path: root/board/toradex/common/tdx-cfg-block.c
2021-04-07toradex: configblock: fix module revision in config blocktoradex_2019.07-nexttoradex_2019.07Denys Drozdov
U-boot might display wrong module revision information for modules with an assembly version 'K'. "cfgblock create" does not takes into account all revision digits from PID8. This fix takes into account 6th,7th digits of PID8 to store module revision. Related-to: ELB-3893 Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
2019-07-13toradex: configblock: avoid line continuationsMarcel Ziswiler
Fix issue as reported by checkpatch.pl. Leave long lines as line continuation in text output is not recommended. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-07-13toradex: configblock: fix apalis imx8 targetMarcel Ziswiler
The Apalis iMX8 was missing the interactive part should a customer have bricked his module and want to re-create the configuration block. Fix this. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-07-13toradex: configblock: fix colibri imx8x targetMarcel Ziswiler
The Colibri iMX8X target got re-named late in the cycle which we forgot to reflect here. Furthermore, it was missing the interactive part should a customer have bricked his module and want to re-create the configuration block. Fix this. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-07-13toradex: configblock: generic wi-fi/bt handlingMarcel Ziswiler
Make the interactive Wi-Fi/BT handling generic by pulling it out of the Colibri iMX6ULL interactive part to be re-used for Apalis iMX8 and Colibri iMX8X. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-07-13toradex: configblock: initialize MMC before switching partitionStefan Agner
If the module is in serial downloader mode, we do no longer read the environment from eMMC. Therefor, the eMMC is unitialized when trying to read the config block. Use mmc_init to initialize the selected MMC device before using it. Note: In case the MMC has already been initialized, the mmc_init detects that and returns immediately. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-04-25board: toradex: tdx-cfg-block: add new skusMarcel Ziswiler
Add all the latest new SKUs: - Apalis iMX8 QuadXPlus 2GB Wi-Fi / BT IT - Apalis iMX8 QuadMax 4GB IT - Apalis iMX8 QuadPlus 2GB Wi-Fi / BT - Apalis iMX8 QuadPlus 2GB", - Colibri iMX8 QuadXPlus 2GB IT - Colibri iMX8 DualX 1GB Wi-Fi / Bluetooth - Colibri iMX8 DualX 1GB Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25board: toradex: tdx-cfg-block: clean-up sku handlingMarcel Ziswiler
Clean-up handling of several SKUs. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25tdx-cfg-block: simplify i.MX 6 module detectionStefan Agner
Use CONFIG_TARGET_... at compile time to differentiate between Apalis iMX6, Colibri iMX6 and Colibri iMX6ULL. Avoid code duplication by moving question about Wi-Fi / Bluetooth before IT/non-IT decision. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25tdx-cfg-block: add support for new colibri iMX6ull skusGerard Salvatella
Add support for new Colibri iMX6ULL SKUs. While at it also checkpatch fix the whole files. Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-13tdx-cfg-block: fix off by one issueMarcel Ziswiler
Fix toradex_modules array off by one issue potentially leading to spurious printout during boot e.g. Model: Toradex V1.2A, instead of Model: Toradex UNKNOWN MODULE V1.2A. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-13toradex: configblock: add an -y parameter to 'cfgblock create’Dominik Sliwa
Add an optional -y parameter to 'cfgblock create’ to simplify automation. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2018-09-04board: toradex: common: fail gracefully on missing NAND chipStefan Agner
If the NAND chip is missing get_nand_dev_by_index() returns NULL. Fail gracefully in this case. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2018-07-23board: toradex: add new and upcoming SKUsStefan Agner
2017-09-15blk: Remove various places that do flush cache after readBin Meng
All these places seem to inherit the codes from the MMC driver where a FIXME was put in the comment. However the correct operation after read should be cache invalidate, not flush. The underlying drivers should be responsible for the cache operation. Remove these codes completely. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: York Sun <york.sun@nxp.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: York Sun <york.sun@nxp.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-11board: toradex: use get_nand_dev_by_index()Grygorii Strashko
As part of preparation for nand DM conversion the new API has been introduced to remove direct access to nand_info array. So, use it here instead of accessing to nand_info array directly. Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2017-06-05arm: Add explicit include of <asm/mach-types.h>Simon Glass
Rather than relying on common.h to provide this include, which is going away at some point, include it explicitly in each file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-01tegra: Convert MMC to use driver model for operationsSimon Glass
Enable CONFIG_DM_MMC_OPS and CONFIG_BLK for all Tegra devices. This moves Tegra to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-11-28toradex: config block handlingMarcel Ziswiler
Add Toradex factory configuration block handling. The config block is a data structure which gets stored to flash during production testing. The structure holds such information as board resp. hardware revision, product ID and serial number which is used as the NIC part of the Ethernet MAC address as well. The config block will be read upon boot by the show_board_info() function, displayed as part of the board information and passed to Linux via device tree or ATAGs. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
