path: root/fs/yaffs2
2011-12-10fs/yaffs2/yaffs_guts.c: Fix GCC 4.6 compile warning (and bug)Wolfgang Denk
Fix: yaffs_guts.c: In function 'yaffs_GarbageCollectBlock': yaffs_guts.c:2761:6: warning: variable 'retVal' set but not used [-Wunused-but-set-variable] Here GCC actually detected a bug. The code was always returning OK instead of the previously set retrun code. Fix that. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: William Juul <wiljuul@cisco.com> Cc: Scott Wood <scottwood@freescale.com> Acked-by: William Juul <wiljuul@cisco.com>
2011-11-16Fix warnings in yaffsSimon Glass
Sorry if this is already fixed somewhere - I could not find it. This fixes the warnings show below. yaffs_tagscompat.c: In function 'yaffs_TagsCompatabilityReadChunkWithTagsFromNAND': yaffs_tagscompat.c:151: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:150: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:149: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:148: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:147: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:146: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:145: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:144: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:141: note: initialized from here Signed-off-by: Simon Glass <sjg@chromium.org>
2011-11-16fs/yaffs2/yaffs_guts.c: Fix some GCC 4.6 warningsAnatolij Gustschin
Fix: yaffs_guts.c: In function 'yaffs_CheckChunkErased': yaffs_guts.c:854:6: warning: variable 'result' set but not used yaffs_guts.c: In function 'yaffs_UpdateObjectHeader': yaffs_guts.c:3463:6: warning: variable 'result' set but not used yaffs_guts.c: In function 'yaffs_GrabChunkCache': yaffs_guts.c:3774:6: warning: variable 'pushout' set but not used yaffs_guts.c: In function 'yaffs_Scan': yaffs_guts.c:5237:6: warning: variable 'result' set but not used yaffs_guts.c: In function 'yaffs_CheckObjectDetailsLoaded': yaffs_guts.c:5748:6: warning: variable 'alloc_failed' set but not used yaffs_guts.c:5747:6: warning: variable 'result' set but not used yaffs_guts.c: In function 'yaffs_ScanBackwards': yaffs_guts.c:5808:6: warning: variable 'deleted' set but not used yaffs_guts.c:5806:6: warning: variable 'result' set but not used yaffs_guts.c: In function 'yaffs_GetObjectName': yaffs_guts.c:6657:7: warning: variable 'result' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-10-27GCC4.6: Squash warnings in yaffs_guts.cMarek Vasut
yaffs_guts.c: In function 'yaffs_ReadDataFromFile': yaffs_guts.c:4461:8: warning: 'chunk' may be used uninitialized in this function yaffs_guts.c:4462:8: warning: 'start' may be used uninitialized in this function yaffs_guts.c: In function 'yaffs_WriteDataToFile': yaffs_guts.c:4581:8: warning: 'chunk' may be used uninitialized in this function yaffs_guts.c:4582:8: warning: 'start' may be used uninitialized in this function yaffs_guts.c: In function 'yaffs_ResizeFile': yaffs_guts.c:4816:8: warning: 'newSizeOfPartialChunk' may be used uninitialized in this function yaffs_guts.c:4817:8: warning: 'newFullChunks' may be used uninitialized in this function Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: William Juul <william.juul@tandberg.com>
2011-10-27GCC4.6: Drop dead code from yaffs_guts.cMarek Vasut
Drop yaffs_DeleteWorker(): yaffs_guts.c:1556:12: warning: 'yaffs_DeleteWorker' defined but not used Drop yaffs_VerifyTnodeWorker(): yaffs_guts.c:600:12: warning: 'yaffs_VerifyTnodeWorker' defined but not used Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-09-10YAFFS2: fs/yaffs2/yaffs_guts.c - fix build warningsWolfgang Denk
