path: root/env
2019-07-18MLK-22287 imx8mn: enable CONFIG_ENV_DEFAULT_NOWHERE at defaultYe Li
This CONFIG_ENV_DEFAULT_NOWHERE config must be enabled for USB download when we implemented the override function to select env storage medium. To avoid adding it to every imx8mn defconfig, enable the config as default on imx8mn. Signed-off-by: Ye Li <ye.li@nxp.com>
2019-07-17MLK-22283 env: fix NAND ENV build issue introduced by env offset changeYe Li
Get below build error in nand env, because we should not call function in array initialization. env/nand.c: In function ‘env_nand_save’: env/nand.c:196:15: error: initializer element is not constant .offset = env_get_offset(CONFIG_ENV_OFFSET), Signed-off-by: Ye Li <ye.li@nxp.com>
2019-07-17MLK-22279-2 env: Add a config to enable nowhere as default locationYe Li
When booting from USB there is no place to store the environment and should use default env. However CONFIG_ENV_IS_NOWHERE has dependence with other env storage config. If we enable multiple storages, NOWHERE can't be enabled. And saveenv won't be built if NOWHERE is set. This patch introduces a new CONFIG_ENV_DEFAULT_NOWHERE, that can enable NOWHERE as a default env location when other storage are not avaliable. And allow to build saveenv. Signed-off-by: Ye Li <ye.li@nxp.com>
2019-07-17MLK-22279-1 env: Add env_get_offset to override static env offsetYe Li
Add env_get_offset interface to override static CONFIG_ENV_OFFSET, and update env location driver to use env_get_offset. So for different storage medium, we are able to store the env at different offset. We don't support this feature when CONFIG_ENV_IS_EMBEDDED is set. Signed-off-by: Ye Li <ye.li@nxp.com>
2018-07-05MLK-18776 env: sata: Add missed env location for SATA bootYe Li
The env location label ENVL_ESATA is missed in location tables, so when we configure the ENV in SATA, u-boot fails to get correct env location and cause boot hang in board_f. Signed-off-by: Ye Li <ye.li@nxp.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2018-06-01MLK-18478 env: Fix dead loop when env save failedYe Li
When env save is failed, 2018 u-boot will loop infinitely to save the env, and each time returns failure. The root cause is env_driver_lookup only returns current env location for ENVOP_SAVE, no matter what the prio is. So the loop can't exit until the save is successful. Signed-off-by: Ye Li <ye.li@nxp.com>
2018-04-26MLK-18141-2 env: Kconfig: Add ENV_IS_IN_SATA configYe Li
The ENV_IS_IN_SATA config is missed, add it into env/Kconfig, that we can enable it for SATA boot. Signed-off-by: Ye Li <ye.li@nxp.com>
2018-04-26MLK-18141-1 env: sata: Fix build warning and breakYe Li
Fix below build warning and errors: env/sata.c: In function ‘env_sata_save’: env/sata.c:59:9: warning: implicit declaration of function ‘sata_get_dev’ [-Wimplicit-function-declaration] sata = sata_get_dev(env_sata); ^~~~~~~~~~~~ env/sata.c:59:7: warning: assignment makes pointer from integer without a cast [-Wint-conversion] sata = sata_get_dev(env_sata); ^ env/sata.c: In function ‘env_sata_load’: env/sata.c:101:10: warning: ‘return’ with a value, in function returning void return -EIO; ^ env/sata.c:94:13: note: declared here static void env_sata_load(void) ^~~~~~~~~~~~~ env/sata.c:105:7: warning: assignment makes pointer from integer without a cast [-Wint-conversion] sata = sata_get_dev(env_sata); ^ env/sata.c:108:10: warning: ‘return’ with a value, in function returning void return -EIO; ^ env/sata.c:94:13: note: declared here static void env_sata_load(void) ^~~~~~~~~~~~~ env/sata.c:113:10: warning: ‘return’ with a value, in function returning void return -EIO; ^ env/sata.c:94:13: note: declared here static void env_sata_load(void) ^~~~~~~~~~~~~ env/sata.c:116:9: warning: ‘return’ with a value, in function returning void return env_import(buf, 1); ^~~~~~~~~~~~~~~~~~ env/sata.c:94:13: note: declared here static void env_sata_load(void) ^~~~~~~~~~~~~ env/sata.c: At top level: env/sata.c:120:14: error: ‘ENVL_ESATA’ undeclared here (not in a function) .location = ENVL_ESATA, ^~~~~~~~~~ env/sata.c:122:11: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types] .load = env_sata_load, Signed-off-by: Ye Li <ye.li@nxp.com>
2018-04-26MLK-14828 env_sata: Fix SATA saveenv issueYe Li
Wrong env buffer was passed into sata write function, so the saveenv can't work. Fix this issue. Signed-off-by: Ye Li <ye.li@nxp.com> (cherry picked from commit 0fe7573cffcb50d6bcb401f644cc37f5af28b388)
2018-02-20env: mmc/fat/ext4: make sure that the MMC sub-system is initialized before ↵Faiz Abbas
using it When booting from a non-MMC device, the MMC sub-system may not be initialized when the environment is first accessed. We need to make sure that the MMC sub-system is ready in even a non-MMC boot case. Therefore, initialize mmc before loading environment from it. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2018-02-16env: restore old env_get_char() behaviourGoldschmidt Simon
