path: root/include
2020-06-12colibri_imx6: use distro_bootcmd as default boot cmdIgor Opaniuk
1. Drop legacy emmcboot, usbboot and sdboot wrappers from env. 2. Change bootcmd to use only distro_bootcmd 3. Change the "boot try" order. Default one is: SD -> eMMC -> USB -> DHCP 4. Drop DFU defines Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2020-06-12colibri_imx7: use distro_bootcmd as default boot cmdIgor Opaniuk
2020-06-12apalis_imx6: use distro_bootcmd as default boot cmdIgor Opaniuk
2020-04-06apalis-tk1: enable distrobootIgor Opaniuk
1. Enable Distro Boot instead of legcay emmcboot wrapper 2. Drop emmcboot and sdboot wrappers 3. Provide proper boot order for Distro Boot Relates-to: ELB-2678 Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2020-03-28configs/colibri_vf.h: drop sdboot in favour of distro_bootcmdMax Krummenacher
The distro bootscript uses kernel_image to get the file name of the kernel, so change that variable name. UBI boot has precedence in the default boot command. If one wants to boot from SD with a working NAND installation stop in U-Boot and enter: setenv fdtfile ${soc}-colibri-${fdt_board}.dtb && run distro_bootcmd Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-03-04board: apalis_imx6: Add KSZ9131 phy skew settingsPhilippe Schenker
This patch adds skew register settings for KSZ9131. It checks first which phy is on the board and then applies the correct skew settings. Skew settings calculation for the KSZ9131: The i.MX6 SoC has an output skew tolerance of -100ps to 900ps. All PCB traces where routed exactly the same length so we can calculate the skew settings without taking the length into consideration. RXC skew (PHY to MAC): - We use the 2ns DLL controlled delay on the PHY - We do not use the skew registers This results in the following values: RXC PHY fixed Delay 2000ps PHY Added Delay 0ps T_setup_R min 2.00ns T_setup_R typ 2.00ns T_setup_R max 2.00ns T_hold_R min 1.60ns T_hold_R typ 2.00ns T_hold_R max 2.40ns That means we are well within RGMII specs. TXC skew (MAC to PHY): - We use the 2ns DLL controlled delay on the PHY - We then substract ~0.6ns with TXD[0:3] and TXC clock pad skew register in a resulting ~1.4ns delay. This results in the following values under consideration of the tolerances: TXC min TXC typ TXC max MAC min -100ps -100ps -100ps MAC max 900ps 900ps 900ps PHY fixed Delay 2000ps 2000ps 2000ps PHY added Delay -340ps -600ps -859ps T_setup_T min 1.56ns 1.30ns 1.04ns T_setup_T typ 2.06ns 1.80ns 1.54ns T_setup_T max 2.56ns 2.30ns 2.04ns T_hold_T min 1.04ns 1.30ns 1.56ns T_hold_T typ 1.94ns 2.20ns 2.46ns T_hold_T max 2.84ns 3.10ns 3.36ns This shows that T_hold_T min and T_setup_T min times are out of spec for RGMII timing. However the KSZ9131 has a minimal value for this time of 0.8ns which is met under all circumstances. Related-to: ELB-1299 Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2020-03-04drivers: net: phy: micrel_ksz90x1.c: Add basic support for KSZ9131Philippe Schenker
This adds basic support for the new Micrel KSZ9131 phy. Related-to: ELB-1299 Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2020-03-04net: phy: micrel: Use defines for PHY_IDs and MASKPhilippe Schenker
2019-12-23common: fdt_support: add support for setting usable memoryIgor Opaniuk
Add support for setting linux,usable-memory property in the memory node of device tree for the kernel [1]. This property holds a base address and size, describing a limited region in which memory may be considered available for use by the kernel. Memory outside of this range is not available for use. [1] https://www.kernel.org/doc/Documentation/devicetree/bindings/chosen.txt Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> (cherry picked from commit 949b5a969d107613b61a1e5eaf9e43c75a97f42c)
2019-10-14colibri-imx6ull/imx7: define bootubipart for distro bootStefan Agner
When using distro boot to boot from UBI volumes the boot partition has been hardcoded to "UBI" (capital letters). However, our default MTD layout uses "ubi" (lower case letter). Define "ubi" as the default UBI partition for distro boot for Toradex. This allows to use distro boot without having to redefine the MTD partition layout which is useful for TorizonCore. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2019-09-19colibri_imx7: add addresses required for distro bootStefan Agner
