path: root/doc/README.MPC866
2004-09-28* Patch by Yuli Barcohen, 13 Jul 2004:wdenk
Allow clock setting on MPC866/MPC885 series chips according to environment variable `cpuclk' * Patch by Yuli Barcohen, 20 Apr 2004: Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x
2004-01-31Fix variable CPU clock for MPC859/866 systems for low CPU clockswdenk
2004-01-29* Implement adaptive SDRAM timing configuration based on actual CPULABEL_2004_01_29_1030wdenk
clock frequency for INCA-IP; fix problem with board hanging when switching from 150MHz to 100MHz * Add PCMCIA CS support for BMS2003 board