With multiple environments, the 'get_char' callback for env drivers does not really make sense any more because it is only supported by two drivers (eeprom and nvram). To restore single character loading for these drivers, override 'env_get_char_spec'. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-02-16env: Fix env_load_locationYork Sun
Commit 7d714a24d725 ("env: Support multiple environments") added static variable env_load_location. When saving environmental variables, this variable is presumed to have the value set before. In case the value was set before relocation and U-Boot runs from a NOR flash, this variable wasn't writable. This causes failure when saving the environment. To save this location, global data must be used instead. Signed-off-by: York Sun <york.sun@nxp.com> CC: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-02-12Fix misaligned buffer in env_fat_saveAlex Kiernan
When saving the environment on a platform which has DMA alignment larger than the natural alignment, env_fat_save triggers a debug message in file_fat_write: Saving Environment to FAT... writing uboot.env FAT: Misaligned buffer address (9df1c8e0) OK Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-01env: sf: use env_import_redund to simplify env_sf_loadSimon Goldschmidt
For the redundant environment configuration, env_sf_load still contained duplicate code instead of using env_import_redund(). Simplify the code by only executing the load twice and delegating everything else to env_import_redund. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-02-01env: make env drivers propagate env_import return valueSimon Goldschmidt
For multiple env drivers to correctly implement fallback when one environment fails to load (e.g. crc error), the return value of env_import has to be propagated by all env driver's load function. Without this change, the first driver that succeeds to load an environment with an invalid CRC return 0 (success) and no other drivers are checked. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-02-01env: move more common code to env_import_redundSimon Goldschmidt
There is more common code in mmc, nand and ubi env drivers that can be shared by moving to env_import_redund. For this, a status/error value whether the buffers were loaded are passed as additional parameters to env_import_redund. Ideally, these are already returned to the env driver by the storage driver. This is the case for mmc, nand and ubi, so for this change, code deduplicated. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-31env: make env_import(_redund) return 0 on success, not 1Simon Goldschmidt
env_import (and env_import_redund) currently return 1 on success and 0 on error. However, they are only used from functions returning 0 on success or a negative value on error. Let's clean this up by making env_import and env_import_redund return 0 on success and -EIO on error (as was the case for all users before). Users that cared for the return value are also updated. Funny enough, this only affects onenand.c and sf.c Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: sunxi: Enable FAT-based environment support by defaultMaxime Ripard
Now that we have everything in place to implement the transition scheme, let's enable it by default. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Mark env_get_location as weakMaxime Ripard
Allow boards and architectures to override the default environment lookup code by overriding env_get_location. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Allow to build multiple environments in KconfigMaxime Ripard
Now that we have everything in place in the code, let's allow to build multiple environments backend through Kconfig. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: mmc: depends on the MMC frameworkMaxime Ripard
The raw MMC environment directly calls into the MMC framework. Make sure it's enabled before we can select it. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-27env: Initialise all the environmentsMaxime Ripard
Since we want to have multiple environments, we will need to initialise all the environments since we don't know at init time what drivers might fail when calling load. Let's init all of them, and only consider for further operations the ones that have not reported any errors at init time. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Support multiple environmentsMaxime Ripard
Now that we have everything in place to support multiple environment, let's make sure the current code can use it. The priority used between the various environment is the same one that was used in the code previously. At read / init times, the highest priority environment is going to be detected, and we'll use the same one without lookup during writes. This should implement the same behaviour than we currently have. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: common: Make the debug messages play a little nicerMaxime Ripard
Since we have global messages to indicate what's going on, the custom messages in the environment drivers only make the output less readable. Make the common code play a little nicer by removing all the extra output in the standard case. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: mmc: Make the debug messages play a little nicerMaxime Ripard
