path: root/lib/libfdt
2011-07-14libfdt: Implement property iteration functionsDavid Gibson
For ages, we've been talking about adding functions to libfdt to allow iteration through properties. So, finally, here are some. I got bogged down on this for a long time because I didn't want to expose offsets directly to properties to the callers. But without that, attempting to make reasonable iteration functions just became horrible. So eventually, I settled on an interface which does now expose property offsets. fdt_first_property_offset() and fdt_next_property_offset() are used to step through the offsets of the properties starting from a particularly node offset. The details of the property at each offset can then be retrieved with either fdt_get_property_by_offset() or fdt_getprop_by_offset() which have interfaces similar to fdt_get_property() and fdt_getprop() respectively. No explicit testcases are included, but we do use the new functions to reimplement the existing fdt_get_property() function. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> This was extracted from the DTC commit: 73dca9ae0b9abe6924ba640164ecce9f8df69c5a Mon Sep 17 00:00:00 2001 Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2011-07-14Support ePAPR compliant phandle propertiesDavid Gibson
Currently, the Linux kernel, libfdt and dtc, when using flattened device trees encode a node's phandle into a property named "linux,phandle". The ePAPR specification, however - aiming as it is to not be a Linux specific spec - requires that phandles be encoded in a property named simply "phandle". This patch adds support for this newer approach to dtc and libfdt. Specifically: - fdt_get_phandle() will now return the correct phandle if it is supplied in either of these properties - fdt_node_offset_by_phandle() will correctly find a node with the given phandle encoded in either property. - By default, when auto-generating phandles, dtc will encode it into both properties for maximum compatibility. A new -H option allows either only old-style or only new-style properties to be generated. - If phandle properties are explicitly supplied in the dts file, dtc will not auto-generate ones in the alternate format. - If both properties are supplied, dtc will check that they have the same value. - Some existing testcases are updated to use a mix of old and new-style phandles, partially testing the changes. - A new phandle_format test further tests the libfdt support, and the -H option. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> This was extracted from the DTC commit: d75b33af676d0beac8398651a7f09037555a550b Mon Sep 17 00:00:00 2001 Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2010-04-13Move libfdt/ into lib/Peter Tyser
Move the libfdt directory into the common lib/ directory to clean up the top-level directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
