path: root/doc/README.omap3
2011-11-04OMAP3: mvblx: Initial support for mvBlueLYNX-XMichael Jones
Add support for the MATRIX VISION mvBlueLYNX-X, an OMAP3-based intelligent camera. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27omap3: Add interface for omap3 DMASimon Schwarz
Adds an interface to use the OMAP3 DMA. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap: gpio: generic changes after changing APISanjeev Premi
This patch contains the generic changes required after change to generic API in the previous patch. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02OMAP3: add CM-T35 boardMike Rapoport
This patch adds support for CM-T35 board Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-07-07Coding style cleanup; update CHANGELOGWolfgang Denk
2009-06-12Fix a typo in the instructions on using omap3's gpio interface.Tom Rix
Using the example for reading a gpio, shows the problem. NULL should be the gpio number. Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2009-06-12OMAP3 Port kernel omap gpio interface.Tom Rix
Port version 2.6.27 of the linux kernel's omap gpio interface to u-boot. The orignal source is in linux/arch/arm/plat-omap/gpio.c See doc/README.omap3 for instructions on use. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12ZOOM2 Add initial support for Zoom2Tom Rix
Zoom2 is a new board from Texas Instruments and LogicPD The logicpd web site is a good source for general information on this board. Please start looking here if the below links are broken. http://www.logicpd.com This is a pdf of the product http://www.logicpd.com/sites/default/files/1012659A_Zoom_OMAP34x-II_MDP_Brief.pdf This is the product description web page http://www.logicpd.com/products/development-kits/texas-instruments-zoom%E2%84%A2-omap34x-ii-mdp This patch provides a zoom2 base target by copying zoom1 and by making some obvious changes. To configure, run make omap3_zoom2_config Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-01-28OMAP3: Add Zoom1 board supportDirk Behme
Support for Zoom MDK with OMAP3430. Details of Zoom MDK available here: http://www.logicpd.com/products/devkit/ti/zoom_mobile_development_kit Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add Pandora supportDirk Behme
Add Pandora support. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add EVM boardDirk Behme
Add EVM board support. Signed-off-by: Manikandan Pillai <mani.pillai@ti.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add Overo boardDirk Behme
Add Overo board support. Signed-off-by: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add common power code, README, and BeagleBoardDirk Behme
Add BeagleBoard support, common power code and README. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
