path: root/disk
2005-02-24Cleanup USB and partition defineswdenk
2004-04-18* Cleanup, minor fixeswdenk
* Patch by Rune Torgersen, 16 Apr 2004: LBA48 fixes * Patches by Pantelis Antoniou, 16 Apr 2004: - Fix some compile problems; add "once" functionality for the netretry variable
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2004-01-03Patches by Stephan Linz, 11 Dec 2003:wdenk
- more documentation for NIOS port - new struct nios_pio_t, struct nios_spi_t - Reconfiguration for NIOS Development Kit DK1C20: o move board related code from board/dk1c20 to board/altera/dk1c20 o create a new common source path board/altera/common and move generic flash access stuff into it o change/expand configuration file DK1C20.h - Add support for NIOS Development Kit DK1S10 - Add status LED support for NIOS systems - Add dual 7-segment LED support for Altera NIOS DevKits
2003-09-10* Patches by Denis Peter, 9 Sep 2003:U-Boot-0_4_8wdenk
add FAT support for IDE, SCSI and USB * Patches by Gleb Natapov, 2 Sep 2003: - cleanup of POST code for unsupported architectures - MPC824x locks way0 of data cache for use as initial RAM; this patch unlocks it after relocation to RAM and invalidates the locked entries. * Patch by Gleb Natapov, 30 Aug 2003: new I2C driver for mpc107 bridge. Now works from flash. * Patch by Dave Ellis, 11 Aug 2003: - JFFS2: fix typo in common/cmd_jffs2.c - JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option - JFFS2: remove node version 0 warning - JFFS2: accept JFFS2 PADDING nodes - SXNI855T: add AM29LV800 support - SXNI855T: move environment from EEPROM to flash - SXNI855T: boot from JFFS2 in NOR or NAND flash * Patch by Bill Hargen, 11 Aug 2003: fixes for I2C on MPC8240 - fix i2c_write routine - fix iprobe command - eliminates use of global variables, plus dead code, cleanup.
2003-09-10* Add support for USB Mass Storage Devices (BBB)wdenk
(tested with USB memory sticks only) * Avoid flicker on TRAB's VFD
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
2003-05-20* Patch by David Updegraff, 22 Apr 2003:LABEL_2003_05_20_1630wdenk
update for CrayL1 board * Patch by Pantelis Antoniou, 21 Apr 2003: add boot support for ARTOS (a proprietary OS) * Patch by Steven Scholz, 11 Apr 2003: Add support for RTC DS1338 * Patch by Rod Boyce, 24 Jan 2003: Fix counting of extended partitions in diskboot command
2002-03-08Initial revisionwdenk
2001-07-05Initial revisionwdenk
2001-03-29Initial revisionwdenk
