path: root/common/cmd_version.c
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-02-02Print compiler and linker version with the version commandAlexander Holler
After years of unsuccessful research I've finally shamelessly stolen other peoples intellectual properties to present the all-new and world-changing updated version command: - U-Boot>> version U-Boot 2010.12-00014-g7435056-dirty (Jan 18 2011 - 23:19:38) MyBoard gcc (GCC) 0.42 (Distro foobar) GNU ld (GNU Binutils) 0.314159265 - May the toolchain bugs rest in peace. Signed-off-by: Alexander Holler <holler@ahsoftware.de>
2009-11-23command.c: Break commands out to appropriate cmd_*.c filesPeter Tyser
command.c should contain common code related to commands, not miscellaneous command implementations. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
