path: root/fs
2019-06-20fs: do_load: pass device path for efi payloadMian Yousaf Kaukab
fatload command can be used to load the EFI payload since EFI system partition is always a FAT partition. Call into EFI code from do_load() to set the device path from which the last binary was loaded. An EFI application like grub2 can’t find its configuration file without the device path set. Since device path is now set in do_load() there is no need to set it in do_load_wrapper() for the load command. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-28fs: fat: allocate a new cluster for root directory of fat32AKASHI Takahiro
Contrary to fat12/16, fat32 can have root directory at any location and its size can be expanded. Without this patch, root directory won't grow properly and so we will eventually fail to add files under root directory. Please note that this can happen even if you delete many files as deleted directory entries are not reclaimed but just marked as "deleted" under the current implementation. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-28fs: fat: flush a directory cluster properlyAKASHI Takahiro
When a long name directory entry is created, multiple directory entries may be occupied across a directory cluster boundary. Since only one directory cluster is cached in a directory iterator, a first cluster must be written back to device before switching over a second cluster. Without this patch, some added files may be lost even if you don't see any failures on write operation. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-28fs: fat: write to non-cluster-aligned root directoryAKASHI Takahiro
With the commit below, fat now correctly handles a file read under a non-cluster-aligned root directory of fat12/16. Write operation should be fixed in the same manner. Fixes: commit 9b18358dc05d ("fs: fat: fix reading non-cluster-aligned root directory") Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Cc: Anssi Hannula <anssi.hannula@bitwise.fi> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-28fs: fat: Fix possible double free of fatbufAndrew F. Davis
fat_itr_root() allocates fatbuf so we free it on the exit path, if the function fails we should not free it, check the return value and skip freeing if the function fails. Signed-off-by: Andrew F. Davis <afd@ti.com>
2019-05-28fs: fat: correct file name normalizationHeinrich Schuchardt
File names may not contain control characters (< 0x20). Simplify the coding. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-05fs: btrfs: add zstd decompression supportMarek Behún
This adds decompression support for Zstandard, which has been included in Linux btrfs driver for some time. Signed-off-by: Marek Behún <marek.behun@nic.cz>
2019-05-03fs: btrfs: fix btrfs methods return values on failureMarek Behún
The btrfs implementation methods .ls(), .size() and .read() returns 1 on failure, but the command handlers expect values <0 on failure. For example if given a nonexistent path, the load command currently returns success, and hush scripting does not work. Fix this by setting return values of these methods to -1 instead of 1 on failure. Signed-off-by: Marek Behún <marek.behun@nic.cz>
2019-05-03fs: btrfs: Do not print mount fail message when not btrfs filesystemMarek Behún
Other filesystem drivers don't do this. Signed-off-by: Marek Behún <marek.behun@nic.cz>
2019-04-27Revert "fs: btrfs: fix false negatives in ROOT_ITEM search"Tom Rini
Per Pierre this change shouldn't have been applied as it was superseded by "fs: btrfs: fix btrfs_search_tree invalid results" which is also applied now as 1627e5e5985d. This reverts commit 633967f9818cb6a0e87ffa8cba33148a5bcc6edb. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-26fs: btrfs: fix btrfs_search_tree invalid resultsPierre Bourdon
