path: root/include/serial.h
2012-03-18net/miiphy/serial: drop duplicate "NAMESIZE" defineMike Frysinger
A few subsystems are using the same define "NAMESIZE". This has been working so far because they define it to the same number. However, I want to change the size of eth_device's NAMESIZE, so rather than tweak the define names, simply drop references to it. Almost no one does, and the handful that do can easily be changed to a sizeof(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-19x86: Initial commit for running as a coreboot payloadGabe Black
Add a target for running u-boot as a coreboot payload in boards.cfg, a board, CPU and a config. This is a skeleton implementation which always reports the size of memory as 64 MB. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-12-05serial: constify serial_assign()Gerlando Falauto
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-05serial: cosmetic checkpatch complianceGerlando Falauto
2011-10-09serial: uartlite: Support for SERIAL_MULTIMichal Simek
Add support for SERIAL MULTI for uartlite. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-08-02Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: jtag-console: fix timer usage Blackfin: switch to common display_options() Blackfin: serial: move early debug strings into .rodata section Blackfin: adi boards: also set stderr to nc with helper Blackfin: update anomaly lists to latest public info Blackfin: serial: convert to bfin_{read,write} helpers Blackfin: split out async setup Blackfin: adi boards: enable pretty flash progress output Blackfin: drop unused dma.h header from start code Blackfin: portmux: allow header to be included in assembly files Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: enable mmc_spi support Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update network settings Blackfin: sync MMR read/write helpers with Linux Blackfin: gpio: optimize free path a little Blackfin: post: setup default CONFIG_SYS_POST_WORD_ADDR Blackfin: uart: fix printf warning Blackfin: add init.elf helper code Blackfin: dont reset SWRST on newer bf526 parts Blackfin: adi boards: enable multi serial support by default Blackfin: uart: add multiple serial support Blackfin: uart: move debug buffers into local bss
2011-07-26serial: implement common uart post testMike Frysinger
The current arch/driver specific UART posts basically boil down to setting the UART to loop back mode, then reading and writing data. If we ignore the loop back part, the rest can be built upon the existing common serial API. So let's do just that. First add a call back for serial drivers to implement loop back control. Then write a post test that walks all of the serial drivers, puts them into loop back mode, and verifies that reading/writing at all the diff baud rates is OK. If a serial driver doesn't support loop back mode (either it can't or it hasn't done so yet), then skip it. This should allow for people to easily migrate to the new post test with existing serial drivers. I haven't touched the few already existing uart post tests as I don't the hardware or knowledge of converting them over. So I've marked the new test as weak which will allow the existing tests to override the default until they are converted. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26serial: drop useless ctlr fieldMike Frysinger
The multi serial support has a "ctlr" field which almost no one uses, but everyone is forced to set to useless strings. So punt it. Funny enough, the only code that actually reads this field (the mpc8xx driver) has a typo where it meant to look for the SCC driver. Fix it while converting the check to use the name field. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Heiko Schocher <hs@denx.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rix <Tom.Rix@windriver.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Craig Nauman <cnauman@diagraph.com> CC: Marek Vasut <marek.vasut@gmail.com> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Mahavir Jain <mjain@marvell.com>
2011-07-12Blackfin: uart: add multiple serial supportMike Frysinger
This brings CONFIG_SERIAL_MULTI support to the Blackfin on-chip UARTs. Ends up adding only ~512bytes per additional UART. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-02-21serial: Add Tegra2 serial port supportTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
2010-09-08Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-08-26ARMV7: S5P: rename from CONFIG_S5PC1XX to CONFIG_S5PMinkyu Kang
Use the same configuration around S5P SoCs. (s5pc100, s5pc110, s5pc210 and so on) Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-08-10ARM: Add support for MB86R0x SoCsMatthias Weisser
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-05-06x86: Use CONFIG_SERIAL_MULTIGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-04-30SAMSUNG: serial: modify name from s5pc1xx to s5pMinkyu Kang
