path: root/include/asm-generic
2012-01-09gpio: Modify common gpio.h to more closely match LinuxJoe Hershberger
Change "int gp" to "unsigned gpio" Add request and free entry-points Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-10-17Add generic gpio.h in asm-genericSimon Glass
Since we want want to have a standard GPIO interface, this adds a definition for this into include/asm-generic/gpio.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2010-05-06x86: Fix support for booting bzImageGraeme Russ
Add support for newer (up to 2.6.33) kernels Add zboot command which takes the address of a bzImage as its first argument and (optionally) the size of the bzImage as the second argument (the second argument is needed for older kernels which do not include the bzImage size in the header) Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-03-14asm-generic/unaligned.h: dynamic default unaligned accessesMike Frysinger
This is based on the asm-arm/unaligned.h, but made generic so all arches that cannot do unaligned accesses can utilize it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17asm-generic/signal.h: import from linuxRobin Getz
We need signal.h for Blackfin/KGDB, so import the asm-generic/signal.h for people to leverage. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-09asm-generic: Consolidate errno.h to asm-generic/errno.hMichal Simek
This patch use blackfin errno.h implementation which correspond Linux kernel one. MIPS implemetation is different that's why I keep it. I removed ppc_error_no.h from Marvell boards which was the same too. I have got ack from ppc40x, blackfin, arm, coldfire and avr custodians. Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <monstr@monstr.eu>