Define addresses required for full distro boot support. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2019-08-16colibri_imx7: boot kernel in secure modeColibri-iMX7_Console-Image_3.0b2.65-20190830Colibri-iMX6_Console-Image_3.0b2.65-20190830Colibri-iMX6ULL_Console-Image_3.0b2.65-20190830Apalis-iMX6_Console-Image_3.0b2.65-20190830Apalis-TK1_Console-Image_3.0b2.65-20190830Apalis-TK1-Mainline_Console-Image_3.0b2.65-20190830Igor Opaniuk
NXP downstream kernel uses legacy method to enable other cores, which requires kernel to run in a security mode (althought upstream kernel uses PSCI for this). As we're using NXP kernel in our BSPs, lets enable this by default. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-08-16apalis-tk1: configs: remove legacy usbboot commandIgor Opaniuk
Remove obsolete legacy usbboot wrapper, as distroboot can handle booting from USB drivers. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (cherry picked from commit bd20266d1923f1230ed15020fbb12aa56f3f46b7)
2019-08-16apalis-tk1: support v1.2 hardware revisionMarcel Ziswiler
Support the V1.2 hardware revision with the following pin muxing changes: Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4 are now used as DDC pins. Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are now used as USB power enable signals. Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power enable signals are now used as GPIO3 and GPIO4. Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is loaded on V1.2 and later modules and resp. USB power enable signals activated. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (cherry picked from commit 4c63a601b90db131e92d3f6f6da6a4bc2b287df1)
2019-08-16apalis-tk1: remove default vesa vga mode from vidargsMarcel Ziswiler
Remove video=tegrafb0:640x480-16@60 aka VESA VGA mode from vidargs in order for the panel specification in the device tree to be used. This causes the default to be the 10.1" LVDS display which will be available in the Toradex webshop shortly. Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (cherry picked from commit d415eab4f0abb3b9dd84c50c9ded0ff976a32a2f)
2019-08-16apalis-tk1: add pcie_aspm=off to defargsIgor Opaniuk
Disabling ASPM fixes incompatibilities with some PCIe cards Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (cherry picked from commit f7c668a4e8dce3975a7c07834c448584f768a44f)
2019-08-16apalis-tk1: enable user debug by defaultIgor Opaniuk
Let the kernel print some debug messages when a user program crashes due to an exception. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (cherry picked from commit 11d96e122a29eab51242b6502dd7ff9cce533fef)
2019-07-16board: toradex: declare consoleargsOleksandr Suvorov
Concept: store all console-related kernel parameters in dedicated variable. Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-07-13colibri-imx6ull: fix vidargsMarcel Ziswiler
Unfortunately, that missing M makes the current downstream NXP BSP 4.14.98_2.0.0_ga crash early during Linux kernel boot. Fix this. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Tested-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-11apalis-tk1: switch to zimageMax Krummenacher
Switch to the generic compressed Kernel image type (zImage) instead of the U-Boot specific uImage format. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-07-09colibri-imx6ull: support building with DM_VIDEO=yIgor Opaniuk
1. This fixes linking issues when building with DM_VIDEO enabled mxsfb driver. 2. Provide proper defines for both VIDEO=y and DM_VIDEO=y. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-09video: fsl_dcu_fb: refactor init functionsIgor Opaniuk
Move dcu-related code to fsl_dcu_probe_common, keep in video_hw_init() only legacy video stack (filling GraphicPanel struct etc.). Add wrappers for all init functions, that will let to provide struct fb_info as an additional param (needed for further moving it from the global scope to driver private data struct in DM converted driver). Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-09apalis-imx8: enable hdp firmware loadingMarcel Ziswiler
2019-07-09MLK-17205-3 video: imx: hdp: Adding configs for HDP firmware loadingOliver Brown
Added default environment for hdp loading. Added hdp loading as default for iMX8QM MEK board. Signed-off-by: Oliver Brown <oliver.brown@nxp.com> (cherry picked from downstream commit 432e5b4347841095c3b5a8a0d106f35deadd006e) (cherry picked from downstream commit cb78a32fa8eb8c37932be003ebe4fa1f8c46c1d5)
