path: root/include/menu.h
2012-02-12common, menu: show menu on startup if CONFIG_MENU_SHOW is definedHeiko Schocher
show a menu on startup instead running the shell. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Jason Hobbs <jason.hobbs@calxeda.com>
2012-02-12common, menu: add statusline supportHeiko Schocher
add the possibility to show a statusline when printing a menu Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17common, menu: use abortboot for menu timeoutJason Hobbs
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-17Add generic, reusable menu codeJason Hobbs
This will be used first by the pxe code, but is intended to be generic and reusable for other jobs in U-boot. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
