path: root/include/usbdescriptors.h
2011-12-16USB: Use (get|put)_unaligned for accessing wMaxPacketSizeTom Rini
In 9792987721c7980453fe6447c3fa6593b44f8458 Stefan describes a usecase where the previous behavior of leaving wMaxPacketSize be unaligned caused fatal problems. The initial fix for this problem was incomplete however as it showed another cases of non-aligned access that previously worked implicitly. This switches to making sure that all access of wMaxPacketSize are done via (get|put)_unaligned. In order to maintain a level of readability to the code in some cases we now use a variable for the value of wMaxPacketSize and in others, a macro. Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Remy Bohmer <linux@bohmer.net> OpenRISC: Tested-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Beagleboard xM, Pandaboard run-tested, s5p_goni build-tested. Signed-off-by: Tom Rini <trini@ti.com>
2011-12-11usb: align usb_endpoint_descriptor to 16-bit boundaryStefan Kristiansson
The usb_endpoint_descriptor struct is 7 bytes large and is defined as an array (ep_desc[USB_MAXENDPOINTS]) in the usb_interface struct in include/usb.h This fact will result in that every odd index in that array will start at an uneven address, this in turn makes accesses to u16 wMaxPacketSize unaligned. Such accesses are illegal on the OpenRISC architecture (as well as other architectures) and will render a bus error. Setting the aligned(2) attribute on usb_endpoint_descriptor will force wMaxPacketSize to a 16-bit boundary. Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2009-12-20USB add macros for debugging usb device setup.Tom Rix
When developing usb device features, it is useful to print out common usb structures. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2006-06-14Code cleanupWolfgang Denk
2006-06-14Various USB related patchesWolfgang Denk
- Add support for mpc8xx USB device. - Add support for Common Device Class - Abstract Control Model USB console. - Add support for flow control in USB slave devices. - Add support for switching between gserial and cdc_acm using environment. - Minor changes to usbdcore_omap1510.c usbdcore_omap1510.h - Update usbcore slightly to ease host enumeration. - Fix non-portable endian problems in usbdcore and usbdcore_ep0. - Add AdderUSB_config as a defconfig to enable usage of the USB console by default with the Adder87x U-Boot port. Patches by Bryan O'Donoghue <bodonoghue@codehermit.ie>, 29 May 2006
2004-03-12Add support for Siemens SX1 mobile phone;LABEL_2004_03_12_0130wdenk
add support for USB-based console (enable with "setenv stdout usbtty; setenv stdin usbtty")