btrfs_search_tree should return the first item in the tree that is greater or equal to the searched item. The search algorithm did not properly handle the edge case where the searched item is higher than the last item of the node but lower than the first item of the next node. Instead of properly returning the first item of the next node, it was returning an invalid path pointer (pointing to a non-existent item after the last item of the node + 1). This fixes two issues in the btrfs driver: - Looking for a ROOT_ITEM could fail if it was the first item of its leaf node. - Iterating through DIR_INDEX entries (for readdir) could fail if the first DIR_INDEX entry was the first item of a leaf node. Signed-off-by: Pierre Bourdon <delroth@gmail.com> Cc: Marek Behun <marek.behun@nic.cz>
2019-04-26fs: fat: Build only if CONFIG_FS_FAT=yIsmael Luceno Cortes
Signed-off-by: Ismael Luceno <ismael.luceno@silicon-gears.com>
2019-04-26fs: btrfs: fix false negatives in ROOT_ITEM searchPierre Bourdon
ROOT_ITEMs in btrfs are referenced without knowing their actual "offset" value. To perform these searches using only two items from the key, the btrfs driver uses a special "btrfs_search_tree_key_type" function. The algorithm used by that function to transform a 3-tuple search into a 2-tuple search was subtly broken, leading to items not being found if they were the first in their tree node. This commit fixes btrfs_search_tree_key_type to properly behave in these situations. Signed-off-by: Pierre Bourdon <delroth@gmail.com> Cc: Marek Behun <marek.behun@nic.cz>
2019-04-09Fix ext4 block group descriptor sizingBenjamin Lim
Ext4 allows for arbitrarily sized block group descriptors when 64-bit addressing is enabled, which was previously not properly supported. This patch dynamically allocates a chunk of memory of the correct size. Signed-off-by: Benjamin Lim <jarsp.ctf@gmail.com>
2019-04-09fs: fat: fix reading non-cluster-aligned root directoryAnssi Hannula
A FAT12/FAT16 root directory location is specified by a sector offset and it might not start at a cluster boundary. It also resides before the data area (before cluster 2). However, the current code assumes that the root directory is located at a beginning of a cluster, causing no files to be found if that is not the case. Since the FAT12/FAT16 root directory is located before the data area and is not aligned to clusters, using unsigned cluster numbers to refer to the root directory does not work well (the "cluster number" may be negative, and even allowing it be signed would not make it properly aligned). Modify the code to not use the normal cluster numbering when referring to the root directory of FAT12/FAT16 and instead use a cluster-sized offsets counted from the root directory start sector. This is a relatively common case as at least the filesystem formatter on Win7 seems to create such filesystems by default on 2GB USB sticks when "FAT" is selected (cluster size 64 sectors, rootdir size 32 sectors, rootdir starts at half a cluster before cluster 2). dosfstools mkfs.vfat does not seem to create affected filesystems. Signed-off-by: Anssi Hannula <anssi.hannula@bitwise.fi> Reviewed-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com> Tested-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com>
2019-04-09fs: ext4: Problem with ext4load and sparse filesGero Schumacher
Hi, when I try to load a sparse file via ext4load, I am getting the error message 'invalid extent' After a deeper look in the code, it seems to be an issue in the function ext4fs_get_extent_block in fs/ext4/ext4_common.c: The file starts with 1k of zeros. The blocksize is 1024. So the first extend block contains the following information: eh_entries: 1 eh_depth: 1 ei_block 1 When the upper layer (ext4fs_read_file) asks for fileblock 0, we are running in the 'invalid extent' error message. For me it seems, that the code is not prepared for handling a sparse block at the beginning of the file. The following change, solved my problem: I am really not an expert in ext4 filesystems. Can somebody please have a look at this issue and give me a feedback, if I am totally wrong or not?