Since we have global messages to indicate what's going on, the custom messages in the environment drivers only make the output less readable. Make MMC play a little nicer by removing all the extra \n and formatting that is redundant with the global output. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-27env: fat: Make the debug messages play a little nicerMaxime Ripard
Since we have global messages to indicate what's going on, the custom messages in the environment drivers only make the output less readable. Make FAT play a little nicer by removing all the extra \n and formatting that is redundant with the global output. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Make it explicit where we're loading our environment fromMaxime Ripard
Since we can have multiple environments now, it's better to provide a decent indication on what environments were tried and which were the one to fail and succeed. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Make the env save message a bit more explicitMaxime Ripard
Since we'll soon have support for multiple environments, the environment saving message might end up being printed multiple times if the higher priority environment cannot be used. That might confuse the user, so let's make it explicit if the operation failed or not. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Pass additional parameters to the env lookup functionMaxime Ripard
In preparation for the multiple environment support, let's introduce two new parameters to the environment driver lookup function: the priority and operation. The operation parameter is meant to identify, obviously, the operation you might want to perform on the environment. The priority is a number passed to identify the environment priority you want to retrieve. The lowest priority parameter (0) will be the primary source. Combining the two parameters allow you to support multiple environments through different priorities, and to change those priorities between read and writes operations. This is especially useful to implement migration mechanisms where you want to always use the same environment first, be it to read or write, while the common case is more likely to use the same environment it has read from to write it to. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Rename env_driver_lookup_default and env_get_default_locationMaxime Ripard
The env_driver_lookup_default and env_get_default_location functions are about to get refactored to support loading from multiple environment. The name is therefore not really well suited anymore. Drop the default part to be a bit more relevant. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27cmd: nvedit: Get rid of the env lookupMaxime Ripard
The nvedit command is the only user of env_driver_lookup_default outside of the environment code itself, and it uses it only to print the environment it's about to save to during env save. As we're about to rework the environment to be able to handle multiple environment sources, we might not have an idea of what environment backend is going to be used before trying (and possibly failing for some). Therefore, it makes sense to remove that message and move it to the env_save function itself. As a side effect, we also can get rid of the call to env_driver_lookup_default that is also about to get refactored. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-22env: ENV_IS_IN_FAT improvementsTuomas Tynkkynen
Make it select FS_FAT as well, because if it's not selected, enabling ENV_IS_IN_FAT causes a Kconfig warning: warning: (ENV_IS_IN_FAT) selects FAT_WRITE which has unmet direct dependencies (FS_FAT) This also allows dropping some code from config_fallbacks. Also drop the unnecessary help text about having to enable CONFIG_FAT_WRITE - Kconfig automatically handles that. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-17Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2018-01-17env: sf: Add support for env init for QSPI-NORAshish Kumar
ENV variables can now be used before relocation. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-15env: enable accessing the environment in an EXT4 partitionJorge Ramirez-Ortiz
For example to store the environment in a file named "/uboot.env" in MMC "0", where partition "1" contains the EXT4 filesystem, the following configs should be added to the board's default config: CONFIG_ENV_IS_IN_EXT4=y CONFIG_ENV_EXT4_DEVICE_AND_PART="0:1" CONFIG_ENV_EXT4_FILE="/uboot.env" CONFIG_ENV_EXT4_INTERFACE="mmc" Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org> [trini: Fix some line over 80 chars issues] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-18rockchip: move CONFIG_ENV_SIZE and CONFIG_ENV_OFFSET to KconfigKlaus Goger
