path: root/drivers/bios_emulator
2011-11-27drivers/bios_emulator/x86emu/ops2.c: Fix GCC 4.6 build warningKumar Gala
Fix: x86emu/ops2.c: In function 'x86emuOp2_set_byte': x86emu/ops2.c:171:11: warning: variable 'name' set but not used [-Wunused-but-set-variable] Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-16drivers/bios_emulator/x86emu/ops.c: Fix GCC 4.6 build warningKumar Gala
Fix: x86emu/ops.c: In function 'x86emuOp_int3': x86emu/ops.c:3521:9: warning: variable 'tmp' set but not used [-Wunused-but-set-variable] x86emu/ops.c: In function 'x86emuOp_int_IMM': x86emu/ops.c:3549:9: warning: variable 'tmp' set but not used [-Wunused-but-set-variable] x86emu/ops.c: In function 'x86emuOp_into': x86emu/ops.c:3579:9: warning: variable 'tmp' set but not used [-Wunused-but-set-variable] x86emu/ops.c: In function 'x86emuOp_aad': x86emu/ops.c:3993:8: warning: variable 'a' set but not used [-Wunused-but-set-variable] Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-17Replace space and tab checks with isblankJason Hobbs
These are various places I found that checked for conditions equivalent to isblank. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2010-04-08ati_radeon: Support PCI virtual not eq bus mapping.Ed Swarthout
Use pci_bus_to_virt() to convert the bus address from the BARs to virtual address' to eliminate the direct mapping requirement. Rename variables to better match usage (_phys -> _bus or no-suffix) This fixes the mpc8572ds CONFIG_PHYS_64BIT mode failure: "videoboot: Video ROM failed to map!" Tested on mpc8572ds with and without CONFIG_PHYS_64BIT. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2010-04-08ati_radeon: return with error when emulator failsEd Swarthout
Console was being switched to video even if emulator fails and causing this hang: Scanning PCI bus 04 04 00 1095 3132 0104 00 PCIE3 on bus 03 - 04 Video: ATI Radeon video card (1002, 5b60) found @(2:0:0) videoboot: Booting PCI video card bus 2, function 0, device 0 videoboot: Video ROM failed to map! 640x480x8 31kHz 59Hz radeonfb: FIFO Timeout ! Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Tested-by: Anatolij Gustschin <agust@denx.de>
2009-12-17drivers/bios_emulator: Fix compile error in .depend not being generatedKumar Gala
make -C drivers/bios_emulator/ make[2]: Entering directory `drivers/bios_emulator' In file included from atibios.c:49: biosemui.h:47:21: error: biosemu.h: No such file or directory ... x86emu/decode.c:40:28: error: x86emu/x86emui.h: No such file or directory ... Due to lack of proper CPPFLAGS being passed to .depend generation rule Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-12Leave x86emu op code tables in default sectionEd Swarthout
Forcing the tables into got2 caused extra relocation when using -mrelocatable. This patch requires any board defining CONFIG_BIOSEMU to use -mrelocatable. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Jin Zhengxiong <Jason.Jin@freescale.com>
2009-07-29Update Freescale copyrights to remove "All Rights Reserved"Kumar Gala
"All Rights Reserved" conflicts with the GPL. Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
2009-07-23unify HOST_CFLAGS and HOSTCFLAGSMike Frysinger
The top build system sets up HOSTCFLAGS a bit and exports it, but other places use HOST_CFLAGS instead. Unify the two as HOSTCFLAGS so that the values stay in sync. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-23drivers/bios_emulator: Fix gcc 4.4 compiler warningKumar Gala
biosemu.c: In function 'BE_setVGA': biosemu.c:147: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-07drivers/bios_emulator: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-10-17Fix the function conflict in x86emu when DEBUG is onJason Jin
The function parse_line() in common/main.c was exposed globally by commit 6636b62a6efc7f14e6e788788631ae7a7fca4537, Result in conflict with the same name funciton in drivers/bios_emulator/x86emu/debug.c when define the DEBUG. This patch fix this by renaming the function in the debug.c file. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2008-02-16Wipe out assembler warnings while compiling x86 biosemuAnatolij Gustschin
This patch tries to get rid of some assembler warnings about changed .got2 section type while compiling x86 bios emulator code. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2007-11-18Fix compiler warnings for PPC systems. Update CHANGELOG.Wolfgang Denk
2007-09-07Add BUILD_DIR support for bios emulator.Jason Jin
2007-08-16Bios emulator - fix microblaze toolchain problemMichal Simek
microblaze CPU have problem with bios_emulator code. Microblaze toolchain doesn't support PRAGMA PACK. Signed-off-by: Michal Simek <monstr@monstr.eu>
2007-08-09Minor fix for bios emulator makefileJason Jin
Add $(obj) to LIB avoiding objects be built in the source dir Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2007-08-09Add CONFIG_BIOSEMU define to guard all the bios emulator codeJason Jin
Signed-off-by: Jason Jin <Jason.jin@freescale.com> This patch fix the compile issue on the board that did not enable the bios emulator
2007-08-06Coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-08-06This is a BIOS emulator, porting from SciTech for u-boot, mainly forJason Jin
ATI video card BIOS. and can be used for x86 code emulation by some modifications. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
