Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
This provides a way of simulating GPIOs by setting values which are seen
by the normal gpio_get/set_value() calls.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
ARM boards should use the generic GPIO API
This means changing gpio to unsigned type
Remove the unused gpio_toggle() function which is not part of the API
Comment that free should not modify pin state
fixed merge conflict in da8xx_gpio.c, tegra2_gpio.c, and
extended to the new mxs_gpio.c.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Signed-off-by: Jason Liu <jason.hui@linaro.org>
... rather than open-coding the register accesses.
However, gpio_request() typically stores the "label" parameter in a global
data structure. This causes problems when called from gpio_config_uart(),
since the code is running before relocation. To solve this, pass a NULL
string to gpio_request(), and modify gpio_request() not to touch the string
if it's NULL.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Fix:
da8xx_gpio.c: In function 'gpio_toggle_value':
da8xx_gpio.c:208:23: warning: variable 'bank' set but not used
[-Wunused-but-set-variable]
This patch fixes a small off-by-one bug in the GPIO driver for the mxs platform that allowed the selection gpio pins of one bank more than the SoC actually has.
Signed-off-by: Robert Deliën <robert at delien.nl>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
* 'sr@denx.de' of git://git.denx.de/u-boot-staging:
Makefile: Add the missing dependency for spl target
gpio: Adapt PCA9698 to standard GPIO API
* 'master' of git://git.denx.de/u-boot-nios:
nios2: Offer ft_board_setup() capability and call fdt_fixup_ethernet().
board/nios2-generic: Use altera_pio driver and remove board specific driver
gpio: Add driver for Altera's PIO core
nios2: Pseudo implement dcache_status/enable/disable()
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
Cc: Detlev Zundel <dzu@denx.de>
This driver may handle multiple PIO cores and thus needs to be
setup by calling the altera_pio_init() function within the early
board setup routine.
The driver comes with some extras, see below the copyleft header.
Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com>
Tested-by: Thomas Chou <thomas@wytron.com.tw>
Build pass with following config:
dkb_config
aspenite_config
Signed-off-by: Lei Wen <leiwen@marvell.com>
For files like the drivers/serial/serial.c, it must include the
platform file, as the CONFIG_SYS_NS16550_COM1 must reference to the
definition in the platform definition files.
Include the platform definition file in the config file, so that it
would decouple the dependence for the driver files.
The function kw_gpio_is_valid returns zero on success, so
adapt the error check accordingly.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
cc: Dieter Kiermaier <dk-arm-linux@gmx.de>
This patch adds generic GPIO driver framework support for Marvell SoCs.
To enable GPIO driver define CONFIG_MARVELL_GPIO and for GPIO commands
define CONFIG_CMD_GPIO in your board configuration file.
Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
This patch adds support for software I2C for GONI and Universal C210 reference targets.
It adds support for access to GPIOs by number, not as it is present,
by bank and offset.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
IMX processors has a slightly different interface
to access GPIOs and do not make use of the provided GPIO
framework. The patch substitutes mxc_ specific
functions and make use of the API in asm/gpio.h
This change is driven by need of general gpio_* functions,
which as their parameter are accepting the GPIO pin number, NOT
block and pin.
This makes the code alike to omap, and allows for using more
generic frameworks (e.g. software I2C).
Add a generic GPIO driver for the DaVinci DA8xx processors. It is turned
on by defining CONFIG_DA8XX_GPIO and fulfills the generic GPIO interface
specified in <asm/gpio.h> . The driver has support for both manipulating
GPIO pins as well as automatically configuring the pin multiplexor
registers to set the pin function to GPIO.
Signed-off-by: Laurence Withers <lwithers@guralp.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
and remove the now unused asm/arch-at91/io.h
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
As exception among the i.MX processors, the i.MX31 has headers
without general names (mx31-regs.h, mx31.h instead of imx-regs.h and
clock.h). This requires several nasty #ifdef in the drivers to
include the correct header. The patch cleans up the driver and
renames the header files as for the other i.MX processors.
This patch adds the Multiple Function Pin configuration support for
Marvell PANTHEON SoCs
This patch add mxc_gpio support for Freescale MX53 processor
Signed-off-by: Jason Liu <r64343@freescale.com>
This adds support for for the PCA9535/PCA9539 family of gpio devices which
have 16 output pins.
To let the driver know which devices are 16-pin it is necessary to define
CONFIG_SYS_I2C_PCA953X_WIDTH in your board config file. This is used to
create an array of {chip, ngpio} tuples that are used to determine the
width of a particular chip. For backwards compatibility it is assumed that
any chip not defined in CONFIG_SYS_I2C_PCA953X_WIDTH has 8 pins.
Acked-by: Peter Tyser <ptyser@xes-inc.com>
Tested-by: Peter Tyser <ptyser@xes-inc.com>
Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Most of the Marvell SoCs has Multi Function Pin (MFP) configuration registers
For ex. ARMADA100.
These registers are programmed to expose the specific functionality
associated with respective SoC Pins
This driver provides configuration APIs,
using them, configuration need to be done in board specific code
for ex- following code configures MFPs 107 and 108 for UART_TX/RX functionality
int board_early_init_f(void)
u32 mfp_cfg[] = {
/* Console on UART1 */
MFP107_UART1_RXD,
MFP108_UART1_TXD,
MFP_EOC /*End of configureation*/
/* configure MFP's */
mfp_config(mfp_cfg);
return 0;
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
The patch adds support for setting gpios to the
MX51 processor and change name to the corresponding
functions for MX31. In this way, it is possible to get rid
of nasty #ifdef switches related to the processor type.
Use the same configuration around S5P SoCs.
(s5pc100, s5pc110, s5pc210 and so on)
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
When set to PULL_NONE, gpio_set_pull function is returned without write the register.
This patch fixed it.
The patch adds an accessor function to get the value of a gpio.
Because of s5pc1xx gpio is same as s5p seires SoC,
move gpio functions to drvier/gpio/
and modify structure's name from s5pc1xx_ to s5p_.
* add a real AT91 GPIO driver instead of header inline code
* resolve the mixing of port and pins
* change board config files to use new driver
* add macros to gpio to realize backward compatibility
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
later
These are few files directly imported from Linux kernel source.
Those are not modifyed at all ar per strategy.
These files contains source with GPLv2 only
whereas u-boot expects GPLv2 or latter
These files are updated for the same from prior permission from original writes
Acked-by: Nicolas Pitre <nico@marvell.com>
Signed-off-by: Dieter Kiermaier <dk-arm-linux@gmx.de>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
Tested-by: Heiko Schocher <hs@denx.de>
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
This is a minimal driver, so far only managing output. It will
be used by the mxc_spi.c driver.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
Initial support for NXP's 4 and 8 bit I2C gpio expanders
(eg pca9537, pca9557, etc). The CONFIG_PCA953X define
enables support for the devices while the CONFIG_CMD_PCA953X
define enables the pca953x command. The CONFIG_CMD_PCA953X_INFO
define enables an 'info' sub-command which provides summary
information for the given pca953x device.
