path: root/include/linux
2012-02-28nand: reinstate lazy bad block scanningScott Wood
commit 2a8e0fc8b3dc31a3c571e439fbf04b882c8986be ("nand: Merge changes from Linux nand driver") accidentally reverted commit 13f0fd94e3cae6f8a0d9fba5d367e311edc8ebde ("NAND: Scan bad blocks lazily."). Reinstate the change, as amended by commit ff49ea8977b56916edd5b1766d9939010e30b181 ("NAND: Mark the BBT as scanned prior to calling scan_bbt."). Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-02-28Revert "nand: make 1-bit software ECC configurable"Scott Wood
This reverts commit 4fee6c2f295f932b8febdc7ce8731ba045695fa5. It breaks boards that currently rely on soft-ecc, as pointed out here: http://patchwork.ozlabs.org/patch/140872/ The reverted patch should be resubmitted with documentation, and with the CONFIG_MTD_ECC_SOFT selected from every board that needs it. We could start by looking at what NAND driver the board selects, and whether that driver ever asks for soft ECC. Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-02-12linkage.h: move from blackfin to common includesMacpaul Lin
1. Add linkage.h support from blackfin to common include, which is a reduced version from Linux. 2. Add architecture part support of linkage.h into blackfin 3. Fix include path of in blackfin related to linkage.h due to header file movement. Signed-off-by: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-01-26nand: make 1-bit software ECC configurableChristian Hitz
The software ECC algorithm is not necessary when hardware ECC is available and can be left out for a smaller image size. Enable with CONFIG_MTD_ECC_SOFT. Signed-off-by: Christian Hitz <christian.hitz@aizo.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-01-26nand: Sanitize ONFI strings.Christian Hitz
[backport from linux commit 02f8c6aee8df3cdc935e9bdd4f2d020306035dbe] This is part of the synchronization with the nand driver to the Linux 3.0 state. Signed-off-by: Christian Hitz <christian.hitz@aizo.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-01-26nand: Merge changes to BBT from Linux nand driverChristian Hitz
[backport from linux commit 02f8c6aee8df3cdc935e9bdd4f2d020306035dbe] This patch synchronizes the nand driver with the Linux 3.0 state. Signed-off-by: Christian Hitz <christian.hitz@aizo.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-01-26nand: Merge changes from Linux nand driverChristian Hitz
[backport from linux commit 02f8c6aee8df3cdc935e9bdd4f2d020306035dbe] This patch synchronizes the nand driver with the Linux 3.0 state. Signed-off-by: Christian Hitz <christian.hitz@aizo.com> Cc: Scott Wood <scottwood@freescale.com> [scottwood@freescale.com: minor fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-01-26nand: Merge BCH code from Linux nand driverChristian Hitz
[backport from linux commit 02f8c6aee8df3cdc935e9bdd4f2d020306035dbe] This patch merges the BCH ECC algorithm from the 3.0 Linux kernel. This enables U-Boot to support modern NAND flash chips that require more than 1-bit of ECC in software. Signed-off-by: Christian Hitz <christian.hitz@aizo.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-06nand: Add common functions to linux/mtd/nand.hSimon Schwarz
Functions often used in SPL are now part of linux/mtd/nand.h. Static modifiers are removed from these functions in drivers/mtd/nand/nand_base.c. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Cc: scottwood@freescale.com Cc: s-paulraj@ti.com Cc: albert.u.boot@aribaud.net Acked-by: Scott Wood <scottwood@freescale.com>
2011-10-17Add isblankJason Hobbs
Existing ctype checks are implemented using a 256 byte lookup table, allowing each character to be in any of 8 character classes. Since there are 8 existing character classes without the blank class, I implemented isblank without using the lookup table. Since there are only two blank characters - tab and space - this is a more reasonable approach than doubling the size of the lookup table to accommodate one more class. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-03NAND: Really ignore bad blocks when scrubbingMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> [scottwood@freescale.com: use chip instead of redundant priv_nand] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-01Add missing header for gcc3Scott McNutt
