path: root/common/cmd_mmc.c
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-07-15mmc: rescan fails on empty slotMichael Jones
Fail in 'mmc rescan' if mmc_init() returns error Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Andy Fleming <afleming@freescale.com>
2011-07-15MMC: add erase function to both mmc and sdLei Wen
Erase is a very basic function since the begin of sd specification is announced. Although we could write a bulk of full 0xff memory to the range to take place of erase, it is more convenient and safe to implement the erase function itself. Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-15MMC: unify mmc read and write operationLei Wen
mmc read and write command has so many in common, unfiy those two to force consistency across the those two. Signed-off-by: Lei Wen <leiwen@marvell.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Andy Fleming <afleming@freescale.com>
2011-05-18mmc: enable partition switch function for emmcLei Wen
For emmc, it may have up to 7 partitions: two boot partitions, one user partition, one RPMB partition and four general purpose partitions. (Refer to JESD84-A44.pdf/page 154) As bootloader may need to read out or reflashing images on those different partitions, it is better to enable the partition switch with console command support. Also for partition would be restore to user partition(part 0) when CMD0 is used, so change mmc_init routine to perform normal initialization only once for each slot, unless use the rescan command to force init again. Signed-off-by: Lei Wen <leiwen@marvell.com> Acked-by: Andy Fleming <afleming@freescale.com>
2011-05-18cmd_mmc: eliminate device num in the mmc commandLei Wen
mmc command applied device, like ide and usb... Signed-off-by: Lei Wen <leiwen@marvell.com> Acked-by: Andy Fleming <afleming@freescale.com>
2011-04-13mmc: show mmc capacity using print_sizeMinkyu Kang
Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2010-09-21cmd_mmc: use common usage functionMike Frysinger
Rather than using a custom "Usage:", use the common cmd_usage() function, and tail into it now that it returns 1 for us. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-18mmc: print out partition tableLei Wen
2010-09-10Prepare v2010.09-rc1v2010.09-rc1Wolfgang Denk
Coding style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-08-10fix cmd_mmc.c, line 136 missing "Reinhard Meyer
Remove warning for missing " at the end of line 136 Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-09various cmd_* files: fixed layout a little bitFrans Meulenbroeks
Most of the files have U_BOOT_CMD on a separate line, but a few didn't and had the first line on the same line as U_BOOT_CMD. This changes these files by adding a line break and a tab Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2010-08-09various cmd_* files: remove the command name from the help messageFrans Meulenbroeks
removed the command name from the help message as it is already printed. for cmd_mmc also rewrote the message a little bit Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-21cmd_mmc remove \nFrans Meulenbroeks
This patch removes the \n after the help message for mmcinfo. This resulted in an empty line being displayed after the mmcinfo line when the help command was given. Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2009-07-17cmd_mmc: make curr_device staticMike Frysinger
The curr_device variable isn't used outside of cmd_mmc, so mark it static to avoid conflicts with other pieces of code (like sata which also exports a curr_device). Otherwise we end up with stuff like: common/libcommon.a(cmd_sata.o):(.data.curr_device+0x0): multiple definition of `curr_device' common/libcommon.a(cmd_mmc.o):(.data.curr_device+0x0): first defined here Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-02mmc: check find_mmc_device return valueRabin Vincent
find_mmc_device returns NULL if an invalid device number is specified. Check for this to avoid dereferencing NULL pointers. Signed-off-by: Rabin Vincent <rabin@rab.in>
2009-06-02mmc: clean up help textsRabin Vincent
Remove some repeated words and superfluous newlines in the mmc command help entries. Signed-off-by: Rabin Vincent <rabin@rab.in>
2009-04-04cmd_mmc: add support for device command for selecting mmc deviceMinkyu Kang
This patch improves device command for selecting mmc device Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-04-04more command usage cleanupMike Frysinger
Fix up a few dangling commands like in "Command usage cleanup" commit. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-19MMC: Don't use new framework code if not enabledDirk Behme
Don't use code of new MMC framework in cmd_mmc if CONFIG_GENERIC_MMC isn't enabled. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-02-19Coding style cleanup, update CHANGELOGWolfgang Denk
2009-02-16Add MMC FrameworkAndy Fleming
Here's a new framework (based roughly off the linux one) for managing MMC controllers. It handles all of the standard SD/MMC transactions, leaving the host drivers to implement only what is necessary to deal with their specific hardware. This also hooks the infrastructure into the PowerPC board code (similar to how the ethernet infrastructure now hooks in) Some of this code was contributed by Dave Liu <daveliu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-16Convert mmc_init to mmc_legacy_initAndy Fleming
This is to get it out of the way of incoming MMC framework Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[i-n]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[i-z]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
