path: root/nand_spl/nand_boot_fsl_ifc.c
2011-09-29nand: Freescale Integrated Flash Controller NAND supportDipen Dudhat
Add NAND support (including spl) on IFC, such as is found on the p1010. Note that using hardware ECC on IFC with small-page NAND (which is what comes on the p1010rdb reference board) means there will be insufficient OOB space for JFFS2, since IFC does not support 1-bit ECC. UBI should work, as it does not use OOB for anything but ECC. When hardware ECC is not enabled in CSOR, software ECC is now used. Signed-off-by: Dipen Dudhat <Dipen.Dudhat@freescale.com> [scottwood@freescale.com: ECC rework and misc fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
