path: root/common/lynxkdi.c
2011-10-22checkpatch whitespace cleanupsStephen Warren
This avoids the following checkpatch warning in later patches: ERROR: "(foo*)" should be "(foo *)" ERROR: space required before the open brace '{' ERROR: space prohibited before that close parenthesis ')' ERROR: spaces required around that '||' (ctx:WxV) WARNING: space prohibited between function name and open parenthesis '(' WARNING: line over 80 characters This fixes all the white-space warnings/errors in my subsequent patch, and within this current patch. A number of other checkpatch warnings and errors are still present in this patch itself, but are beyond simple whitespace fixes, so are not solved by this patch. v2: New patch Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2009-03-28Fix implicit declaration of function 'eth_[gs]etenv_enetaddr'Wolfgang Denk
...and some other compile warnings. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-20lynxkdi: get mac address from environmentMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2008-08-13common: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-02-07[new uImage] Cleanup cmd_bootm.cMarian Balakowicz
- sort and cleanup headers, declarations, etc. - group related routines - cleanup indentation, white spaces Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2006-03-12Add loads of ntohl() in image header handlingWolfgang Denk
Patch by Steven Scholz, 10 Jun 2005
2005-08-08Changed CONFIG_440_xx to CONFIG_440xx for a consistent design (405 and linux)Stefan Roese
Patch by Stefan Roese, 08 Aug 2005
2005-08-01Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone.Stefan Roese
Patch by Steven Blakeslee, 27 Jul 2005
2003-07-27* Patch by Scott McNutt, 21 Jul 2003:wdenk
Add support for LynuxWorks Kernel Downloadable Images (KDIs). Both LynxOS and BlueCat linux KDIs are supported. * Patch by Richard Woodruff, 25 Jul 2003: use more reliable reset for OMAP/925T * Patch by Nye Liu, 25 Jul 2003: fix typo in mpc8xx.h * Patch by Richard Woodruff, 24 Jul 2003: Fixes for cmd_nand.c: - Fixed null dereferece which could result in incorrect ECC values. - Added support for devices with no Ready/Busy signal hooked up. - Added OMAP1510 read/write protect handling. - Fixed nand.h's ECCPOS. A conflict existed with POS5 and badblock for non-JFFS2. - Switched default ECC to be JFFS2.
