path: root/common/main.c
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-06Add cmd_process() to process commands in one placeSimon Glass
We currently have the same code in hush.c and main.c. This brings the code into one place. As an added feature, if the command function returns CMD_RET_USAGE then cmd_process() will print a usage message for the command before returning the standard failure code of 1. ARM code size increases about 32 bytes with this clean-up. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-06Create a single cmd_call() function to handle command executionSimon Glass
We should aim for a single point of entry to the commands, whichever parser is used. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-06Don't include standard parser if hush is usedSimon Glass
This saves about 1KB of code space on ARM with CONFIG_SYS_HUSH_PARSER defined. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-06Stop using builtin_run_command()Simon Glass
Boards can select either the 'built-in' parser or the hush parser. We should not call builtin_run_command() if we are using the hush parser. We use run_command() instead, since it knows how to call the correct parser. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06Rename run_command2() to run_command()Simon Glass
This is a more sensible name, so rename it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06Rename run_command() to builtin_run_command()Simon Glass
The current run_command() is only one of the parsing options - the other is hush. We should not call run_command() when the hush parser is being used. So we rename this function to better explain its purpose. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06Remove CMD_PXE's static on run_command()Simon Glass
It really isn't clear why this is here and there is no comment, so drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12common, menu: show menu on startup if CONFIG_MENU_SHOW is definedHeiko Schocher
show a menu on startup instead running the shell. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Jason Hobbs <jason.hobbs@calxeda.com>
2012-02-12common: add possibility for readline_into_buffer timeoutHeiko Schocher
add possibility to add a timeout when reading a line into a buffer. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17Add pxe commandJason Hobbs
Add pxe command, which is intended to mimic PXELINUX functionality. 'pxe get' uses tftp to retrieve a file based on UUID, MAC address or IP address. 'pxe boot' interprets the contents of PXELINUX config like file to boot using a specific initrd, kernel and kernel command line. This patch also adds a README.pxe file - see it for more details on the pxe command. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-17Replace space and tab checks with isblankJason Hobbs
These are various places I found that checked for conditions equivalent to isblank. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-17cosmetic: remove unneeded curly bracesJason Hobbs
This prevents a checkpatch warning in the patch to use isblank Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-17common: add run_command2 for running simple or hush commandsJason Hobbs
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17common, menu: use abortboot for menu timeoutJason Hobbs
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26automatic update from FIT image: add optional address parameterAndreas Pretzsch
Current update_tftp() flow: 1.) fetch "updatefile" from defined TFTP server 2.) check if FIT format 3.) flash contained images Add an address parameter to update_tftp(). If this address is non-zero, skip the TFTP transfer and use the image at this address. Also extend update_tftp() to return success/fail. Signed-off-by: Andreas Pretzsch <apr@cn-eng.de>
2011-07-25cosmetic, main: correct indentation/spacing issuesJason Hobbs
2011-07-25cosmetic, main: clean up declarations of abortbootJason Hobbs
Remove an unneeded prototype declaration from the top of main.c, and use plain inline instead of __inline__ to please checkpatch. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-01-09cmd editing: mark erase/tab seqs constantMike Frysinger
These strings are only read, so no need to have them be writable. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28autocomplete: remove runtime handler installMike Frysinger
Rather than add runtime overhead of installing completion handlers, do it statically at build time. This requires a new build time helper macro to declare a command and the completion handler at the same time. Then we convert the env related funcs over to this. This gives an opportunity to also unify the U_BOOT_CMD macros. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28do_bootd: unify duplicate prototypesMike Frysinger
2010-10-06Replace MAX_CMDBUF_SIZE references with CONFIG_SYS_CBSIZEPeter Tyser
The MAX_CMDBUF_SIZE define is unneeded as it should always equal CONFIG_SYS_CBSIZE. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-08-09cmd editing: optimize/shrink output blankingMike Frysinger
No need to output spaces 1 char at a time in a loop when the printf code can do the same thing with the right format string. This shrinks things and gives a nice speed up when killing off lines more than a byte or two as printf will send out the buffer in one big chunk. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-23Remove AmigaOneG3SE boardWolfgang Denk
The AmigaOneG3SE board has been orphaned or a very long time, and broken for more than 12 releases resp. more than 3 years. As nobody seems to be interested any more in this stuff we may as well ged rid of it, especially as it clutters many areas of the code so it is a continuous pain for all kinds of ongoing work. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-10FIX: watchdog timeout, while waiting for inputJens Scharsig
* add WATCHDOG_RESET to !tstc() loops * prevents watchdog timeout, while waiting for input, if CONFIG_BOOT_RETRY_TIME or CONFIG_SHOW_ACTIVITY defined Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-03-21cmd history: Match history buffer size to console bufferJohn Schmoller
