path: root/fs/reiserfs
2011-12-12fs/reiserfs/reiserfs.c: Fix compiler warningAnatolij Gustschin
Fix: reiserfs.c: In function 'reiserfs_mount': reiserfs.c:360:22: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-08-31fs: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2007-07-10fs/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09fs/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04fs/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2004-03-25Code cleanupLABEL_2004_03_25_1630wdenk
2004-03-25* Patch by Pavel Bartusek, 21 Mar 2004wdenk
Add Reiserfs support * Patch by Hinko Kocevar, 20 Mar 2004 - Add auto-release for SMSC LAN91c111 driver - Add save/restore of PTR and PNR regs as suggested in datasheet