Fix these: yaffs_guts.c: In function 'yaffs_ReadDataFromFile': yaffs_guts.c:4622: warning: pointer targets in passing argument 3 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c:4622: warning: pointer targets in passing argument 4 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c: In function 'yaffs_WriteDataToFile': yaffs_guts.c:4745: warning: pointer targets in passing argument 3 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c:4745: warning: pointer targets in passing argument 4 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c: In function 'yaffs_ResizeFile': yaffs_guts.c:4968: warning: pointer targets in passing argument 3 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c:4968: warning: pointer targets in passing argument 4 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c: In function 'yaffs_GutsInitialise': yaffs_guts.c:7235: warning: assignment from incompatible pointer type yaffs_guts.c: In function 'yaffs_CreateNewObject': yaffs_guts.c:2143: warning: 'tn' may be used uninitialized in this function yaffs_guts.c: In function 'yaffs_MknodObject': yaffs_guts.c:2258: warning: 'str' may be used uninitialized in this function Signed-off-by: Wolfgang Denk <wd@denx.de>
Fix these: yaffs_guts.c: At top level: yaffs_guts.c:400: warning: 'yaffs_SkipFullVerification' defined but not used Testing shows no changes of the image sizes. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-10YAFFS2: fs/yaffs2/yaffs_nand.[hc] - fix build warningsWolfgang Denk
Fix these: yaffs_guts.c: In function 'yaffs_Scan': yaffs_guts.c:5436: warning: pointer targets in passing argument 4 of 'yaffs_QueryInitialBlockState' differ in signedness yaffs_guts.c: In function 'yaffs_ScanBackwards': yaffs_guts.c:6017: warning: pointer targets in passing argument 4 of 'yaffs_QueryInitialBlockState' differ in signedness yaffs_nand.c: In function 'yaffs_QueryInitialBlockState': yaffs_nand.c:109: warning: pointer targets in passing argument 4 of 'dev->queryNANDBlock' differ in signedness yaffs_nand.c:113: warning: pointer targets in passing argument 4 of 'yaffs_TagsCompatabilityQueryNANDBlock' differ in signedness Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-10YAFFS2: fs/yaffs2/Makefile - fix build warningsWolfgang Denk
Drop the "-DNO_Y_INLINE" setting to fix these: yaffs_guts.h:806: warning: 'yaffs_GetBlockInfo' defined but not used Impact on image size is negligible - for the VCMA9 board the text segment size grew from 496353 to 496357 bytes (i. e. 0.0008%); total image size even remained constant. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-10YAFFS2: fs/yaffs2/yaffscfg.c - fix build warningsWolfgang Denk
Fix these: yaffscfg.c: In function 'cmd_yaffs_mread_file': yaffscfg.c:316: warning: format '%08x' expects type 'unsigned int', but argument 3 has type 'char *' yaffscfg.c: In function 'cmd_yaffs_ls': yaffscfg.c:371: warning: format '%7d' expects type 'int', but argument 3 has type 'off_t' Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-21Make the YAFFS filesystem workRemy Bohmer
Recently the YAFFS filesystem support has been added to U-boot. However, just enabling CONFIG_YAFFS2 is not enough to get it working. ymount will generate an exception (when dereferencing mtd->readoob()), because the genericDevice is a null pointer. Further, a lot of logging is produced while using YAFFS fs, so logging should also be disabled. Both issues are solved by this patch. With this patch and CONFIG_YAFFS2 enabled, I get a readable filesystem in U-boot, as well as in Linux. Tested on a Atmel AT91SAM9261EK board. Signed-off-by: Remy Bohmer <linux@bohmer.net> Acked-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-14Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-08-12moving files from yaffs2/direct/ to yaffs2/ and deleting all symlinksWilliam Juul
Signed-off-by: William Juul <william.juul@tandberg.com>
2008-08-12Clean out unneeded filesWilliam Juul
2008-08-12Create symlinks from yaffs2/direct to yaffs2William Juul
2008-08-12Incorporate yaffs2 into U-bootWilliam Juul
To use YAFFS2 define CONFIG_YAFFS2 Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12YAFFS2 importWilliam Juul
Direct import of yaffs as a tarball as of 20071113 from their public CVS-web at http://www.aleph1.co.uk/cgi-bin/viewcvs.cgi/yaffs2/ The code can also be imported on the command line with: export CVSROOT=:pserver:anonymous@cvs.aleph1.co.uk:/home/aleph1/cvs cvs logon (Hit return when asked for a password) cvs checkout yaffs2 Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com>