2019-07-07Merge tag 'dm-pull-7jul19' of https://gitlab.denx.de/u-boot/custodians/u-boot-dmTom Rini
Fix booting for wandboard
2019-07-07imx6: wandboard: allow booting from MMC 2Heinrich Schuchardt
One of the SD-CARD slots on the Wandboard Quad B1 is MMC 2. Enable it as a boot device. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-07-07Merge https://gitlab.denx.de/u-boot/custodians/u-boot-usbTom Rini
- DWC and i.MX6 fixes
2019-07-05Merge tag 'rpi-next-2019.07' of https://github.com/mbgg/u-bootTom Rini
- fix complation error for CONFIG_USB - update RPi3 DTBs to v5.1-rc6 state - add defconfig for RPi3 B+ - Fix BCM2835_MBOX_TAG_TEST_PIXEL_ORDER define
2019-07-05dm: Add a No-op uclassJean-Jacques Hiblot
This uclass is intended for devices that do not need any features from the uclass, including binding children. This will typically be used by devices that are used to bind child devices but do not use dm_scan_fdt_dev() to do it. That is for example the case of several USB wrappers that have 2 child devices (1 for device and 1 for host) but bind only one at a any given time. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-07-02rockchip: config: tiner-rk3288: extend CONFIG_SYS_MONITOR_LEN to 600KBKever Yang
The raw u-boot.bin for tinker board has been about 450KB without debug option, and 550KB with all debug on, and the default value is 200KB, which is not enough for run raw u-boot.bin. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-29efi_loader: correct signature of ConvertPointer()Heinrich Schuchardt
ConvertPointer() must be EFIAPI. The first parameter should be of type efi_uint_t. Use the same parameter name as the UEFI specification. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-06-28Merge tag 'u-boot-imx-20190628' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx Fixes for 2019.07 - menlo board - allow SDB on Sabre - HAB for mx6sl - apalis board
2019-06-28apalis_imx6: increase phy autoneg timeoutIgor Opaniuk
Default value (4000ms) of PHY_ANEG_TIMEOUT for Micrel KSZ9031 contoller isn't sufficient to finish auto-negotiation, which sometimes leads to timeout errors: Apalis iMX6 # dhcp FEC Waiting for PHY auto negotiation to complete......... TIMEOUT ! Increase the auto-negotiation time-out to 15000ms. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Philippe Schenker <philippe.schenker@toradex.com>
2019-06-28ARM: imx: m53menlo: Convert to DM VIDEOMarek Vasut
Enable DM Video support on iMX53 M53Menlo and fix minor details to restore previous behavior of the system. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-27pico-imx7d: remove unused 'script' variablePierre-Jean Texier
Since the pico-pi uses the distroboot, this commit remove the 'script' variable (cf boot_scripts). Signed-off-by: Pierre-Jean Texier <pjtexier@koncepto.io> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-06-27apalis_imx6: fix set_emmcargs wrapperIgor Opaniuk
Fix set_emmcargs wrapper, which prepares proper bootargs for booting from eMMC. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Philippe Schenker <philippe.schenker@toradex.com>
2019-06-27usb: gadget: f_sdp: Allow SPL to load and boot FIT via SDPFrieder Schrempf
Add support for loading u-boot FIT images over the USB SDP protocol in the SPL Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de> [Various build fixes] Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Tested-by: Fabio Estevam <festevam@gmail.com> Tested-by: Lukasz Majewski <lukma@denx.de>
2019-06-26rockchip: rk3328: add SPL supportKever Yang
Add SPL support for rk3328, default with of-platdata enabled. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> [cherry picked from https://github.com/rockchip-linux/u-boot/commit/cb2b7a1bc75ebb116b1eb9b0ae0223e84d86fc4b with minor modifications] Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-21Merge tag 'efi-2019-07-rc5-3' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for v2019.07-rc5 (3) This pull request provides error fixes for the graphical output protocol, the text output protocol, and the extended text input protocol. Setting the boot device for the bootefi command is now not only supported by the 'load' command but also for the file system specific commands like 'fatload'.
