path: root/include/ide.h
2011-04-30IDE: fix compiler warningsWolfgang Denk
The changes introduced by commit 0abddf8 ``cmd_ide: enhance new feature "CONFIG_IDE_AHB"'' caused compiler warnings like cmd_ide.c: In function 'ide_init': cmd_ide.c:716: warning: assignment from incompatible pointer type Constify the respective function arguments to fix this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-04-30cmd_ide: enhance new feature "CONFIG_IDE_AHB"Macpaul Lin
Although most IDE controller is designed to be connected to PCI bridge, there are still some IDE controller support AHB interface for SoC design. The driver implementation of these IDE-AHB controllers differ from other IDE-PCI controller, some additional registers and commands access is required during CMD/DATA I/O. Hence a configuration "CONFIG_IDE_AHB" in cmd_ide.c is required to be defined to support these kinds of SoC controllers. Such as Faraday's FTIDE020 series and Global Unichip's UINF-0301. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2009-09-25mucmc52, uc101: delete ata@3a00 node, if no CF card is detectedHeiko Schocher
U-Boot can detect if an IDE device is present or not. If not, and this new config option is activated, U-Boot removes the ATA node from the DTS before booting Linux, so the Linux IDE driver does not probe the device and crash. This is needed for buggy hardware (uc101) where no pull down resistor is connected to the signal IDE5V_DD7. Signed-off-by: Heiko Schocher <hs@denx.de>
2007-08-28IDE: - make ide_inb () and ide_outb () "weak", so boards canHeiko Schocher
define there own I/O functions. (Needed for the pcs440ep board). - The default I/O Functions are again 8 Bit accesses. - Added CONFIG_CMD_IDE for the pcs440ep Board. Signed-off-by: Heiko Schocher <hs@denx.de>
2007-02-20[PATCH 9_9] Use "void *" not "unsigned long *" for block dev read_write ↵Grant Likely
buffer pointers Block device read/write is anonymous data; there is no need to use a typed pointer. void * is fine. Also add a hook for block_read functions Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-02-20[PATCH 1_4] Merge common get_dev() routines for block devicesGrant Likely
Each of the filesystem drivers duplicate the get_dev routine. This change merges them into a single function in part.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2002-08-27Initial revisionwdenk
