path: root/common/cmd_immap.c
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[i-n]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[i-z]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-10-13Support passing of OF flat trees to the kernel.Wolfgang Denk
Patch by Pantelis Antoniou, 04 Sep 2005
2005-09-26Add iopset command on mpc8xxWolfgang Denk
Patch by Daniel Eisenhut, 25 Mar 2005
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2003-09-18* Patches by Jon Diekema, 17 Sep 2003:wdenk
- update README (SHOW_BOOT_PROGRESS values for cmd_nand.c and env_common.c) - sbc8260 tweaks - adjust "help" output
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-16* Patch by Nicolas Lacressonniere, 11 Jun 2003:wdenk
Modifications for Atmel AT91RM9200DK ARM920T based development kit - Add Atmel DataFlash support for reading and writing. - Add possibility to boot a Linux from DataFlash with BOOTM command. - Add Flash detection on Atmel AT91RM9200DK (between Atmel AT49BV1614 and AT49BV1614A flashes) - Replace old Ethernet PHY layer functions - Change link address * Patch by Frank Smith, 9 Jun 2003: use CRIT_EXCEPTION for machine check on 4xx * Patch by Detlev Zundel, 13 Jun 2003: added implementation of the "carinfo" command in cmd_immap.c
