path: root/board
2021-04-07toradex: configblock: fix module revision in config blocktoradex_2019.07-nexttoradex_2019.07Denys Drozdov
U-boot might display wrong module revision information for modules with an assembly version 'K'. "cfgblock create" does not takes into account all revision digits from PID8. This fix takes into account 6th,7th digits of PID8 to store module revision. Related-to: ELB-3893 Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
2020-03-04board: apalis_imx6: Add KSZ9131 phy skew settingsPhilippe Schenker
This patch adds skew register settings for KSZ9131. It checks first which phy is on the board and then applies the correct skew settings. Skew settings calculation for the KSZ9131: The i.MX6 SoC has an output skew tolerance of -100ps to 900ps. All PCB traces where routed exactly the same length so we can calculate the skew settings without taking the length into consideration. RXC skew (PHY to MAC): - We use the 2ns DLL controlled delay on the PHY - We do not use the skew registers This results in the following values: RXC PHY fixed Delay 2000ps PHY Added Delay 0ps T_setup_R min 2.00ns T_setup_R typ 2.00ns T_setup_R max 2.00ns T_hold_R min 1.60ns T_hold_R typ 2.00ns T_hold_R max 2.40ns That means we are well within RGMII specs. TXC skew (MAC to PHY): - We use the 2ns DLL controlled delay on the PHY - We then substract ~0.6ns with TXD[0:3] and TXC clock pad skew register in a resulting ~1.4ns delay. This results in the following values under consideration of the tolerances: TXC min TXC typ TXC max MAC min -100ps -100ps -100ps MAC max 900ps 900ps 900ps PHY fixed Delay 2000ps 2000ps 2000ps PHY added Delay -340ps -600ps -859ps T_setup_T min 1.56ns 1.30ns 1.04ns T_setup_T typ 2.06ns 1.80ns 1.54ns T_setup_T max 2.56ns 2.30ns 2.04ns T_hold_T min 1.04ns 1.30ns 1.56ns T_hold_T typ 1.94ns 2.20ns 2.46ns T_hold_T max 2.84ns 3.10ns 3.36ns This shows that T_hold_T min and T_setup_T min times are out of spec for RGMII timing. However the KSZ9131 has a minimal value for this time of 0.8ns which is met under all circumstances. Related-to: ELB-1299 Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2019-12-23board: colibri_imx7: reserve DDR memory for Cortex-M4Igor Opaniuk
i.MX 7's Cortex-M4 core can run from DDR and uses DDR memory for the rpmsg communication. Both use cases need a fixed location of memory reserved. For the rpmsg use case the reserved area needs to be in sync with the kernel's hardcoded vring descriptor location. Use the linux,usable-memory property to carve out 1MB of memory in case the M4 core is running. Also make sure that the i.MX 7 specific rpmsg driver does not get loaded in case we do not carve out memory. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> (cherry picked from commit c671d8af0bb07b028d808b994b83b2ec25578a44)
2019-12-18ARM: dts: imx6ull-colibri: change hierarchy of DTS filesIgor Opaniuk
Introduce imx6ull-colibri-u-boot.dtsi for u-boot specific properties to keep original imx6ull-colibri.dts in sync with Linux. Move all contents of imx6ull-colibri.dts to imx6ull-colibri.dtsi + additionally fix checkpatch warnings. Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> (cherry picked from commit 7d6ca12313377bad4ceafc3fa1da414d101f6b77)
2019-08-16apalis-tk1: support v1.2 hardware revisionMarcel Ziswiler
Support the V1.2 hardware revision with the following pin muxing changes: Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4 are now used as DDC pins. Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are now used as USB power enable signals. Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power enable signals are now used as GPIO3 and GPIO4. Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is loaded on V1.2 and later modules and resp. USB power enable signals activated. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (cherry picked from commit 4c63a601b90db131e92d3f6f6da6a4bc2b287df1)
2019-08-16apalis-tk1: remove non-essential power rails on bootDominik Sliwa
When mainline kernels reboot TK1 they use SW_RESET, that reset mode does not reset PMIC. Some rails need to be off for RAM Re-repair to work correctly. Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (cherry picked from commit 5a20adf446bc248a8db02f6d262b43b14587812d)
2019-08-16apalis-tk1: set apalis gpio 8 aka fan_enIgor Opaniuk
Make sure the Apalis GPIO 8 aka FAN_EN is on when using Apalis TK1 modules. Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (cherry picked from commit 538ab6c0a1a51da0caf9525607499e8cd6ef12b7)
