards using the nand_spl functionality in their individual board directory. Currently this function was being used by the smdk6400 board. Added the board specific function definition. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-2783xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Haiying Wang <r54964@freescale.com>
2010-11-27ppc4xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
This commit adapts 4xx boards for partial linking with --gc-sections. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Tirumala Marri <tmarri@apm.com> Cc: David Updegraff <dave@cray.com> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Larry Johnson <lrj@acm.org> Cc: Peter De Schrijver <p2@mind.be> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Daniel Poirot <dan.poirot@windriver.com> Acked-by: Stefan Roese <sr@denx.de>
2010-11-2783xx: Fix NAND_SPL link addressScott Wood
Apply the same fix for 83xx as was done for 85xx in commit 96196a1f7546904563994d2d041804a816d7c139. Without this, NAND SPLs are built with the text base intended for the main image, resulting in a broken, very large u-boot-nand.bin. The block of defines for NAND boot is moved closer to where CONFIG_SYS_TEXT_BASE is defined. We can't directly use CONFIG_SYS_NAND_U_BOOT_DST in the definition of CONFIG_SYS_TEXT_BASE because autoconf.mk will include the literal text "CONFIG_SYS_NAND_U_BOOT_DST", but at least keep them close and point out that they're supposed to be the same. Signed-off-by: Scott Wood <scottwood@freescale.com>
2010-11-17Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-11-17tx25: fix linker file for newer ld supportAlbert Aribaud
older ld emitted all ELF relocations in input sections named .rel.dyn, whereas newer ld uses names of the form .rel*. The linker script only collected .rel.dyn input sections. Rewrite to collect all .rel* input sections. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-11-12powerpc/85xx: add CONFIG_SYS_TEXT_BASE_SPL for 85xx nand spl buildHaiying Wang
Introduce a SPL specific CONFIG_SYS_TEXT_BASE_SPL define to be used by the linker. This has similiar semantics to CONFIG_SYS_TEXT_BASE however since SPL is a unqiue image we introduce a new variable to control its text base address. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