Because of other s5p series SoC will use these serial functions, modify function's name and structure's name. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-04-24mpc5121: add PSC serial communication routinesAnatolij Gustschin
2010-04-24mpc512x: add multi serial PSC supportAnatolij Gustschin
Extend mpc512x serial driver to support multiple PSC ports. Subsequent patches for PDM360NG board support make use of this functionality by defining CONFIG_SERIAL_MULTI in the board config file. Additionally the used PSC devices are specified by defining e.g. CONFIG_SYS_PSC1, CONFIG_SYS_PSC4 and CONFIG_SYS_PSC6. Support for PSC devices other than 1, 3, 4 and 6 is not added by this patch because these aren't used currently. In the future it can be easily added using DECLARE_PSC_SERIAL_FUNCTIONS(N) and INIT_PSC_SERIAL_STRUCTURE(N) macros in cpu/mpc512x/serial.c. Additionally you have to add code for registering added devices in serial_initialize() in common/serial.c. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-04-24serial: struct serial_device: add uninit() entry for driversAnatolij Gustschin
Subsequent patch extends mpc512x serial driver to support multiple PSC ports. The driver will provide an uninit() function to stop the serial controller and to disable the controller's clock. Adding uninit() entry to struct serial_device allows disabling the serial controller after usage of a stdio serial device. This patch adds uninit() entry to the struct serial_device and fixes initialization of this structure in the code accordingly. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-12-20OMAP3 zoom2 Use usbtty if the debug board is not connected.Tom Rix
The preferred serial output comes from the debug board. When the debug board is disconnected, fall back on using usbtty from the usb connector on the Zoom2 board. This shows up as /dev/ttyACM0 in a linux host. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-20USBTTY make some function declarations easier to use.Tom Rix
Zoom2 needs to use these declarations and the include directory is a better place from them than in the middle of the driver directory. It did not make sense to create a new file for just a couple of lines so they were appended to the serial.h Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-13s5pc1xx: support serial driverMinkyu Kang
This patch includes the serial driver for s5pc1xx. s5pc1xx uart driver needs own register setting and clock configuration. So, need to special driver. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-028xxx: Second UART port added for MPC85xx, MPC83xx, MPC86xx processorsPoonam Aggrwal
Defining the next two configs allows to switch the serial port from the console using the setenv stdin and stdout 1. #define CONFIG_SERIAL_MULTI 1 /* Enable both serial ports */ 2. #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-12ZOOM2 Add serial support.Tom Rix
Zoom2 serial is in general supplied by one of the 4 UARTS on the debug board. The default serial is from the USB connector on left side of the debug board. The USB connector will produce 2 of the 4 UARTS. On your host pick the first enumeration. The details of the setting of the serial gpmc setup are not available. The values were provided by another party. The serial port set up is the same with Zoom1. Baud rate 115200, 8 bit data, no parity, 1 stop bit, no flow. The kernel bootargs are console=ttyS3,115200n8 Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2008-02-04ARM: s3c24xx: Multiple serial port supportHarald Welte
This patch adds support for CONFIG_SERIAL_MULTI on s3c24x0 CPU's Signed-off-by: Harald Welte <laforge@openmoko.org>
2007-10-31ppc4xx: Add PPC405EX supportStefan Roese
2007-09-07PXA270: Add support for multiple serial ports.stefano babic
This patch adds support for multiple serial ports to the PXA target. FFUART, BTUART and STUART are supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-03-24[PATCH] Clean up 40EZ/Acadia supportStefan Roese
This patch cleans up all the open issue of the preliminary Acadia support. Signed-off-by: Stefan Roese <sr@denx.de>
2006-08-30Make the serial driver framework work with CONFIG_SERIAL_MULTI enabledWolfgang Denk
2006-06-16Add support for CONFIG_SERIAL_MULTI on MPC5xxxWolfgang Denk
Patch by Martin Krause, 8 Jun 2006 This patch supports two serial consoles on boards with a MPC5xxx CPU. The console can be switched at runtime by setting stdin, stdout and stderr to the desired serial interface (serial0 or serial1). The PSCs to be used as console port are definded by CONFIG_PSC_CONSOLE and CONFIG_PSC_CONSOLE2. See README.serial_multi for details.
2005-01-09* Patch by Leif Lindholm, 23 Sep 2004:wdenk
add support for the AMD db1550 board * Patch by Travis Sawyer, 15 Sep 2004: Add CONFIG_SERIAL_MULTI support for ppc4xx, update README.serial_multi
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