2019-08-16apalis-tk1: do not explicitly release reset_moci#Marcel Ziswiler
By keeping RESET_MOCI_CTRL low we avoid explicitly releasing RESET_MOCI#. Please note that module hardware versions up to V1.1A will already release RESET_MOCI# in hardware coming out of reset. Please further note that with this change the USB hub on the Apalis Evaluation board is kept in reset in U-Boot and therefore none of its ports are operational in U-Boot. Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com> (cherry picked from commit 5b5de78b4a6ff8c2bbd71a6b51d6fdf32f420eef)
2019-07-13toradex: configblock: avoid line continuationsMarcel Ziswiler
Fix issue as reported by checkpatch.pl. Leave long lines as line continuation in text output is not recommended. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-07-13toradex: configblock: fix apalis imx8 targetMarcel Ziswiler
The Apalis iMX8 was missing the interactive part should a customer have bricked his module and want to re-create the configuration block. Fix this. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-07-13toradex: configblock: fix colibri imx8x targetMarcel Ziswiler
The Colibri iMX8X target got re-named late in the cycle which we forgot to reflect here. Furthermore, it was missing the interactive part should a customer have bricked his module and want to re-create the configuration block. Fix this. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-07-13toradex: configblock: generic wi-fi/bt handlingMarcel Ziswiler
Make the interactive Wi-Fi/BT handling generic by pulling it out of the Colibri iMX6ULL interactive part to be re-used for Apalis iMX8 and Colibri iMX8X. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-07-13toradex: configblock: initialize MMC before switching partitionStefan Agner
If the module is in serial downloader mode, we do no longer read the environment from eMMC. Therefor, the eMMC is unitialized when trying to read the config block. Use mmc_init to initialize the selected MMC device before using it. Note: In case the MMC has already been initialized, the mmc_init detects that and returns immediately. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-07-09video: fsl_dcu_fb: add DM_VIDEO supportIgor Opaniuk
Extend the driver to build with DM_VIDEO enabled. DTS files must additionally include 'u-boot,dm-pre-reloc' property in soc and child nodes to enable driver binding to fsl_dcu_fb device. Currently display timings aren't obtained from DT. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-09video: fsl_dcu_fb: refactor init functionsIgor Opaniuk
Move dcu-related code to fsl_dcu_probe_common, keep in video_hw_init() only legacy video stack (filling GraphicPanel struct etc.). Add wrappers for all init functions, that will let to provide struct fb_info as an additional param (needed for further moving it from the global scope to driver private data struct in DM converted driver). Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-04board: amlogic: add mailing-list to MAINTAINERSNeil Armstrong
Add missing mailing-list to the amlogic boards MAINTAINERS file. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-07-04wandboard: README: Adjust the U-Boot proper binary nameFabio Estevam
After the conversion to DM the U-Boot proper binary name is 'u-boot-dtb.img', so adjust it accordingly. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04wandboard: Add FIT image supportFabio Estevam
After the transition to DM, only the mx6dl/solo wandboard is supported. Add FIT image support so that all the wandboard variants can be supported, like it was prior to the DM conversion. Successfully booted Linux on mx6q/solo/qp wandboards. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-01Merge tag 'u-boot-atmel-fixes-2019.07-b' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-atmel Second set of u-boot-atmel fixes for 2019.07 cycle
2019-06-28Merge tag 'u-boot-imx-20190628' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx Fixes for 2019.07 - menlo board - allow SDB on Sabre - HAB for mx6sl - apalis board
2019-06-28ARM: imx: m53menlo: Convert to DM VIDEOMarek Vasut
Enable DM Video support on iMX53 M53Menlo and fix minor details to restore previous behavior of the system. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-27ARM: imx: m53menlo: Convert MMC, USB and block to DMMarek Vasut