When include/linux/compiler.h is included, the associated gcc3 header is required for older build environments. Signed-off-by: Scott McNutt <smcnutt@psyent.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-11Minor coding style cleanup.Wolfgang Denk
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-27phylib: Detect link on 10G devices correctlyAndy Fleming
gen10g_startup() had 2 bugs: 1) It had a boolean logic error in checking the MMD mask, and always checked all of them. 2) It checked devices which don't actually report link state, which meant that it would never believe the link was fully up. Fix the boolean logic, and then mask the MMD mask so only link-reporting devices are checked. Signed-off-by: Andy Fleming <afleming@freescale.com> Reported-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2011-04-20Create PHY Lib for U-BootAndy Fleming
Extends the mii_dev structure to participate in a full-blown MDIO and PHY driver scheme. The mii_dev structure and miiphy calls are modified in such a way to allow the original mii command and miiphy infrastructure to work as before, but also to support a new set of APIs which allow (among other things) sharing of PHY driver code and 10G support The mii command will continue to support normal PHY management functions (Clause 22 of 802.3), but will not be changed to support 10G (Clause 45). The basic design is similar to PHY Lib from Linux, but simplified for U-Boot's network and driver infrastructure. We now have MDIO drivers and PHY drivers An MDIO driver provides: read write reset A PHY driver provides: (optionally): probe config - initial setup, starting of auto-negotiation startup - waiting for AN, and reading link state shutdown - any cleanup needed The ethernet drivers interact with the PHY Lib using these functions: phy_connect() phy_config() phy_startup() phy_shutdown() Each PHY driver can be configured separately, or all at once using config_phylib_all_drivers.h (added in the patch which adds the drivers) We also provide generic drivers for Clause 22 (10/100/1000), and Clause 45 (10G) PHYs. We also implement phy_reset(), and call it in phy_connect(). Because phy_reset() is essentially the same as miiphy_reset, but: a) must support 10G PHYs, and b) should use the phylib primitives, we implement miiphy_reset, using phy_reset(), but only when CONFIG_PHYLIB is set. Otherwise, we just use the old version. In this way, we save on compile size, even if we don't manage to save code size. Pulled ethtool.h and mdio.h from: git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6 782d640afd15af7a1faf01cfe566ca4ac511319d With many, many deletions so as to enable compilation under u-boot Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-01NAND: add support for reading ONFI page tableFlorian Fainelli
This patch adds support for reading an ONFI page parameter from a NAND device supporting it. If this is the case, struct nand_chip onfi_version member contains the supported ONFI version, 0 otherwise. This allows NAND drivers past nand_scan_ident to set the best timings for the NAND chip. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-02-19USB: Add USB RNDIS gadget protocolVitaly Kuzmichev
Port USB gadget RNDIS protocol support from linux-2.6.26 (.27 gadget stack actually has composite drivers). Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2011-02-19USB-CDC: Port struct net_device_statsVitaly Kuzmichev
Port struct net_device_stats and statistics collecting needed for RNDIS protocol. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2011-01-18lib: add crc7 from LinuxThomas Chou
Crc7 is used to compute mmc spi command packet checksum. Copy from linux-2.6 lib/crc7.c include/linux/crc7.h commit ad241528c4919505afccb022acbab3eeb0db4d80 Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2011-01-12mtd: nand: Allow caller to pass alternative ID table to nand_scan_ident()Lei Wen
This patch sync with David's patch on Linux for handling nand_scan_ident. commit 5e81e88a4c140586d9212999cea683bcd66a15c6 Author: David Woodhouse <David.Woodhouse@intel.com> Date: Fri Feb 26 18:32:56 2010 +0000 mtd: nand: Allow caller to pass alternative ID table to nand_scan_ident() Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Lei Wen <leiwen@marvell.com>
2010-12-22Merge branch 'next' of ../nextWolfgang Denk
2010-12-17NAND: add NAND_CMD_PARAM (0xec) definitionFlorian Fainelli