Match history buffer size to console buffer size. History buffer size was hard coded to 256, artificially limiting the command buffer size. The history buffer now tracks CONFIG_SYS_CBSIZE. Signed-off-by: John Schmoller <jschmoller@xes-inc.com>
2010-03-21console: Fix console buffer overrunJohn Schmoller
When CONFIG_SYS_CBSIZE equals MAX_CMDBUF_SIZE, a command string of maximum length will overwrite part of the history buffer, causing the board to die. Expand the console_buffer and hist_lines buffer by one character each to hold the missing NULL char. Signed-off-by: John Schmoller <jschmoller@xes-inc.com>
2010-03-11Move CONFIG_UPDATE_TFTP code after CONFIG_PREBOOTWolfgang Denk
The auto-update feature (CONFIG_UPDATE_TFTP) requires that the env variable serverip be set for the TFTP access. If DHCP is to be used to get the serverip env variable, this doesn't work as DHCP happens after the auto-update attempt has run. A solution is to run DHCP in PREBOOT, but even this is too late. To solve this, we move update_tftp() below the PREBOOT stuff. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-10-27readline(): Add ability to modify a string bufferPeter Tyser
If the 'buf' parameter is a non-0-length string, its contents will be edited. Previously, the initial contents of 'buf' were ignored and the user entered its contents from scratch. This change is necessary to support the upcoming "editenv" command but could also be used for future commands which require a user to modify an existing string. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-27cread_line(): Remove unused variablesPeter Tyser
2009-10-27Check for NULL prompt in readline_into_buffer()Peter Tyser
Previously, passing readline() or readline_into_buffer() a NULL 'prompt' parameter would result in puts() printing garbage when CONFIG_CMDLINE_EDITING was enabled. Note that no board currently triggers this bug. Enabling CONFIG_CMDLINE_EDITING on some boards (eg bab7xx) would result in the bug appearing. This change is only intended to prevent someone from running into this issue in the future. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-05-15Remove inline qualifier from show_boot_progress()Emil Medve
The 'inline' is conflicting with the semantic of 'weak' attribute and with the way the show_boot_progress() function is used. Also gcc 4.4 is complaining about it: main.c:51: error: inline function 'show_boot_progress' cannot be declared weak Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2009-01-24common/main: support bootdelay=0 for CONFIG_AUTOBOOT_KEYEDPeter Korsgaard
Support bootdelay=0 in abortboot for the CONFIG_AUTOBOOT_KEYED case similar to the CONFIG_ZERO_BOOTDELAY_CHECK support for the !CONFIG_AUTOBOOT_KEYED case. Do this by reversing the loop so we do at least one iteration before checking for timeout. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
2008-10-18hush: add showvar command for hush shell.Heiko Schocher
This new command shows the local variables defined in the hush shell: => help showvar showvar - print values of all hushshell variables showvar name ... - print value of hushshell variable 'name' Also make the set_local_var() and unset_local_var () no longer static, so it is possible to define local hush shell variables at boot time. If CONFIG_HUSH_INIT_VAR is defined, u-boot calls hush_init_var (), where boardspecific code can define local hush shell variables at boottime. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18Automatic software update from TFTP serverBartlomiej Sieka
The auto-update feature allows to automatically download software updates from a TFTP server and store them in Flash memory during boot. Updates are contained in a FIT file and protected with SHA-1 checksum. More detailed description can be found in doc/README.update. Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-08-06Fix merge problemsStefan Roese
2008-07-09Fix printf errors.Andrew Klossner
The compiler will help find mismatches between printf formats and arguments if you let it. This patch adds the necessary attributes to declarations in include/common.h, then begins to correct the resulting compiler warnings. Some of these were bugs, e.g., "$d" instead of "%d" and incorrect arguments. Others were just annoying, like int-long mismatches on a system where both are 32 bits. It's worth fixing the annoying errors to catch the real ones. Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
2008-06-03Additional fix to readline_into_buffer() with CONFIG_CMDLINE_EDITING before ↵Peter Tyser
relocating Removed unneeded command line history initialization. Also, the original code would access the 'initted' variable before relocation to SDRAM which resulted in erratic behavior since the bss is not initialized when executing from flash. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-05-09Fix readline_into_buffer() with CONFIG_CMDLINE_EDITING before relocatingJames Yang
When CONFIG_CMDLINE_EDITING is enabled, readline_into_buffer() doesn't work before relocating to RAM because command history is written into a global array that is not writable before relocation. This patch defers to the no-editing and no-history code in readline_into_buffer() if it is called before relocation. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-18The patch introduces the CRITICAL feature of POST tests. If the test marked ↵Yuri Tikhonov
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-01-12Make bootretry work when command line editing is enabledAndreas Engel
Currently, when CONFIG_CMDLINE_EDITING is set, bootretry doesn't work. This patch fixes the problem. Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
2008-01-11Fix compiler warningKumar Gala
main.c: In function 'readline_into_buffer': main.c:927: warning: unused variable 'p_buf' Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-09Expose parse_line() globally.James Yang
Add new function readline_into_buffer() that allows the output of readline to be put into a pointer to char buffer. This refactoring allows other functions besides the main command loop to also use the same input mechanism. Signed-off-by: James Yang <James.Yang@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com>