Enable DM block and DM MMC and DM USB support on iMX53 M53Menlo . Convert board code to match the DM support. This also enables DM pincontrol to configure the SDHI pins. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-27ARM: imx: m53menlo: Enable DM GPIOMarek Vasut
Enable DM GPIO support on iMX53 M53Menlo and fix up board code where applicable. Enable MALLOC_F to let the GPIO controllers bind early on. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-27pico-imx7d: README: Adjust the binary name after DM conversionFabio Estevam
After the conversion to DM the U-Boot binary is called u-boot-dtb.imx, so fix the README file accordingly. Signed-off-by: Fabio Estevam <festevam@gmail.com> Acked-by: Joris Offouga <offougajoris@gmail.com>
2019-06-27board: atmel: fix pda variable not being resetEugen Hristev
In case someone detects a PDA and u-boot sets the 'pda' variable, and the user does a saveenv, the pda is set in env, and if the screen is removed, u-boot will still have in the env the 'pda' variable, even if no screen is attached. In order to fix this, we have to reset the 'pda' variable, such that it's not just set if the screen is detected, but also unset if no screen is detected. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2019-06-26rockchip: rk3399: Fix enabling boot-on regulatorsMark Kettenis
The new common rockchip pinctrl driver does not support explicit requests for a particular pinctrl function. As a result, the board_init() function bails out early before enabling the boot-on regulators. Fix this by simply removing the request for pwm0, pwm2 and pwm3. The generic DM code already does the necessary configuration if necessary. Reported-by: Levin Du <djw@t-chip.com.cn> Signed-of-by: Mark Kettenis <kettenis@openbsd.org>
2019-06-26rockchip: rk3399: Support common spl_board_initJagan Teki
Support common spl_board_init by moving code from puma board file into, common rk3399-board-spl.c. Part of the code has sysreset-gpio, regulators_enable_boot_on but right now only puma board is using this with relevant config options rest remains common for all targets. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26board: rk3399: Drop explicit uart enablement in spl_board_initJagan Teki
preloader_console_init is used for printing SPL boot banner that usually called from spl_board_init. The current spl_board_init in evb and rock960 is enabling explicit pinctrl, debug uart prior to calling preloader_console_init which eventually not required since board_init_f is already enabled debug uart. So, drop those explicit enablement calls from spl_board_init of evb, rock960. Tested this by enabling CONFIG_SPL_BOARD_INIT and adding u-boot,dm-pre-reloc property for uart node. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26Kconfig: Add u-boot.itb BUILD_TARGET for RockchipJagan Teki
Add u-boot.itb BUILD_TARGET for Rockchip platform when SPL_LOAD_FIT is being used. This can get rid of building itb explicitly with 'make u-boot.itb' so, from now all required images will build just by make. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26board: puma: Get bl31.bin via BL31 and rk3399m0.bin via PMUM0Jagan Teki
Right now puma rk3399 board need to copy bl31-rk3399.bin and rk3399m0.bin into u-boot source directory to make use of building u-boot.itb. So, add environment variable - BL31 for bl31.bin (instead of bl31-rk3399.bin to compatible with other platform BL31 env) - PMUM0 for rk3399m0.bin If the builds are not exporting BL31, PMUM0 env, the fit_spl_atf.sh will notify with warning about which document to refer for more information like this: WARNING: BL31 file bl31.bin NOT found, resulting binary is non-functional Please read Building section in doc/README.rockchip WARNING: PMUM0 file rk3399m0.bin NOT found, resulting binary is non-functional Please read Building section in doc/README.rockchip Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26rockchip: rk3328: add rock64-rk3328_defconfigMatwey V. Kornilov
The ROCK64 is a credit card size SBC based on Rockchip RK3328 Quad-Core ARM Cortex A53. This series allow building u-boot SPL and u-boot.itb for Rock64 board. The proprietary TPL is stil required for deploy: ./tools/mkimage -n rk3328 -T rksd \ -d ./rkbin/bin/rk33/rk3328_ddr_333MHz_v1.16.bin idbloader.img cat ./spl/u-boot-spl.bin >> idbloader.img dd if=idbloader.img of=/dev/sdcard seek=64 conv=notrunc dd if=u-boot.itb of=/dev/sdcard seek=16384 conv=notrunc Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-21arm64: zynqmp: Cover ultra96 dts file by MAINTAINERS fragmentMichal Simek
