path: root/include/sdhci.h
2011-11-25mmc: mv_sdhci: Fix host version read for Armada100Ajay Bhargav
sdhci_readw does not work for host version read in Armada100 series SoCs. This patch fix this issue by making a sdhci_readl call to get host version. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-11-03mmc: sdhci: add mmc structure for hostLei Wen
So that sdhci host would tell in the driver that the mmc current attributes. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-11-03mmc: sdhci: fix build warningLei Wen
If CONFIG_MMC_SDHCI_IO_ACCESSORS is defined, the following warning would shows up: include/sdhci.h:224: warning: 'struct sdhci_host' declared inside parameter list include/sdhci.h:224: warning: its scope is only this definition or declaration, which is probably not what you want include/sdhci.h:225: warning: 'struct sdhci_host' declared inside parameter list include/sdhci.h:226: warning: 'struct sdhci_host' declared inside parameter list include/sdhci.h:227: warning: 'struct sdhci_host' declared inside parameter list include/sdhci.h:228: warning: 'struct sdhci_host' declared inside parameter list include/sdhci.h:229: warning: 'struct sdhci_host' declared inside parameter list Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-07-15MMC: add sdhci generic frameworkLei Wen
Nowdays, there are plenty of mmc driver in uboot adopt the sd standard host design, aka as sdhci. It is better to centralize the common logic together to better maintenance. Signed-off-by: Lei Wen <leiwen@marvell.com> Acked-by: Andy Fleming <afleming@freescale.com>