2019-06-21config_distro_bootcmd: Init IDE devicesJoshua Watt
IDE devices are no longer automatically probed by u-boot, so it should be done by the distro boot command before attempting to boot from IDE (just like scsi and nvme) Signed-off-by: Joshua Watt <JPEWhacker@gmail.com>
2019-06-21board: Arcturus: DM: Disable drivers without DM support.Oleksandr Zhadan
Extra "not DM" controllers support is disabled. u-boot BSP still good enough to upgrade and run images. Signed-off-by: Oleksandr Zhadan <oleks@arcturusnetworks.com> Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com>
2019-06-20efi_loader: EFI_SIMPLE_TEXT_OUTPUT_PROTOCOL definitionHeinrich Schuchardt
EFI_SIMPLE_TEXT_OUTPUT_PROTOCOL.Reset() is a function and not a void * pointer. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-06-20Merge https://gitlab.denx.de/u-boot/custodians/u-boot-mpc85xxTom Rini
- PCIe driver change to support DM model - T2080QDS migrated to use PCIe DM model
2019-06-20powerpc: T208xQDS: Disable legacy PCIe driver when DM_PCI is enabledHou Zhiqiang
Disable legacy PCIe driver and unused PCIe macros when DM_PCI enabled. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-20powerpc: mpc85xx: Move CONFIG_FSL_PCIE_RESET to KconfigHou Zhiqiang
Use the Kconfig option to select the PCIe reset errata. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriqTom Rini
- LS1046AFRWY support - USB errata fix and secure boot defconfig support for LS1028A - Enabled SDHC and SATA for LX2160 - LS1046A serdes fixes - other minor fixes
2019-06-19armv8: ls1046afrwy: Add support for LS1046AFRWY platformVabhav Sharma
LS1046AFRWY board supports LS1046A family SoCs. This patch add base support for this board. Board support's 4GB ddr memory, i2c, micro-click module,microSD card, serial console,qspi nor flash,ifc nand flash,qsgmii network interface, usb 3.0 and serdes interface to support two x1gen3 pcie interface. Signed-off-by: Camelia Groza <camelia.groza@nxp.com> Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com> Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19armv8: ls2088ardb: Fix MC firmware loading during SD bootWasim Khan
During SD boot, MC firmware and DPC are copied from SD card to DDR. Size reserved between MC and DPC firmware on DDR is 1MB. If the size of MC firmware(load address 0x80000000) is more than 1 MB then part of MC firmware will be overwritten by DPC firmware (load address 0x80100000). Fix: Update the MC/DPL/DPC firmware's DDR address as per their respective addresses in SD card. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19armv8: ls2088aqds: Fix MC firmware loading during SD bootWasim Khan
2019-06-19armv8: ls2088aqds: Add bootcmd for TFA bootWasim Khan
Add bootcmd for IFC NOR boot and SD boot. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