Avnet Ultra96 dts file should be also cover by MAINTAINERS fragment. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-06-21am335x, guardian: update the maintainer listMoses Christopher
Signed-off-by: Moses Christopher <BollavarapuMoses.Christopher@in.bosch.com>
2019-06-21vexpress64: fix a typo of SPDX-License-IdentifierMasahiro Yamada
Misspelling of SPDX-License-Identifier is rather fatal than other general typos, so must be fixed. This file spells SPDX-Licence-Identifier. ^ I also moved it to the very top of the file with // comment style. Detected by grepping the source tree: $ git grep --not -e SPDX-License-Identifier --and -e SPDX- board/armltd/vexpress64/pcie.c: * SPDX-Licence-Identifier: GPL-2.0+ Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Liviu Dudau <liviu.dudau@foss.arm.com>
2019-06-21board: Arcturus: DM: Disable drivers without DM support.Oleksandr Zhadan
Extra "not DM" controllers support is disabled. u-boot BSP still good enough to upgrade and run images. Signed-off-by: Oleksandr Zhadan <oleks@arcturusnetworks.com> Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com>
2019-06-20Merge https://gitlab.denx.de/u-boot/custodians/u-boot-mpc85xxTom Rini
- PCIe driver change to support DM model - T2080QDS migrated to use PCIe DM model
2019-06-20powerpc: T208xQDS: Compile the legacy PCIe routines conditionallyHou Zhiqiang
Compile the legacy PCIe initialization reoutines only when DM_PCI is not enabled. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriqTom Rini
- LS1046AFRWY support - USB errata fix and secure boot defconfig support for LS1028A - Enabled SDHC and SATA for LX2160 - LS1046A serdes fixes - other minor fixes
2019-06-19board/freescale/common: secure_boot: Set bootdelay to -2.Udit Agarwal
Uboot prompt must not be available while running secure boot. TO ensure this bootdelay must be set to -2. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19armv8: ls1046afrwy: Add support for LS1046AFRWY platformVabhav Sharma
LS1046AFRWY board supports LS1046A family SoCs. This patch add base support for this board. Board support's 4GB ddr memory, i2c, micro-click module,microSD card, serial console,qspi nor flash,ifc nand flash,qsgmii network interface, usb 3.0 and serdes interface to support two x1gen3 pcie interface. Signed-off-by: Camelia Groza <camelia.groza@nxp.com> Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com> Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19armv8: ls1028a: Add secure boot defconfigYuantian Tang
Add secure boot defconfig for ls1028aqds and ls1028ardb boards. Signed-off-by: Yuantian Tang <andy.tang@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19board: lx2160a: fix fsl-mc status in fdt with bootefiMian Yousaf Kaukab
fsl-mc lazyapply command applies dpl from efi_exit_boot_services(). Status of fsl-mc node in working fdt is updated at this stage. However, an efi application like grub may already have copied the fdt. So the updates to fdt done at efi_exit_boot_services() may not be visible to the OS. Fix it by updating fdt earlier if fsl-mc lazyapply command is used. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19board/fsl/layerscape: Modify the aliases namesPankaj Bansal
when compiling dts file using DTC_FLAG='-@', the device tree compiler reports these warnings: Warning (alias_paths): /aliases: aliases property name must include only lowercase and '-' Fixed the node aliases to silence these warnings. Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-17Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- Drop zipitz2 board (Tom) - Add DEPRECATED option (Tom) - Mark legacy or non-dm drivers as DEPRECATED (Jagan)
2019-06-15Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
- More board removal
2019-06-14MAINTAINERS: change Ramon Fried email addressRamon Fried
Change my email address, too many mails gets to my private mail, created specific email account just for developmement. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2019-06-14sh: r0p7734: Remove the boardMarek Vasut
Last change to this board was done in 2016, has no prospects of ever being converted to DM, drop it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Chris Brandt <chris.brandt@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Vladimir Zapolskiy <vz@mleia.com> Cc: Yoshihiro Shimoda <shimoda.yoshihiro.uh@renesas.com>
2019-06-14sh: ap325rxa: Remove the boardMarek Vasut
2019-06-14sh: ap_sh4a_4a: Remove the boardMarek Vasut
2019-06-14sh: ms7750se: Remove the boardMarek Vasut