This commit adds ENV_SIZE and ENV_OFFSET configuration items for ARCH_ROCKCHIP, but keeps these non-visible (i.e. not prompt is given). With these new items present, the configuration from the header files is moved to Kconfig. Keeping these non-visible is necessary to have the possibility to select new default values if CONFIG_IS_IN_* is changed (interactively or with oldconfig). Otherwise it will always be set to a previous value if used with a prompt. As an example if we do a defconfig with CONFIG_IS_IN_MMC and change it to CONFIG_IS_IN_SPI_FLASH via menuconfig, ENV_SIZE and ENV_OFFSET will not be changed to the correct values as defconfig will already have set them to the default values of CONFIG_IS_IN_MMC in .config. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-29env: suppress a spurious warning with GCC 7.1Philipp Tomsich
GCC 7.1 seems to be smart enough to track val through the various static inline functions, but not smart enough to see that val will always be initialised when no error is returned. This triggers the following warning: env/mmc.c: In function 'mmc_get_env_addr': env/mmc.c:121:12: warning: 'val' may be used uninitialized in this function [-Wmaybe-uninitialized] To make it easier for compiler to understand what is going on, let's initialise val. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-21env: Remove CONFIG_ENV_AES supportTom Rini
This support has been deprecated since v2017.09 due to security issues. We now remove this support. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-11-17env: Save environment at the end of an MMC partitionJorge Ramirez-Ortiz
Allow the platform to define a partition by name at the end of which the environment data will be located. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-10-27env: x86: braswell: Set ENV_IS_IN_SPI_FLASH as defaultBin Meng
Imply does not work for a Kconfig choice. Update ENV_IS_IN_SPI_FLASH to be the default one for Intel Braswell. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-16env: Drop CONFIG_ENV_IS_IN_DATAFLASHTuomas Tynkkynen
Last user of this option went away in commit: fdc7718999 ("board: usb_a9263: Update to support DT and DM") Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-15ARM: uniphier: switch to CONFIG_ENV_IS_NOWHEREMasahiro Yamada
The non-volatile storage varies board by board. The default should be NOWHERE. Please choose a proper device via Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-08env: Migrate CONFIG_ENV_AES to Kconfig and deprecateTom Rini
The underlying implementation for ENV_AES has security complications and is not recommended for use. Please see CVE-2017-3225 and CVE-2017-3226 for more details. Mark this as deprecated now and delete this in the medium term if no one comes forward to re-work the support. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-02Kconfig: Add EEPROM options to Kconfig when I2C_EEPROM is setAdam Ford
Add the following options to drivers/misc/Kconfig: SYS_I2C_EEPROM_ADDR SYS_I2C_EEPROM_BUS SYS_EEPROM_SIZE SYS_EEPROM_PAGE_WRITE_BITS SYS_EEPROM_PAGE_WRITE_DELAY_MS SYS_I2C_EEPROM_ADDR_LEN SYS_I2C_EEPROM_ADDR_OVERFLOW This does not migrate any boards, but provides a foundations for those who want/need these options Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Migrate uniphier] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-20env: Replace all open-coded gd->env_valid values with ENV_ flagsSimon Glass
Some of these were missed in the conversion. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-20env: Allow env_load() to detect errorsSimon Glass
Now that we have errors available in the environment driver's load() method, check the return valid. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-20env: Correct case of no sub-init functionTom Rini
With the change to the environment code to remove the common init stage of pointing to the default environment and setting it as valid, combined with the change to switch gd->env_valid from 0/1/2 to an enum we now must set env_valid to one of the enum values rather than an int. And in this case, not only was setting it to an int wrong, it was now the wrong value. Finally, in the case of ENV_IS_NOWHERE we must still say that our envionrment is invalid after init for things to continue to function. Fixes: 7938822a6b75 ("env: Drop common init() functions") Tested-by: Marek Vasut <marek.vasut@gmail.com> Reported-by: Marek Vasut <marek.vasut@gmail.com> Reported-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> --- Changes in v3: - Actually include changes for env/nowhere.c
2017-08-20env: Sort selection of default choicesAndy Shevchenko
It would be easier to catch out which platform is using which default. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-08-16env: Adjust the load() method to return an errorSimon Glass
The load() methods have inconsistent behaviour on error. Some of them load an empty default environment. Some load an environment containing an error message. Others do nothing. As a step in the right direction, have the method return an error code. Then the caller could handle this itself in a consistent way. Signed-off-by: Simon Glass <sjg@chromium.org>