2019-04-09fs: Add a new command to create symbolic linksJean-Jacques Hiblot
The command line is: ln <interface> <dev[:part]> target linkname Currently symbolic links are supported only in ext4 and only if the option CMD_EXT4_WRITE is enabled. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-09fs: ext4: Add support for the creation of symbolic linksJean-Jacques Hiblot
Re-use the functions used to write/create a file, to support creation of a symbolic link. The difference with a regular file are small: - The inode mode is flagged with S_IFLNK instead of S_IFREG - The ext2_dirent's filetype is FILETYPE_SYMLINK instead of FILETYPE_REG - Instead of storing the content of a file in allocated blocks, the path to the target is stored. And if the target's path is short enough, no block is allocated and the target's path is stored in ext2_inode.b.symlink As with regulars files, if a file/symlink with the same name exits, it is unlinked first and then re-created. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Fix ext4 env code] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-09fs: ext4: constify the buffer passed to write functionsJean-Jacques Hiblot
There is no need to modify the buffer passed to ext4fs_write_file(). The memset() call is not required here and was likely copied from the equivalent part of the ext4fs_read_file() function where we do need it. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-09fs: ext4: cache extent dataStephen Warren
When a file contains extents, U-Boot currently reads extent-related data for each block in the file, even if that data is located in the same block each time. This significantly slows down loading of files that use extents. Implement a very dumb cache to prevent repeatedly reading the same block. Files with extents now load as fast as files without. Note: There are many cases where read_allocated_block() is called. This patch only addresses one of those places; all others still read redundant data in any case they did before. This is a minimal patch to fix the load command; other cases aren't fixed. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2019-04-09mtd: ubi, ubifs debug: Use pr_debug instead of pr_critEran Matityahu
Before printk.h was introduced and MTDDEBUG was removed, pr_crit() was calling MTDDEBUG(), which was since then replaced by the current pr_debug(). pr_debug is more appropriate here. Signed-off-by: Eran Matityahu <eran.m@variscite.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-03-22fs: ext4: do not write on filesystem with metadata_csum featureSébastien Szymanski
U-Boot doesn't support metadata_csum feature. Writing to filesystem with metadata_csum feature makes the filesystem corrupted and unbootable by Linux: [ 2.527495] EXT4-fs (mmcblk0p2): ext4_check_descriptors: Checksum for group 0 failed (52188!=0) [ 2.537421] EXT4-fs (mmcblk0p2): ext4_check_descriptors: Checksum for group 1 failed (5262!=0) ... [ 2.653308] EXT4-fs (mmcblk0p2): ext4_check_descriptors: Checksum for group 14 failed (42611!=0) [ 2.662179] EXT4-fs (mmcblk0p2): ext4_check_descriptors: Checksum for group 15 failed (21527!=0) [ 2.687920] JBD2: journal checksum error [ 2.691982] EXT4-fs (mmcblk0p2): error loading journal [ 2.698292] VFS: Cannot open root device "mmcblk0p2" or unknown-block(179,2): error -74 Don't write to filesystem with meatadata_csum feature to not corrupt the filesystem. Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-02-28fs: fat: fix link error when building with DEBUG=1Heinrich Schuchardt
When compiling with DEBUG=1 an error fs/fat/fat_write.c:831: undefined reference to `__aeabi_ldivmod' occurred. We should use do_div() instead of the modulus operator. filesize and cur_pos cannot be negative. So let's use u64 to avoid warnings. Fixes: cb8af8af5ba0 ("fs: fat: support write with non-zero offset") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-19fs: fat: Reduce default max clustersize 64KiB from malloc poolTien Fong Chee
Release cluster block immediately when no longer use would help to reduce 64KiB memory allocated to the memory pool. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2019-02-19fs: fat: dynamically allocate memory for temporary bufferTien Fong Chee
Drop the statically allocated get_contents_vfatname_block and dynamically allocate a buffer only if required. This saves 64KiB of memory. Signed-off-by: Stefan Agner <stefan.ag...@toradex.com> Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2019-02-09fs: ext4: Unmount FS in do_fs_type()Marek Vasut
