path: root/doc/README.IceCube
2004-04-18* Temporarily disabled John Kerl's extended MII command code becausewdenk
"miivals.h" is missing * Patches by Mark Jonas, 13 Apr 2004: - Remove CS0 chip select timing setting from cpu/mpc5xxx/start.S - Add sync instructions to IceCube SDRAM init code - Move SDRAM chip constants into seperate include files - Unify DDR and SDR initialization code - Unify all IceCube (Lite5xxx) target names
2004-04-10Release version 1.1.0U-Boot-1_1_0wdenk
