path: root/include/mc13892.h
2011-12-06MC13892: Add REGMODE0 bits definitionsMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de>
2011-02-02MC13892: Add SWx buck switchers definitionsMarek Vasut
Define voltages configurable on SWx buck switchers. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-02-02MX5:MX53: add initial support for MX53EVK boardLiu Hui-R64343
Add initial support for MX53EVK board support. FEC, SD/MMC, UART, I2C, have been supported. Signed-off-by: Jason Liu <r64343@freescale.com>
2010-10-28mx51evk: Fix 2 hours reset issueShawn Guo
The mx51evk u-boot has an issue that system will get reset every 2 hours. MC13892 has an inside charge timer which expires in 120 minutes. If ICHRG and CHGAUTOB are not set properly, this timer expiration will get system power recycled. Since mx51evk has no Li-Ion battery on board, the patch sets ICHRG in externally powered mode and sets CHGAUTOB bit to avoid automatic charging, so that system will not get reset by this timer expiration. The patch also corrects the bit field definition of register 48 (Charger 0) per latest MC13892 Reference Manual. Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
2010-10-07MX51: Support for TTECH vision2 boardStefano Babic
The patch adds support for TTECH vision2 board. The board has 512MB RAM, SDHC slot and 4MB SPI device from StMicron. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-05-05MX: Added definition file for MC13892Stefano Babic
The MC13892 is a Power Controller used with processors of the family MX.51. The file adds definitions to be used to setup the internal registers via SPI. Signed-off-by: Stefano Babic <sbabic@denx.de>