Unlike other generic FS accessors, fs_get_info() does not call fs_close() at the end of it's operation. Thus, using fs_get_info() in do_fs_type() without calling fs_close() causes potential memory leak by creating new filesystem structures on each call of do_fs_type(). The test case to trigger this problem is as follows. It is required to have ext4 filesystem on the first partition of the SDMMC device, since ext4 requires stateful mount and causes memory allocation. => while true ; do mmc rescan ; fstype mmc 1 ; done Eventually, the mounting of ext4 will fail due to malloc failures and the filesystem will not be correctly detected. This patch fixes the problem by adding the missing fs_close(). Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com>
2019-02-02lmb: handle more than one DRAM BANKSimon Goldschmidt
This fixes the automatic lmb initialization and reservation for boards with more than one DRAM bank. This fixes the CVE-2018-18439 and -18440 fixes that only allowed to load files into the firs DRAM bank from fs and via tftp. Found-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-02-01spl: fat/fs: Add control to build FS EXT4 in SPLTien Fong Chee
CONFIG_SPL_FS_EXT4 can be used to include/exclude the FS EXT4 from SPL build. Excluding the FS EXT4 from SPL build can help to save 20KiB memory. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPL_FS_EXT4Tien Fong Chee
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01spl: fat/fs: Add option to include/exclude FAT write build in SPLTien Fong Chee
Most of the time SPL only needs very simple FAT reading, so having CONFIG_IS_ENABLED(FAT_WRITE) to exclude it from SPL build would help to save 64KiB default max clustersize from memory. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FATTien Fong Chee
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-16fs: prevent overwriting reserved memorySimon Goldschmidt
This fixes CVE-2018-18440 ("insufficient boundary checks in filesystem image load") by using lmb to check the load size of a file against reserved memory addresses. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-11Revert "fs: fat: assign rootdir sector when accessing root directory"Tom Rini
This particular commit is causing a regression on stih410-b2260 and other platforms when reading from FAT16. Noting that I had rebased the original fix from Thomas onto then-current master, there is also question from Akashi-san if the change is still needed after other FAT fixes that have gone in. This reverts commit a68b0e11ea774492713a65d9fd5bb525fcaefff3. Reported-by: Patrice Chotard <patrice.chotard@st.com> Cc: AKASHI Takahiro <takahiro.akashi@linaro.org> Cc: Thomas RIENOESSL <thomas.rienoessl@bachmann.info> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-31fs: cbfs: Fix out of bound access during CBFS walking throughBin Meng
The call to file_cbfs_fill_cache() is given with the parameter 'start' pointing to the offset by the CBFS base address, but with the parameter 'size' that equals to the whole CBFS size. During CBFS walking through, it checks files one by one and after it pass over the end of the CBFS which is 4GiB boundary it tries to check files from address 0 and so on, until the overall size the codes checked hits to the given 'size'. Fix this by passing 'start' pointing to the CBFS base address. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-31fs: cbfs: remove wrong header validationChristian Gmeiner
cbfs_fileheader.len indicates the content size of the file in the cbfs, and it has nothing to do with cbfs_fileheader.offset which is the starting address of the file in the cbfs. Remove such check in file_cbfs_next_file(). Before this change 'cbfsinit' failed with 'Bad CBFS file'. After this change all cbfs commands are working as expected. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> [bmeng: keep the necessary header sanity check] Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-06fs: fix FAT name extractionPatrick Wildt
The long name apparently can be accumulated using multiple 13-byte slots. Unfortunately we never checked how many we can actually fit in the buffer we are reading to. Signed-off-by: Patrick Wildt <patrick@blueri.se>
2018-12-06fs: check FAT cluster sizePatrick Wildt
The cluster size specifies how many sectors make up a cluster. A cluster size of zero makes no sense, as it would mean that the cluster is made up of no sectors. This will later lead into a division by zero in sect_to_clust(), so better take care of that early. The MAX_CLUSTSIZE define can reduced using a define to make some room in low-memory system. Unfortunately if the code reads a filesystem with a bigger cluster size it will overflow the buffer. Signed-off-by: Patrick Wildt <patrick@blueri.se>