This command is used to read the device ONFI parameters page. Signed-off-by: Florian Fainelli <florian@openwrt.org>
2010-12-17nand: constify id/manu tablesMike Frysinger
These id tables need not be writable. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-12-17Coding style (white space) cleanup.Wolfgang Denk
2010-12-16Merge branch 'master' of ../master into nextWolfgang Denk
2010-12-09include/linux/mii.h: update for supporting GEMacpaul Lin
This file has been synced (copy) from Linux source code. This commit was based on kernel 2.6.32. It updates gigabit related phy registers and basic definitions. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-11-28ctype: constify lookup tableMike Frysinger
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-26include/asm-offsets.h: automatically generate assembler constantsWolfgang Denk
A recurrent issue is that certain C level constructs like sizeof() or offsetof() cannot be used in assembler files, which is inconvenient when such constructs are used in the definition of macro names etc. To avoid duplication of such definitions (and thus another cause of problems), we adapt the Linux way to automatically generate the respective definitions from the respective C header files. In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36 kernel tree. We also copy the concept of the include/generated/ directory which can be used to hold other automatically generated files as well. We start with an architecture-independent lib/asm-offsets.c which generates include/generated/generic-asm-offsets.h (included by include/asm-offsets.h, which is what will be referred to in the actual source code). Later this may be extended by architecture-specific arch/*/lib/asm-offsets.c files that will generate a include/generated/asm-offsets.h. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22Add linux framebuffer header include/linux/fb.hStefano Babic
[port of linux 2.6.34 commit 6a9ee8af344e3bd7dbd61e67037096cdf7f83289] Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-11mtd: OneNAND: add support for OneNAND manufactured by NumonyxEnric Balletbo i Serra
This patch adds the Numonyx manufacturer code (0x20) to onenand manufacturers. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Steve Sakoman <steve.sakoman@linaro.org> Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
2010-10-11mtd: add an mtd method for get_len_incl_bad()Ben Gardiner
The logic to 'spread' mtd partitions needs to calculate the length in the mtd device, including bad blocks. This patch introduces a new function, mtd_get_len_incl_bad that can return both the length including bad blocks and whether that length was truncated on the device. This new function will be used by the mtdparts spread command later in this series. The definition of the function is #ifdef'd out in configurations that do not use the new 'mtdparts spread' command. Signed-off-by: Ben Gardiner<bengardiner@nanometrics.ca> CC: Scott Wood <scottwood@freescale.com>
2010-10-11nand: remove dead code and suspend/resumeScott Wood
Get rid of the several "#if 0" sections that were keeping around Linux code that isn't relevant to U-Boot. Besides cluttering the code, these sections make tracking upstream changes harder, rather than easier. It's easy to discard obviously irrelevant diff hunks that patch rejects, but it's not as easy to notice hunks that apply cleanly to the #if 0 section, but *are* relevant to U-Boot and require modification elsewhere. Also remove suspend/resume, as this is not applicable to U-Boot. Removal saves 232 bytes on powerpc. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2010-09-20USB-CDC: Fix coding style issuesVitaly Kuzmichev
Fixes most of checkpatch warnings and errors in USB gadget stack. The most frequently encountered problems are: 1) "(foo*)", "foo * bar", "foo* bar" 2) C99 // comments 3) No spaces before/after/around '?', ':', '=', '==', ',', '&', '(' 4) Spaces before '[' 5) Spaces between function names and '(' 6) Block braces in wrong places 7) Spaces before tabs 8) Macros with complex values not enclosed in parenthesis 9) Multiline comments start just after /* Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2010-09-20Integrate USB gadget layer and USB CDC driver layerRemy Bohmer
Derived from Linux kernel 2.6.27 Signed-off-by: Thomas Smits <ts.smits@gmail.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2010-05-06x86: Fix support for booting bzImageGraeme Russ