2018-12-02fs: update fs_dev_part in fs_set_blk_dev_with_part()AKASHI Takahiro
As in the case of fs_set_blk_dev(), fs_set_blk_dev_with_part() should maintain and update fs_dev_part whenever called. Without this patch, a problem will come up when an efi binary associated with efi's BOOTxxxx variable is invoked via "bootefi bootmgr". Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-11-20fs: fat: assign rootdir sector when accessing root directoryThomas RIENOESSL
This fixes problems accessing drives formated under Windows as FAT16. Signed-off-by: Thomas RIENOESSL <thomas.rienoessl@bachmann.info> [trini: Rebase on top of f528c140c801] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-11-16fs: Makefile: Add fs.c under SPL for fs_loaderKeerthy
Add fs.c under SPL as well as it is needed for fs_loader Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Add as obj-$(CONFIG_FS_LOADER) for non-SPL_FRAMEWORK builds] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-11-07fs: ubifs: Fix UBIFS decompression on 64 bitPaul Davey
Add local size_t variable to crypto_comp_decompress as intermediate storage for destination length to avoid memory corruption and incorrect results on 64 bit targets. This is what linux does for the various lz compression implementations. Signed-off-by: Paul Davey <paul.davey@alliedtelesis.co.nz> Cc: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de>
2018-10-16fs: fat: Fix warning in normalize_longname()Tom Rini
As observed with clang: fs/fat/fat_write.c:1024:13: warning: comparison of constant 128 with expression of type 'char' is always false [-Wtautological-constant-out-of-range-compare] if ((0x80 <= c) && (c <= 0xff)) ~~~~ ^ ~ fs/fat/fat_write.c:1024:25: warning: comparison of constant 255 with expression of type 'char' is always true [-Wtautological-constant-out-of-range-compare] if ((0x80 <= c) && (c <= 0xff)) ~ ^ ~~~~ Fixes: 25bb9dab14f4 ("fs: fat: check and normalize file name") Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-10-08fs: btrfs: Fix tree traversal with btrfs_next_slot()Yevgeny Popovych
When traversing slots in a btree (via btrfs_path) with btrfs_next_slot(), we didn't correctly identify that the last slot in the leaf was reached and we should jump to the next leaf. This could lead to any kind of runtime errors or corruptions, like: * file data not being read at all, or is read partially * file is read but is corrupted * (any) metadata being corrupted or not read at all, etc The easiest way to reproduce this is to read a large enough file that its EXTENT_DATA items don't fit into a single leaf. Signed-off-by: Yevgeny Popovych <yevgenyp@pointgrab.com> Cc: Marek Behun <marek.behun@nic.cz> Tested-by: Marek Behún <marek.behun@nic.cz>
2018-10-06fs: fat: fix set_cluster()Heinrich Schuchardt
Avoid CoverityScan warning SIGN_EXTENSION by changing the type of parameter size of set_cluster(). Avoid leaking stack content when writing an incomplete last sector. Reported-by: Coverity (CID: 184096) Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-10-06fs: fat: memory leak in fat_unlink()Heinrich Schuchardt
Do not leak filename_copy in case of error. Catch out of memory when calling strdup. Reported-by: Coverity (CID: 184086) Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-09-30fs: btrfs: Fix cache alignment bugsMarek Vasut
The btrfs implementation passes cache-unaligned buffers into the block layer, which triggers cache alignment problems down in the block device drivers. Align the buffers to prevent this. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Behun <marek.behun@nic.cz>
2018-09-23fs: fat: unaligned buffers are not an errorHeinrich Schuchardt
The FAT driver supports unaligned reads and writes and EFI applications will make use of these. So a misaligned buffer is only worth a debug message. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23fs: fat: support unlinkAKASHI Takahiro
In this patch, unlink support is added to FAT file system. A directory can be deleted only if it is empty. In this implementation, only a directory entry for a short file name will be removed. So entries for a long file name can and should be reclaimed with fsck. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23fs: add unlink interfaceAKASHI Takahiro
"unlink" interface is added to file operations. This is a preparatory change as unlink support for FAT file system will be added in next patch. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23fs: fat: support mkdirAKASHI Takahiro
In this patch, mkdir support is added to FAT file system. A newly created directory contains only "." and ".." entries. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