Add support for newer (up to 2.6.33) kernels Add zboot command which takes the address of a bzImage as its first argument and (optionally) the size of the bzImage as the second argument (the second argument is needed for older kernels which do not include the bzImage size in the header) Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-04-02nios2: add struct stat support in linux/stat.hThomas Chou
This is needed for jffs2 support. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-01-18move definition of macros likely and unlikely to compiler.hMatthias Kaehlcke
the macros likely and unlikely were defined in include/linux/mtd/compat.h, but used in code not related to MTD. moved the macro definitions to compiler.h Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
2009-12-05add lzop decompression supportPeter Korsgaard
Add lzop decompression support to the existing lzo bitstream handling (think gzip versus zlib), and support it for uImage decompression if CONFIG_LZO is enabled. Lzop doesn't compress as good as gzip (~10% worse), but decompression is very fast (~0.7s faster here on a slow ppc). The lzop decompression code is based on Albin Tonnerre's recent ARM Linux lzo support patch. Cc: albin.tonnerre@free-electrons.com Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
2009-11-18NAND:Extending the nand_ecclayout structureSandeep Paulraj
NANDs with page size of lesser than and equal to 2K are reaching EOL. They are bing replaced with NANDs of page size 4K and above. To support this we have to extend the eccpos field Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-11-15Merge branch 'master' into nextWolfgang Denk
2009-11-13Flex-OneNAND driver supportAmul Kumar Saha
This patch adds support for Flex-OneNAND devices. Signed-off-by: Rohit Hagargundgi <h.rohit@samsung.com> Signed-off-by: Amul Kumar Saha <amul.saha@samsung.com>
2009-11-13NAND: Update to support 64 bit device sizeSandeep Paulraj
This patch adds support for NANDs greater than 2 GB. Patch is based on the MTD NAND driver in the kernel. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-11-07ARM: Use Linux version for unaligned access codeRemy Bohmer
The asm-arm/unaligned.h includes linux/unaligned/access_ok.h This file is unsafe to be used on ARM, since it does an unaligned memory accesses which fails on ARM. Lookin at Linux the basic difference seems to be the header "include/asm-arm/unaligned.h". The Linux version of "unaligned.h" does *not* include "access_ok.h" at all. It includes "le_byteshift.h" and "be_byteshift.h" instead. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Stefan Roese <sr@denx.de> -- include/asm-arm/unaligned.h | 3 - include/linux/unaligned/be_byteshift.h | 70 +++++++++++++++++++++++++++++++++ include/linux/unaligned/le_byteshift.h | 70 +++++++++++++++++++++++++++++++++ 3 files changed, 142 insertions(+), 1 deletion(-) create mode 100644 include/linux/unaligned/be_byteshift.h create mode 100644 include/linux/unaligned/le_byteshift.h
2009-10-24s5pc1xx: SMDKC100: fix compile warningsMinkyu Kang
fix the following compile warnings warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-13s5pc1xx: support onenand driverMinkyu Kang
This patch includes the onenand driver for s5pc100 Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-09-17Correct ffs/fls regression for PowerPC etcSimon Kagstrom
Commits 02f99901ed1c9d828e3ea117f94ce2264bf8389e 52d61227b66d4099b39c8309ab37cb67ee09a405 introduced a regression where platform-specific ffs/fls implementations were defined away. This patch corrects that by using PLATFORM_xxx instead of the name itself. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de>
2009-09-15Define ffs/fls for all architecturesSimon Kagstrom
UBIFS requires fls(), which is not defined for arm (and some other architectures) and this patch adds it. The implementation is taken from Linux and is generic. ffs() is also defined for those that miss it. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-09-15Move __set/clear_bit from ubifs.h to bitops.hSimon Kagstrom
__set_bit and __clear_bit are defined in ubifs.h as well as in asm/include/bitops.h for some architectures. This patch moves the generic implementation to include/linux/bitops.h and uses that unless it's defined by the architecture. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
